Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12383
commit ef71937464c2afc1bfe2377da711444dc11938d4 Author: Stefan Reinauer stefan.reinauer@coreboot.org Date: Tue Nov 10 11:34:51 2015 -0800
[REMOVAL] tyan/s2895
As announced in http://permalink.gmane.org/gmane.linux.bios/81918 I am removing all boards older than 10 years from the tree.
Change-Id: I9099f90c073197cc95bb9630788016b7b8221922 Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- src/mainboard/tyan/s2895/Kconfig | 55 ----- src/mainboard/tyan/s2895/Kconfig.name | 2 - src/mainboard/tyan/s2895/acpi_tables.c | 99 --------- src/mainboard/tyan/s2895/board_info.txt | 4 - src/mainboard/tyan/s2895/cmos.layout | 60 ------ src/mainboard/tyan/s2895/devicetree.cb | 153 -------------- src/mainboard/tyan/s2895/dsdt.asl | 342 -------------------------------- src/mainboard/tyan/s2895/get_bus_conf.c | 168 ---------------- src/mainboard/tyan/s2895/irq_tables.c | 175 ---------------- src/mainboard/tyan/s2895/mainboard.c | 22 -- src/mainboard/tyan/s2895/mptable.c | 200 ------------------- src/mainboard/tyan/s2895/resourcemap.c | 263 ------------------------ src/mainboard/tyan/s2895/romstage.c | 155 --------------- 13 files changed, 1698 deletions(-)
diff --git a/src/mainboard/tyan/s2895/Kconfig b/src/mainboard/tyan/s2895/Kconfig deleted file mode 100644 index 21db63c..0000000 --- a/src/mainboard/tyan/s2895/Kconfig +++ /dev/null @@ -1,55 +0,0 @@ -if BOARD_TYAN_S2895 - -config BOARD_SPECIFIC_OPTIONS # dummy - def_bool y - select CPU_AMD_SOCKET_940 - select NORTHBRIDGE_AMD_AMDK8 - select SOUTHBRIDGE_NVIDIA_CK804 - select SOUTHBRIDGE_AMD_AMD8131 - select HT_CHAIN_DISTRIBUTE - select SUPERIO_SMSC_LPC47B397 - select HAVE_OPTION_TABLE - select HAVE_PIRQ_TABLE - select HAVE_MP_TABLE - select HAVE_ACPI_TABLES - select BOARD_ROMSIZE_KB_1024 - select QRANK_DIMM_SUPPORT - select K8_ALLOCATE_IO_RANGE - -config MAINBOARD_DIR - string - default tyan/s2895 - -config APIC_ID_OFFSET - hex - default 0x10 - -config CK804_NUM - int - default 2 - -config MAINBOARD_PART_NUMBER - string - default "S2895" - -config MAX_CPUS - int - default 4 - -config MAX_PHYSICAL_CPUS - int - default 2 - -config HT_CHAIN_UNITID_BASE - hex - default 0 - -config HT_CHAIN_END_UNITID_BASE - hex - default 0x20 - -config IRQ_SLOT_COUNT - int - default 11 - -endif # BOARD_TYAN_S2895 diff --git a/src/mainboard/tyan/s2895/Kconfig.name b/src/mainboard/tyan/s2895/Kconfig.name deleted file mode 100644 index ff55226..0000000 --- a/src/mainboard/tyan/s2895/Kconfig.name +++ /dev/null @@ -1,2 +0,0 @@ -config BOARD_TYAN_S2895 - bool "S2895 (Thunder K8WE)" diff --git a/src/mainboard/tyan/s2895/acpi_tables.c b/src/mainboard/tyan/s2895/acpi_tables.c deleted file mode 100644 index d66a5de..0000000 --- a/src/mainboard/tyan/s2895/acpi_tables.c +++ /dev/null @@ -1,99 +0,0 @@ -/* - * Island Aruma ACPI support - * written by Stefan Reinauer stepan@openbios.org - * (C) 2005 Stefan Reinauer - * - * - * Copyright 2005 AMD - * 2005.9 yhlu modify that to more dynamic for AMD Opteron Based MB - */ - -#include <console/console.h> -#include <string.h> -#include <arch/acpi.h> -#include <arch/smp/mpspec.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <cpu/x86/msr.h> -#include <cpu/amd/mtrr.h> -#include <cpu/amd/amdk8_sysconf.h> -#include "northbridge/amd/amdk8/acpi.h" -#include <cpu/amd/powernow.h> - -/* APIC */ -unsigned long acpi_fill_madt(unsigned long current) -{ - unsigned long apic_addr; - device_t dev; - struct resource *res; - - get_bus_conf(); - - /* create all subtables for processors */ - current = acpi_create_madt_lapics(current); - - /* Write NVIDIA CK804 IOAPIC. */ - dev = dev_find_slot(0x0, PCI_DEVFN(0x1,0)); - ASSERT(dev != NULL); - - res = find_resource(dev, PCI_BASE_ADDRESS_1); - ASSERT(res != NULL); - - current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, 4, - res->base, 0); - /* Initialize interrupt mapping if mptable.c didn't. */ -#if (!CONFIG_GENERATE_MP_TABLE) - pci_write_config32(dev, 0x7c, 0x0120d218); - pci_write_config32(dev, 0x80, 0x12008a00); - pci_write_config32(dev, 0x84, 0x00080d7d); -#endif - - /* Write AMD 8131 two IOAPICs. */ - dev = dev_find_slot(0x40, PCI_DEVFN(0x0,1)); - if (dev) { - apic_addr = pci_read_config32(dev, PCI_BASE_ADDRESS_0) & ~0xf; - current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, 5, - apic_addr, 0x18); - } - - dev = dev_find_slot(0x40, PCI_DEVFN(0x1, 1)); - if (dev) { - apic_addr = pci_read_config32(dev, PCI_BASE_ADDRESS_0) & ~0xf; - current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, 6, - apic_addr, 0x1C); - } - - /* Write second NVIDIA CK804 IOAPIC. */ - dev = dev_find_slot(0x80, PCI_DEVFN(0x1, 0)); - ASSERT(dev != NULL); - - res = find_resource(dev, PCI_BASE_ADDRESS_1); - ASSERT(res != NULL); - - current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, 7, - res->base, 0x20); - /* Initialize interrupt mapping if mptable.c didn't. */ -#if (!CONFIG_GENERATE_MP_TABLE) - pci_write_config32(dev, 0x7c, 0x0000d218); // Why does the factory BIOS have 0? - pci_write_config32(dev, 0x80, 0x00000000); - pci_write_config32(dev, 0x84, 0x00000d00); // Same here. -#endif - - /* IRQ9 */ - current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) - current, 0, 9, 9, MP_IRQ_TRIGGER_EDGE | MP_IRQ_POLARITY_LOW); - - /* IRQ0 -> APIC IRQ2. */ - /* Doesn't work on this board. */ - - /* 0: mean bus 0--->ISA */ - /* 0: PIC 0 */ - /* 2: APIC 2 */ - /* 5 mean: 0101 --> Edge-triggered, Active high */ - - /* create all subtables for processors */ - /* acpi_create_madt_lapic_nmis returns current, not size. */ - current = acpi_create_madt_lapic_nmis(current, 5, 1); - - return current; -} diff --git a/src/mainboard/tyan/s2895/board_info.txt b/src/mainboard/tyan/s2895/board_info.txt deleted file mode 100644 index ba138fd..0000000 --- a/src/mainboard/tyan/s2895/board_info.txt +++ /dev/null @@ -1,4 +0,0 @@ -Board name: Thunder K8WE (S2895) -Category: desktop -Board URL: http://www.tyan.com/archive/products/html/thunderk8we.html -Release year: 2005 diff --git a/src/mainboard/tyan/s2895/cmos.layout b/src/mainboard/tyan/s2895/cmos.layout deleted file mode 100644 index 4e081ea..0000000 --- a/src/mainboard/tyan/s2895/cmos.layout +++ /dev/null @@ -1,60 +0,0 @@ -entries - -0 384 r 0 reserved_memory -384 1 e 4 boot_option -388 4 r 0 reboot_bits -392 3 e 5 baud_rate -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core -400 1 e 1 power_on_after_fail -412 4 e 6 debug_level -440 4 e 9 slow_cpu -444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory -728 256 h 0 user_data -984 16 h 0 check_sum -# Reserve the extended AMD configuration registers -1000 24 r 0 amd_reserved - - - -enumerations - -#ID value text -1 0 Disable -1 1 Enable -2 0 Enable -2 1 Disable -4 0 Fallback -4 1 Normal -5 0 115200 -5 1 57600 -5 2 38400 -5 3 19200 -5 4 9600 -5 5 4800 -5 6 2400 -5 7 1200 -6 6 Notice -6 7 Info -6 8 Debug -6 9 Spew -8 0 DDR400 -8 1 DDR333 -8 2 DDR266 -8 3 DDR200 -9 0 off -9 1 87.5% -9 2 75.0% -9 3 62.5% -9 4 50.0% -9 5 37.5% -9 6 25.0% -9 7 12.5% - -checksums - -checksum 392 983 984 diff --git a/src/mainboard/tyan/s2895/devicetree.cb b/src/mainboard/tyan/s2895/devicetree.cb deleted file mode 100644 index 4250160..0000000 --- a/src/mainboard/tyan/s2895/devicetree.cb +++ /dev/null @@ -1,153 +0,0 @@ -chip northbridge/amd/amdk8/root_complex # Root complex - device cpu_cluster 0 on # (L)APIC cluster - chip cpu/amd/socket_940 # CPU socket - device lapic 0 on end # Local APIC of the CPU - end - end - device domain 0 on # PCI domain - subsystemid 0x10f1 0x2895 inherit - chip northbridge/amd/amdk8 # Northbridge / RAM controller - device pci 18.0 on # Link 0 == LDT 0 - chip southbridge/nvidia/ck804 # Southbridge - device pci 0.0 on end # HT - device pci 1.0 on # LPC - chip superio/smsc/lpc47b397 # Super I/O - device pnp 2e.0 on # Floppy - io 0x60 = 0x3f0 - irq 0x70 = 6 - drq 0x74 = 2 - end - device pnp 2e.3 on # Parallel port - io 0x60 = 0x378 - irq 0x70 = 7 - drq 0x74 = 4 - end - device pnp 2e.4 on # Com1 - io 0x60 = 0x3f8 - irq 0x70 = 4 - end - device pnp 2e.5 off # Com2 - io 0x60 = 0x2f8 - irq 0x70 = 3 - end - device pnp 2e.7 on # PS/2 keyboard & mouse - io 0x60 = 0x60 - io 0x62 = 0x64 - irq 0x70 = 1 - irq 0x72 = 12 - end - device pnp 2e.8 on # Hardware monitor - io 0x60 = 0x480 - chip drivers/generic/generic # LM95221 CPU temp - device i2c 2b on end - end - chip drivers/generic/generic # EMCT03 - device i2c 54 on end - end - end - device pnp 2e.a on # RT - io 0x60 = 0x400 - end - end - end - device pci 1.1 on # SM 0 - chip drivers/generic/generic # DIMM 0-0-0 - device i2c 50 on end - end - chip drivers/generic/generic # DIMM 0-0-1 - device i2c 51 on end - end - chip drivers/generic/generic # DIMM 0-1-0 - device i2c 52 on end - end - chip drivers/generic/generic # DIMM 0-1-1 - device i2c 53 on end - end - chip drivers/generic/generic # DIMM 1-0-0 - device i2c 54 on end - end - chip drivers/generic/generic # DIMM 1-0-1 - device i2c 55 on end - end - chip drivers/generic/generic # DIMM 1-1-0 - device i2c 56 on end - end - chip drivers/generic/generic # DIMM 1-1-1 - device i2c 57 on end - end - end - device pci 1.1 on # SM 1 - chip drivers/generic/generic # MAC EEPROM - device i2c 51 on end - end - end - device pci 2.0 on end # USB 1.1 - device pci 2.1 on end # USB 2 - device pci 4.0 on end # ACI - device pci 4.1 off end # MCI - device pci 6.0 on end # IDE - device pci 7.0 on end # SATA 1 - device pci 8.0 on end # SATA 0 - device pci 9.0 on end # PCI - device pci a.0 on end # NIC - device pci b.0 off end # PCI E 3 - device pci c.0 off end # PCI E 2 - device pci d.0 off end # PCI E 1 - device pci e.0 on end # PCI E 0 - register "ide0_enable" = "1" - register "ide1_enable" = "1" - register "sata0_enable" = "1" - register "sata1_enable" = "1" - # 1: SMBus under 2e.8, 2: SM0 3: SM1 - register "mac_eeprom_smbus" = "3" - register "mac_eeprom_addr" = "0x51" - end - end - device pci 18.0 on end # Link 1 - device pci 18.0 on # Link 2 == LDT 2 - chip southbridge/amd/amd8131 # Southbridge - device pci 0.0 on end - device pci 0.1 on end - device pci 1.0 on - device pci 6.0 on end # LSI SCSI - device pci 6.1 on end - end - device pci 1.1 on end - end - end - device pci 18.1 on end - device pci 18.2 on end - device pci 18.3 on end - end - chip northbridge/amd/amdk8 # Northbridge / RAM controller - device pci 19.0 on # Link 0 == LDT 0 - chip southbridge/nvidia/ck804 # Southbridge - device pci 0.0 on end # HT - device pci 1.0 on end # LPC - device pci 1.1 off end # SM - device pci 2.0 off end # USB 1.1 - device pci 2.1 off end # USB 2 - device pci 4.0 off end # ACI - device pci 4.1 off end # MCI - device pci 6.0 off end # IDE - device pci 7.0 off end # SATA 1 - device pci 8.0 off end # SATA 0 - device pci 9.0 off end # PCI - device pci a.0 on end # NIC - device pci b.0 off end # PCI E 3 - device pci c.0 off end # PCI E 2 - device pci d.0 off end # PCI E 1 - device pci e.0 on end # PCI E 0 - # 1: SMBus under 2e.8, 2: SM0 3: SM1 - register "mac_eeprom_smbus" = "3" - register "mac_eeprom_addr" = "0x51" - end - end - device pci 19.0 on end - device pci 19.0 on end - device pci 19.1 on end - device pci 19.2 on end - device pci 19.3 on end - end - end -end diff --git a/src/mainboard/tyan/s2895/dsdt.asl b/src/mainboard/tyan/s2895/dsdt.asl deleted file mode 100644 index ef6f4cb..0000000 --- a/src/mainboard/tyan/s2895/dsdt.asl +++ /dev/null @@ -1,342 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2004 Nick Barker Nick.Barker9@btinternet.com - * Copyright (C) 2007, 2008 Rudolf Marek r.marek@assembler.cz - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* - * ISA portions taken from QEMU acpi-dsdt.dsl. - */ - -DefinitionBlock ("DSDT.aml", "DSDT", 1, "CORE ", "CB-DSDT ", 1) -{ - #include "northbridge/amd/amdk8/util.asl" - - /* For now only define 2 power states: - * - S0 which is fully on - * - S5 which is soft off - * Any others would involve declaring the wake up methods. - */ - Name (_S0, Package () { 0x00, 0x00, 0x00, 0x00 }) - Name (_S5, Package () { 0x02, 0x02, 0x00, 0x00 }) - - /* Root of the bus hierarchy */ - Scope (_SB) - { - /* Top PCI device (CK804) */ - Device (PCI0) - { - Name (_HID, EisaId ("PNP0A03")) - Name (_ADR, 0x00) - Name (_UID, 0x00) - Name (_BBN, 0x00) - - External (BUSN) - External (MMIO) - External (PCIO) - External (SBLK) - External (TOM1) - External (HCLK) - External (SBDN) - External (HCDN) - - Method (_CRS, 0, NotSerialized) - { - Name (BUF0, ResourceTemplate () - { - IO (Decode16, - 0x0CF8, // Address Range Minimum - 0x0CF8, // Address Range Maximum - 0x01, // Address