Attention is currently required from: Kevin Keijzer, Angel Pons, Arthur Heymans, Nicholas Chin, Fabian Groffen, Elyes Haouas.
Kevin Keijzer has uploaded a new patch set (#6) to the change originally created by Fabian Groffen. ( https://review.coreboot.org/c/coreboot/+/73097 )
Change subject: mb/asrock/b75m-itx: Add Sandy/Ivy Bridge board B75M-ITX ......................................................................
This board is based off b75pro3-m, which is very similar. Compared to it, it just lacks a COM1 header, and the secondary ASMedia SATA3 controller.
Tested with: CPUs: - Core i5-3330 - Core i5-3470 - Core i7-3770
RAM: - single bank 4GB CL11 - two banks 4+4GB CL9 - two banks 8+8GB CL10
OS: - Gentoo Linux LiveUSB, KDE desktop (Linux 5.15.72)
Working: - GRUB2 payload with embedded default config for boot from USB, disk - UEFI EDK2 payload - Intel ME stripped - Native raminit - Integrated graphics with libgfxinit (HDMI, DVI and VGA) - (boot from) SATA2, SATA3, ports - Rear USB 2 and 3 ports (supports boot) - Internal USB 3.0 ports - Realtek GbE NIC - 2.0 channel audio via lineout jack output - ACPI (power button triggers OS event)
Untested: - Internal USB 2.0 ports - eSATA port - 7.1 channel audio
Signed-off-by: Fabian Groffen grobian@gentoo.org Change-Id: Ia6a6eb3e922920f4afbcb7828cd2b779b9caebcb --- A src/mainboard/asrock/b75m-itx/Kconfig A src/mainboard/asrock/b75m-itx/Kconfig.name A src/mainboard/asrock/b75m-itx/Makefile.inc A src/mainboard/asrock/b75m-itx/acpi/ec.asl A src/mainboard/asrock/b75m-itx/acpi/platform.asl A src/mainboard/asrock/b75m-itx/acpi/superio.asl A src/mainboard/asrock/b75m-itx/board_info.txt A src/mainboard/asrock/b75m-itx/cmos.default A src/mainboard/asrock/b75m-itx/cmos.layout A src/mainboard/asrock/b75m-itx/data.vbt A src/mainboard/asrock/b75m-itx/devicetree.cb A src/mainboard/asrock/b75m-itx/dsdt.asl A src/mainboard/asrock/b75m-itx/early_init.c A src/mainboard/asrock/b75m-itx/gma-mainboard.ads A src/mainboard/asrock/b75m-itx/gpio.c A src/mainboard/asrock/b75m-itx/hda_verb.c A src/mainboard/asrock/b75m-itx/mainboard.c 17 files changed, 616 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/97/73097/6
