Ravishankar Sarawadi (ravishankar.sarawadi@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16246
commit fdace469be47657fdf3fe0ae0023848328a3debc Author: Ravi Sarawadi ravishankar.sarawadi@intel.com Date: Wed Aug 17 23:44:56 2016 -0700
soc/intel/apollolake: Save DIMM info from SMBIOS memory HOB
Read FSP produced memory HOB and use it to populate DIMM info. DIMM 'part_num' info is stored statically based on memory/SKU id.
CQ-DEPEND=CL:16245 BUG = chrome-os-partner:55505 Test = 'dmidecode -t 17' and 'mosys -k memory spd print all' Change-Id: Ifcbb3329fd4414bba90eb584e065b1cb7f120e73 Signed-off-by: Ravi Sarawadi ravishankar.sarawadi@intel.com --- src/mainboard/google/reef/romstage.c | 29 +++++++- src/soc/intel/apollolake/include/soc/meminit.h | 2 + src/soc/intel/apollolake/include/soc/romstage.h | 1 + src/soc/intel/apollolake/meminit.c | 91 ++++++++++++++++++++++++- src/soc/intel/apollolake/romstage.c | 8 +++ 5 files changed, 127 insertions(+), 4 deletions(-)
diff --git a/src/mainboard/google/reef/romstage.c b/src/mainboard/google/reef/romstage.c index f9743b5..6ca6b5a 100644 --- a/src/mainboard/google/reef/romstage.c +++ b/src/mainboard/google/reef/romstage.c @@ -13,9 +13,16 @@ * GNU General Public License for more details. */
+#include <cbmem.h> +#include <console/console.h> +#include <fsp/util.h> #include <gpio.h> +#include <memory_info.h> +#include <smbios.h> +#include <soc/fsp/FspmUpd.h> #include <soc/meminit.h> #include <soc/romstage.h> +#include <string.h> #include "gpio.h"
static const struct lpddr4_swizzle_cfg board_swizzle = { @@ -82,12 +89,14 @@ static const struct lpddr4_sku skus[] = { .ch1_rank_density = LP4_8Gb_DENSITY, .ch0_dual_rank = 1, .ch1_dual_rank = 1, + .part_num = "K4F6E304HB-MGCJ", }, /* K4F8E304HB-MGCJ - both logical channels */ [1] = { .speed = LP4_SPEED_2400, .ch0_rank_density = LP4_8Gb_DENSITY, .ch1_rank_density = LP4_8Gb_DENSITY, + .part_num = "K4F8E304HB-MGCJ", }, /* * MT53B512M32D2NP-062WT:C - both logical channels. While the parts @@ -100,18 +109,21 @@ static const struct lpddr4_sku skus[] = { .ch1_rank_density = LP4_8Gb_DENSITY, .ch0_dual_rank = 1, .ch1_dual_rank = 1, + .part_num = "MT53B512M32D2NP", }, /* MT53B256M32D1NP-062 WT:C - both logical channels */ [3] = { .speed = LP4_SPEED_2400, .ch0_rank_density = LP4_8Gb_DENSITY, .ch1_rank_density = LP4_8Gb_DENSITY, + .part_num = "MT53B256M32D1NP", }, /* K4F8E304HB-MGCH - both logical channels */ [PROTO_SKU] = { .speed = LP4_SPEED_2400, .ch0_rank_density = LP4_8Gb_DENSITY, .ch1_rank_density = LP4_8Gb_DENSITY, + .part_num = "K4F8E304HB-MGCH", }, };
@@ -121,9 +133,8 @@ static const struct lpddr4_cfg lp4cfg = { .swizzle_config = &board_swizzle, };
-void mainboard_memory_init_params(struct FSPM_UPD *memupd) +static int get_mem_sku(void) { - int mem_sku; gpio_t pads[] = { [3] = MEM_CONFIG3, [2] = MEM_CONFIG2, [1] = MEM_CONFIG1, [0] = MEM_CONFIG0, @@ -133,7 +144,19 @@ void mainboard_memory_init_params(struct FSPM_UPD *memupd) * Read memory SKU id with internal pullups enabled to handle * proto boards with no SKU id pins. */ - mem_sku = gpio_pullup_base2_value(pads, ARRAY_SIZE(pads)); + return gpio_pullup_base2_value(pads, ARRAY_SIZE(pads)); +} + +void mainboard_memory_init_params(struct FSPM_UPD *memupd) +{ + int mem_sku = get_mem_sku();
meminit_lpddr4_by_sku(&memupd->FspmConfig, &lp4cfg, mem_sku); } + +void mainboard_save_dimm_info(void) +{ + int mem_sku = get_mem_sku(); + + save_dimm_info(&lp4cfg, mem_sku); +} diff --git a/src/soc/intel/apollolake/include/soc/meminit.h b/src/soc/intel/apollolake/include/soc/meminit.h index a7da1ac..e42acb3 100644 --- a/src/soc/intel/apollolake/include/soc/meminit.h +++ b/src/soc/intel/apollolake/include/soc/meminit.h @@ -101,6 +101,7 @@ struct lpddr4_sku { int ch1_rank_density; int ch0_dual_rank; int ch1_dual_rank; + const char *part_num; };
struct lpddr4_cfg { @@ -115,5 +116,6 @@ struct lpddr4_cfg { */ void meminit_lpddr4_by_sku(struct FSP_M_CONFIG *cfg, const struct lpddr4_cfg *lpcfg, size_t sku_id); +void save_dimm_info(const struct lpddr4_cfg *lpcfg, int mem_sku);
