Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8087
commit c8e1d7b8d0d3abe2a19c221c84040e9b0951cf4c Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Mon Jan 5 00:29:36 2015 +1100
northbridge/via/vx800/examples: Remove rotting source
This is just bit-rotting and its likely this will continue to rot by the time someone notices it exits it will be too late (i.e., today).
Change-Id: I40ef2cd8e3d563079b086f51dabab0960a0a13b3 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/northbridge/via/vx800/examples/chipset_init.c | 1241 -------------------- .../via/vx800/examples/driving_clk_phase_data.c | 242 ---- src/northbridge/via/vx800/examples/romstage.c | 541 --------- 3 files changed, 2024 deletions(-)
diff --git a/src/northbridge/via/vx800/examples/chipset_init.c b/src/northbridge/via/vx800/examples/chipset_init.c deleted file mode 100644 index 3f9c70f..0000000 --- a/src/northbridge/via/vx800/examples/chipset_init.c +++ /dev/null @@ -1,1241 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2009 One Laptop per Child, Association, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#if CONFIG_HAVE_ACPI_RESUME -#include <arch/acpi.h> -#endif -#include "../vx800.h" - -#include <arch/io.h> -#include "pci_rawops.h" - -static const struct VIA_PCI_REG_INIT_TABLE mSbStage1InitTbl[] = { - // Combine Stage1 registers - {0x00, 0xFF, SB_LPC_REG(0x41), 0x40, 0x40}, - - // Acpi init registers in sb stage1 - {0x00, 0xFF, SB_LPC_REG(0x40), 0x04, 0x04}, // Enable 4D0/4D1 support - {0x00, 0xFF, SB_LPC_REG(0x4E), 0x00, 0x08}, // Enable RTC port 74/75 - {0x00, 0xFF, SB_LPC_REG(0x51), 0x0D, 0x0D}, // and KBC - {0x00, 0xFF, SB_LPC_REG(0x52), 0x0F, 0x09}, // Enable Serial IRQ - {0x00, 0xFF, SB_LPC_REG(0x67), 0x00, 0x04}, // Set FERR voltage to 1.5v - {0x00, 0xFF, SB_LPC_REG(0x98), 0xFF, 0x00}, // Disable GP3 Timer - - {0x00, 0xFF, SB_IDEC_REG(0xb9), 0x01, 0x01}, - - {0x00, 0xFF, SB_VLINK_REG(0xE6), 0xFF, 0x39}, // Enable SMM A-Seg, MSI and Io APIC - ///// SPI-BAR. - //// SPI_BASE_ADDRESS = 0xFED1 0000 - {0x00, 0xFF, SB_LPC_REG(0xBC), 0xFF, 0x00}, - {0x00, 0xFF, SB_LPC_REG(0xBD), 0xFF, 0xD1}, - {0x00, 0xFF, SB_LPC_REG(0xBE), 0xFF, 0xFE}, -// {0x00, 0xFF, ((0x11<<16)|(0x00<<8)|0xBC), 0xFF, 0x00},//this , for the different macro -// {0x00, 0xFF, ((0x11<<16)|(0x00<<8)|0xBD), 0xFF, 0xD1}, -// {0x00, 0xFF, ((0x11<<16)|(0x00<<8)|0xBE), 0xFF, 0xFE}, - ///// End of 2008-04-17 - - {0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // End of Table -}; - -static const struct VIA_PCI_REG_INIT_TABLE mNbStage2InitTable[] = { - // D0F0: AGP Feature. For 3353, No AGP Feature - - // D0F2~D0F3 is configured by MemoryInit Peim - - // D0F4: NB PMU - { 0x00, 0xFF, NB_PMU_REG(0x84), 0x00, 0xDB }, - { 0x00, 0xFF, NB_PMU_REG(0x85), 0x00, 0x05 }, - { 0x00, 0xFF, NB_PMU_REG(0x89), 0x00, 0xF8 }, - { 0x00, 0xFF, NB_PMU_REG(0x8B), 0x00, 0xBF }, - { 0x00, 0xFF, NB_PMU_REG(0x8D), 0x00, 0xFC }, - { 0x00, 0xFF, NB_PMU_REG(0x8E), 0x00, 0x19 }, - { 0x00, 0xFF, NB_PMU_REG(0x8F), 0x03, 0x00 }, - { 0x00, 0xFF, NB_PMU_REG(0x90), 0x00, 0xFF }, - { 0x00, 0xFF, NB_PMU_REG(0x91), 0x00, 0xFF }, - { 0x00, 0xFF, NB_PMU_REG(0x92), 0x00, 0xCC }, - { 0x00, 0xFF, NB_PMU_REG(0xA0), 0x00, 0x80 }, - { 0x00, 0xFF, NB_PMU_REG(0xA1), 0x00, 0xE0 }, - { 0x00, 0xFF, NB_PMU_REG(0xA2), 0x00, 0xD6 }, - { 0x00, 0xFF, NB_PMU_REG(0xA3), 0x00, 0x80 }, - { 0x00, 0xFF, NB_PMU_REG(0xA8), 0x00, 0x20 }, - - // D0F5: NB APIC, PXPTRF and MSGC - //Note: the Rx6A, RCRBH Base Address, is not set, which is related to PCIE Root Complex. - //Note: the Rx60, Extended CFG Address. Support and Rx61, Extended CFG Address, are set by NB Peim that is in the PEI Phase. - //Note: the Rx42, APIC Interrupt((BT_INTR)) Control, is set by NB Peim that is in PEI phase. - { 0x00, 0xFF, NB_PXPTRF_REG(0x50), 0x00, 0x00 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x54), 0x00, 0x80 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x55), 0x00, 0x04 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x58), 0x00, 0x00 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x59), 0x00, 0x02 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x5E), 0x00, 0x00 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x5F), 0x00, 0x06 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x80), 0x00, 0x18 }, //Set RVC1DM, RTHBHIT, RUWRDYD, RUPRRDY1, RUWPOPHD to 1. - { 0x00, 0xFF, NB_PXPTRF_REG(0x82), 0x00, 0x00 }, //Set RVC1RPSW, RVC1RQ1T to 1. - { 0x00, 0xFF, NB_PXPTRF_REG(0x83), 0x00, 0x81 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x84), 0x00, 0x28 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x85), 0x00, 0xC0 }, - { 0x00, 0xFF, NB_MSGC_REG(0xA3), 0x00, 0x01 }, // RWAKEEN - //{ 0x00, 0xFF, NB_PXPTRF_REG(0x64), 0x40, 0x00 }, //RTDNP2B32EN - { 0x00, 0xFF, NB_PXPTRF_REG(0xF3), 0xFC, 0x20 }, - { 0x00, 0xFF, NB_PXPTRF_REG(0x85), 0x00, 0x00 }, //RP2P1ABORT - - -// fine-tune -// If no settings, C7 will hang or reboot in XP, but CN will not. - { 0x00, 0xFF, NB_HOST_REG(0x51), 0x84, 0x00 }, - { 0x00, 0xFF, NB_HOST_REG(0x52), 0x0F, 0x03 }, - { 0x00, 0xFF, NB_HOST_REG(0x54), 0x04, 0x00 }, - { 0x00, 0xFF, NB_HOST_REG(0x55), 0x04, 0x00 }, - { 0x00, 0xFF, NB_HOST_REG(0x59), 0x09, 0x01 }, - { 0x00, 0xFF, NB_HOST_REG(0x5C), 0x10, 0x10 }, - { 0x00, 0xFF, NB_HOST_REG(0x5F), 0x0E, 0x08 }, - { 0x00, 0xFF, NB_HOST_REG(0x92), 0xFF, 0x04 }, // ACPI Base addr - { 0x00, 0xFF, NB_HOST_REG(0x97), 0x01, 0x01 }, // APIC MSI - { 0x00, 0xFF, NB_HOST_REG(0x99), 0x02, 0x00 }, // APIC MSI - //GTL - { 0x00, 0xFF, NB_HOST_REG(0x73), 0xFF, 0x66 }, - { 0x00, 0xFF, NB_HOST_REG(0xB2), 0xFF, 0x33 }, - { 0x00, 0xFF, NB_HOST_REG(0xB3), 0xFF, 0x33 }, - { 0x00, 0xFF, NB_HOST_REG(0xBC), 0xFF, 0x33 }, - { 0x00, 0xFF, NB_HOST_REG(0xBD), 0xFF, 0x33 }, - { 0x00, 0xFF, NB_HOST_REG(0xC5), 0x30, 0x20 }, - { 0x00, 0xFF, NB_HOST_REG(0xC8), 0x10, 0x00 }, - - - // End of Table - {0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // End of Table -}; - -static const struct VIA_PCI_REG_INIT_TABLE mBusControllerInitTable[] = { - // D17F0: LPC - { 0x00, 0xFF, SB_LPC_REG(0x40), 0x44, 0x44 }, // Enable I/O Recovery Time, 4D0/4D1 Support - { 0x00, 0xFF, SB_LPC_REG(0x42), 0xF8, 0xF0 }, // ENLBUF, GINTREN, FLUSHEN, RBRSTRD - { 0x00, 0xFF, SB_LPC_REG(0x43), 0x0F, 0x0B }, // RENDTX, ENWBTO, ENRBTO - //{ 0x00, 0xFF, SB_LPC_REG(0x46), 0x00, 0x10 }, // It is related to INTH# - //{ 0x00, 0xFF, SB_LPC_REG(0x48), 0x00, 0x0C }, //RMRPW, RIRPW // Reserved in 409 by Eric - - // Internal RTC, Mouse, Keyboard // set in PEI by Eric - //{ 0x00, 0xFF, SB_LPC_REG(0x51), 0x10, 0x0D }, // Enable Internal RTC, Internal PS2 Mouse/Keyboard - - // RTC - { 0x00, 0xFF, SB_LPC_REG(0x58), 0x00, 0x01 }, //RTC Rx32 Map to Centrury Byte - - //{ 0x00, 0xFF, SB_LPC_REG(0x40), 0x00, 0x02 }, // RDMEGAS - //{ 0x00, 0xFF, SB_LPC_REG(0x4E), 0x00, 0x08 }, // Enable RTC port 74/75, ENEXRTC // set in PEI by Eric - - // Serial IRQ // set in PEI by Eric - //{ 0x00, 0xFF, SB_LPC_REG(0x52), 0x0F, 0x09 }, // Enable Serial IRQ, Start Frame Width is 6 PCI Clock. - - // Enable 4D0h/4D1h Port - //{ 0x00, 0xFF, SB_LPC_REG(0x40), 0x00, 0x04 }, // EISAXT // set in PEI by Eric - - // Config ROM Interface - // Enable SPI/Set SPI Memory Base Address - // It is initialized in PEI Phase - - // Subsystem ID/Vendor ID Back Door - { 0x00, 0xFF, SB_LPC_REG(0x70), 0xFF, 0x06 }, - { 0x00, 0xFF, SB_LPC_REG(0x71), 0xFF, 0x11 }, - { 0x00, 0xFF, SB_LPC_REG(0x72), 0xFF, 0x09 }, - { 0x00, 0xFF, SB_LPC_REG(0x73), 0xFF, 0x34 }, - - { 0x00, 0xFF, SB_LPC_REG(0x4C), 0xC0, 0x40 }, - { 0x00, 0xFF, SB_LPC_REG(0x5B), 0x00, 0x51 }, // Orgin value 0x53, modify for 409 by Eric - { 0x00, 0xFF, SB_LPC_REG(0x67), 0x03, 0x01 }, - - - { 0x00, 0xFF, SB_LPC_REG(0x50), 0x7E, 0x00 }, // Setting PCI device enable - { 0x00, 0xFF, SB_LPC_REG(0x51), 0xD0, 0x00 }, // Setting PCI device enable - { 0x00, 0xFF, SB_VLINK_REG(0xD1), 0x04, 0x00 }, // Setting HDAC enable - {0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // End of Table -}; - -static const struct VIA_PCI_REG_INIT_TABLE mPCI1InitTable[] = { - //PCI1 Programming Sequence - //(1)Configure