Mathew King has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/50450 )
Change subject: mb/google/guybrush: Second pass GPIO configuration ......................................................................
Configure the non native function GPIOs based on the guybrush reference schematic.
BUG=b:177909472 TEST=builds
Change-Id: I0fdc4d7369353f88cf05e2e1ec08898d4605e602 Signed-off-by: Mathew King mathewk@chromium.org --- M src/mainboard/google/guybrush/variants/baseboard/gpio.c 1 file changed, 78 insertions(+), 78 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/50450/1
diff --git a/src/mainboard/google/guybrush/variants/baseboard/gpio.c b/src/mainboard/google/guybrush/variants/baseboard/gpio.c index b7d66a3..d3bc7ce 100644 --- a/src/mainboard/google/guybrush/variants/baseboard/gpio.c +++ b/src/mainboard/google/guybrush/variants/baseboard/gpio.c @@ -13,98 +13,98 @@ PAD_NF(GPIO_1, SYS_RESET_L, PULL_NONE), /* WAKE_L */ PAD_NF(GPIO_2, WAKE_L, PULL_NONE), - /* AGPIO3 */ - PAD_NC(GPIO_3), - /* AGPIO4 */ - PAD_NC(GPIO_4), - /* AGPIO5 */ - PAD_NC(GPIO_5), - /* AGPIO6 */ - PAD_NC(GPIO_6), - /* AGPIO7 */ - PAD_NC(GPIO_7), - /* AGPIO8 */ - PAD_NC(GPIO_8), - /* AGPIO9 */ - PAD_NC(GPIO_9), + /* GSC_SOC_INT_L */ + PAD_INT(GPIO_3, PULL_NONE, EDGE_LOW, STATUS_DELIVERY), + /* SOC_PEN_DETECT_ODL */ + PAD_WAKE(GPIO_4, PULL_NONE, EDGE_HIGH, S0i3), + /* EN_PP5000_PEN */ + PAD_GPO(GPIO_5, LOW), + /* EN_PP3300_WLAN */ + PAD_GPO(GPIO_6, LOW), + /* EN_PP3300_TCHPAD */ + PAD_GPO(GPIO_7, LOW), + /* EN_PWR_WWAN_X */ + PAD_GPO(GPIO_8, LOW), + /* SOC_TCHPAD_INT_ODL */ + PAD_INT(GPIO_9, PULL_NONE, EDGE_HIGH, STATUS_DELIVERY), /* S0A3 */ PAD_NF(GPIO_10, S0A3, PULL_NONE), - /* AGPIO11 */ - PAD_NC(GPIO_11), - /* AGPIO12 */ - PAD_NC(GPIO_12), + /* SOC_FP_RST_L */ + PAD_GPO(GPIO_11, LOW), + /* SLP_S3_GATED */ + PAD_GPO(GPIO_12, LOW), /* GPIO_13 - GPIO_15: Not available */ /* USB_OC0_L */ PAD_NF(GPIO_16, USB_OC0_L, PULL_NONE), - /* AGPIO17 */ - PAD_NC(GPIO_17), - /* AGPIO18 */ - PAD_NC(GPIO_18), + /* SOC_SAR_INT_L */ + PAD_INT(GPIO_17, PULL_NONE, EDGE_LOW, STATUS_DELIVERY), + /* WWAN_AUX_RST_L */ + PAD_GPO(GPIO_18, LOW), /* I2C3_SCL */ PAD_NF(GPIO_19, I2C3_SCL, PULL_NONE), /* I2C3_SDA */ PAD_NF(GPIO_20, I2C3_SDA, PULL_NONE), - /* AGPIO21 */ - PAD_NC(GPIO_21), - /* AGPIO22 */ - PAD_NC(GPIO_22), + /* SOC_FP_INT_L */ + PAD_INT(GPIO_21, PULL_NONE, EDGE_LOW, STATUS_DELIVERY), + /* EC_SOC_WAKE_L */ + PAD_WAKE(GPIO_22, PULL_NONE, EDGE_LOW, S0i3), /* AC_PRES */ PAD_NF(GPIO_23, AC_PRES, PULL_UP), - /* AGPIO24 */ - PAD_NC(GPIO_24), + /* WWAN_RST_LWWAN_RST_L */ + PAD_GPO(GPIO_24, LOW), /* GPIO_25: Not available */ /* PCIE_RST0_L */ PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* GPIO_28: Not available */ - /* AGPIO29 */ - PAD_NC(GPIO_29), + /* FP_CS_L */ + PAD_GPO(GPIO_29, HIGH), /* ESPI_CS_L */ PAD_NF(GPIO_30, ESPI_CS_L, PULL_NONE), /* SPI_CS3_L */ PAD_NF(GPIO_31, SPI_CS3_L, PULL_NONE), - /* AGPIO32 */ - PAD_NC(GPIO_32), + /* EN_PWR_FP */ + PAD_GPO(GPIO_32, LOW), /* GPIO_33 - GPIO_39: Not available */ - /* AGPIO40 */ - PAD_NC(GPIO_40), + /* SSD_AUX_RST_L */ + PAD_GPO(GPIO_40, LOW), /* GPIO_41: Not available */ - /* EGPIO42 */ - PAD_NC(GPIO_42), + /* WWAN_DPR_SAR_ODL */ + PAD_GPO(GPIO_42, LOW), /* GPIO_43 - GPIO_66: Not available */ - /* EGPIO67 */ - PAD_NC(GPIO_67), - /* AGPIO68 */ - PAD_NC(GPIO_68), - /* AGPIO69 */ - PAD_NC(GPIO_69), - /* EGPIO70 */ - PAD_NC(GPIO_70), + /* SOC_BIOS_WP_L */ + PAD_GPI(GPIO_67, PULL_NONE), + /* EN_PP3300_TCHSCR */ + PAD_GPO(GPIO_68, LOW), + /* EN_SPKR */ + PAD_GPO(GPIO_69, LOW), + /* SD_AUX_RST_L */ + PAD_GPO(GPIO_70, LOW), /* GPIO_71 - GPIO_73: Not available */ - /* EGPIO74 */ - PAD_NC(GPIO_74), - /* EGPIO75 */ - PAD_NC(GPIO_75), - /* EGPIO76 */ - PAD_NC(GPIO_76), + /* RAM_ID_CHAN_SEL */ + PAD_GPI(GPIO_74, PULL_NONE), + /* RAM_ID_2 / DEV_BEEP_LRCLK */ + PAD_GPI(GPIO_75, PULL_NONE), + /* EN_PWR_CAMERA */ + PAD_GPO(GPIO_76, LOW), /* GPIO_77 - GPIO_83: Not available */ - /* AGPIO84 */ - PAD_NC(GPIO_84), - /* AGPIO85 */ - PAD_NC(GPIO_85), + /* EC_SOC_INT_ODL */ + PAD_GPI(GPIO_84, PULL_NONE), + /* WWAN_DISABLE */ + PAD_GPO(GPIO_85, HIGH), /* SPI_CLK2 */ PAD_NF(GPIO_86, SPI_CLK, PULL_NONE), - /* AGPIO87 */ - PAD_NC(GPIO_87), - /* AGPIO88 */ - PAD_NC(GPIO_88), - /* AGPIO89 */ - PAD_NC(GPIO_89), - /* AGPIO90 */ - PAD_NC(GPIO_90), - /* AGPIO91 */ - PAD_NC(GPIO_91), + /* RAM_ID_1 / DEV_BEEP_DATA */ + PAD_GPI(GPIO_87, PULL_NONE), + /* RAM_ID_3 / DEV_BEEP_BCLK */ + PAD_GPI(GPIO_88, PULL_NONE), + /* TCHSCR_INT_ODL */ + PAD_GPI(GPIO_89, PULL_NONE), + /* HP_INT_ODL */ + PAD_GPI(GPIO_90, PULL_NONE), + /* SD_EX_PRSNT_L */ + PAD_GPI(GPIO_91, PULL_NONE), /* CLK_REQ0_L */ PAD_NF(GPIO_92, CLK_REQ0_L, PULL_NONE), /* GPIO_93 - GPIO_103: Not available */ @@ -118,8 +118,8 @@ PAD_NF(GPIO_107, SPI2_HOLD_L_ESPI2_D3, PULL_NONE), /* ESPI_ALERT_L */ PAD_NF(GPIO_108, ESPI_ALERT_D1, PULL_NONE), - /* EGPIO109 */ - PAD_NC(GPIO_109), + /* RAM_ID_0 / DEV_BEEP_EN */ + PAD_GPI(GPIO_109, PULL_NONE), /* GPIO_110 - GPIO_112: Not available */ /* I2C2_SCL */ PAD_NF(GPIO_113, I2C2_SCL, PULL_NONE), @@ -130,19 +130,19 @@ /* CLK_REQ2_L */ PAD_NF(GPIO_116, CLK_REQ2_L, PULL_NONE), /* GPIO_117 - GPIO_119: Not available */ - /* EGPIO120 */ - PAD_NC(GPIO_120), - /* EGPIO121 */ - PAD_NC(GPIO_121), + /* TCHSCR_REPORT_EN */ + PAD_GPO(GPIO_120, LOW), + /* TCHSCR_RESET */ + PAD_GPO(GPIO_121, LOW), /* GPIO_122 - GPIO_128: Not available */ - /* AGPIO129 */ - PAD_NC(GPIO_129), - /* AGPIO130 */ - PAD_NC(GPIO_130), + /* SOC_DISABLE_DISP_BL */ + PAD_GPO(GPIO_129, LOW), + /* WLAN_DISABLE */ + PAD_GPO(GPIO_130, HIGH), /* CLK_REQ3_L */ PAD_NF(GPIO_131, CLK_REQ3_L, PULL_NONE), - /* EGPIO132 */ - PAD_NC(GPIO_132), + /* BT_DISABLE */ + PAD_GPO(GPIO_132, HIGH), /* UART1_TXD */ PAD_NF(GPIO_140, UART1_TXD, PULL_NONE), /* UART0_RXD */ @@ -151,8 +151,8 @@ PAD_NF(GPIO_142, UART1_RXD, PULL_NONE), /* UART0_TXD */ PAD_NF(GPIO_143, UART0_TXD, PULL_NONE), - /* AGPIO144 */ - PAD_NC(GPIO_144), + /* FPMCU_BOOT_0 */ + PAD_GPO(GPIO_144, LOW), /* I2C0_SCL */ PAD_NF(GPIO_145, I2C0_SCL, PULL_NONE), /* I2C0_SDA */
