Felix Singer has submitted this change. ( https://review.coreboot.org/c/coreboot/+/80610?usp=email )
Change subject: mb/lenovo: Add ThinkCentre M700/M900 Tiny board (Skylake/Kaby Lake) ......................................................................
The M700 / M900 Tiny boards are USFF PCs that come with Skylake LGA1151 processors. M700 comes with B150 chipset, M900 comes with Q170 and is vPro capable.
There is an onboard discrete TPM 1.2. Intel PTT fTPM can also be enabled in vendor FW, but for now it's not used here.
LPSS UART for debugging is available on pins 17,18 on the underside of the mainboard, but it is not enabled by default.
Tested unit is M900 with i5-6500T. Boots to Fedora 38 w/ kernel 6.5.5 and Windows 11.
Tested and working:
- Serial port (via optional module) - Rear DisplayPort connectors - Graphics w/ libgfxinit - Ethernet - SATA - NVMe - Internal speaker, front combo jack, rear line-out - Discrete TPM 1.2 - USB ports (Port 1 untested, apparently broken on my unit) - M.2 2230 Wi-Fi slot (needs ASPM L1s disabled) - S3 suspend - ME disable via NVRAM setting
Untested:
- Front mic input - Optional expansion headers: DisplayPort, USB, PS/2, SATA / PCIe
Change-Id: I6786e068ec03c8bf243e1767cd7b9d50512ea77f Signed-off-by: Michał Kopeć michal.kopec@3mdeb.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/80610 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Singer service+coreboot-gerrit@felixsinger.de --- A src/mainboard/lenovo/m900_tiny/Kconfig A src/mainboard/lenovo/m900_tiny/Kconfig.name A src/mainboard/lenovo/m900_tiny/Makefile.mk A src/mainboard/lenovo/m900_tiny/acpi/ec.asl A src/mainboard/lenovo/m900_tiny/acpi/superio.asl A src/mainboard/lenovo/m900_tiny/board_info.txt A src/mainboard/lenovo/m900_tiny/bootblock.c A src/mainboard/lenovo/m900_tiny/cmos.default A src/mainboard/lenovo/m900_tiny/cmos.layout A src/mainboard/lenovo/m900_tiny/data.vbt A src/mainboard/lenovo/m900_tiny/devicetree.cb A src/mainboard/lenovo/m900_tiny/dsdt.asl A src/mainboard/lenovo/m900_tiny/gma-mainboard.ads A src/mainboard/lenovo/m900_tiny/gpio.c A src/mainboard/lenovo/m900_tiny/gpio_early.c A src/mainboard/lenovo/m900_tiny/hda_verb.c A src/mainboard/lenovo/m900_tiny/include/mainboard/gpio.h A src/mainboard/lenovo/m900_tiny/ramstage.c A src/mainboard/lenovo/m900_tiny/romstage.c 19 files changed, 854 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Felix Singer: Looks good to me, approved
diff --git a/src/mainboard/lenovo/m900_tiny/Kconfig b/src/mainboard/lenovo/m900_tiny/Kconfig new file mode 100644 index 0000000..ffcf058 --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/Kconfig @@ -0,0 +1,44 @@ +# SPDX-License-Identifier: GPL-2.0-only + +if BOARD_LENOVO_THINKCENTRE_M900_TINY + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select BOARD_ROMSIZE_KB_16384 + select DRIVERS_UART_8250IO + select HAVE_ACPI_RESUME + select HAVE_ACPI_TABLES + select HAVE_CMOS_DEFAULT + select HAVE_OPTION_TABLE + select INTEL_GMA_HAVE_VBT + select INTEL_INT15 + select MAINBOARD_HAS_LIBGFXINIT + select MAINBOARD_HAS_TPM1 + select MAINBOARD_USES_IFD_GBE_REGION + select MEMORY_MAPPED_TPM + select SKYLAKE_SOC_PCH_H + select SOC_INTEL_COMMON_BLOCK_HDA_VERB + select SOC_INTEL_KABYLAKE + select SUPERIO_NUVOTON_NCT6687D + +config UART_FOR_CONSOLE + default 2 if INTEL_LPSS_UART_FOR_CONSOLE + default 0 + +config MAINBOARD_DIR + default "lenovo/m900_tiny" + +config MAINBOARD_PART_NUMBER + default "ThinkCentre M700 / M900 Tiny" + +config PRERAM_CBMEM_CONSOLE_SIZE + default 0xd00 + +config DIMM_SPD_SIZE + default 512 #DDR4 + +# TODO: fix and enable +config DRIVER_LENOVO_SERIALS + default n + +endif diff --git a/src/mainboard/lenovo/m900_tiny/Kconfig.name b/src/mainboard/lenovo/m900_tiny/Kconfig.name new file mode 100644 index 0000000..6727a9c --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/Kconfig.name @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0-only + +config BOARD_LENOVO_THINKCENTRE_M900_TINY + bool "ThinkCentre M700 / M900 Tiny" diff --git a/src/mainboard/lenovo/m900_tiny/Makefile.mk b/src/mainboard/lenovo/m900_tiny/Makefile.mk new file mode 100644 index 0000000..44db091 --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/Makefile.mk @@ -0,0 +1,13 @@ +## SPDX-License-Identifier: GPL-2.0-only + +CPPFLAGS_common += -I$(src)/mainboard/$(MAINBOARDDIR)/include + +bootblock-y += bootblock.c +bootblock-y += gpio_early.c + +romstage-y += romstage.c + +ramstage-y += gpio.c +ramstage-y += hda_verb.c +ramstage-y += ramstage.c +ramstage-$(CONFIG_MAINBOARD_USE_LIBGFXINIT) += gma-mainboard.ads diff --git a/src/mainboard/lenovo/m900_tiny/acpi/ec.asl b/src/mainboard/lenovo/m900_tiny/acpi/ec.asl new file mode 100644 index 0000000..479296c --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/acpi/ec.asl @@ -0,0 +1,5 @@ +/* SPDX-License-Identifier: CC-PDDC */ + +/* Please update the license if adding licensable material. */ + +/* dummy */ diff --git a/src/mainboard/lenovo/m900_tiny/acpi/superio.asl b/src/mainboard/lenovo/m900_tiny/acpi/superio.asl new file mode 100644 index 0000000..13623c5 --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/acpi/superio.asl @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#define SUPERIO_DEV SIO0 +#define SUPERIO_PNP_BASE 0x2e +#define NCT6687D_SHOW_SP1 +#define NCT6687D_SHOW_EC + +#include <superio/nuvoton/nct6687d/acpi/superio.asl> diff --git a/src/mainboard/lenovo/m900_tiny/board_info.txt b/src/mainboard/lenovo/m900_tiny/board_info.txt new file mode 100644 index 0000000..db7669c --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/board_info.txt @@ -0,0 +1,7 @@ +Category: desktop +Board URL: https://psref.lenovo.com/Product/ThinkCentre_M900_Tiny +ROM package: SOIC-8 +ROM protocol: SPI +ROM socketed: n +Flashrom support: y +Release year: 2015 diff --git a/src/mainboard/lenovo/m900_tiny/bootblock.c b/src/mainboard/lenovo/m900_tiny/bootblock.c new file mode 100644 index 0000000..ab5f402 --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/bootblock.c @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <bootblock_common.h> +#include <device/pnp_ops.h> +#include <mainboard/gpio.h> +#include <soc/gpio.h> +#include <superio/nuvoton/common/nuvoton.h> +#include <superio/nuvoton/nct6687d/nct6687d.h> + +#define SERIAL_DEV PNP_DEV(0x2e, NCT6687D_SP1) +#define POWER_DEV PNP_DEV(0x2e, NCT6687D_SLEEP_PWR) + +void bootblock_mainboard_early_init(void) +{ + mainboard_configure_early_gpios(); + + /* Replicate vendor settings for multi-function pins in global config LDN */ + nuvoton_pnp_enter_conf_state(SERIAL_DEV); + pnp_write_config(SERIAL_DEV, 0x13, 0x0c); + pnp_write_config(SERIAL_DEV, 0x1d, 0x08); + pnp_write_config(SERIAL_DEV, 0x1f, 0xf0); + pnp_write_config(SERIAL_DEV, 0x22, 0xbc); + pnp_write_config(SERIAL_DEV, 0x23, 0xdf); + pnp_write_config(SERIAL_DEV, 0x24, 0x81); + pnp_write_config(SERIAL_DEV, 0x25, 0xff); + pnp_write_config(SERIAL_DEV, 0x29, 0x6d); + pnp_write_config(SERIAL_DEV, 0x2a, 0x8f); + + /* Configure pin for PECI */ + pnp_set_logical_device(POWER_DEV); + pnp_write_config(POWER_DEV, 0xf3, 0x0c); + + nuvoton_pnp_exit_conf_state(POWER_DEV); + + /* Enable serial */ + if (CONFIG(CONSOLE_SERIAL)) + nuvoton_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); +} diff --git a/src/mainboard/lenovo/m900_tiny/cmos.default b/src/mainboard/lenovo/m900_tiny/cmos.default new file mode 100644 index 0000000..84236aa --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/cmos.default @@ -0,0 +1,6 @@ +## SPDX-License-Identifier: GPL-2.0-only + +boot_option=Fallback +debug_level=Debug +power_on_after_fail=Disable +nmi=Enable diff --git a/src/mainboard/lenovo/m900_tiny/cmos.layout b/src/mainboard/lenovo/m900_tiny/cmos.layout new file mode 100644 index 0000000..322fa7d --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/cmos.layout @@ -0,0 +1,60 @@ +## SPDX-License-Identifier: GPL-2.0-only + +# ----------------------------------------------------------------- +entries + +#start-bit length config config-ID name + +# ----------------------------------------------------------------- +0 120 r 0 reserved_memory + +# ----------------------------------------------------------------- +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +388 4 h 0 reboot_counter + +# ----------------------------------------------------------------- +# coreboot config options: console +395 4 e 6 debug_level + +# coreboot config options: cpu +400 1 e 1 hyper_threading + +# coreboot config options: southbridge +408 1 e 1 nmi +409 2 e 7 power_on_after_fail + +# coreboot config options: ME +416 1 e 2 me_state +417 3 h 0 me_state_counter + +# coreboot config options: check sums +984 16 h 0 check_sum + +# ----------------------------------------------------------------- + +enumerations + +#ID value text +1 0 Disable +1 1 Enable +2 0 Enable +2 1 Disable +4 0 Fallback +4 1 Normal +6 0 Emergency +6 1 Alert +6 2 Critical +6 3 Error +6 4 Warning +6 5 Notice +6 6 Info +6 7 Debug +6 8 Spew +7 0 Disable +7 1 Enable +7 2 Keep +# ----------------------------------------------------------------- +checksums + +checksum 392 423 984 diff --git a/src/mainboard/lenovo/m900_tiny/data.vbt b/src/mainboard/lenovo/m900_tiny/data.vbt new file mode 100644 index 0000000..7e6fe3d --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/data.vbt Binary files differ diff --git a/src/mainboard/lenovo/m900_tiny/devicetree.cb b/src/mainboard/lenovo/m900_tiny/devicetree.cb new file mode 100644 index 0000000..e9f15d6 --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/devicetree.cb @@ -0,0 +1,223 @@ +## SPDX-License-Identifier: GPL-2.0-only + +chip soc/intel/skylake + # Enable deep Sx states + register "deep_s5_enable_ac" = "1" + register "deep_s5_enable_dc" = "1" + register "deep_sx_config" = "DSX_EN_LAN_WAKE_PIN | DSX_EN_WAKE_PIN" + + register "eist_enable" = "1" + + # GPE configuration + # Note that GPE events called out in ASL code rely on this + # route. i.e. If this route changes then the affected GPE + # offset bits also need to be changed. + register "gpe0_dw0" = "GPP_G" + register "gpe0_dw1" = "GPP_D" + register "gpe0_dw2" = "GPP_E" + + # Enabling SLP_S3#, SLP_S4#, SLP_SUS and SLP_A Stretch + # SLP_S3 Minimum Assertion Width. Values 0: 60us, 1: 1ms, 2: 50ms, 3: 2s + register "PmConfigSlpS3MinAssert" = "0x02" + + # SLP_S4 Minimum Assertion Width. Values 0: default, 1: 1s, 2: 2s, 3: 3s, 4: 4s + register "PmConfigSlpS4MinAssert" = "0x04" + + # SLP_SUS Minimum Assertion Width. Values 0: 0ms, 1: 500ms, 2: 1s, 3: 4s + register "PmConfigSlpSusMinAssert" = "0x03" + + # SLP_A Minimum Assertion Width. Values 0: 0ms, 1: 4s, 2: 98ms, 3: 2s + register "PmConfigSlpAMinAssert" = "0x03" + + # PL2 override 65W + register "power_limits_config" = "{ + .tdp_pl2_override = 65, + }" + + register "SerialIoDevMode" = "{ + [PchSerialIoIndexUart2] = PchSerialIoSkipInit, // LPSS UART + }" + + # VR Settings Configuration for 4 Domains + #+----------------+-------+-------+-------+-------+ + #| Domain/Setting | SA | IA | GTUS | GTS | + #+----------------+-------+-------+-------+-------+ + #| Psi1Threshold | 20A | 20A | 20A | 20A | + #| Psi2Threshold | 4A | 5A | 5A | 5A | + #| Psi3Threshold | 1A | 1A | 1A | 1A | + #| Psi3Enable | 1 | 1 | 1 | 1 | + #| Psi4Enable | 1 | 1 | 1 | 1 | + #| ImonSlope | 0 | 0 | 0 | 0 | + #| ImonOffset | 0 | 0 | 0 | 0 | + #| IccMax | 11A | 66A | 48A | 48A | + #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | + #| AcLoadline | 3.9 | 2.1 | 3.1 | 3.1 | + #| DcLoadline | 3.9 | 2.1 | 3.1 | 3.1 | + #+----------------+-------+-------+-------+-------+ + register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(4), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(11), + .voltage_limit = 1520, + .ac_loadline = 390, + .dc_loadline = 390, + }" + + register "domain_vr_config[VR_IA_CORE]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(66), + .voltage_limit = 1520, + .ac_loadline = 210, + .dc_loadline = 210, + }" + + register "domain_vr_config[VR_GT_UNSLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(48), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + register "domain_vr_config[VR_GT_SLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = VR_CFG_AMP(48), + .voltage_limit = 1520, + .ac_loadline = 310, + .dc_loadline = 310, + }" + + # Send an extra VR mailbox command for the PS4 exit issue + register "SendVrMbxCmd" = "2" + + device cpu_cluster 0 on end + device domain 0 on + subsystemid 0x17aa 0x30d0 inherit + device ref igpu on + register "PrimaryDisplay" = "Display_iGFX" + end + device ref sa_thermal on end + device ref gmm on end + device ref south_xhci on + register "usb2_ports" = "{ + [0] = USB2_PORT_MID(OC0), // Front Port 1 + [1] = USB2_PORT_MID(OC0), // Front Port 2 + [2] = USB2_PORT_MID(OC1), // Rear Port 3 + [3] = USB2_PORT_MID(OC2), // Rear Port 4 + [4] = USB2_PORT_MID(OC3), // Rear Port 5 + [5] = USB2_PORT_MID(OC4), // Rear Port 6 + [6] = USB2_PORT_MID(OC1), // Internal header + [8] = USB2_PORT_SHORT(OC_SKIP), // M.2 2230 + }" + register "usb3_ports" = "{ + [0] = USB3_PORT_DEFAULT(OC0), // Front Port 1 + [1] = USB3_PORT_DEFAULT(OC0), // Front Port 2 + [2] = USB3_PORT_DEFAULT(OC3), // Rear Port 3 + [3] = USB3_PORT_DEFAULT(OC3), // Rear Port 4 + [4] = USB3_PORT_DEFAULT(OC1), // Rear Port 5 + [5] = USB3_PORT_DEFAULT(OC1), // Rear Port 6 + }" + end + device ref thermal on end + device ref heci1 on end + device ref sata on + register "SataSalpSupport" = "1" + register "SataPortsEnable" = "{ + [0] = 1, + [1] = 1, + [2] = 1, + [3] = 1, + [4] = 1, + }" + register "SataPortsHotPlug" = "{ + [0] = 1, + [1] = 1, + }" + end + device ref pcie_rp17 on # M.2 2280 / 2242 - SSD + register "PcieRpEnable[16]" = "1" + register "PcieRpClkReqSupport[16]" = "1" + register "PcieRpClkReqNumber[16]" = "1" + register "PcieRpAdvancedErrorReporting[16]" = "1" + register "PcieRpLtrEnable[16]" = "1" + register "PcieRpClkSrcNumber[16]" = "7" + register "PcieRpHotPlug[16]" = "1" + end + device ref pcie_rp7 on # M.2 2230 - WLAN + register "PcieRpEnable[6]" = "1" + register "PcieRpClkReqSupport[6]" = "1" + register "PcieRpClkReqNumber[6]" = "11" + register "PcieRpAdvancedErrorReporting[6]" = "1" + register "PcieRpLtrEnable[6]" = "1" + register "PcieRpClkSrcNumber[6]" = "1" + register "PcieRpHotPlug[6]" = "1" + chip drivers/wifi/generic + register "wake" = "GPE0_PCI_EXP" + device generic 0 on end + end + end + device ref lpc_espi on + # Set LPC Serial IRQ mode + register "serirq_mode" = "SERIRQ_CONTINUOUS" + chip superio/nuvoton/nct6687d + device pnp 2e.1 off end # Parallel port + device pnp 2e.2 on # COM1 - optional module + io 0x60 = 0x3f8 + irq 0x70 = 3 + end + device pnp 2e.3 off end # COM2, IR + device pnp 2e.5 off end # Keyboard + device pnp 2e.6 off end # CIR + device pnp 2e.7 off end # GPIO0-7 + device pnp 2e.8 off end # P80 UART + device pnp 2e.9 off end # GPIO8-9, GPIO1-8 AF + device pnp 2e.a on # ACPI + io 0x60 = 0xa10 + end + device pnp 2e.b on # EC + io 0x60 = 0xa20 + end + device pnp 2e.c off end # RTC + device pnp 2e.d off end # Deep Sleep + device pnp 2e.e on # TACH/PWM assignment + irq 0xe4 = 0x10 + irq 0xe5 = 0x09 + end + device pnp 2e.f off end # Function register + end + chip drivers/pc80/tpm + device pnp 0c31.0 on end + end + end + device ref hda on end + device ref smbus on end + device ref gbe on end + end +end diff --git a/src/mainboard/lenovo/m900_tiny/dsdt.asl b/src/mainboard/lenovo/m900_tiny/dsdt.asl new file mode 100644 index 0000000..4a91cd5 --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/dsdt.asl @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpi.h> +DefinitionBlock( + "dsdt.aml", + "DSDT", + ACPI_DSDT_REV_2, + OEM_ID, + ACPI_TABLE_CREATOR, + 0x20110725 +) +{ + #include <acpi/dsdt_top.asl> + #include <soc/intel/common/block/acpi/acpi/platform.asl> + #include <soc/intel/common/block/acpi/acpi/globalnvs.asl> + #include <cpu/intel/common/acpi/cpu.asl> + + Device (_SB.PCI0) { + #include <soc/intel/skylake/acpi/ipu.asl> + #include <soc/intel/skylake/acpi/systemagent.asl> + #include <soc/intel/skylake/acpi/pch.asl> + } + + #include <southbridge/intel/common/acpi/sleepstates.asl> +} diff --git a/src/mainboard/lenovo/m900_tiny/gma-mainboard.ads b/src/mainboard/lenovo/m900_tiny/gma-mainboard.ads new file mode 100644 index 0000000..fc6b6dd --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/gma-mainboard.ads @@ -0,0 +1,20 @@ +-- SPDX-License-Identifier: GPL-2.0-or-later + +with HW.GFX.GMA; +with HW.GFX.GMA.Display_Probing; + +use HW.GFX.GMA; +use HW.GFX.GMA.Display_Probing; + +private package GMA.Mainboard is + -- Two onboard DP++, one header for optional DP, HDMI or VGA port + ports : constant Port_List := + (DP1, + DP2, + DP3, + HDMI1, + HDMI2, + HDMI3, + others => Disabled); + +end GMA.Mainboard; diff --git a/src/mainboard/lenovo/m900_tiny/gpio.c b/src/mainboard/lenovo/m900_tiny/gpio.c new file mode 100644 index 0000000..65c9cbf --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/gpio.c @@ -0,0 +1,253 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <mainboard/gpio.h> +#include <soc/gpio.h> + +/* Pad configuration was generated automatically using intelp2m utility */ +static const struct pad_config gpio_table[] = { + + /* ------- GPIO Community 0 ------- */ + + /* ------- GPIO Group GPP_A ------- */ + + PAD_CFG_NF(GPP_A0, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_A1, UP_20K, PLTRST, NF1), + PAD_CFG_NF(GPP_A2, UP_20K, PLTRST, NF1), + PAD_CFG_NF(GPP_A3, UP_20K, PLTRST, NF1), + PAD_CFG_NF(GPP_A4, UP_20K, PLTRST, NF1), + PAD_CFG_NF(GPP_A5, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_A6, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_A7, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_A8, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_A9, DN_20K, PLTRST, NF1), + PAD_CFG_NF(GPP_A10, DN_20K, PLTRST, NF1), + PAD_CFG_NF(GPP_A11, NONE, PLTRST, NF1), + PAD_NC(GPP_A12, NONE), + PAD_CFG_NF(GPP_A13, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_A14, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_A15, UP_20K, DEEP, NF1), + PAD_NC(GPP_A16, NONE), + PAD_CFG_GPO(GPP_A17, 1, PLTRST), + PAD_NC(GPP_A18, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_A19, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_A20, NONE), + PAD_NC(GPP_A21, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_A22, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPO(GPP_A23, 1, PLTRST), + + /* ------- GPIO Group GPP_B ------- */ + + PAD_CFG_GPO(GPP_B0, 0, DEEP), + PAD_CFG_GPO(GPP_B1, 0, DEEP), + PAD_CFG_NF(GPP_B2, NONE, PLTRST, NF1), + PAD_CFG_GPI_TRIG_OWN(GPP_B3, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_B4, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_B5, NONE), + PAD_CFG_NF(GPP_B6, NONE, DEEP, NF1), + PAD_NC(GPP_B7, NONE), + PAD_NC(GPP_B8, NONE), + PAD_NC(GPP_B9, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_B10, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPO(GPP_B11, 0, DEEP), + PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_B14, DN_20K, PLTRST, NF1), + PAD_CFG_GPI_TRIG_OWN(GPP_B15, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_B16, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_B17, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPO(GPP_B18, 0, PLTRST), + PAD_CFG_NF(GPP_B19, NONE, PLTRST, NF1), + PAD_CFG_GPI_TRIG_OWN(GPP_B20, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_B21, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPO(GPP_B22, 0, PLTRST), + PAD_CFG_NF(GPP_B23, DN_20K, PLTRST, NF1), + + /* ------- GPIO Community 1 ------- */ + + /* ------- GPIO Group GPP_C ------- */ + + PAD_CFG_NF(GPP_C0, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_C1, NONE, DEEP, NF1), + PAD_CFG_GPI_TRIG_OWN(GPP_C2, NONE, DEEP, OFF, ACPI), + PAD_CFG_NF(GPP_C3, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_C4, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_C5, NONE, PLTRST, NF1), + /* GPP_C6 - RESERVED */ + /* GPP_C7 - RESERVED */ + PAD_CFG_GPI_TRIG_OWN(GPP_C8, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_C9, NONE), + PAD_NC(GPP_C10, NONE), + PAD_NC(GPP_C11, NONE), + PAD_NC(GPP_C12, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_C13, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_C14, NONE), + PAD_CFG_GPO(GPP_C15, 1, PLTRST), + PAD_CFG_NF(GPP_C16, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_C17, NONE, DEEP, NF1), + PAD_CFG_GPI_TRIG_OWN(GPP_C18, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_C19, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_C22, NONE), + PAD_CFG_GPO(GPP_C23, 0, PLTRST), + + /* ------- GPIO Group GPP_D ------- */ + + PAD_NC(GPP_D0, NONE), + PAD_NC(GPP_D1, NONE), + PAD_NC(GPP_D2, NONE), + PAD_NC(GPP_D3, NONE), + PAD_NC(GPP_D4, NONE), + PAD_NC(GPP_D5, NONE), + PAD_NC(GPP_D6, NONE), + PAD_NC(GPP_D7, NONE), + PAD_NC(GPP_D8, NONE), + PAD_CFG_GPO(GPP_D9, 1, PLTRST), + PAD_CFG_GPO(GPP_D10, 1, PLTRST), + PAD_NC(GPP_D11, NONE), + PAD_NC(GPP_D12, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_D13, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_D14, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_D15, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_D16, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_D17, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_D18, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_D19, NONE), + PAD_NC(GPP_D20, NONE), + PAD_NC(GPP_D21, NONE), + PAD_NC(GPP_D22, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_D23, NONE, PLTRST, OFF, ACPI), + + /* ------- GPIO Group GPP_E ------- */ + + PAD_CFG_GPI_TRIG_OWN(GPP_E0, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_E1, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_E2, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_E3, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_E4, NONE), + PAD_NC(GPP_E5, NONE), + PAD_NC(GPP_E6, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_E7, NONE, PLTRST, OFF, ACPI), + PAD_CFG_NF(GPP_E8, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_E9, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_E10, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_E11, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_E12, NONE, DEEP, NF1), + + /* ------- GPIO Group GPP_F ------- */ + + PAD_NC(GPP_F0, NONE), + PAD_CFG_NF(GPP_F1, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_F2, NONE, DEEP, NF1), + PAD_NC(GPP_F3, NONE), + PAD_NC(GPP_F4, NONE), + PAD_CFG_GPI_SCI(GPP_F5, NONE, DEEP, EDGE_SINGLE, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_F6, NONE, RSMRST, OFF, ACPI), + PAD_NC(GPP_F7, NONE), + PAD_NC(GPP_F8, NONE), + PAD_NC(GPP_F9, NONE), + PAD_CFG_GPI_APIC_HIGH(GPP_F10, NONE, PLTRST), + PAD_CFG_GPI_TRIG_OWN(GPP_F11, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_APIC_HIGH(GPP_F12, NONE, PLTRST), + PAD_CFG_GPI_APIC_HIGH(GPP_F13, NONE, PLTRST), + PAD_CFG_GPI_APIC_HIGH(GPP_F14, NONE, DEEP), + PAD_CFG_NF(GPP_F15, NONE, DEEP, NF1), + PAD_NC(GPP_F16, NONE), + PAD_NC(GPP_F17, NONE), + PAD_NC(GPP_F18, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_F19, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_F20, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_F21, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_F22, NONE), + PAD_NC(GPP_F23, NONE), + + /* ------- GPIO Group GPP_G ------- */ + + PAD_NC(GPP_G0, NONE), + PAD_NC(GPP_G1, NONE), + PAD_NC(GPP_G2, NONE), + PAD_NC(GPP_G3, NONE), + PAD_NC(GPP_G4, NONE), + PAD_NC(GPP_G5, NONE), + PAD_NC(GPP_G6, NONE), + PAD_NC(GPP_G7, NONE), + PAD_CFG_NF(GPP_G8, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_G9, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_G10, NONE, DEEP, NF1), + PAD_CFG_NF(GPP_G11, NONE, DEEP, NF1), + PAD_CFG_GPI_TRIG_OWN(GPP_G12, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_G13, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_G14, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_G15, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_G16, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_G17, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPO(GPP_G18, 