D17F7 - { 0x00, 0xFF, SB_VLINK_REG(0x04), 0x00, 0x03 }, - { 0x00, 0xFF, SB_VLINK_REG(0x0C), 0x00, 0x08 }, // Reserved in 409 by Eric - { 0x00, 0xFF, SB_VLINK_REG(0x4F), 0x40, 0x41 }, //RENPPB, RP2CFLSH - { 0x00, 0xFF, SB_VLINK_REG(0x77), 0x00, 0x48 }, //ROP2CFLSH, RFFTMR[1:0]. ROP2CFLSH work with Rx4F[0](RP2CFLSH) assertion - // { 0x00, 0xFF, SB_VLINK_REG(0x51), 0x00, 0x80 }, //RSUB_DEC_P2P, RSUBDECOD(Window xp). If Bit7 is set, PCI lock will occured. - // { 0x00, 0xFF, SB_VLINK_REG(0x51), 0x00, 0x81 }, //RSUB_DEC_P2P, RSUBDECOD(Window Vista) - //(2)Configure D19F0 - { 0x00, 0xFF, SB_P2PB_REG(0x04), 0x00, 0x07 }, - - //(3)Performance Recommended Setting - - //Save Power - { 0x00, 0xFF, SB_VLINK_REG(0xE2), 0x1F, 0x01 }, - { 0x00, 0xFF, SB_VLINK_REG(0xE3), 0xF1, 0x5E }, - { 0x00, 0xFF, SB_VLINK_REG(0x74), 0x40, 0x00 }, - //Enhence Host To PCI cycle performance and PCI-To-Host Cycle performance - { 0x00, 0xFF, SB_VLINK_REG(0x70), 0x00, 0x82 }, - { 0x00, 0xFF, SB_VLINK_REG(0x71), 0x30, 0xC0 }, - { 0x00, 0xFF, SB_VLINK_REG(0x72), 0x00, 0xEE }, - - //Cycle Control - { 0x00, 0xFF, SB_VLINK_REG(0x73), 0x00, 0x01 }, - { 0x00, 0xFF, SB_VLINK_REG(0x74), 0x00, 0x0C }, - //Arbitration control - { 0x00, 0xFF, SB_VLINK_REG(0x75), 0x00, 0x0F }, - { 0x00, 0xFF, SB_VLINK_REG(0x76), 0x00, 0xD0 }, - {0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // End of Table -}; - -static const struct VIA_PCI_REG_INIT_TABLE mCCAInitTable[] = { - { 0x00, 0xFF, SB_VLINK_REG(0xFC), 0x02, 0x08 }, //RVWREQ, ROABKDOOR - - //CCA's Register Programming sequence - { 0x00, 0xFF, SB_VLINK_REG(0x50), 0x00, 0x08 }, //Config Azalia's upstream cycle high priority and other low priority - { 0x00, 0xFF, SB_VLINK_REG(0x51), 0x40, 0x80 }, //Disable bypass asynchronous circuit - { 0x00, 0xFF, SB_VLINK_REG(0x52), 0x00, 0x11 }, // Set SM Internal Device and HDAC Occupy Timer - { 0x00, 0xFF, SB_VLINK_REG(0x53), 0x00, 0x11 }, // Set SM Internal Device and HDAC Promote Timer - { 0x00, 0xFF, SB_VLINK_REG(0x54), 0xFF, 0x02 }, //Use SB internal devices's original REQ - { 0x00, 0xFF, SB_VLINK_REG(0x73), 0x10, 0x00 }, //RPINOWSC. Enable APIC Cycle Block P2C Write Cycle - { 0x00, 0xFF, SB_VLINK_REG(0x74), 0x00, 0x3C }, //RLCKXP2C, RFSBVK. - { 0x00, 0xFF, SB_VLINK_REG(0xE1), 0x07, 0x00 }, //RBLKAPIC, RAZC3 - { 0x00, 0xFF, SB_VLINK_REG(0x7C), 0x04, 0x02 }, //RNMIFSB, RFSBVK - { 0x00, 0xFF, SB_VLINK_REG(0xE0), 0xF0, 0x90 }, //RCCA_NEWCLK, RCCA_CLKON. Use New dynamic clock scheme - { 0x00, 0xFF, SB_VLINK_REG(0xE7), 0xFF, 0x00 }, //Let CCA use dynamic clock. - //The CCA is also relate to D17F0 - //{ 0x00, 0xFF, SB_LPC_REG(0x49), 0x1F, 0x00 }, //Disable CCA Test Mode - { 0x00, 0xFF, SB_LPC_REG(0x74), 0xFF, 0x00 }, // Let DMA cycles from internal devices directly go to NB // Reserved in 409 by Eric - {0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // End of Table -}; - -static const struct VIA_PCI_REG_INIT_TABLE IDEC_INIT[] = { - //{0x00, 0xFF, SB_IDEC_REG(0x09), 0x00, 0x05}, //set to native mode - {0x00, 0xFF, SB_IDEC_REG(0x04), 0x00, 0x07}, - //{0x00, 0xFF, SB_VLINK_REG(0x7C), 0x00, 0x7F}, - {0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // End of Table -}; - -static const struct VIA_PCI_REG_INIT_TABLE mSbApicInitTable[] = { - { 0x00, 0xFF, SB_LPC_REG(0x4D), 0x04, 0x00 }, - { 0x00, 0xFF, SB_LPC_REG(0x5B), 0x0E, 0x00 }, - { 0x00, 0xFF, SB_LPC_REG(0x6C), 0x08, 0x00 }, - { 0x00, 0xFF, SB_LPC_REG(0x58), 0x00, 0x40 }, - { 0x00, 0xFF, SB_VLINK_REG(0x74), 0x00, 0x04 }, - //{ 0x00, 0xFF, SB_VLINK_REG(0x7C), 0x00, 0x7F }, - { 0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // End of Table -}; - -void AcpiInit(void) -{ - device_t_raw rawdevice = 0; - u8 sbchiprev; - rawdevice = PCI_RAWDEV(0, 0x11, 0); - // Set the PMIO base io address - pci_rawmodify_config16(rawdevice, 0x88, VX800_ACPI_IO_BASE, - 0xff80); - // Enable PMIO - pci_rawmodify_config16(rawdevice, 0x80, 0x8000, 0x8000); - // Enable Soft Resume - outw(inw(VX800_ACPI_IO_BASE + 0x04) | 0x8000, - VX800_ACPI_IO_BASE + 0x04); - - // Get SB Revision - sbchiprev = pci_rawread_config8(rawdevice, 0xf6); - printk(BIOS_DEBUG, "SB chip revision =%x\n", sbchiprev); - - // Fill Register Table - via_pci_inittable(sbchiprev, mSbStage1InitTbl); - - // Close all SMI/Io Traps - outb(0x00, VX800_ACPI_IO_BASE + 0x42); -} - -void Stage2NbInit(void) -{ - device_t_raw rawdevice = 0; - u8 nbchiprev; - u32 subid = 0; - rawdevice = PCI_RAWDEV(0, 0, 4); - nbchiprev = pci_rawread_config8(rawdevice, 0xf6); - printk(BIOS_DEBUG, "NB chip revision =%x\n", nbchiprev); - - via_pci_inittable(nbchiprev, mNbStage2InitTable); - - rawdevice = PCI_RAWDEV(0, 0, 0); - - subid = PCI_DEVICE_ID_VIA_VX855_D0F0 << 16 + PCI_VENDOR_ID_VIA; - pci_rawwrite_config32(rawdevice, 0x2C, subid); - - //vx855 NB no pcie bus - //vx855 NB no apic -} - -void IDECSupportOption(u8 sbchiprev) -{ - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, 0, 0x08); - - pci_rawmodify_config8(PCI_RAWDEV(0, 0xf, 0), 0x45, 0x00, 0x80); - pci_rawmodify_config8(PCI_RAWDEV(0, 0xf, 0), 0x0A, 0x01, 0xFF); - pci_rawmodify_config8(PCI_RAWDEV(0, 0xf, 0), 0x45, 0x80, 0x00); - pci_rawmodify_config8(PCI_RAWDEV(0, 0xf, 0), 0x40, 0x02, 0x00); - - pci_rawmodify_config8(PCI_RAWDEV(0, 0xf, 0), 0x09, 0x00, 0x05); //COMPATIBLE MODE -// pci_rawmodify_config8(PCI_RAWDEV(0, 0xf, 0), 0x09, 0x05, 0x05);//native MODE - - via_pci_inittable(sbchiprev, IDEC_INIT); -} - -void InitIDEC(u8 sbchiprev) -{ - IDECSupportOption(sbchiprev); -} - -void InitUHCI(u8 Number, u8 bEnable) -{ - u8 Mask, Value; - u16 D16; - u8 BaseAddress; - u8 BitShift; - // USB Device 16 - // Function : Number - // 0 : 0 - // 1 : 1 - // 2 : 2 - // The BitShift is got from Datasheet. - - switch (Number) { - case 0: - BaseAddress = 0; - BitShift = 4; - break; - case 1: - BaseAddress = 1; - BitShift = 5; - break; - case 2: - default: - BaseAddress = 2; - BitShift = 2; - break; - } - - if (bEnable) { - Mask = 0x1 << BitShift; - Value = 0x0; - } else { - Mask = 0x0; - Value = 0x1 << BitShift; - } - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, Value, Mask); - - - if (bEnable) { - D16 = 0; - pci_rawwrite_config16(PCI_RAWDEV(0, 0x10, BaseAddress), - 0x20, D16); - - // Config some Control Register - Mask = 0x00; - Value = 0x12; - - pci_rawmodify_config8(PCI_RAWDEV(0, 0x10, BaseAddress), - 0x41, Value, Mask); - Mask = 0x00; - Value = 0xEB; - pci_rawmodify_config8(PCI_RAWDEV(0, 0x10, BaseAddress), - 0x4B, Value, Mask); - } - return; -} - -static const struct VIA_PCI_REG_INIT_TABLE mEHCIInitTable[] = { - //EHCI - { 0x00, 0xFF, SB_EHCI_REG(0x43), 0x00, 0xC0 }, - { 0x00, 0xFF, SB_EHCI_REG(0x50), 0x00, 0x80 }, - { 0x00, 0xFF, SB_EHCI_REG(0x48), 0x20, 0x9E }, - { 0x00, 0xFF, SB_EHCI_REG(0x49), 0x10, 0x68 }, - { 0x00, 0xFF, SB_EHCI_REG(0x4B), 0x00, 0x69 }, - { 0x00, 0xFF, SB_EHCI_REG(0x4D), 0x00, 0x94 }, - { 0x00, 0xFF, SB_EHCI_REG(0x52), 0x08, 0x00 }, - { 0x00, 0xFF, SB_EHCI_REG(0x5A), 0x00, 0x8A }, - { 0x00, 0xFF, SB_EHCI_REG(0x5B), 0x00, 0x89 }, - { 0x00, 0xFF, SB_EHCI_REG(0x5C), 0x00, 0x03 }, - { 0x00, 0xFF, SB_EHCI_REG(0x5D), 0x00, 0x9A }, - { 0x00, 0xFF, SB_EHCI_REG(0x5E), 0x00, 0x00 }, - { 0x00, 0xFF, SB_EHCI_REG(0x6B), 0x00, 0x00 }, - { 0x00, 0xFF, SB_EHCI_REG(0x6D), 0x00, 0x00 }, - { 0x00, 0xFF, SB_EHCI_REG(0x6F), 0xF0, 0x00 }, - { 0x00, 0xFF, SB_EHCI_REG(0x4E), 0x01, 0x01 }, - { 0x00, 0xFF, SB_EHCI_REG(0x4F), 0x00, 0x11 }, - { 0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // End of Table -}; - -void InitEHCI(u8 Number, u8 bEnable) -{ - u8 Mask, Value; - u8 EHCIRevision; - - if (bEnable) { - Mask = 0x1 << 1; - Value = 0x0; - } else { - Mask = 0x0; - Value = 0x1 << 1; - } - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, Value, Mask); - - - if (bEnable) { - // Get Chipset Revision - EHCIRevision = - pci_rawread_config8(PCI_RAWDEV(0, 0x10, 4), 0xF6); - printk(BIOS_DEBUG, "EHCI Revision =%x\n", EHCIRevision); - via_pci_inittable(EHCIRevision, mEHCIInitTable); - } -} - -#define TRUE 1 -void InitUSBC(u8 sbchiprev) -{ - InitUHCI(0, TRUE); - InitUHCI(1, TRUE); - InitUHCI(2, TRUE); - InitEHCI(0, TRUE); -} - -void