Attention is currently required from: Arthur Heymans, Chen, Gang C, David Hendricks, Jonathan Zhang, Lean Sheng Tan, Patrick Rudolph, Paul Menzel, Shuo Liu, TangYiwei.
Hello Arthur Heymans, Chen, Gang C, David Hendricks, Jonathan Zhang, Lean Sheng Tan, Patrick Rudolph, TangYiwei, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81322?usp=email
to look at the new patch set (#29).
Change subject: mb/intel/beechnutcity_crb: Add GNR/SRF-SP 2S server board Beechnut City ......................................................................
Beechnut City CRB is the 2 socket reference board for 6th Gen Xeon-SP SP SoCs (Granite Rapids SP and Sierra Forest SP).
This patch initially sets the code set up as a compilation target with GNR N-1 FSP, and with basic feature supports (Integrated IO Controller (IIO) configuration, BMC, UART, HPET).
TEST=Build on intel/beechnutcity CRB
Change-Id: I3f6a0fb97b62baadb438fb9f11fdd78fccb3f89a Signed-off-by: Shuo Liu shuo.liu@intel.com Co-authored-by: Gang Chen gang.c.chen@intel.com --- A configs/builder/config.intel.crb.bnc A src/mainboard/intel/beechnutcity_crb/Kconfig A src/mainboard/intel/beechnutcity_crb/Kconfig.name A src/mainboard/intel/beechnutcity_crb/Makefile.mk A src/mainboard/intel/beechnutcity_crb/board.fmd A src/mainboard/intel/beechnutcity_crb/board_info.txt A src/mainboard/intel/beechnutcity_crb/bootblock.c A src/mainboard/intel/beechnutcity_crb/config/iio.c A src/mainboard/intel/beechnutcity_crb/devicetree.cb A src/mainboard/intel/beechnutcity_crb/dsdt.asl A src/mainboard/intel/beechnutcity_crb/ramstage.c A src/mainboard/intel/beechnutcity_crb/romstage.c 12 files changed, 283 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/22/81322/29