#endif /* _SOC_APOLLOLAKE_MEMINIT_H_ */ diff --git a/src/soc/intel/apollolake/include/soc/romstage.h b/src/soc/intel/apollolake/include/soc/romstage.h index e7ee335..5b76f65 100644 --- a/src/soc/intel/apollolake/include/soc/romstage.h +++ b/src/soc/intel/apollolake/include/soc/romstage.h @@ -22,5 +22,6 @@ #include <fsp/api.h>
void mainboard_memory_init_params(struct FSPM_UPD *mupd); +void mainboard_save_dimm_info(void);
#endif /* _SOC_APOLLOLAKE_ROMSTAGE_H_ */ diff --git a/src/soc/intel/apollolake/meminit.c b/src/soc/intel/apollolake/meminit.c index 92b84c8..84f30f1 100644 --- a/src/soc/intel/apollolake/meminit.c +++ b/src/soc/intel/apollolake/meminit.c @@ -12,8 +12,11 @@ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. */ - +#include <cbmem.h> #include <console/console.h> +#include <fsp/util.h> +#include <memory_info.h> +#include <smbios.h> #include <soc/meminit.h> #include <stddef.h> /* required for FspmUpd.h */ #include <soc/fsp/FspmUpd.h> @@ -252,3 +255,89 @@ void meminit_lpddr4_by_sku(struct FSP_M_CONFIG *cfg, lpcfg->swizzle_config); } } + +void save_dimm_info(const struct lpddr4_cfg *lp4cfg, int mem_sku) +{ + int channel, dimm, dimm_max, index; + size_t hob_size; + struct DIMM_INFO *dimm_info; + struct memory_info *mem_info; + struct CHANNEL_INFO *channel_info; + struct FSP_SMBIOS_MEMORY_INFO *memory_info_hob; + + if (mem_sku >= lp4cfg->num_skus) { + printk(BIOS_ERR, "Too few LPDDR4 SKUs: 0x%zx/0x%zx\n", + mem_sku, lp4cfg->num_skus); + return; + } + + memory_info_hob = (struct FSP_SMBIOS_MEMORY_INFO *) + fsp_find_smbios_memory_info(&hob_size); + + /* + * Allocate CBMEM area for DIMM information used to populate SMBIOS + * table 17 + */ + mem_info = cbmem_add(CBMEM_ID_MEMINFO, sizeof(*mem_info)); + printk(BIOS_DEBUG, "CBMEM entry for DIMM info: 0x%p\n", mem_info); + if (mem_info == NULL) + return; + memset(mem_info, 0, sizeof(*mem_info)); + + /* Describe the first N DIMMs in the system */ + index = 0; + dimm_max = ARRAY_SIZE(mem_info->dimm); + for (channel = 0; channel < memory_info_hob->ChannelCount; channel++) { + if (index >= dimm_max) + break; + channel_info = &memory_info_hob->ChannelInfo[channel]; + for (dimm = 0; dimm < channel_info->DimmCount; dimm++) { + if (index >= dimm_max) + break; + dimm_info = &channel_info->DimmInfo[dimm]; + + if (!dimm_info->SizeInMb) + continue; + + /* Populate the DIMM information */ + mem_info->dimm[index].dimm_size = dimm_info->SizeInMb; + mem_info->dimm[index].ddr_type = memory_info_hob->MemoryType; + mem_info->dimm[index].ddr_frequency = + memory_info_hob->MemoryFrequencyInMHz; + mem_info->dimm[index].channel_num = channel_info->ChannelId; + mem_info->dimm[index].dimm_num = dimm_info->DimmId; + memcpy(mem_info->dimm[index].module_part_number, + lp4cfg->skus[mem_sku].part_num, + sizeof(mem_info->dimm[index].module_part_number)); + + switch (memory_info_hob->DataWidth) { + case 8: + mem_info->dimm[index].bus_width = MEMORY_BUS_WIDTH_8; + break; + + case 16: + mem_info->dimm[index].bus_width = MEMORY_BUS_WIDTH_16; + break; + + case 32: + mem_info->dimm[index].bus_width = MEMORY_BUS_WIDTH_32; + break; + + case 64: + mem_info->dimm[index].bus_width = MEMORY_BUS_WIDTH_64; + break; + + case 128: + mem_info->dimm[index].bus_width = MEMORY_BUS_WIDTH_128; + break; + + default: + printk(BIOS_ERR, "Incorrect DIMM Data Width"); + } + index++; + } + } + mem_info->dimm_cnt = index; + printk(BIOS_DEBUG, "%d DIMMs found\n", mem_info->dimm_cnt); +} + diff --git a/src/soc/intel/apollolake/romstage.c b/src/soc/intel/apollolake/romstage.c index 8f17fdd..d631192 100644 --- a/src/soc/intel/apollolake/romstage.c +++ b/src/soc/intel/apollolake/romstage.c @@ -118,6 +118,8 @@ asmlinkage void car_stage_entry(void) if (postcar_frame_init(&pcf, 1*KiB)) die("Unable to initialize postcar frame.\n");
+ mainboard_save_dimm_info(); + /* * We need to make sure ramstage will be run cached. At this point exact * location of ramstage in cbmem is not known. Instruct postcar to cache @@ -169,6 +171,12 @@ void mainboard_memory_init_params(struct FSPM_UPD *mupd) printk(BIOS_DEBUG, "WEAK: %s/%s called\n", __FILE__, __func__); }
+__attribute__ ((weak)) +void mainboard_save_dimm_info(void) +{ + printk(BIOS_DEBUG, "WEAK: %s/%s called\n", __FILE__, __func__); +} + int get_sw_write_protect_state(void) { uint8_t status;