WriteSbApicIndexedReg(u8 Idx, u32 Data) -{ - u32 Data32; - u32 ApicIdxAdr = VX800SB_APIC_BASE; - u32 ApicDataAdr = VX800SB_APIC_BASE + VX800SB_APIC_DATA_OFFSET; - *((u8 *) ApicIdxAdr) = Idx; - Data32 = (*((u32 *) ApicDataAdr)); //this read is needed when write APIC ID ,dont know why. - Data32 = Data; - *((u32 *) ApicDataAdr) = Data32; -} - -void SbApicMmioRegInit(void) -{ - u32 Offset; - WriteSbApicIndexedReg(3, 1); - WriteSbApicIndexedReg(0, 4); - for (Offset = 0x10; Offset < VX800SB_APIC_ENTRY_NUMBER; - Offset += 2) { - WriteSbApicIndexedReg(Offset + 1, 0); - WriteSbApicIndexedReg(Offset, 0x10000); - } -} - -void SbApicInit(u8 sbchiprev) -{ - via_pci_inittable(sbchiprev, mSbApicInitTable); - SbApicMmioRegInit(); -} - -void SbAcpiInit(void) -{ - u8 Mask, Value; - // Enable ACPI - Mask = 0x01; - Value = 0x01; - io_rawmodify_config8(VX800_ACPI_IO_BASE + 0x04, Value, Mask); -} - -#define HPET_ENABLE_BIT 0x80 -#define R_SB_HPET_CONTROL 0x68 -#define HPET_BASE_ADDRESS 0xFED0 // 0xFED00000 -#define R_SB_HPET_ADDRESS 0x69 - -void HpetInit(void) -{ - u8 HpetEnable = HPET_ENABLE_BIT; - u16 HpetBase = HPET_BASE_ADDRESS; - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), R_SB_HPET_CONTROL, - HpetEnable); - pci_rawwrite_config16(PCI_RAWDEV(0, 0x11, 0), - R_SB_HPET_ADDRESS + 1, HpetBase); -} - -static const struct VIA_PCI_REG_INIT_TABLE mPMUInitTable[] = { - // Power Management - { 0x00, 0xFF, SB_LPC_REG(0x80), 0x00, 0x20 }, - { 0x00, 0xFF, SB_LPC_REG(0x8C), 0x02, 0x00 }, - { 0x00, 0xFF, SB_LPC_REG(0x8D), 0x00, 0x18 }, - - //Miscellaneous Configuration 1 - { 0x00, 0xFF, SB_LPC_REG(0x94), 0xF0, 0x28 }, - { 0x00, 0xFF, SB_LPC_REG(0x95), 0x00, 0xC1 }, - { 0x00, 0xFF, SB_LPC_REG(0x96), 0xFF, 0x10 }, - { 0x00, 0xFF, SB_LPC_REG(0x97), 0x00, 0xB2 }, - - //Voltage Change Function Enable - { 0x00, 0xFF, SB_LPC_REG(0x9F), 0x00, 0x21 }, - //Internal PCIe and NM PLL Control - { 0x00, 0xFF, SB_LPC_REG(0xE2), 0x00, 0xEA }, - - { 0x00, 0xFF, SB_LPC_REG(0xE7), 0x00, 0x80 }, - { 0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // End of Table -}; - -void InitPMU(u8 sbchiprev) -{ - u8 Mask, Value; - // Set PMU Registers - via_pci_inittable(sbchiprev, mPMUInitTable); - - - // Set SCI IRQ and its level trigger - Mask = 0x0F; - Value = 0x09; - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x82, Value, Mask); - - Mask = 0x02; - Value = 0x02; - io_rawmodify_config8(0x4d1, Value, Mask); -} - -#define R_SB_MULTI_FUNCTION_SELECT_1 0xE4 -#define R_SB_CX_STATE_BREAK_EVENT_ENABLE_1 0xE6 -#define PMIO_PROCESSOR_CONTROL 0x26 -#define R_SB_PCI_ARBITRATION_2 0x76 -#define R_SB_AUTO_SWITCH_P_STATE 0x8A - -void InitCPUCStatueSupport() -{ - u8 Mask, Value; - - // Config Cx State - // Now it is C2 & C4 Up Down Mode - Mask = 0xFF; - Value = 0x30; - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), R_SB_CX_STATE_BREAK_EVENT_ENABLE_1, Value, Mask); //SB_LPC_REG - - Mask = 0xFF; - Value = 0x1F; - io_rawmodify_config8(VX800_ACPI_IO_BASE + PMIO_PROCESSOR_CONTROL, - Value, Mask); - - Mask = 0x00; - Value = 0x80; - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 7), R_SB_PCI_ARBITRATION_2, Value, Mask); //SB_VLINK_REG - - Mask = 0xFF; - Value = 0x00; - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), R_SB_MULTI_FUNCTION_SELECT_1, Value, Mask); //SB_VLINK_REG - - Mask = 0xFF; - Value = 0x1F; - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), R_SB_AUTO_SWITCH_P_STATE, Value, Mask); //SB_VLINK_REG -} - -void InitSBPM(u8 sbchiprev) -{ - InitPMU(sbchiprev); - SbAcpiInit(); - InitCPUCStatueSupport(); -} - -void Stage2SbInit(void) -{ - device_t_raw rawdevice = 0; - u8 sbchiprev; - - rawdevice = PCI_RAWDEV(0, 11, 0); - sbchiprev = pci_rawread_config8(rawdevice, 0xf6); - printk(BIOS_DEBUG, "SB chip revision =%x\n", sbchiprev); - - //SBBasicInit - via_pci_inittable(sbchiprev, mBusControllerInitTable); - via_pci_inittable(sbchiprev, mPCI1InitTable); - via_pci_inittable(sbchiprev, mCCAInitTable); - - - InitIDEC(sbchiprev); - - InitUSBC(sbchiprev); - - InitSBPM(sbchiprev); - - SbApicInit(sbchiprev); - - HpetInit(); - - //pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, 0x76, 0);//SB_VLINK_REG - -} - -void init_VIA_chipset(void) -{ - printk(BIOS_DEBUG, "In: init_VIA_chipset\n"); - //1.nbstage1 is done in raminit. - //2.sbstage1 - AcpiInit(); - //3.nbstage2 - Stage2NbInit(); - - //4.sbstage2 - Stage2SbInit(); - - //5.open hdac - pci_rawmodify_config32(PCI_RAWDEV(0, 0x11, 7), 0xd1, 0, 0x04); - printk(BIOS_DEBUG, "End: init_VIA_chipset\n"); -} - -/** - * @brief Main function of the DRAM part of coreboot. - * - * Coreboot is divided into Pre-DRAM part and DRAM part. - * - * - * Device Enumeration: - * In the dev_enumerate() phase, - */ - -void main(void) -{ - struct lb_memory *lb_mem; -#if CONFIG_HAVE_ACPI_RESUME - void *wake_vec; -#endif - - u16 tmp; - tmp = inw(VX800_ACPI_IO_BASE + 0x04); - acpi_sleep_type = ((tmp & (7 << 10)) >> 10) == 1 ? 3 : 0; - - u8 y, x; - init_VIA_chipset(); - printk(BIOS_EMERG, "file '%s', line %d\n\n", __FILE__, __LINE__); - -#if 0 - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 4), 0xa3, 0x80); - pci_rawwrite_config8(PCI_RAWDEV(0, 17, 7), 0x60, 0x20); - pci_rawwrite_config8(PCI_RAWDEV(0, 17, 7), 0xE5, - pci_rawread_config8(PCI_RAWDEV(0, 3, 0), - 0x88)); -#endif - - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x51, 0x40, 0x40); //close CE-ATA (Consumer Electronics-ATA) and NFC - - //pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, 0x0, 0x40);//open USB Device Mode Enable - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, 0x40, 0x40); //close USB Device Mode - - //pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, 0x04, 0x04);//close USB 1.1 UHCI Port 4-5 - //pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, 0x02, 0x02);//close USB 2.0 ehci - - - //pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, 0x00, 0x76);//open all usb and usb mode - //pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x50, 0x76, 0x76);//close all usb - - printk(BIOS_INFO, "=================SB 50h=%02x \n", - pci_rawread_config8(PCI_RAWDEV(0, 0x11, 0), 0x50)); - - /* FIXME: Is there a better way to handle this? */ - init_timer(); - printk(BIOS_EMERG, "file '%s', line %d\n\n", __FILE__, __LINE__); - - /* Find the devices we don't have hard coded knowledge about. */ - dev_enumerate(); - printk(BIOS_EMERG, "file '%s', line %d\n\n", __FILE__, __LINE__); -#if 0 - x = y = 0; - printk(BIOS_INFO, "dump ehci3 \n"); - for (; x < 16; x++) { - y = 0; - for (; y < 16; y++) { - printk(BIOS_INFO, "%02x ", - pci_rawread_config8(PCI_RAWDEV - (0, 0x10, 4), - x * 16 + y)); - } - printk(BIOS_INFO, "\n"); - } -#endif - - post_code(0x66); - /* Now compute and assign the bus resources. */ - dev_configure(); - printk(BIOS_EMERG, "file '%s', line %d\n\n", __FILE__, __LINE__); -#if 0 - x = y = 0; - printk(BIOS_INFO, "dump ehci3 \n"); - for (; x < 16; x++) { - y = 0; - for (; y < 16; y++) { - printk(BIOS_INFO, "%02x ", - pci_rawread_config8(PCI_RAWDEV (0, 0x10, 4), x * 16 + y)); - } - printk(BIOS_INFO, "\n"); - } -#endif - - post_code(0x88); - /* Now actually enable devices on the bus */ - dev_enable(); - printk(BIOS_EMERG, "file '%s', line %d\n\n", __FILE__, __LINE__); - /* And of course initialize devices on the bus */ -#if 0 - x = y = 0; - printk(BIOS_INFO, "dump ehci3 \n"); - for (; x < 16; x++) { - y = 0; - for (; y < 16; y++) { - printk(BIOS_INFO, "%02x ", - pci_rawread_config8(PCI_RAWDEV (0, 0x10, 4), x * 16 + y)); - } - printk(BIOS_INFO, "\n"); - } -#endif - - dev_initialize(); - post_code(0x89); - printk(BIOS_EMERG, "file '%s', line %d\n\n", __FILE__, __LINE__); - -// pci_rawwrite_config16(PCI_RAWDEV(0, 0xf, 0), 0xBA, 0x0571); - -#if 0 - x = y = 0; - printk(BIOS_INFO, "dump ehci3 \n"); - for (; x < 16; x++) { - y = 0; - for (; y < 16; y++) { - printk(BIOS_INFO, "%02x ", - pci_rawread_config8(PCI_RAWDEV (0, 0x10, 4), x * 16 + y)); - } - printk(BIOS_INFO, "\n"); - } -#endif - -#if 0 - y = pci_rawread_config8(PCI_RAWDEV(0, 0xf, 0), 0x0d); - y &= 0x0f; - y |= 0x40; - pci_rawwrite_config8(PCI_RAWDEV(0, 