Brandon Breitenstein (brandon.breitenstein@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16309
commit 2b0c89b960adce8c2e1ff5380daf1f37f6c6acd7 Author: Brandon Breitenstein brandon.breitenstein@intel.com Date: Tue Aug 23 14:55:13 2016 -0700
commonlib: fsp_relocate is incompatible with UEFI 2.6
UEFI 2.6 spec casts the return of FFS_FILE2_SIZE to a UINT32 which cannot be read using read_le32(&returnval). adding in a cast in order to safeguard for any non x86 architecture that may use this relocate. The proper change will be to get the UEFI header files changed to not cast this return value.
Change-Id: Ie1b50d99576ac42a0413204bbd599bab9f01828e Signed-off-by: Brandon Breitenstein brandon.breitenstein@intel.com --- src/commonlib/fsp_relocate.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/src/commonlib/fsp_relocate.c b/src/commonlib/fsp_relocate.c index 7f1e49a..d4ca1cd 100644 --- a/src/commonlib/fsp_relocate.c +++ b/src/commonlib/fsp_relocate.c @@ -258,9 +258,14 @@ static size_t ffs_file_size(const EFI_FFS_FILE_HEADER *ffsfh) { size_t size;
- if (IS_FFS_FILE2(ffsfh)) - size = read_le32(&FFS_FILE2_SIZE(ffsfh)); - else { + if (IS_FFS_FILE2(ffsfh)) { + /* this cast is needed with UEFI 2.6 headers in order + to read the UINT32 value that FFS_FILE2_SIZE converts + the return to starting in UEFI 2.6 spec */ + size = (size_t) FFS_FILE2_SIZE(ffsfh); + size = read_le32(&size); + } + else { size = read_le8(&ffsfh->Size[0]) << 0; size |= read_le8(&ffsfh->Size[1]) << 8; size |= read_le8(&ffsfh->Size[2]) << 16;
