Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43378 )
Change subject: soc/intel/skylake: Move `acpi_fill_fadt` to fadt.c ......................................................................
Intel southbridges do this.
Change-Id: I8ecf3c0b0c822185ca66bae1bd65b0cf24512a49 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/soc/intel/skylake/Makefile.inc M src/soc/intel/skylake/acpi.c A src/soc/intel/skylake/fadt.c 3 files changed, 132 insertions(+), 124 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/78/43378/1
diff --git a/src/soc/intel/skylake/Makefile.inc b/src/soc/intel/skylake/Makefile.inc index 75121ab..de516c1 100644 --- a/src/soc/intel/skylake/Makefile.inc +++ b/src/soc/intel/skylake/Makefile.inc @@ -43,6 +43,7 @@ ramstage-y += chip.c ramstage-y += cpu.c ramstage-y += elog.c +ramstage-y += fadt.c ramstage-y += finalize.c ramstage-y += gpio.c ramstage-y += gspi.c diff --git a/src/soc/intel/skylake/acpi.c b/src/soc/intel/skylake/acpi.c index 6da43e9..acd8d55 100644 --- a/src/soc/intel/skylake/acpi.c +++ b/src/soc/intel/skylake/acpi.c @@ -219,130 +219,6 @@ return acpi_madt_irq_overrides(current); }
-void acpi_fill_fadt(acpi_fadt_t *fadt) -{ - const uint16_t pmbase = ACPI_BASE_ADDRESS; - config_t *config = config_of_soc(); - - fadt->header.revision = get_acpi_table_revision(FADT); - - fadt->sci_int = acpi_sci_irq(); - - if (permanent_smi_handler()) { - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - } - - fadt->pm1a_evt_blk = pmbase + PM1_STS; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + PM1_CNT; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + PM2_CNT; - fadt->pm_tmr_blk = pmbase + PM1_TMR; - fadt->gpe0_blk = pmbase + GPE0_STS(0); - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - fadt->pm2_cnt_len = 1; - fadt->pm_tmr_len = 4; - /* There are 4 GPE0 STS/EN pairs each 32 bits wide. */ - fadt->gpe0_blk_len = 2 * GPE0_REG_MAX * sizeof(uint32_t); - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->p_lvl2_lat = 1; - fadt->p_lvl3_lat = 87; - fadt->flush_size = 1024; - fadt->flush_stride = 16; - fadt->duty_offset = 1; - fadt->duty_width = 0; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x00; - fadt->iapc_boot_arch = ACPI_FADT_LEGACY_FREE; - if (!CONFIG(NO_FADT_8042)) - fadt->iapc_boot_arch |= ACPI_FADT_8042; - - fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_SLEEP_BUTTON | - ACPI_FADT_RESET_REGISTER | ACPI_FADT_SEALED_CASE | - ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_PLATFORM_CLOCK; - - if (config->s0ix_enable) - fadt->flags |= ACPI_FADT_LOW_PWR_IDLE_S0; - - fadt->reset_reg.space_id = 1; - fadt->reset_reg.bit_width = 8; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; - fadt->reset_reg.addrl = 0xcf9; - fadt->reset_reg.addrh = 0; - fadt->reset_value = 6; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = fadt->pm1_evt_len * 8; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; - fadt->x_pm1a_evt_blk.addrl = pmbase + PM1_STS; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 1; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.access_size = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = fadt->pm1_cnt_len * 8; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; - fadt->x_pm1a_cnt_blk.addrl = pmbase + PM1_CNT; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 1; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.access_size = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = fadt->pm2_cnt_len * 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; - fadt->x_pm2_cnt_blk.addrl = pmbase + PM2_CNT; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = fadt->pm_tmr_len * 8; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; - fadt->x_pm_tmr_blk.addrl = pmbase + PM1_TMR; - fadt->x_pm_tmr_blk.addrh = 0x0; - - /* - * Windows 10 requires x_gpe0_blk to be set starting with FADT revision 5. - * The bit_width field intentionally overflows here. - * The OSPM can instead use the values in `fadt->gpe0_blk{,_len}`, which - * seems to work fine on Linux 5.0 and Windows 10. - */ - fadt->x_gpe0_blk.