Alignment - 0x08, // Address Length - ) - WordIO (ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, - 0x0000, // Address Space Granularity - 0x0000, // Address Range Minimum - 0x0CF7, // Address Range Maximum - 0x0000, // Address Translation Offset - 0x0CF8, // Address Length - ,, , TypeStatic) - }) - /* Methods bellow use SSDT to get actual MMIO regs - The IO ports are from 0xd00, optionally an VGA, - otherwise the info from MMIO is used. - _SB.GXXX(node, link) - */ - Concatenate (_SB.GMEM (0x00, _SB.PCI0.SBLK), BUF0, Local1) - Concatenate (_SB.GIOR (0x00, _SB.PCI0.SBLK), Local1, Local2) - Concatenate (_SB.GWBN (0x00, _SB.PCI0.SBLK), Local2, Local3) - Return (Local3) - } - - /* PCI Routing Table */ - Name (_PRT, Package () { - /* Since source is 0, index is IRQ. */ - /* in ABCD, A=0, B=1, C=2, D=3 */ - /* SlotFFFF, ABCD, source, index */ - Package (0x04) { 0x0001FFFF, 0x00, 0x00, 0x0A }, /* 0x1 SMBUS IRQ 10 */ - Package (0x04) { 0x0002FFFF, 0x00, 0x00, 0x15 }, /* 0x2 USB IRQ 21 */ - Package (0x04) { 0x0002FFFF, 0x01, 0x00, 0x14 }, /* 0x2 USB IRQ 20 */ - Package (0x04) { 0x0004FFFF, 0x00, 0x00, 0x14 }, /* 0x2 AUDIO IRQ 20 */ - Package (0x04) { 0x0007FFFF, 0x00, 0x00, 0x17 }, /* 0x7 SATA 0 IRQ 23 */ - Package (0x04) { 0x0008FFFF, 0x00, 0x00, 0x16 }, /* 0x8 SATA 1 IRQ 22 */ - Package (0x04) { 0x000aFFFF, 0x00, 0x00, 0x15 }, /* 0xa LAN IRQ 21 */ - }) - - Device (PCIL) - { - Name (_ADR, 0x00090000) - Name (_UID, 0x00) - Name (_BBN, 0x01) - Name (_PRT, Package () { - Package (0x04) { 0x0004FFFF, 0x00, 0x00, 0x10 }, /* 1:04 PCI 32 IRQ16-IRQ19 */ - Package (0x04) { 0x0004FFFF, 0x01, 0x00, 0x11 }, - Package (0x04) { 0x0004FFFF, 0x02, 0x00, 0x12 }, - Package (0x04) { 0x0004FFFF, 0x03, 0x00, 0x13 }, - Package (0x04) { 0x0005FFFF, 0x00, 0x00, 0x13 }, /* 1:05 IEEE-1394 IRQ 19 */ - }) - } - - /* 2:00 PCIe x16 SB IRQ 18 */ - Device (PE16) - { - Name (_ADR, 0x000e0000) - Name (_UID, 0x00) - Name (_BBN, 0x02) - Name (_PRT, Package () { - Package (0x04) { 0x0000FFFF, 0x00, 0x00, 0x12 }, /* PCIE IRQ16-IRQ19 */ - Package (0x04) { 0x0000FFFF, 0x01, 0x00, 0x13 }, - Package (0x04) { 0x0000FFFF, 0x02, 0x00, 0x10 }, - Package (0x04) { 0x0000FFFF, 0x03, 0x00, 0x11 }, - }) - } - - Device (ISA) { - Name (_HID, EisaId ("PNP0A05")) - Name (_ADR, 0x00010000) - - /* PS/2 keyboard (seems to be important for WinXP install) */ - Device (KBD) - { - Name (_HID, EisaId ("PNP0303")) - Method (_STA, 0, NotSerialized) - { - Return (0x0f) - } - Method (_CRS, 0, NotSerialized) - { - Name (TMP, ResourceTemplate () { - IO (Decode16, 0x0060, 0x0060, 0x01, 0x01) - IO (Decode16, 0x0064, 0x0064, 0x01, 0x01) - IRQNoFlags () {1} - }) - Return (TMP) - } - } - - /* PS/2 mouse */ - Device (MOU) - { - Name (_HID, EisaId ("PNP0F13")) - Method (_STA, 0, NotSerialized) - { - Return (0x0f) - } - Method (_CRS, 0, NotSerialized) - { - Name (TMP, ResourceTemplate () { - IRQNoFlags () {12} - }) - Return (TMP) - } - } - - /* Parallel port */ - Device (LP0) - { - Name (_HID, EisaId ("PNP0400")) // "PNP0401" for ECP - Method (_STA, 0, NotSerialized) - { - Return (0x0f) - } - Method (_CRS, 0, NotSerialized) - { - Name (TMP, ResourceTemplate () { - FixedIO (0x0378, 0x10) - IRQNoFlags () {7} - }) - Return (TMP) - } - } - - /* RTC */ - Device (RTC) - { - Name (_HID, EisaId ("PNP0B00")) - Method (_CRS, 0, NotSerialized) - { - Name (TMP, ResourceTemplate () { - FixedIO (0x0070, 0x02) - IRQNoFlags () {8} - }) - Return (TMP) - } - } - - /* Floppy controller */ - Device (FDC0) - { - Name (_HID, EisaId ("PNP0700")) - Method (_STA, 0, NotSerialized) - { - Return (0x0f) - } - Method (_CRS, 0, NotSerialized) - { - Name (BUF0, ResourceTemplate () { - FixedIO (0x03F0, 0x08) - IRQNoFlags () {6} - DMA (Compatibility, NotBusMaster, Transfer8) {2} - }) - Return (BUF0) - } - } - } - } - - /* CK804 2050 */ - Device (PCI1) - { - Name (_HID, EisaId ("PNP0A03")) - Name (_ADR, 0x00) - Name (_UID, 0x00) - Name (_BBN, 0x80) - - Method (_CRS, 0, NotSerialized) - { - Name (BUF0, ResourceTemplate () - { - IO (Decode16, - 0x0CF8, // Address Range Minimum - 0x0CF8, // Address Range Maximum - 0x01, // Address Alignment - 0x08, // Address Length - ) - }) - /* Methods bellow use SSDT to get actual MMIO regs - The IO ports are from 0xd00, optionally an VGA, - otherwise the info from MMIO is used. - _SB.GXXX(node, link) - */ - Concatenate (_SB.GMEM (0x01, 0x00), BUF0, Local1) - Concatenate (_SB.GIOR (0x01, 0x00), Local1, Local2) - Concatenate (_SB.GWBN (0x01, 0x00), Local2, Local3) - Return (Local3) - } - - /* PCI Routing Table for this root bus */ - Name (_PRT, Package () { - /* Since source is 0, index is IRQ. */ - /* in ABCD, A=0, B=1, C=2, D=3 */ - /* SlotFFFF, ABCD, source, index */ - Package (0x04) { 0x000aFFFF, 0x00, 0x00, 0x35 }, /* 0xa LAN IRQ 53 */ - }) - - /* PCIe x16 SB2 IRQ 18 */ - Device (PE16) - { - Name (_ADR, 0x000e0000) - Name (_UID, 0x00) - Name (_BBN, 0x81) - Name (_PRT, Package () { - Package (0x04) { 0x0000FFFF, 0x00, 0x00, 0x32 }, /* PCIE IRQ48-IRQ51 */ - Package (0x04) { 0x0000FFFF, 0x01, 0x00, 0x33 }, - Package (0x04) { 0x0000FFFF, 0x02, 0x00, 0x30 }, - Package (0x04) { 0x0000FFFF, 0x03, 0x00, 0x31 }, - }) - } - - } - - /* AMD 8131 PCI-X tunnel */ - Device (PCI2) - { - Name (_HID, EisaId ("PNP0A03")) - Name (_ADR, 0x00) - Name (_UID, 0x00) - Name (_BBN, 0x40) - - /* There is no _PRT Here because I don't know what to - * put in it. Since the 8131 has its own APIC, it - * isn't wired to other IRQs. */ - - Method (_CRS, 0, NotSerialized) - { - Name (BUF0, ResourceTemplate () - { - IO (Decode16, - 0x0CF8, // Address Range Minimum - 0x0CF8, // Address Range Maximum - 0x01, // Address Alignment - 0x08, // Address Length - ) - }) - /* Methods bellow use SSDT to get actual MMIO regs - The IO ports are from 0xd00, optionally an VGA, - otherwise the info from MMIO is used. - _SB.GXXX(node, link) - */ - Concatenate (_SB.GMEM (0x00, 0x02), BUF0, Local1) - Concatenate (_SB.GIOR (0x00, 0x02), Local1, Local2) - Concatenate (_SB.GWBN (0x00, 0x02), Local2, Local3) - Return (Local3) - } - - /* Channel A PCIX 133 */ - Device (PCXF) - { - Name (_ADR, 0x00000000) - Name (_UID, 0x00) - Name (_BBN, 0x41) - Name (_PRT, Package () { - Package (0x04) { 0x0004FFFF, 0x00, 0x00, 0x18 }, /* PCIE IRQ24-IRQ27 */ - Package (0x04) { 0x0004FFFF, 0x01, 0x00, 