Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9084
commit 3bf7a68eb0bd3d63b5814000389a49146b3aeeef Author: Aaron Durbin adurbin@chromium.org Date: Wed Sep 17 11:43:20 2014 -0500
arm64: add spin table support
There was a hacky and one-off spin table support in tegra132. Make this support generic for all arm64 chips.
BUG=chrome-os-partner:32082 BRANCH=None TEST=Ran with and without secure monitor booting smp into the kernel.
Change-Id: I3425ab0c30983d4c74d0aa465dda38bb2c91c83b Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 024dc3f3e5262433a56ed14934db837b5feb1748 Original-Change-Id: If12083a9afc3b2be663d36cfeed10f9b74bae3c8 Original-Signed-off-by: Aaron Durbin adurbin@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/218654 Original-Reviewed-by: Furquan Shaikh furquan@chromium.org --- src/arch/arm64/Kconfig | 5 ++ src/arch/arm64/Makefile.inc | 1 + src/arch/arm64/armv8/secmon_loader.c | 69 +++++++++++++++++----- src/arch/arm64/boot.c | 4 ++ src/arch/arm64/include/arch/spintable.h | 50 ++++++++++++++++ src/arch/arm64/spintable.c | 100 ++++++++++++++++++++++++++++++++ src/arch/arm64/spintable_asm.S | 38 ++++++++++++ src/include/cbmem.h | 4 +- 8 files changed, 254 insertions(+), 17 deletions(-)
diff --git a/src/arch/arm64/Kconfig b/src/arch/arm64/Kconfig index a070b90..2465bb1 100644 --- a/src/arch/arm64/Kconfig +++ b/src/arch/arm64/Kconfig @@ -20,4 +20,9 @@ config ARCH_USE_SECURE_MONITOR default n select RELOCATABLE_MODULES
+config ARCH_SPINTABLE + bool + default n + depends on ARCH_RAMSTAGE_ARM64 + source src/arch/arm64/armv8/Kconfig diff --git a/src/arch/arm64/Makefile.inc b/src/arch/arm64/Makefile.inc index 1dfaa96..c2caf64 100644 --- a/src/arch/arm64/Makefile.inc +++ b/src/arch/arm64/Makefile.inc @@ -123,6 +123,7 @@ ramstage-y += ../../lib/memset.c ramstage-y += ../../lib/memcpy.c ramstage-y += ../../lib/memmove.c ramstage-y += stage_entry.S +ramstage-$(CONFIG_ARCH_SPINTABLE) += spintable.c spintable_asm.S ramstage-y += transition.c transition_asm.S
rmodules_arm64-y += ../../lib/memset.c diff --git a/src/arch/arm64/armv8/secmon_loader.c b/src/arch/arm64/armv8/secmon_loader.c index 066f1c1..4d83764 100644 --- a/src/arch/arm64/armv8/secmon_loader.c +++ b/src/arch/arm64/armv8/secmon_loader.c @@ -24,6 +24,7 @@
#include <arch/lib_helpers.h> #include <arch/secmon.h> +#include <arch/spintable.h> #include <console/console.h> #include <rmodule.h> #include <string.h> @@ -75,10 +76,43 @@ static secmon_entry_t secmon_load_rmodule(void) return rmodule_entry(&secmon_mod); }
-void secmon_run(void (*entry)(void *), void *cb_tables) +struct secmon_runit { + secmon_entry_t entry; + struct secmon_params bsp_params; + struct secmon_params secondary_params; +}; + +static void secmon_start(void *arg) { - struct secmon_params params; uint32_t scr; + struct secmon_params *p = NULL; + struct secmon_runit *r = arg; + + if (cpu_is_bsp()) + p = &r->bsp_params; + else if (r->secondary_params.entry != NULL) + p = &r->secondary_params; + + printk(BIOS_DEBUG, "CPU%x entering secure monitor.\n", cpu_info()->id); + + /* We want to enforce the following policies: + * NS bit is set for lower EL + */ + scr = raw_read_scr_el3(); + scr |= SCR_NS; + raw_write_scr_el3(scr); + + r->entry(p); +} + +void secmon_run(void (*entry)(void *), void *cb_tables) +{ + const struct spintable_attributes *spin_attrs; + static struct secmon_runit runit; + struct cpu_action action = { + .run = secmon_start, + .arg = &runit, + };