0xf, 0), 0x0d, y); -#endif - -#if 0 - static const d0f0pcitable[5] = { 0xD0, 0, 0, 0, 0xFD }; - static const d0f2pcitable[16 * 7 + 1] = { - 0x88, 0xF8, 0xEF, 0x44, 0x7C, 0x24, 0x63, 0x01, 0x00, 0x09, - 0x00, 0x00, 0x10, 0xA2, 0x88, 0xCE, - 0xFF, 0x0F, 0x00, 0xAA, 0x0A, 0x00, 0x00, 0x00, 0x01, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0xCC, 0x66, 0xAA, 0x55, 0x30, 0x38, 0x0C, 0x00, 0x00, 0x00, - 0x00, 0x22, 0x00, 0xAA, 0x00, 0x00, - 0x44, 0x44, 0x55, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x0B, 0x00, 0x08, 0x00, 0x00, 0x00, 0x0A, 0x01, 0x41, 0x06, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x88, 0x56, 0x70, 0x77, 0x77, 0x07, 0x77, 0x77, 0x04, - 0x77, 0x77, 0x77, 0x77, 0x77, 0x77, - 0x77, 0x77, 0x33, 0x33, 0x77, 0x77, 0x77, 0x77, 0x77, 0x77, - 0x77, 0x77, 0x44, 0x44, 0x14, 0x00, - 0x75 - }; - - static const d0f4pcitable[16 * 6 + 3] = { - 0x30, 0x00, 0x00, - 0xFF, 0xFF, 0xCC, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x80, 0xE0, 0xD6, 0x80, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x01, 0x02, 0x03, 0x04, 0x04, 0x00, 0x00, 0x04, 0x04, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x12, 0x12, 0x00, 0x00, 0x08, 0xF4, - 0x01, 0x01, 0x79, 0x79, 0x0A, 0x00, - }; - static const d0f5pcitable[16 * 10] = { - 0x13, 0x0E, 0x00, 0x00, 0xD2, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x18, 0x9A, 0x00, 0x81, 0x28, 0xC0, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x40, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x26, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - }; - - static const d0f7pcitable[16 * 9] = { - 0x00, 0x2A, 0x00, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x29, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - }; - static const d1f0pcitable[3] = { - 0x01, 0x80, 0x40 - }; - - static const dcf0pcitable[96] = { - 0x10, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x01, 0x00, 0xC2, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, - 0x40, 0x01, 0x03, 0x01, 0x7E, 0x01, - 0x08, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF9, - 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, - }; - - static const d10f4pcitable[48] = { - 0x00, 0x20, 0x43, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x9E, 0x68, - 0x00, 0x09, 0x13, 0x94, 0x03, 0x10, - 0x80, 0x60, 0x11, 0xBF, 0x00, 0xFF, 0x0F, 0x00, 0x04, 0x0B, - 0xCC, 0xCC, 0x00, 0xCC, 0x00, 0x00, - 0x20, 0x20, 0x01, 0x00, 0x05, 0x00, 0x00, 0x00, 0x01, 0x00, - 0x00, 0x00, 0x00, 0x20, 0x00, 0xC0, - }; - - static const d11f0pcitable[16 * 12] = { - 0x44, 0x40, 0xF0, 0x0B, 0x00, 0x00, 0x00, 0x03, 0x00, 0x20, - 0x00, 0x00, 0x04, 0x00, 0x08, 0x00, - 0xC1, 0x4D, 0x19, 0x80, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, - 0x00, 0x51, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x80, 0x00, - 0xD0, 0xFE, 0x00, 0x00, 0x00, 0x00, - 0x06, 0x11, 0x09, 0x84, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, - 0x20, 0x84, 0x49, 0x00, 0x88, 0x00, 0x00, 0x00, 0x01, 0x08, - 0x1F, 0x00, 0x07, 0x1A, 0x00, 0x00, - 0x00, 0x6E, 0xBC, 0x88, 0x28, 0xC1, 0x10, 0x80, 0x00, 0x80, - 0x20, 0x88, 0x00, 0x00, 0x00, 0xAD, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, - 0x00, 0x00, 0x10, 0xD0, 0xFE, 0x90, - 0x01, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x01, 0x04, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0xE7, 0x03, 0xA0, 0x60, 0x20, 0xC0, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, - }; - - static const d11f7pcitable[192] = { - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x80, 0x43, - 0x08, 0x80, 0x11, 0x11, 0x02, 0x0F, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x80, 0x00, 0x00, 0x20, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, - 0x82, 0xC8, 0xEE, 0x01, 0x0C, 0x0F, 0xD0, 0x48, 0x00, 0x00, - 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, - 0x07, 0x00, 0x21, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x93, 0x08, 0x00, 0x5E, 0x00, 0x80, 0x29, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x48, 0x00, 0x00, 0x00, - }; - -#define OPTION_1 1 -#define NOOPTION_1 1 -#ifdef OPTION_1 - static const OPTION_1_d11f0pcitable[16 * 12] = { - 0x44, 0x80, 0xf0, 0x0b, 0x00, 0x00, 0x00, 0x03, 0x00, 0x20, - 0x00, 0x00, 0x04, 0x01, 0x08, 0x00, - 0xc0, 0x4d, 0x19, 0x80, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, - 0x00, 0x53, 0x00, 0xfe, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x04, 0x80, 0x00, - 0xd0, 0xfe, 0x00, 0x00, 0xdf, 0x00, - 0x06, 0x11, 0x53, 0x83, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x20, 0x84, 0x4a, 0x00, 0xda, 0x40, 0x00, 0x00, 0x01, 0x40, - 0x1f, 0x00, 0x07, 0x18, 0x00, 0x00, - 0x00, 0x2e, 0xbc, 0x00, 0x28, 0xc1, 0x10, 0x80, 0x00, 0x80, - 0x08, 0x88, 0x00, 0x00, 0x00, 0xad, - 0x06, 0x11, 0x53, 0x83, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x00, 0x40, 0x80, 0x40, - 0x00, 0x00, 0x00, 0xd3, 0xfe, 0x53, - 0x01, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x01, 0x41, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0xeb, 0x03, 0xa0, 0x60, 0x20, 0x80, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, - }; -#endif - - u8 i; -/* error form ---- but add the chance to resume - for(i=0;i<5;i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 0), i, d0f0pcitable[i+0xcb]); - } -*/ - -/* RO reg - for(i=0;i<5;i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 0), i+0xcb, d0f0pcitable[i]); - } -*/ - -//boot ok, resume still err in linux -#if 1 - for (i = 0; i < 9; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 2), i + 0x50, - d0f2pcitable[i]); - } - //9 is warm reset reg, // boot err in coreboot - for (i = 10; i < 64; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 2), i + 0x50, - d0f2pcitable[i]); - } - //0x90 look d0f2 appendixA1 , if set this to 09 or 0b, then some ddr2 will crash. - for (i = 65; i < 113; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 2), i + 0x50, - d0f2pcitable[i]); - } -#endif -#ifdef OPTION_1 - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 2), 0x66, 0x09); - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 2), 0x70, 0xdd); - // pci_rawwrite_config8(PCI_RAWDEV(0, 0, 2), 0x90, 0x09); - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 2), 0x92, 0x40); - -#endif - - - -#if 1 - - -//d0f3 -/* */ - // pci_rawwrite_config8(PCI_RAWDEV(0, 0, 3), 0x86, 0x3b); setting, my lspci is 0x29 - //set bit4 cause the ide not be found -// pci_rawwrite_config8(PCI_RAWDEV(0, 0, 3), 0x86, 0x2b); - //set bit1 cause the ide not be found - -// pci_rawwrite_config8(PCI_RAWDEV(0, 0, 3), 0x86, 0x29); - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 3), 0x95, 0x05); - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 3), 0x99, 0x12); - - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 3), 0xde, 0x00); -#endif - -//boot ok, resume err in coreboot -#if 1 - for (i = 0; i < 99; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 4), i + 0x8d, - d0f4pcitable[i]); - } -#endif - -#ifdef OPTION_1 - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 4), 0xe9, 0x90); - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 4), 0xec, 0x0); - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 4), 0xed, 0x0); - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 4), 0xee, 0x0); -#endif - - -#if 1 -//boot ok, resume still err in linux - for (i = 0; i < 160; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 5), i + 0x60, - d0f5pcitable[i]); - } - for (i = 0; i < 144; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 7), i + 0x60, - d0f7pcitable[i]); - } - for (i = 0; i < 3; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 1, 0), i + 0xb0, - d1f0pcitable[i]); - } - for (i = 0; i < 96; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0xc, 0), i + 0x40, - dcf0pcitable[i]); - } -#endif - -#ifdef OPTION_1 - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 7), 0x61, 0x0); - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 7), 0x63, 0x0); - pci_rawwrite_config8(PCI_RAWDEV(0, 0, 7), 0x76, 0xd0); - pci_rawwrite_config8(PCI_RAWDEV(0, 0xc, 0), 0x88, 0x81); - pci_rawwrite_config8(PCI_RAWDEV(0, 