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->x_gpe0_blk.bit_width = fadt->gpe0_blk_len * 8; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; - fadt->x_gpe0_blk.addrl = fadt->gpe0_blk; - fadt->x_gpe0_blk.addrh = 0; - - fadt->x_gpe1_blk.space_id = 1; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.access_size = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; -} - static void write_c_state_entries(acpi_cstate_t *map, const int *set, size_t max_c_state) { for (size_t i = 0; i < max_c_state; i++) { diff --git a/src/soc/intel/skylake/fadt.c b/src/soc/intel/skylake/fadt.c new file mode 100644 index 0000000..3914969 --- /dev/null +++ b/src/soc/intel/skylake/fadt.c @@ -0,0 +1,131 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpi.h> +#include <cpu/x86/smm.h> +#include <soc/iomap.h> +#include <soc/pm.h> +#include "chip.h" + +void acpi_fill_fadt(acpi_fadt_t *fadt) +{ + const uint16_t pmbase = ACPI_BASE_ADDRESS; + config_t *config = config_of_soc(); + + fadt->header.revision = get_acpi_table_revision(FADT); + + fadt->sci_int = acpi_sci_irq(); + + if (permanent_smi_handler()) { + fadt->smi_cmd = APM_CNT; + fadt->acpi_enable = APM_CNT_ACPI_ENABLE; + fadt->acpi_disable = APM_CNT_ACPI_DISABLE; + } + + fadt->pm1a_evt_blk = pmbase + PM1_STS; + fadt->pm1b_evt_blk = 0x0; + fadt->pm1a_cnt_blk = pmbase + PM1_CNT; + fadt->pm1b_cnt_blk = 0x0; + fadt->pm2_cnt_blk = pmbase + PM2_CNT; + fadt->pm_tmr_blk = pmbase + PM1_TMR; + fadt->gpe0_blk = pmbase + GPE0_STS(0); + fadt->gpe1_blk = 0; + + fadt->pm1_evt_len = 4; + fadt->pm1_cnt_len = 2; + fadt->pm2_cnt_len = 1; + fadt->pm_tmr_len = 4; + /* There are 4 GPE0 STS/EN pairs each 32 bits wide. */ + fadt->gpe0_blk_len = 2 * GPE0_REG_MAX * sizeof(uint32_t); + fadt->gpe1_blk_len = 0; + fadt->gpe1_base = 0; + fadt->p_lvl2_lat = 1; + fadt->p_lvl3_lat = 87; + fadt->flush_size = 1024; + fadt->flush_stride = 16; + fadt->duty_offset = 1; + fadt->duty_width = 0; + fadt->day_alrm = 0xd; + fadt->mon_alrm = 0x00; + fadt->century = 0x00; + fadt->iapc_boot_arch = ACPI_FADT_LEGACY_FREE; + if (!CONFIG(NO_FADT_8042)) + fadt->iapc_boot_arch |= ACPI_FADT_8042; + + fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | + ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_SLEEP_BUTTON | + ACPI_FADT_RESET_REGISTER | ACPI_FADT_SEALED_CASE | + ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_PLATFORM_CLOCK; + + if (config->s0ix_enable) + fadt->flags |= ACPI_FADT_LOW_PWR_IDLE_S0; + + fadt->reset_reg.space_id = 1; + fadt->reset_reg.bit_width = 8; + fadt->reset_reg.bit_offset = 0; + fadt->reset_reg.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->reset_reg.addrl = 0xcf9; + fadt->reset_reg.addrh = 0; + fadt->reset_value = 6; + + fadt->x_pm1a_evt_blk.space_id = 1; + fadt->x_pm1a_evt_blk.bit_width = fadt->pm1_evt_len * 8; + fadt->x_pm1a_evt_blk.bit_offset = 0; + fadt->x_pm1a_evt_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_pm1a_evt_blk.addrl = pmbase + PM1_STS; + fadt->x_pm1a_evt_blk.addrh = 0x0; + + fadt->x_pm1b_evt_blk.space_id = 1; + fadt->x_pm1b_evt_blk.bit_width = 0; + fadt->x_pm1b_evt_blk.bit_offset = 0; + fadt->x_pm1b_evt_blk.access_size = 0; + fadt->x_pm1b_evt_blk.addrl = 0x0; + fadt->x_pm1b_evt_blk.addrh = 0x0; + + fadt->x_pm1a_cnt_blk.space_id = 1; + fadt->x_pm1a_cnt_blk.bit_width = fadt->pm1_cnt_len * 8; + fadt->x_pm1a_cnt_blk.bit_offset = 0; + fadt->x_pm1a_cnt_blk.access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; + fadt->x_pm1a_cnt_blk.addrl = pmbase + PM1_CNT; + fadt->x_pm1a_cnt_blk.addrh = 0x0; + + fadt->x_pm1b_cnt_blk.space_id = 1; + fadt->x_pm1b_cnt_blk.bit_width = 0; + fadt->x_pm1b_cnt_blk.bit_offset = 0; + fadt->x_pm1b_cnt_blk.access_size = 0; + fadt->x_pm1b_cnt_blk.addrl = 0x0; + fadt->x_pm1b_cnt_blk.addrh = 0x0; + + fadt->x_pm2_cnt_blk.space_id = 1; + fadt->x_pm2_cnt_blk.bit_width = fadt->pm2_cnt_len * 8; + fadt->x_pm2_cnt_blk.bit_offset = 0; + fadt->x_pm2_cnt_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->x_pm2_cnt_blk.addrl = pmbase + PM2_CNT; + fadt->x_pm2_cnt_blk.addrh = 0x0; + + fadt->x_pm_tmr_blk.space_id = 1; + fadt->x_pm_tmr_blk.bit_width = fadt->pm_tmr_len * 8; + fadt->x_pm_tmr_blk.bit_offset = 0; + fadt->x_pm_tmr_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_pm_tmr_blk.addrl = pmbase + PM1_TMR; + fadt->x_pm_tmr_blk.addrh = 0x0; + + /* + * Windows 10 requires x_gpe0_blk to be set starting with FADT revision 5. + * The bit_width field intentionally overflows here. + * The OSPM can instead use the values in `fadt->gpe0_blk{,_len}`, which + * seems to work fine on Linux 5.0 and Windows 10. + */ + fadt->x_gpe0_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_gpe0_blk.bit_width = fadt->gpe0_blk_len * 8; + fadt->x_gpe0_blk.bit_offset = 0; + fadt->x_gpe0_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->x_gpe0_blk.addrl = fadt->gpe0_blk; + fadt->x_gpe0_blk.addrh = 0; + + fadt->x_gpe1_blk.space_id = 1; + fadt->x_gpe1_blk.bit_width = 0; + fadt->x_gpe1_blk.bit_offset = 0; + fadt->x_gpe1_blk.access_size = 0; + fadt->x_gpe1_blk.addrl = 0x0; + fadt->x_gpe1_blk.addrh = 0x0; +}
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43378 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/43378/1/src/soc/intel/skylake/fadt.... File src/soc/intel/skylake/fadt.c:
https://review.coreboot.org/c/coreboot/+/43378/1/src/soc/intel/skylake/fadt.... PS1, Line 62: 1 use macro
https://review.coreboot.org/c/coreboot/+/43378/1/src/soc/intel/skylake/fadt.... PS1, Line 80: 0 use macro
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43378 )
Patch Set 1:
(2 comments)
use macro
Refer to the explanations I provided on CB:43372
use macro
Maxim Polyakov has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43378 )
Patch Set 1: Code-Review+2
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43378 )
Change-Id: I8ecf3c0b0c822185ca66bae1bd65b0cf24512a49 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43378 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Maxim Polyakov max.senia.poliak@gmail.com --- M src/soc/intel/skylake/Makefile.inc M src/soc/intel/skylake/acpi.c A src/soc/intel/skylake/fadt.c 3 files changed, 132 insertions(+), 124 deletions(-)
Approvals: build bot (Jenkins): Verified Maxim Polyakov: Looks good to me, approved
diff --git a/src/soc/intel/skylake/Makefile.inc b/src/soc/intel/skylake/Makefile.inc index 75121ab..de516c1 100644 --- a/src/soc/intel/skylake/Makefile.inc +++ b/src/soc/intel/skylake/Makefile.inc @@ -43,6 +43,7 @@ ramstage-y += chip.c ramstage-y += cpu.c ramstage-y += elog.c +ramstage-y += fadt.c ramstage-y += finalize.c ramstage-y += gpio.c ramstage-y += gspi.c diff --git a/src/soc/intel/skylake/acpi.c b/src/soc/intel/skylake/acpi.c index 0ef8343..1beff3d 100644 --- a/src/soc/intel/skylake/acpi.c +++ b/src/soc/intel/skylake/acpi.c @@ -218,130 +218,6 @@ return acpi_madt_irq_overrides(current); }
