Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8113
commit 87d5a355eddc87ad32494c60402a70ee3d0fdfbd Author: Stefan Reinauer reinauer@chromium.org Date: Mon Jan 5 13:05:44 2015 -0800
superio: Drop print_ implementation from non-romcc boards
Because we have no stack on romcc boards, we had a separate, not as powerful clone of printk: print_*. Back in the day, like more than half a decade ago, we migrated a lot of boards to printk, but we never cleaned up the existing code to be consistent. instead, we worked around the problem with a very messy console.h (nowadays the mess is hidden in romstage_console.c and early_print.h) This patch cleans up the superio code to use printk() on all non-ROMCC boards.
Change-Id: I23fc307f1346cdb7adaaeccfafe17d9205e909ac Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- src/superio/serverengines/pilot/early_init.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/src/superio/serverengines/pilot/early_init.c b/src/superio/serverengines/pilot/early_init.c index 6635645..b609572 100644 --- a/src/superio/serverengines/pilot/early_init.c +++ b/src/superio/serverengines/pilot/early_init.c @@ -36,11 +36,9 @@ void pilot_early_init(pnp_devfn_t dev) { u16 port = dev >> 8;
- print_debug("Using port: "); - print_debug_hex16(port); - print_debug("\n"); + printk(BIOS_DEBUG, "Using port: %04x\n", port); pilot_disable_serial(PNP_DEV(port, 0x1)); - print_debug("disable serial 1\n"); + printk(BIOS_DEBUG, "disable serial 1\n");
pnp_enter_ext_func_mode(dev); pnp_set_logical_device(PNP_DEV(port, 0x3));
