Lijian Zhao (lijian.zhao@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17181
commit e30a6db3a991d003517575f3e5b1f3124f94b7cc Author: Lijian Zhao lijian.zhao@intel.com Date: Fri Oct 28 11:01:09 2016 -0700
soc/intel/apollolake: Add pmc_ipc device support
A dedicated pmc_ipc DSDT entry is required for pmc_ipc kernel driver. The ACPI mode entry includes resources for PMC_IPC1, SRAM, ACPI IO and Punit Mailbox. Also optimize the asl sequence to have SB.PCI0 blocks together.
BRANCH=None BUG=chrome-os-partner:57364 TEST=Boot up into OS successfully and check with dmesg to see the driver has been loaded successfully without errors.
Change-Id: Ib0a300febe1e7fc1796bfeca1a04493f932640e1 Signed-off-by: Lijian Zhao lijian.zhao@intel.com --- src/soc/intel/apollolake/acpi/pmc_ipc.asl | 61 +++++++++++++++++++++++++++ src/soc/intel/apollolake/acpi/southbridge.asl | 9 ++-- 2 files changed, 67 insertions(+), 3 deletions(-)
diff --git a/src/soc/intel/apollolake/acpi/pmc_ipc.asl b/src/soc/intel/apollolake/acpi/pmc_ipc.asl new file mode 100644 index 0000000..d5c1ceb --- /dev/null +++ b/src/soc/intel/apollolake/acpi/pmc_ipc.asl @@ -0,0 +1,61 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corp. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <soc/iomap.h> + +#define MAILBOX_DATA 0x7080 +#define MAILBOX_INTF 0x7084 +#define PMIO_LENGTH 0x80 + +scope (_SB) { + + Device (IPC1) + { + Name (_HID, "INT34D2") + Name (_CID, "INT34D2") + Name (_DDN, "Intel(R) IPC1 Controller") + Name (RBUF, ResourceTemplate () + { + Memory32Fixed (ReadWrite, 0x0, 0x2000, IBAR) + Memory32Fixed (ReadWrite, 0x0, 0x4, MDAT) + Memory32Fixed (ReadWrite, 0x0, 0x4, MINF) + IO (Decode16, ACPI_PMIO_BASE, ACPI_PMIO_BASE + PMIO_LENGTH, + 0x04, PMIO_LENGTH) + Memory32Fixed (ReadWrite, 0x0, 0x2000, SBAR) + Interrupt (ResourceConsumer, Level, ActiveLow, Exclusive, , , ) + { + PMC_INT + } + }) + + Method (_CRS, 0x0, NotSerialized) + { + CreateDwordField (^RBUF, ^IBAR._BAS, IBAS) + Store (PMC_BAR0, IBAS) + + CreateDwordField (^RBUF, ^MDAT._BAS, MDBA) + Store (MCH_BASE_ADDR + MAILBOX_DATA, MDBA) + CreateDwordField (^RBUF, ^MINF._BAS, MIBA) + Store (MCH_BASE_ADDR + MAILBOX_INTF, MIBA) + + CreateDwordField (^RBUF, ^SBAR._BAS, SBAS) + Store (PMC_SRAM_BASE_0, SBAS) + + Return (^RBUF) + } + } + +} \ No newline at end of file diff --git a/src/soc/intel/apollolake/acpi/southbridge.asl b/src/soc/intel/apollolake/acpi/southbridge.asl index 1c10f1a..225bc48 100644 --- a/src/soc/intel/apollolake/acpi/southbridge.asl +++ b/src/soc/intel/apollolake/acpi/southbridge.asl @@ -35,9 +35,6 @@ Scope (_SB) /* PCI IRQ assignment */ #include "pci_irqs.asl"
-/* GPIO controller */ -#include "gpio.asl" - #include "xhci.asl"
/* LPC */ @@ -46,5 +43,11 @@ Scope (_SB) /* eMMC */ #include "scs.asl"
+/* GPIO controller */ +#include "gpio.asl" + +/* PMC IPC controller */ +#include "pmc_ipc.asl" + /* PCI _OSC */ #include <soc/intel/common/acpi/pci_osc.asl>
