Tim Wawrzynczak has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/34528 )
Change subject: mb/google/hatch/helios: Update GPIO and device tree ......................................................................
Based on updated schematics, change polarity of USI_INT, and add the rest of the control GPIOs to the touchscreen ACPI node.
BUG=b:137133194 BRANCH=none TEST=Compiles, don't have next board rev to test with
Change-Id: I1dfb8e649418e4c5e9b897fb4bc11393adc21ea2 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/hatch/variants/baseboard/gpio.c M src/mainboard/google/hatch/variants/helios/overridetree.cb 2 files changed, 12 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/34528/1
diff --git a/src/mainboard/google/hatch/variants/baseboard/gpio.c b/src/mainboard/google/hatch/variants/baseboard/gpio.c index 8a0c948..04028cb 100644 --- a/src/mainboard/google/hatch/variants/baseboard/gpio.c +++ b/src/mainboard/google/hatch/variants/baseboard/gpio.c @@ -195,8 +195,8 @@ PAD_NC(GPP_D14, NONE), /* D15 : TOUCHSCREEN_RST_L */ PAD_CFG_GPO(GPP_D15, 0, DEEP), - /* D16 : USI_INT */ - PAD_CFG_GPI_APIC(GPP_D16, NONE, PLTRST, LEVEL, NONE), + /* D16 : USI_INT_L */ + PAD_CFG_GPI_APIC(GPP_D16, NONE, PLTRST, LEVEL, INVERT), /* D17 : PCH_HP_SDW_CLK */ PAD_NC(GPP_D17, NONE), /* D18 : PCH_HP_SDW_DAT */ diff --git a/src/mainboard/google/hatch/variants/helios/overridetree.cb b/src/mainboard/google/hatch/variants/helios/overridetree.cb index 41c15c8..aebdab7 100644 --- a/src/mainboard/google/hatch/variants/helios/overridetree.cb +++ b/src/mainboard/google/hatch/variants/helios/overridetree.cb @@ -83,13 +83,19 @@ chip drivers/i2c/hid register "generic.hid" = ""GDIX0000"" register "generic.desc" = ""Goodix Touchscreen"" - register "generic.irq" = "ACPI_IRQ_EDGE_LOW(GPP_D16_IRQ)" + register "generic.irq" = + "ACPI_IRQ_EDGE_LOW(GPP_D16_IRQ)" register "generic.probed" = "1" register "generic.reset_gpio" = - "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D15)" - register "generic.reset_delay_ms" = "10" - register "generic.reset_off_delay_ms" = "1" + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D15)" + register "generic.reset_delay_ms" = "120" + register "generic.reset_off_delay_ms" = "3" + register "generic.enable_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_D9)" + register "generic.enable_delay_ms" = "10" register "generic.has_power_resource" = "1" + register "generic.stop_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_H14)" register "hid_desc_reg_offset" = "0x01" device i2c 5d on end end
Paul Fagerburg has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34528 )
Patch Set 1: Code-Review+1
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34528 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/34528/1/src/mainboard/google/hatch/... File src/mainboard/google/hatch/variants/baseboard/gpio.c:
https://review.coreboot.org/c/coreboot/+/34528/1/src/mainboard/google/hatch/... PS1, Line 198: USI_INT_L This change seems to be done in baseboard/gpio.c. Is the hardware change done for all variants?
https://review.coreboot.org/c/coreboot/+/34528/1/src/mainboard/google/hatch/... File src/mainboard/google/hatch/variants/helios/overridetree.cb:
https://review.coreboot.org/c/coreboot/+/34528/1/src/mainboard/google/hatch/... PS1, Line 91: 120 That's a long delay. Just a note: This affects resume time from S0ix since the delay sits in a critical path. It would be good to raise a separate bug to later on test if we really need such a long delay.
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34528 )
Patch Set 1:
(2 comments)
This change seems to be done in baseboard/gpio.c. […]
Kohaku and Helios have it called out as active low, I missed Kindred. I'll update individual GPIO files.
That's a long delay. […]
Other devices using the same part have this delay set. I don't see any details about these numbers in the datasheets, I just wanted to use the conservative number until the specified number is found.
Philip Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34528 )
Patch Set 1:
Is this change compatible with the Helios rev0?
Patch Set 1:
Patch Set 1:
IIRC, that rev didn't come with the touchscreen IC, so it shouldn't hurt anything.
Patch Set 1:
(2 comments)
Other devices using the same part have this delay set. […]
Oh okay. Makes sense. Yeah I just intended to highlight that this will eventually come up as one of the blocks resulting in longer resume time.
https://review.coreboot.org/c/coreboot/+/34528/1/src/mainboard/google/hatch/... PS1, Line 98: GPP_H14 This seems to be NC in gpio.c. Is it really used/required?
Hello Paul Fagerburg, Philip Chen, Shelley Chen, build bot (Jenkins), Furquan Shaikh,
Change-Id: I1dfb8e649418e4c5e9b897fb4bc11393adc21ea2 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/hatch/variants/helios/gpio.c M src/mainboard/google/hatch/variants/helios/overridetree.cb 2 files changed, 15 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/34528/2
Patch Set 2:
(2 comments)
Oh okay. Makes sense. […]
Ack
This seems to be NC in gpio.c. […]
In Helios' gpio.c, this is TOUCHSCREEN_STOP_L. Taking a closer look, it doesn't look like Goodix's kernel driver even uses that GPIO. Left it in for now, with a note to take another look at the reset/enable/stop times & signals.