0, PLTRST), + PAD_CFG_GPI_SCI(GPP_G19, NONE, PLTRST, LEVEL, INVERT), + PAD_CFG_GPI_TRIG_OWN(GPP_G20, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_G21, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_G22, NONE), + PAD_NC(GPP_G23, NONE), + + /* ------- GPIO Group GPP_H ------- */ + + PAD_NC(GPP_H0, NONE), + PAD_NC(GPP_H1, NONE), + PAD_NC(GPP_H2, NONE), + PAD_NC(GPP_H3, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_H4, NONE, PLTRST, OFF, ACPI), + PAD_CFG_NF(GPP_H5, NONE, DEEP, NF1), + PAD_CFG_GPI_TRIG_OWN(GPP_H6, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_H7, NONE), + PAD_NC(GPP_H8, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_H9, NONE, PLTRST, OFF, ACPI), + PAD_NC(GPP_H10, NONE), + PAD_CFG_GPO(GPP_H11, 1, PLTRST), + PAD_CFG_GPO(GPP_H12, 0, PLTRST), + PAD_NC(GPP_H13, NONE), + PAD_NC(GPP_H14, NONE), + PAD_NC(GPP_H15, NONE), + PAD_NC(GPP_H16, NONE), + PAD_NC(GPP_H17, NONE), + PAD_NC(GPP_H18, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_H19, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_H20, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPO(GPP_H21, 1, PLTRST), + PAD_CFG_GPI_TRIG_OWN(GPP_H22, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_H23, NONE, PLTRST, OFF, ACPI), + + /* ------- GPIO Community 2 ------- */ + + /* -------- GPIO Group GPD -------- */ + + PAD_CFG_GPI_TRIG_OWN(GPD0, NONE, PLTRST, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPD1, NONE, PWROK, OFF, ACPI), + PAD_CFG_NF(GPD2, DN_20K, PWROK, NF1), + PAD_CFG_NF(GPD3, UP_20K, PWROK, NF1), + PAD_CFG_NF(GPD4, NONE, PWROK, NF1), + PAD_CFG_NF(GPD5, NONE, PWROK, NF1), + PAD_CFG_NF(GPD6, NONE, PWROK, NF1), + PAD_CFG_GPO(GPD7, 1, PWROK), + PAD_CFG_NF(GPD8, NONE, PWROK, NF1), + PAD_CFG_NF(GPD9, NONE, PWROK, NF1), + PAD_CFG_NF(GPD10, NONE, PWROK, NF1), + PAD_CFG_NF(GPD11, NONE, PWROK, NF1), + + /* ------- GPIO Community 3 ------- */ + + /* ------- GPIO Group GPP_I ------- */ + + PAD_CFG_NF(GPP_I0, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_I1, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_I2, NONE, PLTRST, NF1), + PAD_CFG_GPI_SMI(GPP_I3, NONE, PLTRST, EDGE_SINGLE, NONE), + PAD_CFG_GPI_TRIG_OWN(GPP_I4, NONE, PLTRST, OFF, ACPI), + PAD_CFG_NF(GPP_I5, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_I6, DN_20K, PLTRST, NF1), + PAD_CFG_NF(GPP_I7, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_I8, DN_20K, PLTRST, NF1), + PAD_CFG_NF(GPP_I9, NONE, PLTRST, NF1), + PAD_CFG_NF(GPP_I10, DN_20K, PLTRST, NF1), +}; + +void mainboard_configure_gpios(void) +{ + gpio_configure_pads(gpio_table, ARRAY_SIZE(gpio_table)); +} diff --git a/src/mainboard/lenovo/m900_tiny/gpio_early.c b/src/mainboard/lenovo/m900_tiny/gpio_early.c new file mode 100644 index 0000000..0f46cda --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/gpio_early.c @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <mainboard/gpio.h> +#include <soc/gpio.h> + +/* Early pad configuration */ +static const struct pad_config uart_gpio_table[] = { + PAD_CFG_NF(GPP_C20, NONE, DEEP, NF1), /* UART2_RXD */ + PAD_CFG_NF(GPP_C21, NONE, DEEP, NF1), /* UART2_TXD */ +}; + +void mainboard_configure_early_gpios(void) +{ + if (CONFIG(INTEL_LPSS_UART_FOR_CONSOLE)) + gpio_configure_pads(uart_gpio_table, ARRAY_SIZE(uart_gpio_table)); +} diff --git a/src/mainboard/lenovo/m900_tiny/hda_verb.c b/src/mainboard/lenovo/m900_tiny/hda_verb.c new file mode 100644 index 0000000..b545df4 --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/hda_verb.c @@ -0,0 +1,32 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + 0x10ec0233, /* Codec Vendor / Device ID: Realtek ALC233 */ + 0x17aa30d0, /* Subsystem ID */ + 11, /* Number of 4 dword sets */ + AZALIA_SUBVENDOR(1, 0x17aa30d0), + AZALIA_PIN_CFG(1, 0x12, 