Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17076
commit a03c438fa8f27b0787267aee05895b2275e665c9 Author: Arthur Heymans arthur@aheymans.xyz Date: Thu Oct 20 20:44:54 2016 +0200
nb/i945/gma.c use an if else statement for use of native init
Change-Id: I1e964ed939ca5282008253e3fbdd1d2fa5cbf278 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/northbridge/intel/i945/gma.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/src/northbridge/intel/i945/gma.c b/src/northbridge/intel/i945/gma.c index 3e68aa3..c74384a 100644 --- a/src/northbridge/intel/i945/gma.c +++ b/src/northbridge/intel/i945/gma.c @@ -594,11 +594,6 @@ static void gma_func0_init(struct device *dev) pci_write_config32(dev, PCI_COMMAND, reg32 | PCI_COMMAND_MASTER | PCI_COMMAND_IO | PCI_COMMAND_MEMORY);
- if (!IS_ENABLED(CONFIG_MAINBOARD_DO_NATIVE_VGA_INIT)) { - /* PCI Init, will run VBIOS */ - pci_dev_init(dev); - } - if (IS_ENABLED(CONFIG_MAINBOARD_DO_NATIVE_VGA_INIT)) { /* This should probably run before post VBIOS init. */ printk(BIOS_SPEW, "Initializing VGA without OPROM.\n"); @@ -637,6 +632,9 @@ static void gma_func0_init(struct device *dev) generate_fake_intel_oprom(&conf->gfx, dev, "$VBT LAKEPORT-G"); } + } else { + /* PCI Init, will run VBIOS */ + pci_dev_init(dev); } }
