Hello Felix Singer, build bot (Jenkins), Nico Huber, Furquan Shaikh, Matt DeVillier, Tim Wawrzynczak, Paul Menzel, Subrata Banik, Patrick Rudolph, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/46460
Change subject: soc/intel: drop unneeded ISST configuration code ......................................................................
The code configuring ISST (Intel SpeedShift Technology) sets the ISST capability bits in CPUID.06H:EAX. It does *not* activate HWP (Hardware P-States), which shall be done by the OS only.
Since the capability is enabled by default (opt-out), there is nothing to do for us in the enabled-case. Practically speaking, there is no value at all in disabling the capability, since one can configure the OS to not enable HWP if that is desired.
The two other bits for EPP and HWP interrupt that were set by the code are not set anymore, too. It was tested, on three platforms so far (CML-U, KBL-H, SKL-U), that these are set as well by default in the MSRs reset value (0x1cc0).
To reduce complexity and duplicated code without actual benefit, this code gets dropped. The remaining dt option will be dropped in CB:46462.
Test: Linux on Supermicro X11SSM-F detects and enables HWP: [ 0.415017] intel_pstate: HWP enabled
Change-Id: I952720cf1de78b00b1bf749f10e9c0acd6ecb6b7 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/alderlake/cpu.c M src/soc/intel/cannonlake/cpu.c M src/soc/intel/elkhartlake/cpu.c M src/soc/intel/icelake/cpu.c M src/soc/intel/jasperlake/cpu.c M src/soc/intel/skylake/cpu.c M src/soc/intel/tigerlake/cpu.c 7 files changed, 0 insertions(+), 196 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/60/46460/7