printk(BIOS_SPEW, "payload jump @ %p\n", entry);
@@ -87,25 +121,28 @@ void secmon_run(void (*entry)(void *), void *cb_tables) return; }
- secmon_entry_t doit = secmon_load_rmodule(); + runit.entry = secmon_load_rmodule();
- if (doit == NULL) + if (runit.entry == NULL) die("ARM64 Error: secmon load error");
printk(BIOS_DEBUG, "ARM64: Loaded the el3 monitor...jumping to %p\n", - doit); + runit.entry);
- params.entry = entry; - params.arg = cb_tables; - params.elx_el = EL2; - params.elx_mode = SPSR_USE_L; + runit.bsp_params.entry = entry; + runit.bsp_params.arg = cb_tables; + runit.bsp_params.elx_el = EL2; + runit.bsp_params.elx_mode = SPSR_USE_L; + runit.secondary_params.elx_el = EL2; + runit.secondary_params.elx_mode = SPSR_USE_L;
- /* We want to enforce the following policies: - * NS bit is set for lower EL - */ - scr = raw_read_scr_el3(); - scr |= SCR_NS; - raw_write_scr_el3(scr); + spin_attrs = spintable_get_attributes(); + + if (spin_attrs != NULL) { + runit.secondary_params.entry = spin_attrs->entry; + runit.secondary_params.arg = spin_attrs->addr; + }
- doit(¶ms); + arch_run_on_all_cpus_but_self_async(&action); + secmon_start(&runit); } diff --git a/src/arch/arm64/boot.c b/src/arch/arm64/boot.c index 6307e60..01630f3 100644 --- a/src/arch/arm64/boot.c +++ b/src/arch/arm64/boot.c @@ -21,6 +21,7 @@ #include <arch/lib_helpers.h> #include <arch/secmon.h> #include <arch/stages.h> +#include <arch/spintable.h> #include <arch/transition.h> #include <cbmem.h> #include <console/console.h> @@ -38,6 +39,9 @@ void arch_payload_run(const struct payload *payload)
secmon_run(payload_entry, cb_tables);
+ /* Start the other CPUs spinning. */ + spintable_start(); + /* If current EL is not EL3, jump to payload at same EL. */ if (current_el != EL3) { cache_sync_instructions(); diff --git a/src/arch/arm64/include/arch/spintable.h b/src/arch/arm64/include/arch/spintable.h new file mode 100644 index 0000000..b583ddb --- /dev/null +++ b/src/arch/arm64/include/arch/spintable.h @@ -0,0 +1,50 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef __ARCH_SPINTABLE_H__ +#define __ARCH_SPINTABLE_H__ + +struct spintable_attributes { + void (*entry)(void *); + void *addr; +}; + +#if IS_ENABLED(CONFIG_ARCH_SPINTABLE) + +/* Initialize spintable with provided monitor address. */ +void spintable_init(void *monitor_address); + +/* Start spinning on the non-boot CPUS. */ +void spintable_start(void); + +/* Return NULL on failure, otherwise the spintable info. */ +const struct spintable_attributes *spintable_get_attributes(void); + +#else /* IS_ENABLED(CONFIG_SPINTABLE) */ + +static inline void spintable_init(void *monitor_address) {} +static inline void spintable_start(void) {} +static inline const struct spintable_attributes *spintable_get_attributes(void) +{ + return NULL; +} + +#endif /* IS_ENABLED(CONFIG_SPINTABLE) */ + +#endif /* __ARCH_SPINTABLE_H__ */ diff --git a/src/arch/arm64/spintable.c b/src/arch/arm64/spintable.c new file mode 100644 index 0000000..7a1ab7f --- /dev/null +++ b/src/arch/arm64/spintable.c @@ -0,0 +1,100 