0xc, 0), 0x89, 0x01); - pci_rawwrite_config8(PCI_RAWDEV(0, 0xc, 0), 0x8A, 0x60); -#endif - -//d15f0 - -#if 1 - pci_rawwrite_config8(PCI_RAWDEV(0, 0x10, 0), 0x4a, 0xa2); // no affect. - pci_rawwrite_config8(PCI_RAWDEV(0, 0x10, 1), 0x4a, 0xa2); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x10, 2), 0x4a, 0xa2); - -//boot ok, resume still err in linux, and if disable USB, then all ok -// for(i=0;i<48;i++){ - for (i = 0; i < 44; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0x10, 4), i + 0x40, - d10f4pcitable[i]); - } -#endif - -//#ifdef NOOPTION_1 -#if 0 - pci_rawwrite_config8(PCI_RAWDEV(0, 0x10, 4), 0x6b, 0x01); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x10, 4), 0x6d, 0x00); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x10, 4), 0x6e, 0x08); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x10, 4), 0x6f, 0x80); -#endif - -#if 1 -//before (11.0)is add, s3 resume has already always dead in first resume(more frequenly), and sleep ok -// for(i=0;i<192;i++){ - for (i = 0; i < 6; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - //6 is uart and dvp vcp, will have // HAVE no com1 ,and no gui show,textmode ok ,s3 sleep ok, resume fail - - //7-18 is my familar part - for (i = 7; i < 18; i++) { //sleep ok ,resume sleep err 2 - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - - for (i = 18; i < 21; i++) { //sleep ok , sleep err 1, resume - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - //0x55 56 57 irq intA#B#C# linkA#linkB#linkC# - for (i = 24; i < 27; i++) { //sleep ok , resume sleep err 1 resume 1 - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - //5b port 80h - pci_rawmodify_config8(PCI_RAWDEV(0, 0x11, 0), 0x5b, 0x0, 0x08); - // i++; - // pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i+0x40, d11f0pcitable[i]); - - for (i = 28; i < 72; i++) { //sleep ok , resume sleep err 1 , resume 1ci - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - //7273ACPI BASE - - for (i = 74; i < 112; i++) { //boot ok, resume still err in linux - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - - //B0B4B5 dvp vcp, if copy this ,then no uart, no gui(of unbuntu) - // pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), 0xb0, d11f0pcitable[112]); - i = pci_rawread_config8(PCI_RAWDEV(0, 17, 0), 0xB0); - //multiplex with VCP - // i = i | 0x30; - i = i & 0xf7; - pci_rawwrite_config8(PCI_RAWDEV(0, 17, 0), 0xB0, i); - - - - for (i = 113; i < 114; i++) { //boot ok, resume still err in linux - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - - for (i = 115; i < 116; i++) { //boot ok, resume still err in linux - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - - - for (i = 118; i < 192; i++) { //boot ok, resume still err in linux - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } -#endif -#ifdef NOOPTION_1 -// for(i=0;i<192;i++){ - for (i = 0; i < 6; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - OPTION_1_d11f0pcitable[i]); - } - //6 is uart and dvp vcp, will have // HAVE no com1 ,and no gui show,textmode ok ,s3 sleep ok, resume fail - - //7-18 is my familar part - for (i = 7; i < 18; i++) { // sleep err 2 - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - OPTION_1_d11f0pcitable[i]); - } - - for (i = 18; i < 21; i++) { //sleep ok , resume ??? - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - //0x55 56 57 irq intA#B#C# linkA#linkB#linkC# - for (i = 24; i < 27; i++) { //sleep ok , resume ??? - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - d11f0pcitable[i]); - } - //5b port 80h - i++; - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - OPTION_1_d11f0pcitable[i]); - - for (i = 28; i < 72; i++) { //sleep ok , resume??? - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - OPTION_1_d11f0pcitable[i]); - } - //7273ACPI BASE - - for (i = 74; i < 112; i++) { //boot ok, resume still err in linux - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - OPTION_1_d11f0pcitable[i]); - } - - //B0B4B5 dvp vcp, if copy this ,then no uart, no gui(of unbuntu) - // pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), 0xb0, OPTION_1_d11f0pcitable[112]); - i = pci_rawread_config8(PCI_RAWDEV(0, 17, 0), 0xB0); - //multiplex with VCP - // i = i | 0x30; - i = i & 0xf7; - pci_rawwrite_config8(PCI_RAWDEV(0, 17, 0), 0xB0, i); - - - - for (i = 113; i < 114; i++) { //boot ok, resume still err in linux - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - OPTION_1_d11f0pcitable[i]); - } - - for (i = 115; i < 116; i++) { //boot ok, resume still err in linux - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - OPTION_1_d11f0pcitable[i]); - } - - for (i = 118; i < 192; i++) { //boot ok, resume still err in linux - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), i + 0x40, - OPTION_1_d11f0pcitable[i]); - } -#endif - -#if 1 - pci_rawwrite_config16(PCI_RAWDEV(0, 0xf, 0), 0xBA, PCI_DEVICE_ID_VIA_VX855_IDE); //5324 - pci_rawwrite_config16(PCI_RAWDEV(0, 0xf, 0), 0xBE, - PCI_DEVICE_ID_VIA_VX855_IDE); - pci_rawwrite_config16(PCI_RAWDEV(0, 0x11, 0), 0xA0, - PCI_VENDOR_ID_VIA); - pci_rawwrite_config16(PCI_RAWDEV(0, 0x11, 0), 0xA2, PCI_DEVICE_ID_VIA_VX855_LPC); //8353 - i = pci_rawread_config8(PCI_RAWDEV(0, 0x11, 0), 0x79); - i &= ~0x40; - i |= 0x40; - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 0), 0x79, i); - pci_rawwrite_config16(PCI_RAWDEV(0, 0x11, 0), 0x72, - PCI_DEVICE_ID_VIA_VX855_LPC); - -//boot ok, resume still err in linux - for (i = 0; i < 192; i++) { - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 7), i + 0x40, - d11f7pcitable[i]); - } -#endif -#ifdef OPTION_1 - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 7), 0x61, 0x2a); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 7), 0x63, 0xa0); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 7), 0x64, 0xaa); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 7), 0x84, 0x0); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 7), 0x88, 0x02); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x11, 7), 0xe6, 0x3f); -#endif - pci_rawwrite_config8(PCI_RAWDEV(0, 0x14, 0), 0x40, 0x20); - pci_rawwrite_config8(PCI_RAWDEV(0, 0x14, 0), 0x41, 0x31); - -#ifdef OPTION_1 - pci_rawwrite_config8(PCI_RAWDEV(0, 0x14, 0), 0x40, 0x00); -#endif -#endif - - u8 i911; - //disable CHB L.L - //set VGA memory selection - i911 = pci_rawread_config8(PCI_RAWDEV(0, 0x1, 0), 0xb0); - i911 &= 0xF8; - //ByteVal |= 0x03; - i911 |= 0x01; - pci_rawwrite_config8(PCI_RAWDEV(0, 0x1, 0), 0xb0, i911); - -#if 1 - struct device *dev; - printk(BIOS_INFO, "========= dump all devices...\n"); - for (dev = all_devices; dev; dev = dev->next) { - if (dev->path.type == DEVICE_PATH_PCI) { - printk(BIOS_DEBUG, "%s dump\n", dev_path(dev)); - x = y = 0; - for (; x < 16; x++) { - y = 0; - for (; y < 16; y++) { - printk(BIOS_INFO, "%02x ", - pci_read_config8(dev, x * 16 + y)); - } - printk(BIOS_INFO, "\n"); - } - } - printk(BIOS_INFO, "\n"); - } -#endif - //pci_rawmodify_config8(PCI_RAWDEV(0, 0x10, 4), 0x04, 0x17, 0x17);// - //pci_rawmodify_config8(PCI_RAWDEV(0, 0x10, 4), 0x0c, 0x08, 0xff);/// -} diff --git a/src/northbridge/via/vx800/examples/driving_clk_phase_data.c b/src/northbridge/via/vx800/examples/driving_clk_phase_data.c deleted file mode 100644 index c62de6e..0000000 --- a/src/northbridge/via/vx800/examples/driving_clk_phase_data.c +++ /dev/null @@ -1,242 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2009 One Laptop per Child, Association, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - - #include "northbridge/via/vx800/driving_clk_phase_data.h" - -// DQS Driving -//Reg0xE0, 0xE1 -// According to #Bank to set DRAM DQS Driving -// #Bank 1 2 3 4 5 6 7 8 -static const u8 DDR2_DQSA_Driving_Table[4] = { 0xEE, 0xEE, 0xEE, 0xEE}; -static const u8 DDR2_DQSB_Driving_Table[2] = { 0xEE, 0xEE}; - -// DQ Driving -//Reg0xE2, 0xE3 -// For DDR2: According to bank to set DRAM DQ Driving -static const u8 DDR2_DQA_Driving_Table[4] = { 0xAC, 0xAC, 0xAC, 0xAC }; -static const u8 DDR2_DQB_Driving_Table[2] = { 0xCA, 0xCA }; - - -// CS Driving -//Reg0xE4, 0xE5 -// According to #Bank to set DRAM CS Driving -// DDR1 #Bank 1 