Attention is currently required from: Martin Roth, Matt DeVillier, Stefan Reinauer, Angel Pons. Hello build bot (Jenkins), Martin Roth, Stefan Reinauer, Angel Pons, Arthur Heymans,
https://review.coreboot.org/c/coreboot/+/54019
Change subject: payloads/Tianocore: Update default build target, simplify build options ......................................................................
Drop the deprecated COREBOOTPAYLOAD option, and replace it with MrChromebox's updated UefiPayloadPkg option. Simplify the Kconfig options to make it easier to build from upstream edk2 master. Drop the TIANOCORE_USE_8254_TIMER Kconfig option since it applied only to CorebootPayloadPkg. Clean up the Makefile now that we're only building from a single Tianocore package/target.
Test: build/boot qemu Q35 target with both UefiPayload and Upstream options.
Change-Id: If545fbd0c30be6dcc6ff43107b80980fa23a527e Signed-off-by: Matt DeVillier matt.devillier@gmail.com --- M Documentation/payloads.md M payloads/external/Makefile.inc M payloads/external/tianocore/Kconfig M payloads/external/tianocore/Makefile 4 files changed, 24 insertions(+), 41 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/54019/2
