Alexandru Gagniuc (mr.nuke.me@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11365
commit e159e8b8521fd0307a81b2a668167995cdf8a4b7 Author: Alexandru Gagniuc mr.nuke.me@gmail.com Date: Wed Aug 26 10:11:02 2015 -0400
Kconfig: Remove EXPERT mode
After much consideration, and many years of an EXPERT mode sitting almost completely unused, we've seen that it doesn't work for us. There is no standard on what constitutes EXPERT, and most of coreboot's options Kconfig are expert-level.
We even joked that not selecting "EXPERT" should prevent coreboot from compiling:
@echo $(shell whoami) is not permitted to compile coreboot
Change-Id: Ic22dd54a48190b81d711625efb6b9f3078f41778 Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- payloads/external/SeaBIOS/Kconfig | 1 - src/Kconfig | 11 ----------- src/device/Kconfig | 4 ++-- src/northbridge/amd/amdfam10/Kconfig | 2 +- src/northbridge/amd/amdht/h3finit.c | 4 ++-- 5 files changed, 5 insertions(+), 17 deletions(-)
diff --git a/payloads/external/SeaBIOS/Kconfig b/payloads/external/SeaBIOS/Kconfig index b2ff21e..699b986 100644 --- a/payloads/external/SeaBIOS/Kconfig +++ b/payloads/external/SeaBIOS/Kconfig @@ -18,7 +18,6 @@ endchoice config SEABIOS_PS2_TIMEOUT prompt "PS/2 keyboard controller initialization timeout (milliseconds)" default 0 - depends on EXPERT int help Some PS/2 keyboard controllers don't respond to commands immediately diff --git a/src/Kconfig b/src/Kconfig index 9c01687..2c75750 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -22,14 +22,6 @@ mainmenu "coreboot configuration"
menu "General setup"
-config EXPERT - bool "Expert mode" - help - This allows you to select certain advanced configuration options. - - Warning: Only enable this option if you really know what you are - doing! You have been warned! - config LOCALVERSION string "Local version string" help @@ -111,7 +103,6 @@ config CCACHE config FMD_GENPARSER bool "Generate flashmap descriptor parser using flex and bison" default n - depends on EXPERT help Enable this option if you are working on the flashmap descriptor parser and made changes to fmd_scanner.l or fmd_parser.y. @@ -121,7 +112,6 @@ config FMD_GENPARSER config SCONFIG_GENPARSER bool "Generate SCONFIG parser using flex and bison" default n - depends on EXPERT help Enable this option if you are working on the sconfig device tree parser and made changes to sconfig.l or sconfig.y. @@ -283,7 +273,6 @@ config BOOTBLOCK_SOURCE config SKIP_MAX_REBOOT_CNT_CLEAR bool "Do not clear reboot count after successful boot" default n - depends on EXPERT help Do not clear the reboot count immediately after successful boot. Set to allow the payload to control normal/fallback image recovery. diff --git a/src/device/Kconfig b/src/device/Kconfig index 39e612d..3bee877 100644 --- a/src/device/Kconfig +++ b/src/device/Kconfig @@ -51,7 +51,7 @@ config VGA_ROM_RUN bool "Run VGA Option ROMs" default n if PAYLOAD_SEABIOS default y if !PAYLOAD_SEABIOS - depends on PCI && !MAINBOARD_DO_NATIVE_VGA_INIT && EXPERT + depends on PCI && !MAINBOARD_DO_NATIVE_VGA_INIT help Execute VGA Option ROMs in coreboot if found. This is required to enable PCI/AGP/PCI-E video cards when not using a SeaBIOS @@ -92,7 +92,7 @@ config ON_DEVICE_ROM_RUN bool "Run Option ROMs on PCI devices" default n if PAYLOAD_SEABIOS default y if !PAYLOAD_SEABIOS - depends on PCI && EXPERT + depends on PCI help Execute Option ROMs stored on PCI/PCIe/AGP devices in coreboot.
diff --git a/src/northbridge/amd/amdfam10/Kconfig b/src/northbridge/amd/amdfam10/Kconfig index 13954d4..4d7147d 100644 --- a/src/northbridge/amd/amdfam10/Kconfig +++ b/src/northbridge/amd/amdfam10/Kconfig @@ -120,7 +120,7 @@ config SVI_HIGH_FREQ
menu "HyperTransport setup" #could be implemented for K8 (NORTHBRIDGE_AMD_AMDK8) - depends on (NORTHBRIDGE_AMD_AMDFAM10) && EXPERT + depends on (NORTHBRIDGE_AMD_AMDFAM10)
choice prompt "HyperTransport downlink width" diff --git a/src/northbridge/amd/amdht/h3finit.c b/src/northbridge/amd/amdht/h3finit.c index 0138cd9..849f4a8 100644 --- a/src/northbridge/amd/amdht/h3finit.c +++ b/src/northbridge/amd/amdht/h3finit.c @@ -1399,13 +1399,13 @@ static void selectOptimalWidthAndFrequency(sMainData *pDat) cbPCBFreqLimit = ht_speed_mhz_to_hw(pDat->HtBlock->ht_link_configuration->ht_speed_limit); cbPCBFreqLimit = min(cbPCBFreqLimit, cbPCBFreqLimit_NVRAM);
-#if CONFIG_EXPERT && CONFIG_LIMIT_HT_DOWN_WIDTH_8 +#if CONFIG_LIMIT_HT_DOWN_WIDTH_8 cbPCBABDownstreamWidth = 8; #else cbPCBABDownstreamWidth = 16; #endif
-#if CONFIG_EXPERT && CONFIG_LIMIT_HT_UP_WIDTH_8 +#if CONFIG_LIMIT_HT_UP_WIDTH_8 cbPCBBAUpstreamWidth = 8; #else cbPCBBAUpstreamWidth = 16;