2 3 4 5 6 7 8 -static const u8 DDR2_CSA_Driving_Table_x8[4] = { 0x44, 0x44, 0x44, 0x44 }; -static const u8 DDR2_CSB_Driving_Table_x8[2] = { 0x44, 0x44}; -static const u8 DDR2_CSA_Driving_Table_x16[4]= { 0x44, 0x44, 0x44, 0x44}; -static const u8 DDR2_CSB_Driving_Table_x16[2]= { 0x44, 0x44}; -// MAA Driving -//Reg0xE8, Reg0xE9 -static const u8 DDR2_MAA_Driving_Table[MA_Table][5] = - { - //Chip number, 400, 533, 667 800 ;(SRAS, SCAS, SWE)RxE8 - { 6, 0x86, 0x86, 0x86, 0x86}, // total MAA chips = 00 ~ 06 - { 18, 0x86, 0x86, 0x86, 0x86}, // total MAA chips = 06 ~ 18 - {255, 0xDB, 0xDB, 0xDB, 0xDB} // total MAA chips = 18 ~ - }; - -static const u8 DDR2_MAB_Driving_Table[MA_Table][2] = - { - // Chip number, Value ;(SRAS, SCAS, SWE)RxE9 - { 6, 0x86 }, // total MAB chips = 00 ~ 06 - { 18, 0x86 }, // total MAB chips = 06 ~ 18 - {255, 0xDB } // total MAB chips = 18 ~ - }; - -// DCLK Driving -//Reg0xE6, 0xE7 -// For DDR2: According to #Freq to set DRAM DCLK Driving -// freq 400M, 533M, 667M, 800M - -static const u8 DDR2_DCLKA_Driving_Table[4] = { 0xFF, 0xFF, 0xFF, 0xFF }; -static const u8 DDR2_DCLKB_Driving_Table[4] = { 0xFF, 0xFF, 0xFF, 0xFF }; - -/* -Duty cycle -Duty cycle Control for DQ/DQS/DDRCKG in ChA & ChB -D0F3RxEC/D0F3RxED/D0F3RxEE/D0F3RxEF -According to DRAM frequency to control Duty Cycle -*/ -static const u8 ChA_Duty_Control_DDR2[DUTY_CYCLE_REG_NUM][DUTY_CYCLE_FREQ_NUM] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0xEC, 0x00, 0x30, 0x30, 0x30, 0x30 }, // 1Rank - {0xEE, 0x0F, 0x40, 0x40, 0x00, 0x00 }, - {0xEF, 0xCF, 0x00, 0x30, 0x30, 0x30} - }; - -static const u8 ChB_Duty_Control_DDR2[DUTY_CYCLE_REG_NUM][DUTY_CYCLE_FREQ_NUM] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0xED, 0x00, 0x88, 0x88, 0x84, 0x88 }, // 1Rank - {0xEE, 0xF0, 0x00, 0x00, 0x00, 0x00 }, - {0xEF, 0xFC, 0x00, 0x00, 0x00, 0x00 } - }; - - -/* -DRAM Clock Phase Control for FeedBack Mode -Modify NB Reg: Rx90[7]/Rx91/Rx92/Rx93/Rx94 -Processing: - 1.Program VIA_NB3DRAM_REG90[7]=0b for FeedBack mode - 2.Program clock phase value with ChA/B DCLK enable, VIA_NB3DRAM_REG91[7:3]=00b - 3.Check ChB rank #, if 0, VIA_NB3DRAM_REG91[7]=1b, to disable ChB DCLKO - ChA DCLKO can not be disable, so always program VIA_NB3DRAM_REG91[3]=0b - */ -static const u8 DDR2_ChA_Clk_Phase_Table_1R[3][Clk_Phase_Table_DDR2_Width] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x91, 0xF8, 0x02, 0x01, 0x00, 0x07 }, // 1Rank - {0x92, 0xF8, 0x04, 0x03, 0x03, 0x02 }, - {0x93, 0xF8, 0x06, 0x05, 0x04, 0x03 } - }; - -static const u8 DDR2_ChB_Clk_Phase_Table_1R[3][Clk_Phase_Table_DDR2_Width] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x91, 0x0F, 0x20, 0x10, 0x00, 0x70 }, // 1Rank - {0x92, 0x0F, 0x40, 0x30, 0x30, 0x20 }, - {0x93, 0x0F, 0x60, 0x50, 0x40, 0x30 } - }; - -/*static const u8 DDR2_ChA_Clk_Phase_Table_2R[3][Clk_Phase_Table_DDR2_Width] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x91, 0xF8, 0x04, 0x03, 0x04, 0x01 }, // 1Rank - {0x92, 0xF8, 0x03, 0x06, 0x05, 0x04 }, - {0x93, 0xF8, 0x03, 0x07, 0x06, 0x05 } - };*/ - -static const u8 DDR2_ChA_Clk_Phase_Table_2R[3][Clk_Phase_Table_DDR2_Width] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x91, 0xF8, 0x02, 0x01, 0x00, 0x07}, // 1Rank - {0x92, 0xF8, 0x04, 0x03, 0x03, 0x02 }, - {0x93, 0xF8, 0x06, 0x05, 0x04, 0x03 } - }; - -/* -DRAM Write Data phase control -Modify NB Reg: Rx74/Rx75/Rx76 -*/ -/*static const u8 DDR2_ChA_WrtData_Phase_Table[WrtData_REG_NUM ][WrtData_FREQ_NUM] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x74, 0xF8, 0x03, 0x04, 0x05, 0x02 }, // 1Rank - {0x75, 0xF8, 0x03, 0x04, 0x05, 0x02 }, - {0x76, 0x00, 0x10, 0x80, 0x00, 0x07 } - };*/ - -static const u8 DDR2_ChA_WrtData_Phase_Table[WrtData_REG_NUM ][WrtData_FREQ_NUM] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x74, 0xF8, 0x01, 0x00, 0x00, 0x07 }, // 1Rank - {0x75, 0xF8, 0x01, 0x00, 0x00, 0x07 }, - {0x76, 0x10, 0x80, 0x87, 0x07, 0x06 }, - {0x8C, 0xFC, 0x03, 0x03, 0x03, 0x03 } - }; - -/*static const u8 DDR2_ChB_WrtData_Phase_Table[WrtData_REG_NUM ][WrtData_FREQ_NUM] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x74, 0x8F, 0x30, 0x40, 0x30, 0x20 }, // 1Rank - {0x75, 0x8F, 0x30, 0x40, 0x30, 0x20 }, - {0x8A, 0x00, 0x10, 0x80, 0x07, 0x07 } - }; -*/ -/* -DQ/DQS Output Delay Control -Modify NB D0F3: RxF0/RxF1/RxF2/RxF3 -*/ -static const u8 DDR2_CHA_DQ_DQS_Delay_Table[4][DQ_DQS_Delay_Table_Width] = - { - // RxF0 RxF1 RxF2 RxF3 - { 0x00, 0x00, 0x00, 0x00 },// DDR400 - { 0x00, 0x00, 0x00, 0x00 },// DDR533 - { 0x00, 0x00, 0x00, 0x00 },// DDR667 - { 0x00, 0x00, 0x00, 0x00 }// DDR800 - }; -static const u8 DDR2_CHB_DQ_DQS_Delay_Table[4][DQ_DQS_Delay_Table_Width] = - { - // RxF4 RxF5 RxF6 RxF7 - { 0x00, 0x00, 0x00, 0x00 },// DDR400 - { 0x00, 0x00, 0x00, 0x00 },// DDR533 - { 0x00, 0x00, 0x00, 0x00 },// DDR667 - { 0x00, 0x00, 0x00, 0x00 }// DDR800 - }; - -/* -DQ/DQS input Capture Control -modify NB D0F3_Reg:Rx78/Rx79/Rx7A/Rx7B -*/ - -/*static const u8 DDR2_ChA_DQS_Input_Capture_Tbl[DQS_INPUT_CAPTURE_REG_NUM ][DQS_INPUT_CAPTURE_FREQ_NUM] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x78, 0x00, 0x83, 0x8D, 0x87, 0x83 }, // 1Rank - {0x7A, 0xF0, 0x00, 0x00, 0x00, 0x00 }, - {0x7B, 0x00, 0x10, 0x30, 0x20, 0x10 } - };*/ - - -static const u8 DDR2_ChA_DQS_Input_Capture_Tbl[DQS_INPUT_CAPTURE_REG_NUM ][DQS_INPUT_CAPTURE_FREQ_NUM] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x78, 0xC0, 0x0D, 0x07, 0x03, 0x01 }, // 1Rank - {0x7A, 0xF0, 0x00, 0x00, 0x00, 0x00 }, - {0x7B, 0x00, 0x34, 0x34, 0x20, 0x10 } - }; - -static const u8 DDR2_ChB_DQS_Input_Capture_Tbl[DQS_INPUT_CAPTURE_REG_NUM ][DQS_INPUT_CAPTURE_FREQ_NUM] = - { - // (And NOT) DDR800 DDR667 DDR533 DDR400 - //Reg Mask Value Value Value Value - {0x79, 0x00, 0x89, 0x89, 0x87, 0x83 }, // 1Rank - {0x7A, 0x0F, 0x00, 0x00, 0x00, 0x00 }, - {0x8B, 0x00, 0x34, 0x34, 0x20, 0x10 } - }; - -static const u8 Fixed_DQSA_1_2_Rank_Table[4][2] = -{ -// Rx70 Rx71 - { 0x00, 0x05 }, // DDR800 - { 0x00, 0x06 }, // DDR667 - { 0x00, 0x04 }, // DDR533 - { 0x00, 0x05 } // DDR400 -}; -static const u8 Fixed_DQSA_3_4_Rank_Table[4][2] = -{ -// Rx70 Rx71 - {0x00 , 0x04}, // DDR800 - {0x00 , 0x04}, // DDR667 - {0x00 , 0x03}, // DDR533 - {0x00 , 0x04} // DDR400 -}; diff --git a/src/northbridge/via/vx800/examples/romstage.c b/src/northbridge/via/vx800/examples/romstage.c deleted file mode 100644 index c96511e..0000000 --- a/src/northbridge/via/vx800/examples/romstage.c +++ /dev/null @@ -1,541 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2009 One Laptop per Child, Association, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - - -#include <stdint.h> -#include <device/pci_def.h> -#include <device/pci_ids.h> -#include <arch/io.h> -#include <device/pnp_def.h> -#include "console/console.c" -#include "lib/ramtest.c" -#include "northbridge/via/vx800/vx800.h" -#include "cpu/x86/mtrr/earlymtrr.c" -#include "cpu/x86/bist.h" -#include "pc80/udelay_io.c" -#include "lib/delay.c" -#include "lib/memcpy.c" -#include "cpu/x86/lapic/boot_cpu.c" -#include "driving_clk_phase_data.c" -#include "northbridge/via/vx800/raminit.h" -#include "northbridge/via/vx800/raminit.c" - -static int acpi_is_wakeup_early_via_vx800(void) -{ - device_t dev; - u16 tmp, result; - - print_debug("In acpi_is_wakeup_early_via_vx800\n"); - /* Power management controller */ - dev = pci_locate_device(PCI_ID(PCI_VENDOR_ID_VIA, - PCI_DEVICE_ID_VIA_VX855_LPC), 0); - - if (dev == PCI_DEV_INVALID) - die("Power management controller not found\n"); - - /* Set ACPI base address to I/O VX800_ACPI_IO_BASE. */ - pci_write_config16(dev, 0x88, VX800_ACPI_IO_BASE | 0x1); - - /* Enable ACPI access RTC signal gated with PSON. */ - pci_write_config8(dev, 0x81, 0x84); - - tmp = inw(VX800_ACPI_IO_BASE + 0x04); - result = ((tmp & (7 << 10)) >> 10) == 1 ? 