Ronald G. Minnich (rminnich@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17058
commit 54a36c9805a8c06446bcf951900f24aa8ffcdc25 Author: Ronald G. Minnich rminnich@gmail.com Date: Wed Oct 19 08:07:13 2016 -0700
RISCV: Clean up the common architectural code
We provide a standard payload that makes the jump from machine to supervisor mode; the days of kernels running in machine mode are over.
We do some small tweaks to the virtual memory code. We temporarily disable two functions that won't work on some targets as register numbers changed between 1.7 and 1.9. Once lowrisc catches up we'll reenable them.
Change-Id: I6caadfa9627fa35e31580492be01d4af908d31d9 Signed-off-by: Ronald G. Minnich rminnich@gmail.com --- src/arch/riscv/Makefile.inc | 1 + src/arch/riscv/boot.c | 4 ++++ src/arch/riscv/include/vm.h | 10 ---------- src/arch/riscv/payload.S | 35 +++++++++++++++++++++++++++++++++++ src/arch/riscv/trap_handler.c | 1 + src/arch/riscv/virtual_memory.c | 41 ++++++++++++++++++++++++++++++----------- 6 files changed, 71 insertions(+), 21 deletions(-)
diff --git a/src/arch/riscv/Makefile.inc b/src/arch/riscv/Makefile.inc index 4bab459..cf6ce99 100644 --- a/src/arch/riscv/Makefile.inc +++ b/src/arch/riscv/Makefile.inc @@ -96,6 +96,7 @@ ramstage-y += misc.c ramstage-y += boot.c ramstage-y += tables.c ramstage-y += sbi.S +ramstage-y += payload.S ramstage-y += \ $(top)/src/lib/memchr.c \ $(top)/src/lib/memcmp.c \ diff --git a/src/arch/riscv/boot.c b/src/arch/riscv/boot.c index 7435490..35a9123 100644 --- a/src/arch/riscv/boot.c +++ b/src/arch/riscv/boot.c @@ -13,6 +13,7 @@ * GNU General Public License for more details. */
+#include <lib.h> #include <program_loading.h> #include <vm.h> #include <arch/encoding.h> @@ -21,9 +22,12 @@ void arch_prog_run(struct prog *prog) { void (*doit)(void *) = prog_entry(prog); + void riscvpayload(void);
if (ENV_RAMSTAGE && prog_type(prog) == PROG_PAYLOAD) { + hexdump((void *)0x81000000, 128); initVirtualMemory(); + riscvpayload(); }
doit(prog_entry_arg(prog)); diff --git a/src/arch/riscv/include/vm.h b/src/arch/riscv/include/vm.h index bee2ed4..6472cad 100644 --- a/src/arch/riscv/include/vm.h +++ b/src/arch/riscv/include/vm.h @@ -37,16 +37,6 @@ #define VA_BITS 39 #define MEGAPAGE_SIZE (SUPERPAGE_SIZE << RISCV_PGLEVEL_BITS)
-#define PROT_READ 1 -#define PROT_WRITE 2 -#define PROT_EXEC 4 - -#define MAP_PRIVATE 0x2 -#define MAP_FIXED 0x10 -#define MAP_ANONYMOUS 0x20 -#define MAP_POPULATE 0x8000 -#define MREMAP_FIXED 0x2 - #define EXTRACT_FIELD(val, which) (((val) & (which)) / ((which) & ~((which)-1))) #define INSERT_FIELD(val, which, fieldval) (((val) & ~(which)) | ((fieldval) * ((which) & ~((which)-1))))
diff --git a/src/arch/riscv/payload.S b/src/arch/riscv/payload.S new file mode 100644 index 0000000..bc9654a --- /dev/null +++ b/src/arch/riscv/payload.S @@ -0,0 +1,35 @@ +/* + * This file is part of the coreboot project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + + .global riscvpayload +riscvpayload: + /* Jump to 0xffffffff81000000 in S-mode */ + li t0, 0xffffffff81000000 + csrw mepc, t0 + csrr t0, mstatus + li t1, ~(3<<11) + and t0, t0, t1 + li t2, (1<<11) + or t0, t0, t2 + csrw mstatus, t0 + +#if 0 // remove for testing. +.L2: + li a5,1107296256 + li a4,48 + sw a4,0(a5) + j .L2 +#endif + // We're still in toolchain no mans land. + .word 0x30200073 + //mret diff --git a/src/arch/riscv/trap_handler.c b/src/arch/riscv/trap_handler.c index ad49928..d2b05bd 100644 --- a/src/arch/riscv/trap_handler.c +++ b/src/arch/riscv/trap_handler.c @@ -163,6 +163,7 @@ void trap_handler(trapframe *tf) { break; }
+ //print_page_table(); die("Can't recover from trap. Halting.\n"); }
