Attention is currently required from: Michał Kopeć.
Michał Żygowski has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/68078 )
Change subject: mb/msi/ms7d25: Populate SMBIOS product name based on CNVi presence ......................................................................
MSI PRO Z690-A WIFI DDR4 and MSI PRO Z690-A DDR4 are basically the same boards, except the latter has no WiFi populated. Check the CNVi WiFi presence and return correct SMBIOS product name string.
TEST=Check SMBIOS product name on both WiFi and non-WiFi variants in Linux.
Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Change-Id: I5fedbce413dfb6a589a406d1e34e3e114ca6a40f --- M src/mainboard/msi/ms7d25/mainboard.c 1 file changed, 31 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/78/68078/1
diff --git a/src/mainboard/msi/ms7d25/mainboard.c b/src/mainboard/msi/ms7d25/mainboard.c index 2d46887..e1f60f6 100644 --- a/src/mainboard/msi/ms7d25/mainboard.c +++ b/src/mainboard/msi/ms7d25/mainboard.c @@ -2,6 +2,7 @@
#include <acpi/acpi.h> #include <device/device.h> +#include <soc/pci_devs.h> #include <soc/ramstage.h> #include <smbios.h> #include <string.h> @@ -32,6 +33,19 @@ return "MS-7D25"; }
+const char *smbios_mainboard_product_name(void) +{ + /* Currently we support DDR4 variants, but e.g. DDR5 can be added later */ + if (CONFIG(BOARD_MSI_Z690_A_PRO_WIFI_DDR4)) { + if (is_devfn_enabled(PCH_DEVFN_CNVI_WIFI)) + return "PRO Z690-A WIFI DDR4(MS-7D25)"; + else + return "PRO Z690-A DDR4(MS-7D25)"; + } + + return CONFIG_MAINBOARD_PART_NUMBER; +} + /* Only baseboard serial number is populated */ const char *smbios_system_serial_number(void) {
