Nicola Corna (nicola@corna.info) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18329
commit 1120053ef34cfd81015c5de5ace676f08e8f9657 Author: Nicola Corna nicola@corna.info Date: Sat Feb 11 14:52:24 2017 +0100
ec/lenovo/h8: Fix mute LEDs
thinkpad_acpi expects a SSMS method to turn on/off the mute LED and a MMTS method to turn on/off the microphone mute LED. With these methods implemented the driver can correctly sync the LEDs LEDs with the corresponding statuses.
There seems to be two different bits to mute the audio in the Lenovo H8 EC: * AMUT, used internally (for example to disable the audio before entering S3). * ALMT, controllable by the OS, which also toggles the mute LED (if present).
Tested on a X220T and on a X201.
Change-Id: I578f95f9619a53fd35f8a8bfe5564aeb6c789212 Signed-off-by: Nicola Corna nicola@corna.info --- src/ec/lenovo/h8/acpi/ec.asl | 22 +++++++++++++++++++++- 1 file changed, 21 insertions(+), 1 deletion(-)
diff --git a/src/ec/lenovo/h8/acpi/ec.asl b/src/ec/lenovo/h8/acpi/ec.asl index 497dde4..b8350ad 100644 --- a/src/ec/lenovo/h8/acpi/ec.asl +++ b/src/ec/lenovo/h8/acpi/ec.asl @@ -39,8 +39,11 @@ Device(EC) DKR2, 1, /* Dock register 2 */ Offset (0x2a), EVNT, 8, /* write will trigger EC event */ + Offset (0x30), + , 6, + ALMT, 1, /* Audio Mute + LED */ Offset (0x3a), - AMUT, 1, /* Audio Mute */ + AMUT, 1, /* Audio Mute (internal use) */ , 3, BTEB, 1, WLEB, 1, @@ -362,6 +365,23 @@ Device(EC) { Return (TBSW << 3) } + /* Mute audio */ + Method (SSMS, 1, NotSerialized) + { + Store(Arg0, ALMT) + } + /* Control mute microphone LED */ + Method (MMTS, 1, NotSerialized) + { + If (Arg0) + { + TLED(0x8E) + } + Else + { + TLED(0x0E) + } + } /* Version */ Method (MHKV, 0, NotSerialized) {