0x19 }, - Package (0x04) { 0x0004FFFF, 0x02, 0x00, 0x1a }, - Package (0x04) { 0x0004FFFF, 0x03, 0x00, 0x1b }, - }) - } - - /* Channel B PCIX 100 */ - Device (PCXS) /* Slot 4, Onboard SCSI, Slot 5 */ - { - Name (_ADR, 0x00010000) - Name (_UID, 0x00) - Name (_BBN, 0x42) - Name (_PRT, Package () { - Package (0x04) { 0x0004FFFF, 0x00, 0x00, 0x1c }, /* PCIE IRQ28-IRQ31 */ - Package (0x04) { 0x0004FFFF, 0x01, 0x00, 0x1d }, - Package (0x04) { 0x0004FFFF, 0x02, 0x00, 0x1e }, - Package (0x04) { 0x0004FFFF, 0x03, 0x00, 0x1f }, - Package (0x04) { 0x0006FFFF, 0x00, 0x00, 0x1e }, /* PCIE IRQ28-IRQ31 shifted 2 */ - Package (0x04) { 0x0006FFFF, 0x01, 0x00, 0x1f }, - Package (0x04) { 0x0006FFFF, 0x02, 0x00, 0x1c }, - Package (0x04) { 0x0006FFFF, 0x03, 0x00, 0x1d }, - Package (0x04) { 0x0009FFFF, 0x00, 0x00, 0x1d }, /* PCIE IRQ28-IRQ31 shifted 1 */ - Package (0x04) { 0x0009FFFF, 0x01, 0x00, 0x1e }, - Package (0x04) { 0x0009FFFF, 0x02, 0x00, 0x1f }, - Package (0x04) { 0x0009FFFF, 0x03, 0x00, 0x1c }, - }) - } - } - } -} diff --git a/src/mainboard/tyan/s2895/get_bus_conf.c b/src/mainboard/tyan/s2895/get_bus_conf.c deleted file mode 100644 index b8881f5..0000000 --- a/src/mainboard/tyan/s2895/get_bus_conf.c +++ /dev/null @@ -1,168 +0,0 @@ -#include <console/console.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <string.h> -#include <stdint.h> -#include <cpu/amd/multicore.h> - -#include <cpu/amd/amdk8_sysconf.h> -#include <stdlib.h> - -// Global variables for MB layouts and these will be shared by irqtable mptable and acpi_tables -//busnum is default -unsigned char bus_ck804_0; //1 -unsigned char bus_ck804_1; //2 -unsigned char bus_ck804_2; //3 -unsigned char bus_ck804_3; //4 -unsigned char bus_ck804_4; //5 -unsigned char bus_ck804_5; //6 -unsigned char bus_8131_0; //7 -unsigned char bus_8131_1; //8 -unsigned char bus_8131_2; //9 -unsigned char bus_ck804b_0; //a -unsigned char bus_ck804b_1; //b -unsigned char bus_ck804b_2; //c -unsigned char bus_ck804b_3; //d -unsigned char bus_ck804b_4; //e -unsigned char bus_ck804b_5; //f -unsigned apicid_ck804; -unsigned apicid_8131_1; -unsigned apicid_8131_2; -unsigned apicid_ck804b; - -unsigned pci1234x[] = { //Here you only need to set value in pci1234 for HT-IO that could be installed or not - //You may need to preset pci1234 for HTIO board, please refer to src/northbridge/amd/amdk8/get_sblk_pci1234.c for detail - 0x0000ff0, - 0x0000ff0, - 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0 -}; - -unsigned hcdnx[] = { //HT Chain device num, actually it is unit id base of every ht device in chain, assume every chain only have 4 ht device at most - 0x20202020, - 0x20202020, - 0x20202020, -// 0x20202020, -// 0x20202020, -// 0x20202020, -// 0x20202020, -// 0x20202020, -}; - -unsigned sbdn3; -unsigned sbdnb; - -static unsigned get_bus_conf_done = 0; - -void get_bus_conf(void) -{ - - unsigned apicid_base; - unsigned sbdn; - - device_t dev; - int i; - - if (get_bus_conf_done == 1) - return; //do it only once - - get_bus_conf_done = 1; - - sysconf.hc_possible_num = ARRAY_SIZE(pci1234x); - for (i = 0; i < sysconf.hc_possible_num; i++) { - sysconf.pci1234[i] = pci1234x[i]; - sysconf.hcdn[i] = hcdnx[i]; - } - - get_sblk_pci1234(); - - sysconf.sbdn = (sysconf.hcdn[0] & 0xff); // first byte of first chain - sbdn = sysconf.sbdn; - - sbdn3 = (sysconf.hcdn[1] & 0xff); - - sbdnb = (sysconf.hcdn[2] & 0xff); // first byte of second chain - - bus_ck804_0 = (sysconf.pci1234[0] >> 16) & 0xff; - - /* CK804 */ - dev = dev_find_slot(bus_ck804_0, PCI_DEVFN(sbdn + 0x09, 0)); - if (dev) { - bus_ck804_1 = pci_read_config8(dev, PCI_SECONDARY_BUS); - bus_ck804_5 = pci_read_config8(dev, PCI_SUBORDINATE_BUS); - bus_ck804_5++; - } else { - printk(BIOS_DEBUG, - "ERROR - could not find PCI 1:%02x.0, using defaults\n", - sbdn + 0x09); - - bus_ck804_1 = 2; - bus_ck804_5 = 3; - } - - dev = dev_find_slot(bus_ck804_0, PCI_DEVFN(sbdn + 0x0e, 0)); - if (dev) { - bus_ck804_5 = pci_read_config8(dev, PCI_SECONDARY_BUS); - } else { - printk(BIOS_DEBUG, - "ERROR - could not find PCI 1:%02x.0, using defaults\n", - sbdn + 0x0e); - } - - bus_8131_0 = (sysconf.pci1234[1] >> 16) & 0xff; - /* 8131-1 */ - dev = dev_find_slot(bus_8131_0, PCI_DEVFN(sbdn3, 0)); - if (dev) { - bus_8131_1 = pci_read_config8(dev, PCI_SECONDARY_BUS); - bus_8131_2 = pci_read_config8(dev, PCI_SUBORDINATE_BUS); - bus_8131_2++; - } else { - printk(BIOS_DEBUG, - "ERROR - could not find PCI %02x:01.0, using defaults\n", - bus_8131_0); - - bus_8131_1 = bus_8131_0 + 1; - bus_8131_2 = bus_8131_0 + 2; - } - /* 8131-2 */ - dev = dev_find_slot(bus_8131_0, PCI_DEVFN(sbdn3, 0)); - if (dev) { - bus_8131_2 = pci_read_config8(dev, PCI_SECONDARY_BUS); - } else { - printk(BIOS_DEBUG, - "ERROR - could not find PCI %02x:02.0, using defaults\n", - bus_8131_0); - - bus_8131_2 = bus_8131_1 + 1; - } - - /* CK804b */ - - if (sysconf.pci1234[2] & 0x0f) { //if the second cpu is installed - bus_ck804b_0 = (sysconf.pci1234[2] >> 16) & 0xff; - - dev = dev_find_slot(bus_ck804b_0, PCI_DEVFN(sbdnb + 0x0e, 0)); - if (dev) { - bus_ck804b_5 = pci_read_config8(dev, PCI_SECONDARY_BUS); - } else { - printk(BIOS_DEBUG, - "ERROR - could not find PCI %02x:%02x.0, using defaults\n", - bus_ck804b_0, sbdnb + 0x0e); - bus_ck804b_5 = bus_ck804b_4 + 1; - } - } - -/*I/O APICs: APIC ID Version State Address*/ - if (IS_ENABLED(CONFIG_LOGICAL_CPUS)) - apicid_base = get_apicid_base(4); - else - apicid_base = CONFIG_MAX_PHYSICAL_CPUS; - apicid_ck804 = apicid_base + 0; - apicid_8131_1 = apicid_base + 1; - apicid_8131_2 = apicid_base + 2; - apicid_ck804b = apicid_base + 3; -} diff --git a/src/mainboard/tyan/s2895/irq_tables.c b/src/mainboard/tyan/s2895/irq_tables.c deleted file mode 100644 index 797220e..0000000 --- a/src/mainboard/tyan/s2895/irq_tables.c +++ /dev/null @@ -1,175 +0,0 @@ -#include <console/console.h> -#include <device/pci.h> -#include <string.h> -#include <stdint.h> -#include <arch/pirq_routing.h> - -#include <cpu/amd/amdk8_sysconf.h> - -static void write_pirq_info(struct irq_info *pirq_info, uint8_t bus, uint8_t devfn, uint8_t link0, uint16_t bitmap0, - uint8_t link1, uint16_t bitmap1, uint8_t link2, uint16_t bitmap2,uint8_t link3, uint16_t bitmap3, - uint8_t slot, uint8_t rfu) -{ - pirq_info->bus = bus; - pirq_info->devfn = devfn; - pirq_info->irq[0].link = link0; - pirq_info->irq[0].bitmap = bitmap0; - pirq_info->irq[1].link = link1; - pirq_info->irq[1].bitmap = bitmap1; - pirq_info->irq[2].link = link2; - pirq_info->irq[2].bitmap = bitmap2; - pirq_info->irq[3].link = link3; - pirq_info->irq[3].bitmap = bitmap3; - pirq_info->slot = slot; - pirq_info->rfu = rfu; -} - -extern unsigned char bus_ck804_0; //1 -extern unsigned char bus_ck804_1; //2 -extern unsigned char bus_ck804_2; //3 -extern unsigned char bus_ck804_3; //4 -extern unsigned char bus_ck804_4; //5 -extern unsigned char bus_ck804_5; //6 -extern unsigned char bus_8131_0; //7 -extern unsigned char bus_8131_1; //8 -extern unsigned char bus_8131_2; //9 -extern unsigned char bus_ck804b_0;//a -extern unsigned char bus_ck804b_1;//b -extern unsigned char bus_ck804b_2;//c -extern unsigned char bus_ck804b_3;//d -extern unsigned char bus_ck804b_4;//e -extern unsigned char bus_ck804b_5;//f - - -extern unsigned sbdn3; -extern unsigned sbdnb; - - - -unsigned long write_pirq_routing_table(unsigned long addr) -{ - - struct irq_routing_table *pirq; - struct irq_info *pirq_info; - unsigned slot_num; - uint8_t *v; - unsigned sbdn; - - uint8_t sum=0; - int i; - - get_bus_conf(); // it will find out all bus num and apic that share with mptable.c and mptable.c and acpi_tables.c - sbdn = sysconf.sbdn; - - /* Align the table to be 16 byte aligned. */ - addr += 15; - addr &= ~15; - - /* This table must be between 0xf0000 & 0x100000 */ - printk(BIOS_INFO, "Writing IRQ routing tables to 0x%lx...", addr); - - pirq = (void *)(addr); - v = (uint8_t *)(addr); - - pirq->signature = PIRQ_SIGNATURE; - pirq->version = PIRQ_VERSION; - - pirq->rtr_bus = bus_ck804_0; - pirq->rtr_devfn = ((sbdn+9)<<3)|0; - - pirq->exclusive_irqs = 0; - - pirq->rtr_vendor = 0x10de; - pirq->rtr_device = 0x005c; - - pirq->miniport_data = 0; - - memset(pirq->rfu, 0, sizeof(pirq->rfu)); - - pirq_info = (void *) ( &pirq->checksum + 1); - slot_num = 0; -//pci bridge - write_pirq_info(pirq_info, bus_ck804_0, ((sbdn+9)<<3)|0, 0x1, 0xdef8, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 0, 0); - pirq_info++; slot_num++; -//pcix bridge - write_pirq_info(pirq_info, bus_8131_0, (sbdn3<<3)|0, 0x1, 0xdef8, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 0, 0); - pirq_info++; slot_num++; - - if(sysconf.pci1234[2] & 0xf) { - //second pci bridge - write_pirq_info(pirq_info, bus_ck804b_0, ((sbdnb+9)<<3)|0, 0x1, 0xdef8, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 0x0, 0); - pirq_info++; slot_num++; - } -#if 0 -//smbus - write_pirq_info(pirq_info, bus_ck804_0, ((sbdn+1)<<3)|0, 0x2, 0xdef8, 0, 0, 0, 0, 0, 0, 0, 0); - pirq_info++; slot_num++; - -//usb - write_pirq_info(pirq_info, bus_ck804_0, ((sbdn+2)<<3)|0, 0x1, 0xdef8, 0x2, 0xdef8, 0, 0, 0, 0, 0, 0); - pirq_info++; slot_num++; - -//audio - write_pirq_info(pirq_info, bus_ck804_0, ((sbdn+4)<<3)|0, 0x1, 0xdef8, 0, 0, 0, 0, 0, 0, 0, 0); - pirq_info++; slot_num++; -//sata - write_pirq_info(pirq_info, bus_ck804_0, ((sbdn+7)<<3)|0, 0x1, 0xdef8, 0, 0, 0, 0, 0, 0, 0, 0); - pirq_info++; slot_num++; -//sata - write_pirq_info(pirq_info, bus_ck804_0, ((sbdn+8)<<3)|0, 0x1, 0xdef8, 0, 0, 0, 0, 0, 0, 0, 0); - pirq_info++; slot_num++; -//nic - write_pirq_info(pirq_info, bus_ck804_0, ((sbdn+0xa)<<3)|0, 0x1, 0xdef8, 0, 0, 0, 0, 0, 0, 0, 0); - pirq_info++; slot_num++; - -//Slot1 PCIE x16 - write_pirq_info(pirq_info, bus_ck804_5, (0<<3)|0, 0x3, 0xdef8, 0x4, 0xdef8, 0x1, 0xdef8, 0x2, 0xdef8, 1, 0); - pirq_info++; slot_num++; - -//firewire - write_pirq_info(pirq_info, bus_ck804_1, (0x5<<3)|0, 0x3, 0xdef8, 0, 0, 0, 0, 0, 0, 0, 0); - pirq_info++; slot_num++; - -//Slot2 pci - write_pirq_info(pirq_info, bus_ck804_1, (0x4<<3)|0, 0x1, 0xdef8, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 2, 0); - pirq_info++; slot_num++; -//nic - write_pirq_info(pirq_info, bus_ck804b_0, ((sbdnb+0xa)<<3)|0, 0x1, 0xdef8, 0, 0, 0, 0, 0, 0, 0, 0); - pirq_info++; slot_num++; -//Slot3 PCIE x16 - write_pirq_info(pirq_info, bus_ck804b_5, (0<<3)|0, 0x3, 0xdef8, 0x4, 0xdef8, 0x1, 0xdef8, 0x2, 0xdef8, 3, 0); - pirq_info++; slot_num++; - -//Slot4 PCIX - write_pirq_info(pirq_info, bus_8131_2, (4<<3)|0, 0x1, 0xdef8, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 4, 0); - pirq_info++; slot_num++; - -//Slot5 PCIX - write_pirq_info(pirq_info, bus_8131_2, (9<<3)|0, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 0x1, 0xdef8, 5, 0); - pirq_info++; slot_num++; - -//onboard scsi - write_pirq_info(pirq_info, bus_8131_2, (6<<3)|0, 0x2, 0xdef8, 0x3, 0xdef8, 0, 0, 0, 0, 0, 0); - pirq_info++; slot_num++; - -//Slot6 PCIX - write_pirq_info(pirq_info, bus_8131_1, (4<<3)|0, 0x1, 0xdef8, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 6, 0); - pirq_info++; slot_num++; -#endif - - pirq->size = 32 + 16 * slot_num; - - for (i = 0; i < pirq->size; i++) - sum += v[i]; - - sum = pirq->checksum - sum; - - if (sum != pirq->checksum) { - pirq->checksum = sum; - } - - printk(BIOS_INFO, "done.\n"); - - return (unsigned long) pirq_info; - -} diff --git a/src/mainboard/tyan/s2895/mainboard.c b/src/mainboard/tyan/s2895/mainboard.c deleted file mode 100644 index e62b95e..0000000 --- a/src/mainboard/tyan/s2895/mainboard.c +++ /dev/null @@ -1,22 +0,0 @@ -#include <console/console.h> -#include <device/device.h> -#include <arch/acpi.h> -#include <cpu/amd/powernow.h> -#include <arch/acpi.h> -#include <arch/acpigen.h> -#include <cpu/amd/amdk8_sysconf.h> - -extern u16 pm_base; - -static void mainboard_acpi_fill_ssdt_generator(device_t device) { - amd_generate_powernow(0, 0, 0); -} - -static void mainboard_enable(device_t dev) -{ - dev->ops->acpi_fill_ssdt_generator = mainboard_acpi_fill_ssdt_generator; -} - -struct chip_operations mainboard_ops = { - .enable_dev = mainboard_enable, -}; diff --git a/src/mainboard/tyan/s2895/mptable.c b/src/mainboard/tyan/s2895/mptable.c deleted file mode 100644 index 1abab1b..0000000 --- a/src/mainboard/tyan/s2895/mptable.c +++ /dev/null @@ -1,200 +0,0 @@ -#include <console/console.h> -#include <arch/smp/mpspec.h> -#include <device/pci.h> -#include <string.h> -#include <stdint.h> -#include <cpu/amd/amdk8_sysconf.h> - -extern unsigned char bus_ck804_0; //1 -extern unsigned char bus_ck804_1; //2 -extern unsigned char bus_ck804_2; //3 -extern unsigned char bus_ck804_3; //4 -extern unsigned char bus_ck804_4; //5 -extern unsigned char bus_ck804_5; //6 -extern unsigned char bus_8131_0; //7 -extern unsigned char bus_8131_1; //8 -extern unsigned char bus_8131_2; //9 -extern unsigned char bus_ck804b_0;//a -extern unsigned char bus_ck804b_1;//b -extern unsigned char bus_ck804b_2;//c -extern unsigned char bus_ck804b_3;//d -extern unsigned char bus_ck804b_4;//e -extern unsigned char bus_ck804b_5;//f -extern unsigned apicid_ck804; -extern unsigned apicid_8131_1; -extern unsigned apicid_8131_2; -extern unsigned apicid_ck804b; - -extern unsigned sbdn3; -extern unsigned sbdnb; - -static void *smp_write_config_table(void *v) -{ - struct mp_config_table *mc; - unsigned sbdn; - int i, bus_isa; - - mc = (void *)(((char *)v) + SMP_FLOATING_TABLE_LEN); - - mptable_init(mc, LOCAL_APIC_ADDR); - - smp_write_processors(mc); - - get_bus_conf(); - sbdn = sysconf.sbdn; - - mptable_write_buses(mc, NULL, &bus_isa); - -/*I/O APICs: APIC ID Version State Address*/ - { - device_t dev; - struct resource *res; - uint32_t dword; - - dev = dev_find_slot(bus_ck804_0, PCI_DEVFN(sbdn+ 0x1,0)); - if (dev) { - res = find_resource(dev, PCI_BASE_ADDRESS_1); - if (res) { - smp_write_ioapic(mc, apicid_ck804, 0x11, - res2mmio(res, 0, 0)); - } - - /* Initialize interrupt mapping*/ - - dword = 0x0120d218; - pci_write_config32(dev, 0x7c, dword); - - dword = 0x12008a00; - pci_write_config32(dev, 0x80, dword); - - dword = 0x00080d7d; - pci_write_config32(dev, 0x84, dword); - - } - - dev = dev_find_slot(bus_8131_0, PCI_DEVFN(sbdn3,1)); - if (dev) { - res = find_resource(dev, PCI_BASE_ADDRESS_0); - if (res) { - smp_write_ioapic(mc, apicid_8131_1, 0x11, - res2mmio(res, 0, 0)); - } - } - dev = dev_find_slot(bus_8131_0, PCI_DEVFN(sbdn3+1,1)); - if (dev) { - res = find_resource(dev, PCI_BASE_ADDRESS_0); - if (res) { - smp_write_ioapic(mc, apicid_8131_2, 0x11, - res2mmio(res, 0, 0)); - } - } - - if(sysconf.pci1234[2] & 0xf) { - dev = dev_find_slot(bus_ck804b_0, PCI_DEVFN(sbdnb + 0x1,0)); - if (dev) { - res = find_resource(dev, PCI_BASE_ADDRESS_1); - if (res) { - smp_write_ioapic(mc, apicid_ck804b, 0x11, - res2mmio(res, 0, 0)); - } - - dword = 0x0000d218; // Why does the factory BIOS have 0? - pci_write_config32(dev, 0x7c, dword); - - dword = 0x00000000; - pci_write_config32(dev, 0x80, dword); - - dword = 0x00000d00; // Same here. - pci_write_config32(dev, 0x84, dword); - - } - } - - } - - mptable_add_isa_interrupts(mc, bus_isa, apicid_ck804, 1); - -/*I/O Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ -// Onboard ck804 smbus - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_0, ((sbdn+1)<<2)|1, apicid_ck804, 0xa); -// 10 - -// Onboard ck804 USB 1.1 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_0, ((sbdn+2)<<2)|0, apicid_ck804, 0x15); // 21 - -// Onboard ck804 USB 2 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_0, ((sbdn+2)<<2)|1, apicid_ck804, 0x14); // 20 - -// Onboard ck804 Audio - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_0, ((sbdn+4)<<2)|0, apicid_ck804, 0x14); // 20 - -// Onboard ck804 SATA 0 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_0, ((sbdn +7)<<2)|0, apicid_ck804, 0x17); // 23 - -// Onboard ck804 SATA 1 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_0, ((sbdn +8)<<2)|0, apicid_ck804, 0x16); // 22 - -// Onboard ck804 NIC - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_0, ((sbdn +0x0a)<<2)|0, apicid_ck804, 0x15); // 21 - -//Slot PCIE x16 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_5, (0x00<<2)|i, apicid_ck804, 0x10 + (2+i+4-sbdn%4)%4); - } - -//Onboard Firewire - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_1, (0x05<<2)|0, apicid_ck804, 0x13); // 19 - -//Slot 2 PCI 32 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_1, (0x04<<2)|i, apicid_ck804, 0x10 + (0+i)%4); //16 - } - - if(sysconf.pci1234[2] & 0xf) { -//Onboard ck804b NIC - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804b_0, ((sbdnb+0x0a)<<2)|0, apicid_ck804b, 0x15);//24+4+4+21=53 - -//Slot 3 PCIE x16 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804b_5, (0x00<<2)|i, apicid_ck804b, 0x10 + (2+i+4-sbdnb%4)%4); - } - } - -//Channel B of 8131 - -//Slot 4 PCI-X 100/66 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (4<<2)|i, apicid_8131_2, (0+i)%4); - } - -//Slot 5 PCIX 100/66 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (9<<2)|i, apicid_8131_2, (1+i)%4); // 29 - } - -//OnBoard LSI SCSI - for(i=0;i<2;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (6<<2)|i, apicid_8131_2, (2+i)%4); //30 - } - -//Channel A of 8131 - -//Slot 6 PCIX 133/100/66 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (4<<2)|i, apicid_8131_1, (0+i)%4); //24 - } - -/*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN#*/ - mptable_lintsrc(mc, bus_isa); - /* There is no extension information... */ - - /* Compute the checksums */ - return mptable_finalize(mc); -} - -unsigned long write_smp_table(unsigned long addr) -{ - void *v; - v = smp_write_floating_table(addr, 0); - return (unsigned long)smp_write_config_table(v); -} diff --git a/src/mainboard/tyan/s2895/resourcemap.c b/src/mainboard/tyan/s2895/resourcemap.c deleted file mode 100644 index 8d20883..0000000 --- a/src/mainboard/tyan/s2895/resourcemap.c +++ /dev/null @@ -1,263 +0,0 @@ -/* - * Tyan S2895 needs a different resource map - * - */ - -static void setup_mb_resource_map(void) -{ - static const unsigned int register_values[] = { - /* Careful set limit registers before base registers which contain the enables */ - /* DRAM Limit i Registers - * F1:0x44 i = 0 - * F1:0x4C i = 1 - * F1:0x54 i = 2 - * F1:0x5C i = 3 - * F1:0x64 i = 4 - * F1:0x6C i = 5 - * F1:0x74 i = 6 - * F1:0x7C i = 7 - * [ 2: 0] Destination Node ID - * 000 = Node 0 - * 001 = Node 1 - * 010 = Node 2 - * 011 = Node 3 - * 100 = Node 4 - * 101 = Node 5 - * 110 = Node 6 - * 111 = Node 7 - * [ 7: 3] Reserved - * [10: 8] Interleave select - * specifies the values of A[14:12] to use with interleave enable. - * [15:11] Reserved - * [31:16] DRAM Limit Address i Bits 39-24 - * This field defines the upper address bits of a 40 bit address - * that define the end of the DRAM region. - */ - PCI_ADDR(0, 0x18, 1, 0x44), 0x0000f8f8, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x4C), 0x0000f8f8, 0x00000001, - PCI_ADDR(0, 