Hello build bot (Jenkins), Patrick Georgi, HAOUAS Elyes,
https://review.coreboot.org/c/coreboot/+/42163
Change subject: Revert "sb/amd/cimx/sb800: Fix 16-bit read/write PCI_COMMAND register" ......................................................................
This reverts commit 04506e2987162ec0f280afddd6f4acac070bbf15.
Turned out that `dev->command` is only a `u8` and the way it's used here is wrong: It is not supposed to reflect the state of the register but only gathers (lower) bits to be enabled during allocation.
Change-Id: Iacd2b753939e8adcf5aedd4b9cf101638a324aa6 Signed-off-by: Nico Huber nico.h@gmx.de --- M src/southbridge/amd/cimx/sb800/late.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/42163/1
diff --git a/src/southbridge/amd/cimx/sb800/late.c b/src/southbridge/amd/cimx/sb800/late.c index de91a9a..1cf3ae8 100644 --- a/src/southbridge/amd/cimx/sb800/late.c +++ b/src/southbridge/amd/cimx/sb800/late.c @@ -98,7 +98,7 @@ }
dev->command |= PCI_COMMAND_MASTER; - pci_write_config16(dev, PCI_COMMAND, dev->command); + pci_write_config8(dev, PCI_COMMAND, dev->command); printk(BIOS_DEBUG, "AHCI/RAID controller initialized\n"); }
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42163 )
Patch Set 1: Code-Review+2
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42163 )
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/42163 )
Change-Id: Iacd2b753939e8adcf5aedd4b9cf101638a324aa6 Signed-off-by: Nico Huber nico.h@gmx.de Reviewed-on: https://review.coreboot.org/c/coreboot/+/42163 Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: HAOUAS Elyes ehaouas@noos.fr Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/southbridge/amd/cimx/sb800/late.c 1 file changed, 1 insertion(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified HAOUAS Elyes: Looks good to me, approved Angel Pons: Looks good to me, approved
diff --git a/src/southbridge/amd/cimx/sb800/late.c b/src/southbridge/amd/cimx/sb800/late.c index d57ce00..43a88b7 100644 --- a/src/southbridge/amd/cimx/sb800/late.c +++ b/src/southbridge/amd/cimx/sb800/late.c @@ -98,7 +98,7 @@ }
