Attention is currently required from: Furquan Shaikh, Tim Wawrzynczak, Sridhar Siricilla, Aseda Aboagye, Patrick Rudolph, Karthik Ramasubramanian. Hello build bot (Jenkins), Tim Wawrzynczak, Aseda Aboagye, Sridhar Siricilla, Patrick Rudolph, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/57295
Change subject: soc/intel/common/cse: Add argument for CSE fixed client addr ......................................................................
There are multiple HECI clients in the CSE. heci_send_receive() is sending HECI messages to only the MKHI client. Add an argument to heci_send_receive() funtion to provide flexibility to the caller to select the client for which the message is intended.
In the follow-up patches there will be messages sent to one other client.
BUG=None BRANCH=None TEST=Build and boot brya. HECI message send and receive to MKHI client is working. Also, MEI BUS message to disable bus is working.
Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com Change-Id: Icde6d0155b62472b6a7caadc5fc8ea2e2ba6eb0c --- M src/soc/intel/common/block/cse/cse.c M src/soc/intel/common/block/cse/cse_eop.c M src/soc/intel/common/block/cse/cse_lite.c M src/soc/intel/common/block/include/intelblocks/cse.h 4 files changed, 20 insertions(+), 20 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/57295/6