diff --git a/src/arch/riscv/virtual_memory.c b/src/arch/riscv/virtual_memory.c index be8b488..8b75a3d 100644 --- a/src/arch/riscv/virtual_memory.c +++ b/src/arch/riscv/virtual_memory.c @@ -94,7 +94,7 @@ static void print_page_table_at(pte_t *pt, intptr_t virt_addr, int level)
/* Print the page table structures to the console */ void print_page_table(void) { - print_page_table_at(root_page_table, 0, 0); + print_page_table_at((void *)(read_csr(sptbr) << RISCV_PGSHIFT), 0, 0); }
void flush_tlb(void) @@ -115,9 +115,9 @@ pte_t ptd_create(uintptr_t ppn) pte_t pte_create(uintptr_t ppn, int prot, int user) { pte_t pte = (ppn << PTE_PPN_SHIFT) | PTE_R | PTE_V; - if (prot & PROT_WRITE) + if (prot & PTE_W) pte |= PTE_W; - if (prot & PROT_EXEC) + if (prot & PTE_X) pte |= PTE_X; if (user) pte |= PTE_U; @@ -147,21 +147,32 @@ void init_vm(uintptr_t virtMemStart, uintptr_t physMemStart, uintptr_t pageTable int l2_shift = RISCV_PGLEVEL_BITS + RISCV_PGSHIFT; size_t l2_idx = (virtMemStart >> l2_shift) & ((1 << RISCV_PGLEVEL_BITS)-1); l2_idx += ((vaddr - virtMemStart) >> l2_shift); - middle_pt[l2_idx] = pte_create(paddr >> RISCV_PGSHIFT, PROT_READ|PROT_WRITE|PROT_EXEC, 0); + middle_pt[l2_idx] = pte_create(paddr >> RISCV_PGSHIFT, + PTE_R|PTE_W|PTE_X, 0); }
// map SBI at top of vaddr space - uintptr_t num_sbi_pages = 1; // only need to map a single page for sbi interface + // only need to map a single page for sbi interface + uintptr_t num_sbi_pages = 1; uintptr_t sbiStartAddress = (uintptr_t) &sbi_page; uintptr_t sbiAddr = sbiStartAddress; for (uintptr_t i = 0; i < num_sbi_pages; i++) { uintptr_t idx = (1 << RISCV_PGLEVEL_BITS) - num_sbi_pages + i; - sbi_pt[idx] = pte_create(sbiAddr >> RISCV_PGSHIFT, PROT_READ|PROT_EXEC, 0); + sbi_pt[idx] = pte_create(sbiAddr >> RISCV_PGSHIFT, + PTE_R|PTE_X, 0); sbiAddr += RISCV_PGSIZE; } pte_t* sbi_pte = middle_pt + ((num_middle_pts << RISCV_PGLEVEL_BITS)-1); *sbi_pte = ptd_create((uintptr_t)sbi_pt >> RISCV_PGSHIFT);
+ // IO space. + root_pt[0] = pte_create(0, PTE_W|PTE_R, 0); + root_pt[1] = pte_create(0x40000000>>RISCV_PGSHIFT, + PTE_W|PTE_R, 0); + + // Start of RAM + root_pt[2] = pte_create(0x80000000>>RISCV_PGSHIFT, + PTE_W|PTE_R, 0); mb(); root_page_table = root_pt; uintptr_t ptbr = ((uintptr_t) root_pt) >> RISCV_PGSHIFT; @@ -185,12 +196,14 @@ void initVirtualMemory(void) { printk(BIOS_DEBUG, "-----------------------------\n"); }
+ // TODO: Figure out how to grab this from cbfs printk(BIOS_DEBUG, "Initializing virtual memory...\n"); - uintptr_t physicalStart = 0x90000000; // TODO: Figure out how to grab this from cbfs - uintptr_t virtualStart = 0xffffffff80000000; - uintptr_t pageTableStart = 0x91400000; + uintptr_t physicalStart = 0x81000000; + uintptr_t virtualStart = 0xffffffff81000000; + uintptr_t pageTableStart = 0x80800000; init_vm(virtualStart, physicalStart, pageTableStart); mb(); + flush_tlb();
#if IS_ENABLED(CONFIG_DEBUG_PRINT_PAGE_TABLES) printk(BIOS_DEBUG, "Finished initializing virtual memory, starting walk...\n"); @@ -211,6 +224,7 @@ void mstatus_init(void) set_csr(mie, MIP_MSIP);
/* Configure which exception causes are delegated to supervisor mode */ +/* set_csr(medeleg, (1 << CAUSE_MISALIGNED_FETCH) | (1 << CAUSE_FAULT_FETCH) | (1 << CAUSE_ILLEGAL_INSTRUCTION) @@ -220,7 +234,12 @@ void mstatus_init(void) | (1 << CAUSE_USER_ECALL) );
+*/ /* Enable all user/supervisor-mode counters */ - write_csr(mscounteren, 0b111); - write_csr(mucounteren, 0b111); + /* We'll turn these on once lowrisc gets their bitstream up to + * 1.9. Right now there's no agreement on the values for these + * architectural registers. + */ + //write_csr(mscounteren, 0b111); + //write_csr(mucounteren, 0b111); }