0x40000000), + AZALIA_PIN_CFG(1, 0x14, 0x90170110), + AZALIA_PIN_CFG(1, 0x17, 0x411111f0), + AZALIA_PIN_CFG(1, 0x18, 0x411111f0), + AZALIA_PIN_CFG(1, 0x19, 0x02a11030), + AZALIA_PIN_CFG(1, 0x1a, 0x02a11040), + AZALIA_PIN_CFG(1, 0x1b, 0x01011020), + AZALIA_PIN_CFG(1, 0x1d, 0x40400001), + AZALIA_PIN_CFG(1, 0x1e, 0x411111f0), + AZALIA_PIN_CFG(1, 0x21, 0x0221101f), + + 0x80862809, /* Codec Vendor / Device ID: Intel Skylake HDMI */ + 0x80860101, /* Subsystem ID */ + 4, /* Number of 4 dword sets */ + AZALIA_SUBVENDOR(2, 0x80860101), + AZALIA_PIN_CFG(2, 0x05, 0x18560010), + AZALIA_PIN_CFG(2, 0x06, 0x18560020), + AZALIA_PIN_CFG(2, 0x07, 0x18560030), +}; + +const u32 pc_beep_verbs[] = { +}; +AZALIA_ARRAY_SIZES; diff --git a/src/mainboard/lenovo/m900_tiny/include/mainboard/gpio.h b/src/mainboard/lenovo/m900_tiny/include/mainboard/gpio.h new file mode 100644 index 0000000..c6393be --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/include/mainboard/gpio.h @@ -0,0 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#ifndef MAINBOARD_GPIO_H +#define MAINBOARD_GPIO_H + +void mainboard_configure_early_gpios(void); +void mainboard_configure_gpios(void); + +#endif diff --git a/src/mainboard/lenovo/m900_tiny/ramstage.c b/src/mainboard/lenovo/m900_tiny/ramstage.c new file mode 100644 index 0000000..47add6f --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/ramstage.c @@ -0,0 +1,54 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <console/console.h> +#include <device/device.h> +#include <drivers/intel/gma/int15.h> +#include <gpio.h> +#include <mainboard/gpio.h> +#include <soc/gpio.h> +#include <soc/ramstage.h> + +static void print_board_id(void) +{ + gpio_t id_gpios[] = { + GPP_G14, + GPP_G13, + GPP_G12, + }; + + printk(BIOS_INFO, "Board ID: "); + + switch (gpio_base2_value(id_gpios, ARRAY_SIZE(id_gpios))) { + case 0: + printk(BIOS_INFO, "ThinkCentre M900 Tiny\n"); + break; + case 2: + case 3: + case 4: + printk(BIOS_INFO, "ThinkCentre M700 Tiny\n"); + break; + default: + printk(BIOS_INFO, "Unknown!\n"); + break; + } + + printk(BIOS_INFO, "Serial header %spopulated\n", !gpio_get(GPP_A22) ? "" : "un"); + + printk(BIOS_INFO, "PS/2 header %spopulated\n", !gpio_get(GPP_D14) ? "" : "un"); + + printk(BIOS_INFO, "USB header %spopulated\n", !gpio_get(GPP_C19) ? "" : "un"); + + printk(BIOS_INFO, "DisplayPort header %spopulated\n", !gpio_get(GPP_B15) ? "" : "un"); + + printk(BIOS_INFO, "PCIe / SATA header %spopulated\n", !gpio_get(GPP_B21) ? "" : "un"); +} + +static void mainboard_enable(struct device *dev) +{ + mainboard_configure_gpios(); + print_board_id(); +} + +struct chip_operations mainboard_ops = { + .enable_dev = mainboard_enable, +}; diff --git a/src/mainboard/lenovo/m900_tiny/romstage.c b/src/mainboard/lenovo/m900_tiny/romstage.c new file mode 100644 index 0000000..9dfbfe2 --- /dev/null +++ b/src/mainboard/lenovo/m900_tiny/romstage.c @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <assert.h> +#include <soc/romstage.h> +#include <spd_bin.h> +#include <stdint.h> +#include <string.h> + +void mainboard_memory_init_params(FSPM_UPD *mupd) +{ + const u16 rcomp_resistors[3] = { 121, 75, 100 }; + + const u16 rcomp_targets[5] = { 50, 26, 20, 20, 26 }; + + FSP_M_CONFIG *const mem_cfg = &mupd->FspmConfig; + + struct spd_block blk = { + .addr_map = { 0x50, 0x52 }, + }; + + assert(sizeof(mem_cfg->RcompResistor) == sizeof(rcomp_resistors)); + assert(sizeof(mem_cfg->RcompTarget) == sizeof(rcomp_targets)); + + mem_cfg->DqPinsInterleaved = 1; + mem_cfg->CaVrefConfig = 2; + get_spd_smbus(&blk); + mem_cfg->MemorySpdDataLen = blk.len; + mem_cfg->MemorySpdPtr00 = (uintptr_t)blk.spd_array[0]; + mem_cfg->MemorySpdPtr10 = (uintptr_t)blk.spd_array[1]; + dump_spd_info(&blk); + + memcpy(mem_cfg->RcompResistor, rcomp_resistors, sizeof(mem_cfg->RcompResistor)); + memcpy(mem_cfg->RcompTarget, rcomp_targets, sizeof(mem_cfg->RcompTarget)); + + /* use virtual channel 1 for the dmi interface of the PCH */ + mupd->FspmTestConfig.DmiVc1 = 1; +}
