Attention is currently required from: Jason Glenesk, Marshall Dawson, Karthik Ramasubramanian, Felix Held. Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Marshall Dawson, Felix Held,
https://review.coreboot.org/c/coreboot/+/58114
Change subject: soc/amd/common/block/lpc: Refactor ESPI Setup ......................................................................
ESPI is setup in two different locations in bootblock depending on early port80 routing configuration. Also ESPI is setup in PSP, if verified boot starts before bootblock. Consolidate all the scenarios by initializating ESPI as part of lpc_early_init if verified boot starts after bootblock and ESPI is enabled.
BUG=None TEST=Build and boot to OS in Guybrush. Perform S5->S0, G3->S0, warm reset and suspend/resume cycles for 50 iterations each.
Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com Change-Id: Icfeba17dae0a964c9ca73686e29c18d965589934 --- M src/soc/amd/cezanne/bootblock.c M src/soc/amd/cezanne/early_fch.c M src/soc/amd/cezanne/include/soc/southbridge.h M src/soc/amd/common/block/lpc/lpc_util.c M src/soc/amd/picasso/early_fch.c 5 files changed, 12 insertions(+), 24 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/14/58114/2
