Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/54250 )
Change subject: mb/google/zork: update DRAM table for berknip/dirinboz/gumboz ......................................................................
Add Samsung DDR4 memory part K4AAG165WB-BCWE 16Gb index was generated by gen_part_id
BUG=b:180986354 TEST=none
Signed-off-by: Kevin Chiu kevin.chiu@quantatw.com Change-Id: I94b950b51b41767676ab3ddf89e88860c42f5f1d Reviewed-on: https://review.coreboot.org/c/coreboot/+/54250 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Kangheui Won khwon@chromium.org --- M src/mainboard/google/zork/variants/berknip/spd/Makefile.inc M src/mainboard/google/zork/variants/berknip/spd/dram_id.generated.txt M src/mainboard/google/zork/variants/berknip/spd/mem_parts_used.txt M src/mainboard/google/zork/variants/dirinboz/spd/Makefile.inc M src/mainboard/google/zork/variants/dirinboz/spd/dram_id.generated.txt M src/mainboard/google/zork/variants/dirinboz/spd/mem_parts_used.txt M src/mainboard/google/zork/variants/gumboz/spd/Makefile.inc M src/mainboard/google/zork/variants/gumboz/spd/dram_id.generated.txt M src/mainboard/google/zork/variants/gumboz/spd/mem_parts_used.txt 9 files changed, 9 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Kangheui Won: Looks good to me, approved
diff --git a/src/mainboard/google/zork/variants/berknip/spd/Makefile.inc b/src/mainboard/google/zork/variants/berknip/spd/Makefile.inc index 9c66132..b584838 100644 --- a/src/mainboard/google/zork/variants/berknip/spd/Makefile.inc +++ b/src/mainboard/google/zork/variants/berknip/spd/Makefile.inc @@ -6,7 +6,7 @@ SPD_SOURCES += ddr4-spd-8.hex # ID = 1(0b0001) Parts = K4AAG165WA-BCTD SPD_SOURCES += ddr4-spd-1.hex # ID = 2(0b0010) Parts = MT40A512M16TB-062E:J SPD_SOURCES += ddr4-spd-1.hex # ID = 3(0b0011) Parts = H5AN8G6NDJR-XNC -SPD_SOURCES += ddr4-spd-9.hex # ID = 4(0b0100) Parts = H5ANAG6NCJR-XNC +SPD_SOURCES += ddr4-spd-9.hex # ID = 4(0b0100) Parts = H5ANAG6NCJR-XNC, K4AAG165WB-BCWE SPD_SOURCES += ddr4-spd-1.hex # ID = 5(0b0101) Parts = K4A8G165WC-BCWE SPD_SOURCES += ddr4-spd-7.hex # ID = 6(0b0110) Parts = MT40A1G16KD-062E:E SPD_SOURCES += ddr4-spd-2.hex # ID = 7(0b0111) Parts = H5ANAG6NCMR-XNC diff --git a/src/mainboard/google/zork/variants/berknip/spd/dram_id.generated.txt b/src/mainboard/google/zork/variants/berknip/spd/dram_id.generated.txt index f475d9f..090dc3e 100644 --- a/src/mainboard/google/zork/variants/berknip/spd/dram_id.generated.txt +++ b/src/mainboard/google/zork/variants/berknip/spd/dram_id.generated.txt @@ -8,3 +8,4 @@ K4AAG165WA-BCWE 8 (1000) K4AAG165WA-BCTD 1 (0001) H5ANAG6NCJR-XNC 4 (0100) +K4AAG165WB-BCWE 4 (0100) diff --git a/src/mainboard/google/zork/variants/berknip/spd/mem_parts_used.txt b/src/mainboard/google/zork/variants/berknip/spd/mem_parts_used.txt index 2af091f..e9803b5 100644 --- a/src/mainboard/google/zork/variants/berknip/spd/mem_parts_used.txt +++ b/src/mainboard/google/zork/variants/berknip/spd/mem_parts_used.txt @@ -16,3 +16,4 @@ K4AAG165WA-BCWE, 8 K4AAG165WA-BCTD H5ANAG6NCJR-XNC +K4AAG165WB-BCWE diff --git a/src/mainboard/google/zork/variants/dirinboz/spd/Makefile.inc b/src/mainboard/google/zork/variants/dirinboz/spd/Makefile.inc index 6d8a906..6d8e749 100644 --- a/src/mainboard/google/zork/variants/dirinboz/spd/Makefile.inc +++ b/src/mainboard/google/zork/variants/dirinboz/spd/Makefile.inc @@ -2,7 +2,7 @@ ## This is an auto-generated file. Do not edit!!
