Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10594
commit c21161961c245c5a3285cbd27772ac6aa68f5e99 Author: Stefan Reinauer stefan.reinauer@coreboot.org Date: Thu Jun 18 22:05:13 2015 -0700
break lots of boards
Enable 64bit compilation for AGESA boards :-)
Change-Id: I8d3908557904f6dd27154e2a4b842c94974df81a Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- src/cpu/amd/agesa/Kconfig | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/src/cpu/amd/agesa/Kconfig b/src/cpu/amd/agesa/Kconfig index 282e1ed..45e1d63 100644 --- a/src/cpu/amd/agesa/Kconfig +++ b/src/cpu/amd/agesa/Kconfig @@ -27,10 +27,10 @@ config CPU_AMD_AGESA default y if CPU_AMD_AGESA_FAMILY15_RL default y if CPU_AMD_AGESA_FAMILY16_KB default n - select ARCH_BOOTBLOCK_X86_32 - select ARCH_VERSTAGE_X86_32 - select ARCH_ROMSTAGE_X86_32 - select ARCH_RAMSTAGE_X86_32 + select ARCH_BOOTBLOCK_X86_64 + select ARCH_VERSTAGE_X86_64 + select ARCH_ROMSTAGE_X86_64 + select ARCH_RAMSTAGE_X86_64 select TSC_SYNC_LFENCE select UDELAY_LAPIC select LAPIC_MONOTONIC_TIMER