0x18, 1, 0x54), 0x0000f8f8, 0x00000002, - PCI_ADDR(0, 0x18, 1, 0x5C), 0x0000f8f8, 0x00000003, - PCI_ADDR(0, 0x18, 1, 0x64), 0x0000f8f8, 0x00000004, - PCI_ADDR(0, 0x18, 1, 0x6C), 0x0000f8f8, 0x00000005, - PCI_ADDR(0, 0x18, 1, 0x74), 0x0000f8f8, 0x00000006, - PCI_ADDR(0, 0x18, 1, 0x7C), 0x0000f8f8, 0x00000007, - /* DRAM Base i Registers - * F1:0x40 i = 0 - * F1:0x48 i = 1 - * F1:0x50 i = 2 - * F1:0x58 i = 3 - * F1:0x60 i = 4 - * F1:0x68 i = 5 - * F1:0x70 i = 6 - * F1:0x78 i = 7 - * [ 0: 0] Read Enable - * 0 = Reads Disabled - * 1 = Reads Enabled - * [ 1: 1] Write Enable - * 0 = Writes Disabled - * 1 = Writes Enabled - * [ 7: 2] Reserved - * [10: 8] Interleave Enable - * 000 = No interleave - * 001 = Interleave on A[12] (2 nodes) - * 010 = reserved - * 011 = Interleave on A[12] and A[14] (4 nodes) - * 100 = reserved - * 101 = reserved - * 110 = reserved - * 111 = Interleve on A[12] and A[13] and A[14] (8 nodes) - * [15:11] Reserved - * [13:16] DRAM Base Address i Bits 39-24 - * This field defines the upper address bits of a 40-bit address - * that define the start of the DRAM region. - */ - PCI_ADDR(0, 0x18, 1, 0x40), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x48), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x50), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x58), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x60), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x68), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x70), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x78), 0x0000f8fc, 0x00000000, - - /* Memory-Mapped I/O Limit i Registers - * F1:0x84 i = 0 - * F1:0x8C i = 1 - * F1:0x94 i = 2 - * F1:0x9C i = 3 - * F1:0xA4 i = 4 - * F1:0xAC i = 5 - * F1:0xB4 i = 6 - * F1:0xBC i = 7 - * [ 2: 0] Destination Node ID - * 000 = Node 0 - * 001 = Node 1 - * 010 = Node 2 - * 011 = Node 3 - * 100 = Node 4 - * 101 = Node 5 - * 110 = Node 6 - * 111 = Node 7 - * [ 3: 3] Reserved - * [ 5: 4] Destination Link ID - * 00 = Link 0 - * 01 = Link 1 - * 10 = Link 2 - * 11 = Reserved - * [ 6: 6] Reserved - * [ 7: 7] Non-Posted - * 0 = CPU writes may be posted - * 1 = CPU writes must be non-posted - * [31: 8] Memory-Mapped I/O Limit Address i (39-16) - * This field defines the upp adddress bits of a 40-bit address that - * defines the end of a memory-mapped I/O region n - */ - PCI_ADDR(0, 0x18, 1, 0x84), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x8C), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x94), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x9C), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xA4), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xAC), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xB4), 0x00000048, 0x00000000, -// PCI_ADDR(0, 0x18, 1, 0xBC), 0x00000048, 0x00ffff00, - - /* Memory-Mapped I/O Base i Registers - * F1:0x80 i = 0 - * F1:0x88 i = 1 - * F1:0x90 i = 2 - * F1:0x98 i = 3 - * F1:0xA0 i = 4 - * F1:0xA8 i = 5 - * F1:0xB0 i = 6 - * F1:0xB8 i = 7 - * [ 0: 0] Read Enable - * 0 = Reads disabled - * 1 = Reads Enabled - * [ 1: 1] Write Enable - * 0 = Writes disabled - * 1 = Writes Enabled - * [ 2: 2] Cpu Disable - * 0 = Cpu can use this I/O range - * 1 = Cpu requests do not use this I/O range - * [ 3: 3] Lock - * 0 = base/limit registers i are read/write - * 1 = base/limit registers i are read-only - * [ 7: 4] Reserved - * [31: 8] Memory-Mapped I/O Base Address i (39-16) - * This field defines the upper address bits of a 40bit address - * that defines the start of memory-mapped I/O region i - */ - PCI_ADDR(0, 0x18, 1, 0x80), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x88), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x90), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x98), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xA0), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xA8), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xB0), 0x000000f0, 0x00000000, -// PCI_ADDR(0, 0x18, 1, 0xB8), 0x000000f0, 0x00fc0003, - - /* PCI I/O Limit i Registers - * F1:0xC4 i = 0 - * F1:0xCC i = 1 - * F1:0xD4 i = 2 - * F1:0xDC i = 3 - * [ 2: 0] Destination Node ID - * 000 = Node 0 - * 001 = Node 1 - * 010 = Node 2 - * 011 = Node 3 - * 100 = Node 4 - * 101 = Node 5 - * 110 = Node 6 - * 111 = Node 7 - * [ 3: 3] Reserved - * [ 5: 4] Destination Link ID - * 00 = Link 0 - * 01 = Link 1 - * 10 = Link 2 - * 11 = reserved - * [11: 6] Reserved - * [24:12] PCI I/O Limit Address i - * This field defines the end of PCI I/O region n - * [31:25] Reserved - */ - PCI_ADDR(0, 0x18, 1, 0xC4), 0xFE000FC8, 0x00007000, - PCI_ADDR(0, 0x18, 1, 0xCC), 0xFE000FC8, 0x01fff001, // need to talk to ANALOG of second CK804 to release PCI E reset - PCI_ADDR(0, 0x18, 1, 0xD4), 0xFE000FC8, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xDC), 0xFE000FC8, 0x00000000, - - /* PCI I/O Base i Registers - * F1:0xC0 i = 0 - * F1:0xC8 i = 1 - * F1:0xD0 i = 2 - * F1:0xD8 i = 3 - * [ 0: 0] Read Enable - * 0 = Reads Disabled - * 1 = Reads Enabled - * [ 1: 1] Write Enable - * 0 = Writes Disabled - * 1 = Writes Enabled - * [ 3: 2] Reserved - * [ 4: 4] VGA Enable - * 0 = VGA matches Disabled - * 1 = matches all address < 64K and where A[9:0] is in the - * range 3B0-3BB or 3C0-3DF independen of the base & limit registers - * [ 5: 5] ISA Enable - * 0 = ISA matches Disabled - * 1 = Blocks address < 64K and in the last 768 bytes of eack 1K block - * from matching agains this base/limit pair - * [11: 6] Reserved - * [24:12] PCI I/O Base i - * This field defines the start of PCI I/O region n - * [31:25] Reserved - */ - PCI_ADDR(0, 0x18, 1, 0xC0), 0xFE000FCC, 0x00000033, - PCI_ADDR(0, 0x18, 1, 0xC8), 0xFE000FCC, 0x00008033, - PCI_ADDR(0, 0x18, 1, 0xD0), 0xFE000FCC, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xD8), 0xFE000FCC, 0x00000000, - - /* Config Base and Limit i Registers - * F1:0xE0 i = 0 - * F1:0xE4 i = 1 - * F1:0xE8 i = 2 - * F1:0xEC i = 3 - * [ 0: 0] Read Enable - * 0 = Reads Disabled - * 1 = Reads Enabled - * [ 1: 1] Write Enable - * 0 = Writes Disabled - * 1 = Writes Enabled - * [ 2: 2] Device Number Compare Enable - * 0 = The ranges are based on bus number - * 1 = The ranges are ranges of devices on bus 0 - * [ 3: 3] Reserved - * [ 6: 4] Destination Node - * 000 = Node 0 - * 001 = Node 1 - * 010 = Node 2 - * 011 = Node 3 - * 100 = Node 4 - * 101 = Node 5 - * 110 = Node 6 - * 111 = Node 7 - * [ 7: 7] Reserved - * [ 9: 8] Destination Link - * 00 = Link 0 - * 01 = Link 1 - * 10 = Link 2 - * 11 - Reserved - * [15:10] Reserved - * [23:16] Bus Number Base i - * This field defines the lowest bus number in configuration region i - * [31:24] Bus Number Limit i - * This field defines the highest bus number in configuration region i - */ - PCI_ADDR(0, 0x18, 1, 0xE0), 0x0000FC88, 0x07000003, /* link 0 of cpu 0 --> Nvidia CK 804 Pro */ - PCI_ADDR(0, 0x18, 1, 0xE4), 0x0000FC88, 0x7f080203, /* link 2 of cpu 0 --> AMD8131 */ - PCI_ADDR(0, 0x18, 1, 0xE8), 0x0000FC88, 0xff800013, /* link 0 of cpu 1 --> Nvidia CK 804 Slave */ - PCI_ADDR(0, 0x18, 1, 0xEC), 0x0000FC88, 0x00000000, /*113 link 1 of cpu 1 --> HT connector */ - }; - int max; - max = ARRAY_SIZE(register_values); - setup_resource_map(register_values, max); -} diff --git a/src/mainboard/tyan/s2895/romstage.c b/src/mainboard/tyan/s2895/romstage.c deleted file mode 100644 index 086df63..0000000 --- a/src/mainboard/tyan/s2895/romstage.c +++ /dev/null @@ -1,155 +0,0 @@ -#include <stdint.h> -#include <string.h> -#include <device/pci_def.h> -#include <arch/io.h> -#include <device/pnp_def.h> -#include <cpu/x86/lapic.h> -#include <pc80/mc146818rtc.h> -#include <console/console.h> -#include <lib.h> -#include <spd.h> -#include <cpu/amd/model_fxx_rev.h> -#include "northbridge/amd/amdk8/incoherent_ht.c" -#include <southbridge/nvidia/ck804/early_smbus.h> -#include <northbridge/amd/amdk8/raminit.h> -#include <delay.h> -#include <cpu/x86/lapic.h> -#include "northbridge/amd/amdk8/reset_test.c" -#include <superio/smsc/lpc47b397/lpc47b397.h> -#include "superio/smsc/lpc47b397/early_gpio.c" -#include <cpu/x86/bist.h> -#include "northbridge/amd/amdk8/debug.c" -#include <cpu/amd/mtrr.h> -#include "northbridge/amd/amdk8/setup_resource_map.c" - -#define SERIAL_DEV PNP_DEV(0x2e, LPC47B397_SP1) -#define SUPERIO_GPIO_DEV PNP_DEV(0x2e, LPC47B397_RT) -#define SUPERIO_GPIO_IO_BASE 0x400 - -static void memreset_setup(void) { } -static void memreset(int controllers, const struct mem_controller *ctrl) { } -static void activate_spd_rom(const struct mem_controller *ctrl) { } - -static void sio_gpio_setup(void) -{ - unsigned value; - - /*Enable onboard scsi*/ - lpc47b397_gpio_offset_out(SUPERIO_GPIO_IO_BASE, 0x2c, - (1<<7)|(0<<2)|(0<<1)|(0<<0)); // GP21, offset 0x2c, DISABLE_SCSI_L - value = lpc47b397_gpio_offset_in(SUPERIO_GPIO_IO_BASE, 0x4c); - lpc47b397_gpio_offset_out(SUPERIO_GPIO_IO_BASE, 0x4c, (value|(1<<1))); -} - -static inline int spd_read_byte(unsigned device, unsigned address) -{ - return smbus_read_byte(device, address); -} - -#include "northbridge/amd/amdk8/raminit.c" -#include "northbridge/amd/amdk8/coherent_ht.c" -#include "lib/generic_sdram.c" -#include "resourcemap.c" -#include "cpu/amd/dualcore/dualcore.c" -#include <southbridge/nvidia/ck804/early_setup_ss.h> - -//set GPIO to input mode -#define CK804_MB_SETUP \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+ 5, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* M9,GPIO6, PCIXB2_PRSNT1_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+15, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* M8,GPIO16, PCIXB2_PRSNT2_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+44, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* P5,GPIO45, PCIXA_PRSNT1_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+ 7, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* M5,GPIO8, PCIXA_PRSNT2_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+16, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* K4,GPIO17, PCIXB_PRSNT1_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+45, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* P7,GPIO46, PCIXB_PRSNT2_L*/ - -#include "southbridge/nvidia/ck804/early_setup_car.c" -#include "cpu/amd/model_fxx/init_cpus.c" -#include "northbridge/amd/amdk8/early_ht.c" - -static void sio_setup(void) -{ - unsigned value; - u32 dword; - u8 byte; - - pci_write_config32(PCI_DEV(0, CK804_DEVN_BASE+1, 0), 0xac, 0x047f0400); - - byte = pci_read_config8(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0x7b); - byte |= 0x20; - pci_write_config8(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0x7b, byte); - - dword = pci_read_config32(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0xa0); - dword |= (1<<29)|(1<<0); - pci_write_config32(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0xa0, dword); - - dword = pci_read_config32(PCI_DEV(0, CK804_DEVN_BASE+1, 0), 0xa4); - dword |= (1<<16); - pci_write_config32(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0xa4, dword); - - lpc47b397_enable_serial(SUPERIO_GPIO_DEV, SUPERIO_GPIO_IO_BASE); - value = lpc47b397_gpio_offset_in(SUPERIO_GPIO_IO_BASE, 0x77); - value &= 0xbf; - lpc47b397_gpio_offset_out(SUPERIO_GPIO_IO_BASE, 0x77, value); -} - -void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) -{ - static const u16 spd_addr [] = { - DIMM0, DIMM2, 0, 0, - DIMM1, DIMM3, 0, 0, - DIMM4, DIMM6, 0, 0, - DIMM5, DIMM7, 0, 0, - }; - - int needs_reset; - unsigned bsp_apicid = 0, nodes; - struct mem_controller ctrl[8]; - - if (!cpu_init_detectedx && boot_cpu()) { - /* Nothing special needs to be done to find bus 0 */ - /* Allow the HT devices to be found */ - enumerate_ht_chain(); - sio_setup(); - } - - if (bist == 0) - bsp_apicid = init_cpus(cpu_init_detectedx); - - lpc47b397_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); - console_init(); - - /* Halt if there was a built in self test failure */ - report_bist_failure(bist); - - sio_gpio_setup(); - - setup_mb_resource_map(); - - needs_reset = setup_coherent_ht_domain(); - - wait_all_core0_started(); - - // It is said that we should start core1 after all core0 launched - start_other_cores(); - wait_all_other_cores_started(bsp_apicid); - - needs_reset |= ht_setup_chains_x(); - needs_reset |= ck804_early_setup_x(); - if (needs_reset) { - printk(BIOS_INFO, "ht reset -\n"); - soft_reset(); - } - - allow_all_aps_stop(bsp_apicid); - - nodes = get_nodes(); - //It's the time to set ctrl now; - fill_mem_ctrl(nodes, ctrl, spd_addr); - - enable_smbus(); - - memreset_setup(); - sdram_initialize(nodes, ctrl); - - post_cache_as_ram(); -}