SPD_SOURCES = -SPD_SOURCES += ddr4-spd-9.hex # ID = 0(0b0000) Parts = H5ANAG6NCJR-XNC +SPD_SOURCES += ddr4-spd-9.hex # ID = 0(0b0000) Parts = H5ANAG6NCJR-XNC, K4AAG165WB-BCWE SPD_SOURCES += ddr4-spd-empty.hex # ID = 1(0b0001) SPD_SOURCES += ddr4-spd-3.hex # ID = 2(0b0010) Parts = K4A8G165WC-BCTD SPD_SOURCES += ddr4-spd-empty.hex # ID = 3(0b0011) diff --git a/src/mainboard/google/zork/variants/dirinboz/spd/dram_id.generated.txt b/src/mainboard/google/zork/variants/dirinboz/spd/dram_id.generated.txt index d6d5d09..9f9949c 100644 --- a/src/mainboard/google/zork/variants/dirinboz/spd/dram_id.generated.txt +++ b/src/mainboard/google/zork/variants/dirinboz/spd/dram_id.generated.txt @@ -8,3 +8,4 @@ K4AAG165WA-BCTD 9 (1001) K4AAG165WA-BCWE 10 (1010) H5ANAG6NCJR-XNC 0 (0000) +K4AAG165WB-BCWE 0 (0000) diff --git a/src/mainboard/google/zork/variants/dirinboz/spd/mem_parts_used.txt b/src/mainboard/google/zork/variants/dirinboz/spd/mem_parts_used.txt index 5a6541f..974addb 100644 --- a/src/mainboard/google/zork/variants/dirinboz/spd/mem_parts_used.txt +++ b/src/mainboard/google/zork/variants/dirinboz/spd/mem_parts_used.txt @@ -16,3 +16,4 @@ K4AAG165WA-BCTD, 9 K4AAG165WA-BCWE, 10 H5ANAG6NCJR-XNC +K4AAG165WB-BCWE diff --git a/src/mainboard/google/zork/variants/gumboz/spd/Makefile.inc b/src/mainboard/google/zork/variants/gumboz/spd/Makefile.inc index 6d8a906..6d8e749 100644 --- a/src/mainboard/google/zork/variants/gumboz/spd/Makefile.inc +++ b/src/mainboard/google/zork/variants/gumboz/spd/Makefile.inc @@ -2,7 +2,7 @@ ## This is an auto-generated file. Do not edit!!
SPD_SOURCES = -SPD_SOURCES += ddr4-spd-9.hex # ID = 0(0b0000) Parts = H5ANAG6NCJR-XNC +SPD_SOURCES += ddr4-spd-9.hex # ID = 0(0b0000) Parts = H5ANAG6NCJR-XNC, K4AAG165WB-BCWE SPD_SOURCES += ddr4-spd-empty.hex # ID = 1(0b0001) SPD_SOURCES += ddr4-spd-3.hex # ID = 2(0b0010) Parts = K4A8G165WC-BCTD SPD_SOURCES += ddr4-spd-empty.hex # ID = 3(0b0011) diff --git a/src/mainboard/google/zork/variants/gumboz/spd/dram_id.generated.txt b/src/mainboard/google/zork/variants/gumboz/spd/dram_id.generated.txt index d6d5d09..9f9949c 100644 --- a/src/mainboard/google/zork/variants/gumboz/spd/dram_id.generated.txt +++ b/src/mainboard/google/zork/variants/gumboz/spd/dram_id.generated.txt @@ -8,3 +8,4 @@ K4AAG165WA-BCTD 9 (1001) K4AAG165WA-BCWE 10 (1010) H5ANAG6NCJR-XNC 0 (0000) +K4AAG165WB-BCWE 0 (0000) diff --git a/src/mainboard/google/zork/variants/gumboz/spd/mem_parts_used.txt b/src/mainboard/google/zork/variants/gumboz/spd/mem_parts_used.txt index e5cd7e2..f220073 100644 --- a/src/mainboard/google/zork/variants/gumboz/spd/mem_parts_used.txt +++ b/src/mainboard/google/zork/variants/gumboz/spd/mem_parts_used.txt @@ -17,3 +17,4 @@ K4AAG165WA-BCTD, 9 K4AAG165WA-BCWE, 10 H5ANAG6NCJR-XNC +K4AAG165WB-BCWE
