Francis Rowe (info@gluglug.org.uk) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7058
commit 07a971d55e4d6f11a8d8839055ee6e7d07bd8993 Author: Francis Rowe info@gluglug.org.uk Date: Mon Oct 13 00:14:53 2014 +0100
NOTFORMERGE: ec/lenovo/h8: wlan/trackpoint/touchpad/bluetooth/wwan
Permanently enable them.
Change-Id: Ic76ab9ab9c865f30312378e18af58bece6c3260a Signed-off-by: Francis Rowe info@gluglug.org.uk --- src/ec/lenovo/h8/h8.c | 21 +++++++++++---------- src/ec/lenovo/pmh7/pmh7.c | 11 ++++------- 2 files changed, 15 insertions(+), 17 deletions(-)
diff --git a/src/ec/lenovo/h8/h8.c b/src/ec/lenovo/h8/h8.c index 46480f4..b6bc406 100644 --- a/src/ec/lenovo/h8/h8.c +++ b/src/ec/lenovo/h8/h8.c @@ -252,9 +252,11 @@ static void h8_enable(struct device *dev)
ec_write(H8_FAN_CONTROL, H8_FAN_CONTROL_AUTO);
- if (get_option(&val, "wlan") != CB_SUCCESS) - val = 1; - h8_wlan_enable(val); + // Permanently enable wifi + // Intel wifi could be a security risk because it uses firmware. Wlan chip has DMA + // and could leak data over a side-channel. Using another manufacturer is recommended. + // see http://libreboot.org/docs/index.html#recommended_wifi + h8_wlan_enable(1);
h8_trackpoint_enable(1); h8_usb_power_enable(1); @@ -262,14 +264,13 @@ static void h8_enable(struct device *dev) if (get_option(&val, "volume") == CB_SUCCESS) ec_write(H8_VOLUME_CONTROL, val);
- if (get_option(&val, "bluetooth") != CB_SUCCESS) - val = 1; - h8_bluetooth_enable(val); - - if (get_option(&val, "wwan") != CB_SUCCESS) - val = 1; + // Permanently enable bluetooth. + // NOTE: bluetooth is a potential security risk. Physical removal of the bluetooth module is recommended. + h8_bluetooth_enable(1);
- h8_wwan_enable(val); + // Permanently enable wwan. + // NOTE: wwan is a security risk (remove access plus DMA). Physical removal of both the wwan and sim card is recommended. + h8_wwan_enable(1);
if (conf->has_uwb) { if (get_option(&val, "uwb") != CB_SUCCESS) diff --git a/src/ec/lenovo/pmh7/pmh7.c b/src/ec/lenovo/pmh7/pmh7.c index cc6e891..38aef16 100644 --- a/src/ec/lenovo/pmh7/pmh7.c +++ b/src/ec/lenovo/pmh7/pmh7.c @@ -106,7 +106,6 @@ static void enable_dev(struct device *dev) { struct ec_lenovo_pmh7_config *conf = dev->chip_info; struct resource *resource; - u8 val;
resource = new_resource(dev, EC_LENOVO_PMH7_INDEX); resource->flags = IORESOURCE_IO | IORESOURCE_FIXED; @@ -118,13 +117,11 @@ static void enable_dev(struct device *dev) pmh7_backlight_enable(conf->backlight_enable); pmh7_dock_event_enable(conf->dock_event_enable);
- if (get_option(&val, "touchpad") != CB_SUCCESS) - val = 1; - pmh7_touchpad_enable(val); + // Permanently enable touchpad + pmh7_touchpad_enable(1);
- if (get_option(&val, "trackpoint") != CB_SUCCESS) - val = 1; - pmh7_trackpoint_enable(val); + // Permanently enable trackpoint + pmh7_trackpoint_enable(1); }
struct chip_operations ec_lenovo_pmh7_ops = {
