Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/23048
Change subject: mb/asrock/g41c-gs: Add decode range for Environment Controller ......................................................................
This seems to have been forgotten in the original patch which added the Asrock G41C-GS R2.0, but all variants have a similar SuperIO and set the Environment Controller IO decode address to the same value.
TEST: see if the Linux module w832627dhg can properly read the sensors fan/temp/etc... (currently not further configured so values could be garbage).
Change-Id: Ibff3dffaf0f5c32c3b12336a23839dee501e7160 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/mainboard/asrock/g41c-gs/romstage.c 1 file changed, 2 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/48/23048/1
diff --git a/src/mainboard/asrock/g41c-gs/romstage.c b/src/mainboard/asrock/g41c-gs/romstage.c index 07edfb4..9acf6c1 100644 --- a/src/mainboard/asrock/g41c-gs/romstage.c +++ b/src/mainboard/asrock/g41c-gs/romstage.c @@ -82,6 +82,8 @@ /* Decode range */ pci_write_config16(PCI_DEV(0, 0x1f, 0), LPC_EN, CNF1_LPC_EN | KBC_LPC_EN | LPT_LPC_EN | COMA_LPC_EN); + /* GEN1_DEC Enable IO range 0x290-29c */ + pci_write_config32(LPC_DEV, 0x84 , 0x000c0290); }
void mainboard_romstage_entry(unsigned long bist)
