Attention is currently required from: Jérémy Compostella, Nicholas Chin, Subrata Banik.
Subrata Banik has uploaded a new patch set (#14) to the change originally created by Nicholas Chin. ( https://review.coreboot.org/c/coreboot/+/85905?usp=email )
Change subject: drivers/option: Add CBFS file based option backend ......................................................................
Add a new option backend that uses values stored in CBFS files, similar to the SeaBIOS runtime config options stored in files with the etc/ prefix. Options should be stored in CBFS with the option/ prefix. Values can be set using `cbfstool coreboot.rom add-int -n option/<option-name> -i <value>`. For simplicity, options should be stored in the COREBOOT (RO) FMAP region, which is the default for cbfstool. This backend is not available in SMM due to CBFS dependencies on vboot functions which are not added to SMM, and thus the fallback will be returned by calls to get_uint_option() in SMM.
Tested with QEMU Q35 by setting various options for "sata_mode" and observing the console output for the SATA controller mode during i82801ix_sata initialization.
Change-Id: Ifc0439ee42f13f49ae54d4855d1d9333c39b01f5 Signed-off-by: Nicholas Chin nic.c3.14@gmail.com --- M src/Kconfig M src/drivers/option/Makefile.mk A src/drivers/option/cbfs_file_option.c M src/include/option.h 4 files changed, 39 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/05/85905/14