3 : 0; - print_debug(" boot_mode="); - print_debug_hex16(result); - print_debug("\n"); - return result; -} - -static inline int spd_read_byte(unsigned device, unsigned address) -{ - return smbus_read_byte(device, address); -} - -static void enable_mainboard_devices(void) -{ - device_t dev; - uint16_t values; - - print_debug("In enable_mainboard_devices \n"); - - /* Enable P2P bridge Header for external PCI bus. */ - dev = pci_locate_device(PCI_ID(0x1106, 0xa353), 0); - pci_write_config8(dev, 0x4f, 0x41); -} - -static void enable_shadow_ram(void) -{ - uint8_t shadowreg; - - pci_write_config8(PCI_DEV(0, 0, 3), 0x80, 0xff); - /* 0xf0000-0xfffff - ACPI tables */ - shadowreg = pci_read_config8(PCI_DEV(0, 0, 3), 0x83); - shadowreg |= 0x30; - pci_write_config8(PCI_DEV(0, 0, 3), 0x83, shadowreg); - /* 0xe0000-0xeffff - elfload? */ - - pci_write_config8(PCI_DEV(0, 0, 3), 0x82, 0xff); -} - -/* -this table contains the value needed to be set before begin to init dram. -Note: REV_Bx should be cared when porting a new board!!!!! */ -static const struct VIA_PCI_REG_INIT_TABLE mNbStage1InitTbl[] = { - //VT3409 no pcie - 0x00, 0xFF, NB_APIC_REG(0x61), 0xFF, 0x0E, // Set Exxxxxxx as pcie mmio config range - 0x00, 0xFF, NB_APIC_REG(0x60), 0xF4, 0x0B, // Support extended cfg address of pcie - //0x00, 0xFF, NB_APIC_REG(0x42), 0xF9, 0x02, // APIC Interrupt((BT_INTR)) Control - // Set ROMSIP value by software - - /*0x00, 0xFF, NB_HOST_REG(0x70), 0x77, 0x33, // 2x Host Adr Strobe/Pad Pullup Driving = 3 - 0x00, 0xFF, NB_HOST_REG(0x71), 0x77, 0x33, // 2x Host Adr Strobe/Pad Pulldown Driving = 3 - 0x00, 0xFF, NB_HOST_REG(0x72), 0x77, 0x33, // 4x Host Dat Strobe/Pad Pullup Driving = 3 - 0x00, 0xFF, NB_HOST_REG(0x73), 0x77, 0x33, // 4x Host Dat Strobe/Pad Pulldown Driving = 3 - 0x00, 0xFF, NB_HOST_REG(0x74), 0xFF, 0x21, // Memory I/F timing ctrl - 0x00, 0xFF, NB_HOST_REG(0x74), 0xFF, 0xE1, // Memory I/F timing ctrl - 0x00, 0xFF, NB_HOST_REG(0x75), 0xFF, 0x18, // AGTL+ I/O Circuit - 0x00, 0xFF, NB_HOST_REG(0x76), 0xFB, 0x0C, // AGTL+ Compensation Status - 0x00, 0xFF, NB_HOST_REG(0x78), 0xFF, 0x33, // 2X AGTL+ Auto Compensation Offset - 0x00, 0xFF, NB_HOST_REG(0x79), 0xFF, 0x33, // 4X AGTL+ Auto Compensation Offset - 0x00, 0xFF, NB_HOST_REG(0x7A), 0x3F, 0x72, // AGTL Compensation Status - 0x00, 0xFF, NB_HOST_REG(0x7A), 0x3F, 0x77, // AGTL Compensation Status - 0x00, 0xFF, NB_HOST_REG(0x7B), 0xFF, 0x44, // Input Host Address / Host Strobe Delay Control for HA Group - 0x00, 0xFF, NB_HOST_REG(0x7B), 0xFF, 0x22, // Input Host Address / Host Strobe Delay Control for HA Group - 0x00, 0xFF, NB_HOST_REG(0x7C), 0xFF, 0x00, // Output Delay Control of PAD for HA Group - 0x00, 0xFF, NB_HOST_REG(0x7D), 0xFF, 0xAA, // Host Address / Address Clock Output Delay Control (Only for P4 Bus) - 0x00, 0xFF, NB_HOST_REG(0x7E), 0xFF, 0x10, // Host Address CKG Rising / Falling Time Control (Only for P4 Bus) - 0x00, 0xFF, NB_HOST_REG(0x7E), 0xFF, 0x40, // Host Address CKG Rising / Falling Time Control (Only for P4 Bus) - 0x00, 0xFF, NB_HOST_REG(0x7F), 0xFF, 0x10, // Host Address CKG Rising / Falling Time Control (Only for P4 Bus) - 0x00, 0xFF, NB_HOST_REG(0x7F), 0xFF, 0x40, // Host Address CKG Rising / Falling Time Control (Only for P4 Bus) - 0x00, 0xFF, NB_HOST_REG(0x80), 0x3F, 0x44, // Host Data Receiving Strobe Delay Ctrl 1 - 0x00, 0xFF, NB_HOST_REG(0x81), 0xFF, 0x44, // Host Data Receiving Strobe Delay Ctrl 2 - 0x00, 0xFF, NB_HOST_REG(0x82), 0xFF, 0x00, // Output Delay of PAD for HDSTB - 0x00, 0xFF, NB_HOST_REG(0x83), 0xFF, 0x00, // Output Delay of PAD for HD - 0x00, 0xFF, NB_HOST_REG(0x84), 0xFF, 0x44, // Host Data / Strobe CKG Control (Group 0) - 0x00, 0xFF, NB_HOST_REG(0x85), 0xFF, 0x44, // Host Data / Strobe CKG Control (Group 1) - 0x00, 0xFF, NB_HOST_REG(0x86), 0xFF, 0x44, // Host Data / Strobe CKG Control (Group 2) - 0x00, 0xFF, NB_HOST_REG(0x87), 0xFF, 0x44, // Host Data / Strobe CKG Control (Group 3) */ - - - // CPU Host Bus Control - 0x00, 0xFF, NB_HOST_REG(0x50), 0x1F, 0x08, // Request phase ctrl: Dynamic Defer Snoop Stall Count = 8 - //0x00, 0xFF, NB_HOST_REG(0x51), 0xFF, 0x7F, // CPU I/F Ctrl-1: Disable Fast DRDY and RAW - 0x00, 0xFF, NB_HOST_REG(0x51), 0xFF, 0x7C, // CPU I/F Ctrl-1: Disable Fast DRDY and RAW - 0x00, 0xFF, NB_HOST_REG(0x52), 0xCB, 0xCB, // CPU I/F Ctrl-2: Enable all for performance - //0x00, 0xFF, NB_HOST_REG(0x53), 0xFF, 0x88, // Arbitration: Host/Master Occupancy timer = 8*4 HCLK - 0x00, 0xFF, NB_HOST_REG(0x53), 0xFF, 0x44, // Arbitration: Host/Master Occupancy timer = 4*4 HCLK - 0x00, 0xFF, NB_HOST_REG(0x54), 0x1E, 0x1C, // Misc Ctrl: Enable 8QW burst Mem Access - //0x00, 0xFF, NB_HOST_REG(0x55), 0x06, 0x06, // Miscellaneous Control 2 - 0x00, 0xFF, NB_HOST_REG(0x55), 0x06, 0x04, // Miscellaneous Control 2 - 0x00, 0xFF, NB_HOST_REG(0x56), 0xF7, 0x63, // Write Policy 1 - //0x00, 0xFF, NB_HOST_REG(0x59), 0x3D, 0x01, // CPU Miscellaneous Control 1, enable Lowest-Priority IPL - //0x00, 0xFF, NB_HOST_REG(0x5c), 0xFF, 0x00, // CPU Miscellaneous Control 2 - 0x00, 0xFF, NB_HOST_REG(0x5D), 0xFF, 0xA2, // Write Policy - 0x00, 0xFF, NB_HOST_REG(0x5E), 0xFF, 0x88, // Bandwidth Timer - 0x00, 0xFF, NB_HOST_REG(0x5F), 0x46, 0x46, // CPU Misc Ctrl - // 0x00, 0xFF, NB_HOST_REG(0x90), 0xFF, 0x0B, // CPU Miscellaneous Control 3 - //0x00, 0xFF, NB_HOST_REG(0x96), 0x0B, 0x0B, // CPU Miscellaneous Control 2 - 0x00, 0xFF, NB_HOST_REG(0x96), 0x0B, 0x0A, // CPU Miscellaneous Control 2 - 0x00, 0xFF, NB_HOST_REG(0x98), 0xC1, 0x41, // CPU Miscellaneous Control 3 - 0x00, 0xFF, NB_HOST_REG(0x99), 0x0E, 0x06, // CPU Miscellaneous Control 4 - - - // Set APIC and SMRAM - 0x00, 0xFF, NB_HOST_REG(0x97), 0xFF, 0x00, // APIC Related Control - 0x00, 0xFF, NB_DRAMC_REG(0x86), 0xD6, 0x29, // SMM and APIC Decoding: enable APIC, MSI and SMRAM A-Seg - 0x00, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 // End of the table -}; - -#define USE_VCP 1 //0 means use DVP -#define USE_COM1 1 -#define USE_COM2 0 - -#define gCom1Base 0x3f8 -#define gCom2Base 0x2f8 - -void EmbedComInit(void) -{ - u8 ByteVal; - u16 ComBase; - - //enable NB multiple function control - ByteVal = pci_read_config8(PCI_DEV(0, 0, 0), 0x4f); - ByteVal = ByteVal | 0x01; - pci_write_config8(PCI_DEV(0, 0, 0), 0x4f, ByteVal); - - //VGA Enable - ByteVal = pci_read_config8(PCI_DEV(0, 0, 3), 0xA1); - ByteVal = ByteVal | 0x80; - pci_write_config8(PCI_DEV(0, 0, 3), 0xA1, ByteVal); - - ByteVal = pci_read_config8(PCI_DEV(0, 0, 3), 0xA7); - ByteVal = ByteVal | 0x08; - pci_write_config8(PCI_DEV(0, 0, 3), 0xA7, ByteVal); - - //Enable p2p IO/mem - ByteVal = pci_read_config8(PCI_DEV(0, 1, 0), 0x4); - ByteVal = ByteVal | 0x07; - pci_write_config8(PCI_DEV(0, 1, 0), 0x4, ByteVal); - - //Turn on Graphic chip IO port port access - ByteVal = inb(0x3C3); - ByteVal = ByteVal | 0x01; - outb(ByteVal, 0x3C3); - - //Turn off Graphic chip Register protection - outb(0x10, 0x3C4); - ByteVal = inb(0x3C5); - ByteVal = ByteVal | 0x01; - outb(ByteVal, 0x3C5); - - //south module pad share enable 0x3C5.78[7] - outb(0x78, 0x3C4); - ByteVal = inb(0x3C5); - ByteVal = ByteVal | 0x80; - outb(ByteVal, 0x3C5); - - //enable UART Function multiplex with DVP or VCP pad D17F0Rx46[7,6] - ByteVal = pci_read_config8(PCI_DEV(0, 17, 0), 0x46); - //multiplex with VCP - if (USE_VCP == 1) - ByteVal = (ByteVal & 0x3F) | 0x40; - //multiplex with DVP - else - ByteVal = (ByteVal & 0x3F) | 0xC0; - pci_write_config8(PCI_DEV(0, 17, 0), 0x46, ByteVal); - - //enable embeded com1 and com2 D17F0RxB0[5,4] - ByteVal = pci_read_config8(PCI_DEV(0, 17, 0), 0xB0); - ByteVal = ByteVal & 0xcf; - //multiplex with VCP - if (USE_COM1 == 1) - ByteVal = ByteVal | 0x10; - if (USE_COM2 == 1) - ByteVal = ByteVal | 0x20; - pci_write_config8(PCI_DEV(0, 17, 0), 0xB0, ByteVal); - - if (USE_COM1 == 1) - ComBase = gCom1Base; - else - ComBase = gCom2Base; - -//noharddrive - - //set embeded com1 IO base = 0x3E8 - //D17F0RB4 - //ByteVal = 0xFD; - if (USE_COM1 == 1) { - ByteVal = (u8) ((gCom1Base >> 3) | 0x80); - pci_write_config8(PCI_DEV(0, 17, 0), 0xB4, ByteVal); - ByteVal = pci_read_config8(PCI_DEV(0, 17, 0), 0xb2); - ByteVal = (ByteVal & 0xf0) | 0x04; - pci_write_config8(PCI_DEV(0, 17, 0), 0xB2, ByteVal); - } - //set embeded com2 IO base = 0x2E8 - //D17F0RB5 - //ByteVal = 0xDD; - if (USE_COM2 == 1) { - ByteVal = (u8) ((gCom2Base >> 3) | 0x80); - pci_write_config8(PCI_DEV(0, 17, 