Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10582
commit ba5ff0906b7c8aa9a0bf7113b3c5e5e995559d3f Author: Stefan Reinauer stefan.reinauer@coreboot.org Date: Thu Jun 18 01:17:38 2015 -0700
SB800: Port to 64bit
Change-Id: I944fb254e9470c80b13c9eef9d6b1177a56e615f Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org Signed-off-by: Scott Duplichan scott@notabs.org --- src/southbridge/amd/cimx/sb800/fadt.c | 25 +++++++++++++++++++------ src/southbridge/amd/cimx/sb800/gpio_oem.h | 6 +++--- src/southbridge/amd/cimx/sb800/late.c | 8 ++++---- src/southbridge/amd/cimx/sb800/spi.c | 2 +- 4 files changed, 27 insertions(+), 14 deletions(-)
diff --git a/src/southbridge/amd/cimx/sb800/fadt.c b/src/southbridge/amd/cimx/sb800/fadt.c index 70173b6..d8fdd6f 100644 --- a/src/southbridge/amd/cimx/sb800/fadt.c +++ b/src/southbridge/amd/cimx/sb800/fadt.c @@ -63,8 +63,16 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) memcpy(header->asl_compiler_id, ASLC, 4); header->asl_compiler_revision = 0;
- fadt->firmware_ctrl = (u32) facs; - fadt->dsdt = (u32) dsdt; + if ((uintptr_t)facs > 0xffffffff) + printk(BIOS_DEBUG, "ACPI: FACS lives above 4G\n"); + else + fadt->firmware_ctrl = (uintptr_t)facs; + + if ((uintptr_t)dsdt > 0xffffffff) + printk(BIOS_DEBUG, "ACPI: DSDT lives above 4G\n"); + else + fadt->dsdt = (uintptr_t)dsdt; + fadt->model = 0; /* reserved, should be 0 ACPI 3.0 */ fadt->preferred_pm_profile = FADT_PM_PROFILE; fadt->sci_int = 9; /* HUDSON 1 - IRQ 09 – ACPI SCI */ @@ -153,10 +161,15 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) fadt->res4 = 0; /* reserved, MUST be 0 ACPI 3.0 */ fadt->res5 = 0; /* reserved, MUST be 0 ACPI 3.0 */
- fadt->x_firmware_ctl_l = 0; /* set to 0 if firmware_ctrl is used */ - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (u32) dsdt; - fadt->x_dsdt_h = 0; + + fadt->x_firmware_ctl_l = ((uintptr_t)facs) & 0xffffffff; +#ifdef __x86_64__ + fadt->x_firmware_ctl_h = ((uintptr_t)facs) >> 32; +#endif + fadt->x_dsdt_l = ((uintptr_t)dsdt) & 0xffffffff; +#ifdef __x86_64__ + fadt->x_dsdt_h = ((uintptr_t)dsdt) >> 32; +#endif
fadt->x_pm1a_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; fadt->x_pm1a_evt_blk.bit_width = 32; diff --git a/src/southbridge/amd/cimx/sb800/gpio_oem.h b/src/southbridge/amd/cimx/sb800/gpio_oem.h index a9f59e3..e2c81fc 100644 --- a/src/southbridge/amd/cimx/sb800/gpio_oem.h +++ b/src/southbridge/amd/cimx/sb800/gpio_oem.h @@ -11,9 +11,9 @@ #define SB_GPIO_REG28 28
/* FCH GPIO access helpers */ -#define FCH_IOMUX(gpio_nr) (*(u8*)(ACPI_MMIO_BASE+IOMUX_BASE+(gpio_nr))) -#define FCH_PMIO(reg_nr) (*(u8*)(ACPI_MMIO_BASE+PMIO_BASE+(reg_nr))) -#define FCH_GPIO(gpio_nr) (*(volatile u8*)(ACPI_MMIO_BASE+GPIO_BASE+(gpio_nr))) +#define FCH_IOMUX(gpio_nr) (*(u8*)((uintptr_t)ACPI_MMIO_BASE+IOMUX_BASE+(gpio_nr))) +#define FCH_PMIO(reg_nr) (*(u8*)((uintptr_t)ACPI_MMIO_BASE+PMIO_BASE+(reg_nr))) +#define FCH_GPIO(gpio_nr) (*(volatile u8*)((uintptr_t)ACPI_MMIO_BASE+GPIO_BASE+(gpio_nr)))
static inline u8 fch_gpio_state(unsigned int gpio_nr) { diff --git a/src/southbridge/amd/cimx/sb800/late.c b/src/southbridge/amd/cimx/sb800/late.c index 0ada673..01900fe 100644 --- a/src/southbridge/amd/cimx/sb800/late.c +++ b/src/southbridge/amd/cimx/sb800/late.c @@ -108,15 +108,15 @@ static void ahci_raid_init(struct device *dev) bar5 = pci_read_config32(dev, PCI_BASE_ADDRESS_5); printk(BIOS_DEBUG, "IOMEM base: 0x%X, IRQ: 0x%X\n", bar5, irq);
- caps = *(volatile u32 *)(bar5 + HOST_CAP); + caps = *(volatile u32 *)((uintptr_t)bar5 + HOST_CAP); caps = (caps & 0x1F) + 1; - ports= *(volatile u32 *)(bar5 + HOST_PORTS_IMPL); + ports= *(volatile u32 *)((uintptr_t)bar5 + HOST_PORTS_IMPL); printk(BIOS_DEBUG, "Number of Ports: 0x%x, Port implemented(bit map): 0x%x\n", caps, ports);
/* make sure ahci is enabled */ - val = *(volatile u32 *)(bar5 + HOST_CTL); + val = *(volatile u32 *)((uintptr_t)bar5 + HOST_CTL); if (!(val & HOST_CTL_AHCI_EN)) { - *(volatile u32 *)(bar5 + HOST_CTL) = val | HOST_CTL_AHCI_EN; + *(volatile u32 *)((uintptr_t)bar5 + HOST_CTL) = val | HOST_CTL_AHCI_EN; }
dev->command |= PCI_COMMAND_MASTER; diff --git a/src/southbridge/amd/cimx/sb800/spi.c b/src/southbridge/amd/cimx/sb800/spi.c index 1ce7fcd..694a3b7 100644 --- a/src/southbridge/amd/cimx/sb800/spi.c +++ b/src/southbridge/amd/cimx/sb800/spi.c @@ -35,7 +35,7 @@ static int bus_claimed = 0;
#define AMD_SB_SPI_TX_LEN 8
-static u32 spibar; +static uintptr_t spibar;
static void reset_internal_fifo_pointer(void) {