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA, 02110-1301 USA + */ + +#include <arch/cache.h> +#include <arch/spintable.h> +#include <arch/transition.h> +#include <console/console.h> +#include <cpu/cpu.h> +#include <cbmem.h> +#include <string.h> + +static struct spintable_attributes spin_attrs; + +void spintable_init(void *monitor_address) +{ + extern void __wait_for_spin_table_request(void); + const size_t code_size = 4096; + + if (monitor_address == NULL) { + printk(BIOS_ERR, "spintable: NULL address to monitor.\n"); + return; + } + + spin_attrs.entry = cbmem_add(CBMEM_ID_SPINTABLE, code_size); + + if (spin_attrs.entry == NULL) + return; + + spin_attrs.addr = monitor_address; + + printk(BIOS_INFO, "spintable @ %p will monitor %p\n", + spin_attrs.entry, spin_attrs.addr); + + /* Ensure the memory location is zero'd out. */ + *(uint64_t *)monitor_address = 0; + + memcpy(spin_attrs.entry, __wait_for_spin_table_request, code_size); + + dcache_clean_invalidate_by_mva(monitor_address, sizeof(uint64_t)); + dcache_clean_invalidate_by_mva(spin_attrs.entry, code_size); +} + +static void spintable_enter(void *unused) +{ + struct exc_state state; + const struct spintable_attributes *attrs; + int current_el; + + attrs = spintable_get_attributes(); + + current_el = get_current_el(); + + if (current_el != EL3) + attrs->entry(attrs->addr); + + memset(&state, 0, sizeof(state)); + state.elx.spsr = get_eret_el(EL2, SPSR_USE_L); + + transition_with_entry(attrs->entry, attrs->addr, &state); +} + +const struct spintable_attributes *spintable_get_attributes(void) +{ + if (spin_attrs.entry == NULL) { + printk(BIOS_ERR, "spintable: monitor code not present.\n"); + return NULL; + } + + return &spin_attrs; +} + +void spintable_start(void) +{ + struct cpu_action action = { + .run = spintable_enter, + }; + + if (spintable_get_attributes() == NULL) + return; + + printk(BIOS_INFO, "All non-boot CPUs to enter spintable.\n"); + + arch_run_on_all_cpus_but_self_async(&action); +} diff --git a/src/arch/arm64/spintable_asm.S b/src/arch/arm64/spintable_asm.S new file mode 100644 index 0000000..3066b7e --- /dev/null +++ b/src/arch/arm64/spintable_asm.S @@ -0,0 +1,38 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <arch/asm.h> + +ENTRY(__wait_for_spin_table_request) + /* Entry here is in EL2 with the magic address in x0. */ + mov x28, x0 +1: + ldr x27, [x28] + cmp x27, xzr + b.ne 2f + wfe + b 1b +2: + /* Entry into the kernel. */ + mov x0, xzr + mov x1, xzr + mov x2, xzr + mov x3, xzr + br x27 +ENDPROC(__wait_for_spin_table_request) diff --git a/src/include/cbmem.h b/src/include/cbmem.h index 49eaf48..f605191 100644 --- a/src/include/cbmem.h +++ b/src/include/cbmem.h @@ -73,6 +73,7 @@ #define CBMEM_ID_SMM_SAVE_SPACE 0x07e9acee #define CBMEM_ID_RAM_OOPS 0x05430095 #define CBMEM_ID_MEMINFO 0x494D454D +#define CBMEM_ID_SPINTABLE 0x59175917 #define CBMEM_ID_NONE 0x00000000 #define CBMEM_ID_AGESA_RUNTIME 0x41474553 #define CBMEM_ID_HOB_POINTER 0x484f4221 @@ -117,7 +118,8 @@ struct cbmem_id_to_name { { CBMEM_ID_REFCODE_CACHE, "REFCODE $ " }, \ { CBMEM_ID_POWER_STATE, "POWER STATE" }, \ { CBMEM_ID_RAM_OOPS, "RAMOOPS " }, \ - { CBMEM_ID_MEMINFO, "MEM INFO " }, + { CBMEM_ID_MEMINFO, "MEM INFO " }, \ + { CBMEM_ID_SPINTABLE, "SPIN TABLE " },
struct cbmem_entry;