Patch Set 2: Code-Review+2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34528 )
Patch Set 2: Code-Review+1
Hello Paul Fagerburg, Philip Chen, Paul Menzel, Shelley Chen, build bot (Jenkins), Furquan Shaikh,
BUG=b:137133194, b:138240502 BRANCH=none TEST=Compiles, don't have next board rev to test with
Change-Id: I1dfb8e649418e4c5e9b897fb4bc11393adc21ea2 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/hatch/variants/helios/gpio.c M src/mainboard/google/hatch/variants/helios/overridetree.cb 2 files changed, 12 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/34528/3
Patch Set 3: Code-Review+2
Patch Set 3:
https://review.coreboot.org/c/coreboot/+/34528/3/src/mainboard/google/hatch/... File src/mainboard/google/hatch/variants/helios/gpio.c:
https://review.coreboot.org/c/coreboot/+/34528/3/src/mainboard/google/hatch/... PS3, Line 95: 1 nit: Since this is now de-asserted in power resource, it can be left asserted here. However, since this does not seem to be going to a real stop gpio pin on the touchscreen controller, it probably wouldn't matter much.
Patch Set 3:
nit: Since this is now de-asserted in power resource, it can be left asserted here. […]
Actually, taking a closer look at the schematics, it needs to be asserted here, because the GPIO gates off the reset line, which will cause the power sequencing in _ON to fail. The stop_gpio needs to be removed.
Based on updated schematics, change polarity of USI_INT, and add the reset and enable GPIOs to the touchscreen ACPI node. The stop GPIO can't be used with the current implementation of _ON, as the way it's wired will cause power sequencing to fail.
Change-Id: I1dfb8e649418e4c5e9b897fb4bc11393adc21ea2 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/hatch/variants/helios/gpio.c M src/mainboard/google/hatch/variants/helios/overridetree.cb 2 files changed, 10 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/34528/4
Patch Set 4: Code-Review+2
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/34528 )
Change-Id: I1dfb8e649418e4c5e9b897fb4bc11393adc21ea2 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/34528 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Paul Fagerburg pfagerburg@chromium.org --- M src/mainboard/google/hatch/variants/helios/gpio.c M src/mainboard/google/hatch/variants/helios/overridetree.cb 2 files changed, 10 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Paul Fagerburg: Looks good to me, approved
diff --git a/src/mainboard/google/hatch/variants/helios/gpio.c b/src/mainboard/google/hatch/variants/helios/gpio.c index 12801de..ecb13f3 100644 --- a/src/mainboard/google/hatch/variants/helios/gpio.c +++ b/src/mainboard/google/hatch/variants/helios/gpio.c @@ -51,6 +51,8 @@ PAD_NC(GPP_D8, NONE), /* D10 : ISH_SPI_CLK ==> EN_PP3300_PP1800_FP */ PAD_CFG_GPO(GPP_D10, 0, DEEP), + /* D16 : USI_INT_L */ + PAD_CFG_GPI_APIC(GPP_D16, NONE, PLTRST, LEVEL, INVERT), /* D21 : SPI1_IO2 ==> NC */ PAD_NC(GPP_D21, NONE), /* F0 : GPP_F0 ==> NC */ @@ -90,7 +92,7 @@ /* H13 : M2_SKT2_CFG1 ==> SPKR_RST_L */ PAD_CFG_GPO(GPP_H13, 1, DEEP), /* H14 : M2_SKT2_CFG2 ==> TOUCHSCREEN_STOP_L */ - PAD_CFG_GPO(GPP_H14, 0, PLTRST), + PAD_CFG_GPO(GPP_H14, 1, PLTRST), /* H19 : TIMESYNC[0] ==> MEM_STRAP_0 */ PAD_CFG_GPI(GPP_H19, NONE, PLTRST), /* H22 : MEM_STRAP_1 */ diff --git a/src/mainboard/google/hatch/variants/helios/overridetree.cb b/src/mainboard/google/hatch/variants/helios/overridetree.cb index 41c15c8..cedf046 100644 --- a/src/mainboard/google/hatch/variants/helios/overridetree.cb +++ b/src/mainboard/google/hatch/variants/helios/overridetree.cb @@ -83,12 +83,17 @@ chip drivers/i2c/hid register "generic.hid" = ""GDIX0000"" register "generic.desc" = ""Goodix Touchscreen"" - register "generic.irq" = "ACPI_IRQ_EDGE_LOW(GPP_D16_IRQ)" + register "generic.irq" = + "ACPI_IRQ_EDGE_LOW(GPP_D16_IRQ)" register "generic.probed" = "1" register "generic.reset_gpio" = - "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D15)" + "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D15)" register "generic.reset_delay_ms" = "10" register "generic.reset_off_delay_ms" = "1" + register "generic.enable_gpio" = + "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_D9)" + register "generic.enable_delay_ms" = "10" + register "generic.enable_off_delay_ms" = "1" register "generic.has_power_resource" = "1" register "hid_desc_reg_offset" = "0x01" device i2c 5d on end
