Martin Roth has uploaded this change for review. ( https://review.coreboot.org/25018
Change subject: timestamps: Add timestamps around the vbios load & init ......................................................................
Add timestamps before and after the vBIOS load and after the vBIOS run. This lets us see exactly how long it took to load it from the ROM chip, and how long it takes to run.
BUG=b:64549506 TEST=Build & boot Grunt, see vBIOS load & initialization times.
Change-Id: I878ba653eb086ad6c6614aa08a6d3fe216a9323e Signed-off-by: Martin Roth martinroth@chromium.org --- M src/commonlib/include/commonlib/timestamp_serialized.h M src/device/pci_device.c 2 files changed, 11 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/18/25018/1
diff --git a/src/commonlib/include/commonlib/timestamp_serialized.h b/src/commonlib/include/commonlib/timestamp_serialized.h index de92c72..67bff66 100644 --- a/src/commonlib/include/commonlib/timestamp_serialized.h +++ b/src/commonlib/include/commonlib/timestamp_serialized.h @@ -54,6 +54,9 @@ TS_DEVICE_CONFIGURE = 40, TS_DEVICE_ENABLE = 50, TS_DEVICE_INITIALIZE = 60, + TS_OPTROM_INITIALIZE = 65, + TS_OPTROM_COPY_END = 66, + TS_OPTROM_END = 67, TS_DEVICE_DONE = 70, TS_CBMEM_POST = 75, TS_WRITE_TABLES = 80, @@ -166,6 +169,9 @@ { TS_DEVICE_CONFIGURE, "device configuration" }, { TS_DEVICE_ENABLE, "device enable" }, { TS_DEVICE_INITIALIZE, "device initialization" }, + { TS_OPTROM_INITIALIZE, "Optionrom initialization" }, + { TS_OPTROM_COPY_END, "Optionrom copy done" }, + { TS_OPTROM_END, "Optionrom run done" }, { TS_DEVICE_DONE, "device setup done" }, { TS_CBMEM_POST, "cbmem post" }, { TS_WRITE_TABLES, "write tables" }, diff --git a/src/device/pci_device.c b/src/device/pci_device.c index 02eca66..53831fd 100644 --- a/src/device/pci_device.c +++ b/src/device/pci_device.c @@ -48,6 +48,7 @@ #include <device/hypertransport.h> #include <pc80/i8259.h> #include <security/vboot/vbnv.h> +#include <timestamp.h>
u8 pci_moving_config8(struct device *dev, unsigned int reg) { @@ -719,6 +720,7 @@
if (!should_load_oprom(dev)) return; + timestamp_add_now(TS_OPTROM_INITIALIZE);
rom = pci_rom_probe(dev); if (rom == NULL) @@ -727,6 +729,7 @@ ram = pci_rom_load(dev, rom); if (ram == NULL) return; + timestamp_add_now(TS_OPTROM_COPY_END);
if (!should_run_oprom(dev)) return; @@ -734,6 +737,8 @@ run_bios(dev, (unsigned long)ram); gfx_set_init_done(1); printk(BIOS_DEBUG, "VGA Option ROM was run\n"); + timestamp_add_now(TS_OPTROM_END); + }
/** Default device operation for PCI devices */