0), 0xB5, ByteVal); - ByteVal = pci_read_config8(PCI_DEV(0, 17, 0), 0xb2); - ByteVal = (ByteVal & 0x0f) | 0x30; - pci_write_config8(PCI_DEV(0, 17, 0), 0xB2, ByteVal); - } - //no port 80 biger then 0x10 - - //disable interrupt - ByteVal = inb(ComBase + 3); - outb(ByteVal & 0x7F, ComBase + 3); - outb(0x00, ComBase + 1); - - //set baudrate - ByteVal = inb(ComBase + 3); - outb(ByteVal | 0x80, ComBase + 3); - outb(0x01, ComBase); - outb(0x00, ComBase + 1); - - //set frame fromat - ByteVal = inb(ComBase + 3); - outb(ByteVal & 0x3F, ComBase + 3); - outb(0x03, ComBase + 3); - outb(0x00, ComBase + 2); - outb(0x00, ComBase + 4); - - //SOutput("Embeded com output\n"); - //while(1); -} - -void main(unsigned long bist) -{ - unsigned cpu_reset = 0; - u16 boot_mode; - u8 rambits; - - //device_t dev; - /* Enable multifunction for northbridge. */ - pci_write_config8(PCI_DEV(0, 0, 0), 0x4f, 0x01); - EmbedComInit(); - //enable_vx800_serial(); - //uart_init(); - -/* 1. D15F0 - -a) RxBAh = 71h - -b) RxBBh = 05h - -c) RxBEh = 71h - -d) RxBFh = 05h - -2. D17F0 - -a) RxA0h = 06h - -b) RxA1h = 11h - -c) RxA2h = 27h - -d) RxA3h = 32h - -e) Rx79h = 40h - -f) Rx72h = 27h - -g) Rx73h = 32h -*/ - - u8 Data8; - - pci_write_config16(PCI_DEV(0, 0xf, 0), 0xBA, - PCI_DEVICE_ID_VIA_VX855_IDE); - pci_write_config16(PCI_DEV(0, 0xf, 0), 0xBE, - PCI_DEVICE_ID_VIA_VX855_IDE); - pci_write_config16(PCI_DEV(0, 0x11, 0), 0xA0, PCI_VENDOR_ID_VIA); - pci_write_config16(PCI_DEV(0, 0x11, 0), 0xA2, - PCI_DEVICE_ID_VIA_VX855_LPC); - Data8 = pci_read_config8(PCI_DEV(0, 0x11, 0), 0x79); - Data8 &= ~0x40; - Data8 |= 0x40; - pci_write_config8(PCI_DEV(0, 0x11, 0), 0x79, Data8); - pci_write_config16(PCI_DEV(0, 0x11, 0), 0x72, - PCI_DEVICE_ID_VIA_VX855_LPC); - - console_init(); //there are to function defination of console_init(), while the src/archi386/lib is the right one - - /* decide if this is a s3 wakeup or a normal boot */ - boot_mode = acpi_is_wakeup_early_via_vx800(); - /*add this, to transfer "cpu restart" to "cold boot" - When this boot is not a S3 resume, and PCI registers had been written, - then this must be a cpu restart(result of os reboot cmd). so we need a real "cold boot". */ - if ((boot_mode != 3) - && (pci_read_config8(PCI_DEV(0, 0, 3), 0x80) != 0)) { - outb(6, 0xcf9); - } - - /*x86 cold boot I/O cmd */ - enable_smbus(); - //smbus_fixup(&ctrl);// this fix does help vx800!, but vx855 no need this - - if (bist == 0) { - // CAR need mtrr untill mem is ok, so i disable this early_mtrr_init(); - //print_debug("doing early_mtrr\n"); - //early_mtrr_init(); - } - - /* Halt if there was a built-in self test failure. */ - report_bist_failure(bist); - - print_debug("Enabling mainboard devices\n"); - enable_mainboard_devices(); - - u8 Data; - device_t device; - /* Get NB Chip revision from D0F4RxF6, revision will be used in via_pci_inittable */ - device = PCI_DEV(0, 0, 4); - Data = pci_read_config8(device, 0xf6); - print_debug("NB chip revision ="); - print_debug_hex8(Data); - print_debug("\n"); - /* make NB ready before draminit */ - via_pci_inittable(Data, mNbStage1InitTbl); - - /*add this. - When resume from s3, draminit is skiped, so need to recovery any PCI register related to draminit. - and d0f3 didnt lost its Power during whole s3 time, so any register not belongs to d0f3 need to be recoveried . */ -#if 1 - if (boot_mode == 3) { - u8 i; - u8 ramregs[] = { 0x43, 0x42, 0x41, 0x40 }; - DRAM_SYS_ATTR DramAttr; - - print_debug("This is a S3 wakeup\n"); - - memset(&DramAttr, 0, sizeof(DRAM_SYS_ATTR)); - /*Step1 DRAM Detection; DDR1 or DDR2; Get SPD Data; Rank Presence;64 or 128bit; Unbuffered or registered; 1T or 2T */ - DRAMDetect(&DramAttr); - - /*begin to get ram size, 43,42 41 40 contains the end address of last rank in ddr2-slot */ - device = PCI_DEV(0, 0, 3); - for (rambits = 0, i = 0; i < ARRAY_SIZE(ramregs); i++) { - rambits = pci_read_config8(device, ramregs[i]); - if (rambits != 0) - break; - } - - DRAMDRDYSetting(&DramAttr); - - Data = 0x80; // this value is same with dev_init.c - pci_write_config8(PCI_DEV(0, 0, 4), 0xa3, Data); - pci_write_config8(PCI_DEV(0, 17, 7), 0x60, rambits << 2); - Data = pci_read_config8(MEMCTRL, 0x88); - pci_write_config8(PCI_DEV(0, 17, 7), 0xE5, Data); - - DRAMRegFinalValue(&DramAttr); // I just copy this function from draminit to here! - SetUMARam(); // I just copy this function from draminit to here! - print_debug("Resume from S3, RAM init was ignored\n"); - } else { - ddr2_ram_setup(); - ram_check(0, 640 * 1024); - } -#endif - //ddr2_ram_setup(); - /*this line is the same with cx700 port . */ - enable_shadow_ram(); - - /* - For coreboot most time of S3 resume is the same as normal boot, so some memory area under 1M become dirty, - so before this happen, I need to backup the content of mem to top-mem. - I will reserve the 1M top-men in LBIO table in coreboot_table.c and recovery the content of 1M-mem in wakeup.c - */ -#if PAYLOAD_IS_SEABIOS==1 // - if (boot_mode == 3) { - /* some idea of Libo.Feng at amd.com in http://www.coreboot.org/pipermail/coreboot/2008-December/043111.html - I want move the 1M data, I have to set some MTRRs myself. */ - /* setting mtrr before back memory save s3 resume time about 0.14 seconds */ - /*because CAR stack use cache, and here to use cache , must be careful, - 1 during these mtrr code, must no function call, (after this mtrr, I think it should be ok to use function) - 2 before stack switch, no use variable that have value set before this - 3 due to 2, take care of "cpu_reset", I directlly set it to ZERO. - */ - u32 memtop = *(u32 *) WAKE_MEM_INFO; - u32 memtop1 = *(u32 *) WAKE_MEM_INFO - 0x100000; - u32 memtop2 = *(u32 *) WAKE_MEM_INFO - 0x200000; - u32 memtop3 = - *(u32 *) WAKE_MEM_INFO - 64 * 1024 - 0x100000; - u32 memtop4 = - *(u32 *) WAKE_MEM_INFO - 64 * 1024 - 0x100000 + - 0xe0000; - /* __asm__ volatile ( - "movl $0x204, %%ecx\n\t" - "xorl %%edx, %%edx\n\t" - "movl %0,%%eax\n\t" - "orl $(0 | 6), %%eax\n\t" - "wrmsr\n\t" - - "movl $0x205, %%ecx\n\t" - "xorl %%edx, %%edx\n\t" - "movl $0x100000,%%eax\n\t" - "decl %%eax\n\t" - "notl %%eax\n\t" - "orl $(0 | 0x800), %%eax\n\t" - "wrmsr\n\t" - ::"g"(memtop2) - ); - __asm__ volatile ( - "movl $0x206, %%ecx\n\t" - "xorl %%edx, %%edx\n\t" - "movl %0,%%eax\n\t" - "orl $(0 | 6), %%eax\n\t" - "wrmsr\n\t" - - "movl $0x207, %%ecx\n\t" - "xorl %%edx, %%edx\n\t" - "movl $0x100000,%%eax\n\t" - "decl %%eax\n\t" - "notl %%eax\n\t" - "orl $(0 | 0x800), %%eax\n\t" - "wrmsr\n\t" - ::"g"(memtop1) - ); - __asm__ volatile ( - "movl $0x208, %ecx\n\t" - "xorl %edx, %edx\n\t" - "movl $0,%eax\n\t" - "orl $(0 | 6), %eax\n\t" - "wrmsr\n\t" - - "movl $0x209, %ecx\n\t" - "xorl %edx, %edx\n\t" - "movl $0x100000,%eax\n\t" - "decl %eax\n\t" - "notl %eax\n\t" - "orl $(0 | 0x800), %eax\n\t" - "wrmsr\n\t" - ); - */ - // WAKE_MEM_INFO is inited in get_set_top_available_mem in tables.c - // these two memcpy not not be enabled if set the MTRR around this two lines. - /*__asm__ volatile ( - "movl $0, %%esi\n\t" - "movl %0, %%edi\n\t" - "movl $0xa0000, %%ecx\n\t" - "shrl $2, %%ecx\n\t" - "rep movsd\n\t" - ::"g"(memtop3) - ); - __asm__ volatile ( - "movl $0xe0000, %%esi\n\t" - "movl %0, %%edi\n\t" - "movl $0x20000, %%ecx\n\t" - "shrl $2, %%ecx\n\t" - "rep movsd\n\t" - ::"g"(memtop4) - );*/ - print_debug("copy memory to high memory to protect s3 wakeup vector code \n"); //this can have function call, because no variable used before this - memcpy((unsigned char *) ((*(u32 *) WAKE_MEM_INFO) - - 64 * 1024 - 0x100000), - (unsigned char *) 0, 0xa0000); - memcpy((unsigned char *) ((*(u32 *) WAKE_MEM_INFO) - - 64 * 1024 - 0x100000 + 0xe0000), - (unsigned char *) 0xe0000, 0x20000); - - /* restore the MTRR previously modified. */ -/* __asm__ volatile ( - "wbinvd\n\t" - "xorl %edx, %edx\n\t" - "xorl %eax, %eax\n\t" - "movl $0x204, %ecx\n\t" - "wrmsr\n\t" - "movl $0x205, %ecx\n\t" - "wrmsr\n\t" - "movl $0x206, %ecx\n\t" - "wrmsr\n\t" - "movl $0x207, %ecx\n\t" - "wrmsr\n\t" - "movl $0x208, %ecx\n\t" - "wrmsr\n\t" - "movl $0x209, %ecx\n\t" - "wrmsr\n\t" - );*/ - } -#endif -}
