Attention is currently required from: Christian Walter, Lean Sheng Tan.
Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/73983 )
Change subject: mb/prodrive/atlas: Rework EEPROM layout structures ......................................................................
To avoid having to calculate the length of a struct separately, rework the code to give the struct a tag name, so that `sizeof()` can be used instead. This involves refactoring the `get_emi_eeprom_vpd()` function to return a struct instead of a union, so callers can no longer access the EEPROM data as an array of bytes without additional code, but this array view is only used inside `get_emi_eeprom_vpd()` when reading the data from EMI.
Change-Id: Id1bc40939631baa131b5f60eadbfe42838294ebe Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/prodrive/atlas/vpd.c M src/mainboard/prodrive/atlas/vpd.h 2 files changed, 44 insertions(+), 32 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/73983/1
diff --git a/src/mainboard/prodrive/atlas/vpd.c b/src/mainboard/prodrive/atlas/vpd.c index 12371f7..75d1caf 100644 --- a/src/mainboard/prodrive/atlas/vpd.c +++ b/src/mainboard/prodrive/atlas/vpd.c @@ -8,22 +8,26 @@ #include "mainboard.h" #include "vpd.h"
-const union emi_eeprom_vpd *get_emi_eeprom_vpd(void) +const struct emi_eeprom_vpd *get_emi_eeprom_vpd(void) { - static union emi_eeprom_vpd vpd = {0}; + static union { + struct emi_eeprom_vpd layout; + uint8_t raw[sizeof(struct emi_eeprom_vpd)]; + } vpd = {0};
/* Check if cached VPD is valid */ - if (vpd.header.revision == VPD_LATEST_REVISION) - return &vpd; + if (vpd.layout.header.revision == VPD_LATEST_REVISION) + return &vpd.layout;
ec_emi_read(vpd.raw, EMI_0_IO_BASE_ADDR, 0, 0, sizeof(vpd.raw));
/* If the magic value doesn't match, consider EEPROM VPD unreliable */ - if (vpd.header.magic != VPD_MAGIC) { + if (vpd.layout.header.magic != VPD_MAGIC) { printk(BIOS_WARNING, "Atlas VPD: Bad magic value, using fallback defaults\n"); - vpd.header.revision = 0; + vpd.layout.header.revision = 0; } else { - printk(BIOS_DEBUG, "Atlas VPD: Got revision %u from EC\n", vpd.header.revision); + printk(BIOS_DEBUG, "Atlas VPD: Got revision %u from EC\n", + vpd.layout.header.revision); }
/* @@ -40,21 +44,21 @@ * of the VPD structure with a reasonable fallback value. Note the * intentional falling through. */ - switch (vpd.header.revision) { + switch (vpd.layout.header.revision) { case 0: memset(vpd.raw, 0, sizeof(vpd.raw)); - vpd.header.magic = VPD_MAGIC; - vpd.serial_number[0] = '\0'; - vpd.part_number[0] = '\0'; - vpd.profile = ATLAS_PROF_UNPROGRAMMED; + vpd.layout.header.magic = VPD_MAGIC; + vpd.layout.serial_number[0] = '\0'; + vpd.layout.part_number[0] = '\0'; + vpd.layout.profile = ATLAS_PROF_UNPROGRAMMED; __fallthrough; default: /* Ensure serial numbers are NULL-terminated, update revision last */ - vpd.serial_number[ATLAS_SN_PN_LENGTH - 1] = '\0'; - vpd.part_number[ATLAS_SN_PN_LENGTH - 1] = '\0'; - vpd.header.revision = VPD_LATEST_REVISION; + vpd.layout.serial_number[ATLAS_SN_PN_LENGTH - 1] = '\0'; + vpd.layout.part_number[ATLAS_SN_PN_LENGTH - 1] = '\0'; + vpd.layout.header.revision = VPD_LATEST_REVISION; break; }
- return &vpd; + return &vpd.layout; } diff --git a/src/mainboard/prodrive/atlas/vpd.h b/src/mainboard/prodrive/atlas/vpd.h index 3955c11..086dc8c 100644 --- a/src/mainboard/prodrive/atlas/vpd.h +++ b/src/mainboard/prodrive/atlas/vpd.h @@ -36,24 +36,14 @@
#define ATLAS_SN_PN_LENGTH 20
-#define EMI_EEPROM_LAYOUT_LENGTH ( \ - sizeof(struct emi_eeprom_vpd_header) + \ - ATLAS_SN_PN_LENGTH + \ - ATLAS_SN_PN_LENGTH + \ - sizeof(uint16_t) \ - ) - -union emi_eeprom_vpd { - struct __packed { - struct emi_eeprom_vpd_header header; - char serial_number[ATLAS_SN_PN_LENGTH]; /* xx-xx-xxx-xxx */ - char part_number[ATLAS_SN_PN_LENGTH]; /* xxx-xxxx-xxxx.Rxx */ - uint16_t profile; - }; - uint8_t raw[EMI_EEPROM_LAYOUT_LENGTH]; +struct __packed emi_eeprom_vpd { + struct emi_eeprom_vpd_header header; + char serial_number[ATLAS_SN_PN_LENGTH]; /* xx-xx-xxx-xxx */ + char part_number[ATLAS_SN_PN_LENGTH]; /* xxx-xxxx-xxxx.Rxx */ + uint16_t profile; };
/* Always returns a non-NULL pointer to valid data */ -const union emi_eeprom_vpd *get_emi_eeprom_vpd(void); +const struct emi_eeprom_vpd *get_emi_eeprom_vpd(void);
#endif /* ATLAS_VPD_H */
