Attention is currently required from: Alicja Michalska, Angel Pons, Intel coreboot Reviewers, Jérémy Compostella, Matt DeVillier, Maximilian Brune.
Hello Alicja Michalska, Angel Pons, Intel coreboot Reviewers, Jérémy Compostella, Maximilian Brune, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/87385?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Alicja Michalska, Code-Review+1 by Angel Pons, Code-Review+1 by Jérémy Compostella, Code-Review+2 by Maximilian Brune, Verified+1 by build bot (Jenkins)
The change is no longer submittable: Code-Review and Verified are unsatisfied now.
Change subject: sb/intel/lynxpoint: Add CFR objects for existing options ......................................................................
Add a header with CFR objects for existing configuration options, so that supported boards can make use of them without duplication.
TEST=build/boot google/panther with CFR options enabled.
Change-Id: I5067e7a69f1f53f0f93d337198d3c349facec086 Signed-off-by: Matt DeVillier matt.devillier@gmail.com --- A src/southbridge/intel/lynxpoint/cfr.h 1 file changed, 55 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/85/87385/3
