Yu-Ping Wu has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84342?usp=email )
11 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: mb/google/corsola: Distinguish MT8186T's SKU ID from MT8186 ......................................................................
Compared to MT8186, MT8186T requires initializing the PMIC MT6319 in the DTS file, which necessitates using different SKU ID to distinguish between the MT8186 and MT8186T.
For MT8186, factory pre-flashed 0x7fffffff as unprovisioned SKU ID and kernel can use the corresponding DTS file. To make MT8186T functional on unprovisioned devices, change the SKU ID to 0x7ffffeff, so that the correct DTS file will be selected by the payload.
BUG=b:365730137 TEST=1. Pre-flashed 0x7fffffff and boot OS. 2. Check OS boot normally by 0x7ffffeff. BRANCH=corsola
Change-Id: I91306d3abd508e104851916882fb36a4fd302036 Signed-off-by: Yang Wu wuyang5@huaqin.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/84342 Reviewed-by: Knox Chiou knoxchiou@google.com Reviewed-by: Yu-Ping Wu yupingso@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Yidi Lin yidilin@google.com --- M src/mainboard/google/corsola/boardid.c 1 file changed, 13 insertions(+), 11 deletions(-)
Approvals: build bot (Jenkins): Verified Yidi Lin: Looks good to me, approved Yu-Ping Wu: Looks good to me, approved Knox Chiou: Looks good to me, but someone else must approve
diff --git a/src/mainboard/google/corsola/boardid.c b/src/mainboard/google/corsola/boardid.c index 443c3d1..b0aa888 100644 --- a/src/mainboard/google/corsola/boardid.c +++ b/src/mainboard/google/corsola/boardid.c @@ -5,6 +5,7 @@ #include <console/console.h> #include <ec/google/chromeec/ec.h> #include <soc/auxadc.h> +#include <soc/cpu_id.h>
#include "panel.h"
@@ -12,6 +13,8 @@
#define ADC_LEVELS 12
+#define CROS_SKU_UNPROVISIONED_MT8186T 0x7FFFFEFF + enum { /* RAM IDs */ RAM_ID_LOW_CHANNEL = 2, @@ -112,19 +115,18 @@
cached_sku_code = google_chromeec_get_board_sku();
- if (CONFIG(BOARD_GOOGLE_STARYU_COMMON)) { - if (cached_sku_code == CROS_SKU_UNPROVISIONED || - cached_sku_code == CROS_SKU_UNKNOWN) { - printk(BIOS_WARNING, "SKU code from EC: %s\n", - (cached_sku_code == CROS_SKU_UNKNOWN) ? - "CROS_SKU_UNKNOWN" : "CROS_SKU_UNPROVISIONED"); + if (cached_sku_code == CROS_SKU_UNPROVISIONED || + cached_sku_code == CROS_SKU_UNKNOWN) { + printk(BIOS_WARNING, "SKU code from EC: 0x%x\n", cached_sku_code); + cached_sku_code = CROS_SKU_UNPROVISIONED; + if (get_cpu_id() == MTK_CPU_ID_MT8186T) + cached_sku_code = CROS_SKU_UNPROVISIONED_MT8186T; + + if (CONFIG(BOARD_GOOGLE_STARYU_COMMON)) { /* Reserve last 4 bits to report PANEL_ID */ - cached_sku_code = 0x7FFFFFF0UL | panel_id(); + cached_sku_code &= ~0xF; + cached_sku_code |= panel_id(); } - } else if (cached_sku_code == CROS_SKU_UNKNOWN) { - printk(BIOS_WARNING, "Failed to get SKU code from EC\n"); - cached_sku_code = (get_adc_index(SKU_ID_HIGH_CHANNEL) << 4 | - get_adc_index(SKU_ID_LOW_CHANNEL)); }
printk(BIOS_DEBUG, "SKU Code: %#02x\n", cached_sku_code);
