Gaggery Tsai has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39850 )
Change subject: [WIP]/mb/google/hatch/vr/puff: Add psys_pmax calculation ......................................................................
This patch adds psys_pmax calculation. There are two types of power sources. One is barrel jack and the other is USB TYPE-C. The voltage level is fixed for a barrel jack while TYPE-C maybe varies which dependnets on power ratings. We need to get voltage infomration from EC and calculate correct psys_pmax value.
BUG=b:151972149 TEST=pending on test result
Signed-off-by: Gaggery Tsai gaggery.tsai@intel.com Change-Id: I8ea01f856411e05a533489280fc2b4a46a1440c5 --- M src/mainboard/google/hatch/variants/puff/mainboard.c 1 file changed, 22 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/39850/1
diff --git a/src/mainboard/google/hatch/variants/puff/mainboard.c b/src/mainboard/google/hatch/variants/puff/mainboard.c index f00f47f..518da42 100644 --- a/src/mainboard/google/hatch/variants/puff/mainboard.c +++ b/src/mainboard/google/hatch/variants/puff/mainboard.c @@ -97,6 +97,23 @@ * | n (U22) | 29 | .9n | .9n | x(43) | * +-------------+-----+---------+---------+-------+ */ + +/* + * Psys_pmax consideratins + * Given the hardware design in puff, the serial shunt resistor is 0.01ohm + * The full scale of hardware PSYS signal 0.8v maps to system current 9.58A + * instead of real system power. The equestion is shown below: + * PSYS = 0.8v = (0.01ohm x Iinput) x 50 (INA213, gain 50V/V) x 15k/(15k + 75k) + * Hence, Iinput (Amps) = 9.58A + * Since there is no voltage information from PSYS, different voltage input + * would map to different Psys_pmax settings: + * For Type-C 15V, the Psys_pmax sholud be 15v x 9.58A = 143.7W + * For Type-C 20V, the Psys_pmax should be 20v x 9.58A = 191.6W + * For a barral jack, the Psys_pmax should be 19v x 9.58A = 182W + */ +#define PSYS_IMAX_MINIAMPS 9580 +#define BJ_MINIVOLTS 19000 + static void mainboard_set_power_limits(config_t *conf) { enum usb_chg_type type; @@ -118,8 +135,12 @@ /* set minimum duty cycle */ conf->tdp_psyspl3_dutycycle = PUFF_MIN_DUTYCYCLE; conf->tdp_pl4 = SET_PSYSPL2(psyspl2); + } else { + /* Input type is barrel jack */ + mini_volts = BJ_MINIVOLTS; } - + + conf->psys_pmax = (u16)(((u32)PSYS_IMAX_MINIAMPS * mini_volts)/1000000); conf->tdp_pl2_override = PUFF_PL2; /* set psyspl2 to 90% of max adapter power */ conf->tdp_psyspl2 = SET_PSYSPL2(psyspl2);
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39850 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/39850/1/src/mainboard/google/hatch/... File src/mainboard/google/hatch/variants/puff/mainboard.c:
https://review.coreboot.org/c/coreboot/+/39850/1/src/mainboard/google/hatch/... PS1, Line 142: trailing whitespace
Hello build bot (Jenkins),
Signed-off-by: Gaggery Tsai gaggery.tsai@intel.com Change-Id: I8ea01f856411e05a533489280fc2b4a46a1440c5 --- M src/mainboard/google/hatch/variants/puff/mainboard.c 1 file changed, 21 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/39850/2
Harry Pan has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39850 )
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/39850/2/src/mainboard/google/hatch/... File src/mainboard/google/hatch/variants/puff/mainboard.c:
https://review.coreboot.org/c/coreboot/+/39850/2/src/mainboard/google/hatch/... PS2, Line 102: consideratins considerations?
This patch adds psys_pmax calculation. There are two types of power sources. One is barrel jack and the other is USB TYPE-C. The voltage level is fixed for a barrel jack while TYPE-C maybe varies which dependnets on power ratings. We need to get voltage infomration from EC and calculate correct psys_pmax value. The psys_pmax needs to be set before FSP-S since FSP-S will handle the setting passing to pcode, so move the routine ahead to variant_ramstage_init.
Signed-off-by: Gaggery Tsai gaggery.tsai@intel.com Change-Id: I8ea01f856411e05a533489280fc2b4a46a1440c5 --- M src/mainboard/google/hatch/variants/puff/mainboard.c 1 file changed, 36 insertions(+), 18 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/39850/3
Signed-off-by: Gaggery Tsai gaggery.tsai@intel.com Change-Id: I8ea01f856411e05a533489280fc2b4a46a1440c5 --- M src/mainboard/google/hatch/variants/puff/mainboard.c 1 file changed, 37 insertions(+), 18 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/39850/4
Gaggery Tsai has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39850 )
Patch Set 4:
considerations?
done.
Patch Set 4: Code-Review+1
Verified on BJ90W, TC65W, and TC45W, they all works well (mostly likely).
That said, I noticed there is a corner case in cold boot (1st plug or ectool reboot_ec cold) that the API (google_chromeec_get_usb_pd_power_info) returns type in 9 (USB_CHG_TYPE_UNKNOWN) [1]; this is happening in all adapters I tested (BJ90W/TC65W/TC45W); when we hit such case, the psys from MSR would incorrectly increasing against the external gauge.
[1] firmware log: HP: rv=0 type=9 psys_pmax=182
Patch Set 4:
Please ignore my previous comment of USB_CHG_TYPE_UNKNOWN. It could be my faulty environment, and I am unable to see this odd now.
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39850 )
Patch Set 4:
(12 comments)
https://review.coreboot.org/c/coreboot/+/39850/4//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/39850/4//COMMIT_MSG@12 PS4, Line 12: dependnets depends
https://review.coreboot.org/c/coreboot/+/39850/4//COMMIT_MSG@11 PS4, Line 11: maybe varies which : dependnets on power ratings … can vary depending on the power ratings
https://review.coreboot.org/c/coreboot/+/39850/4//COMMIT_MSG@12 PS4, Line 12: infomration information
https://review.coreboot.org/c/coreboot/+/39850/4//COMMIT_MSG@14 PS4, Line 14: pcode What is that?
https://review.coreboot.org/c/coreboot/+/39850/4/src/mainboard/google/hatch/... File src/mainboard/google/hatch/variants/puff/mainboard.c:
https://review.coreboot.org/c/coreboot/+/39850/4/src/mainboard/google/hatch/... PS4, Line 87: * Given the hardware design in puff, the serial shunt resistor is 0.01ohm Please add a dot/period at the end of sentences.
https://review.coreboot.org/c/coreboot/+/39850/4/src/mainboard/google/hatch/... PS4, Line 90: 15k What is the unit *k*?
https://review.coreboot.org/c/coreboot/+/39850/4/src/mainboard/google/hatch/... PS4, Line 91: * Hence, Iinput (Amps) = 9.58A Sorry my ignorance, I am no engineer, but I get 9.6 A.
Iinput = 0.8 * 100 / 50 / 15 * 90 A = 0.8 * 2 * 6 = 9.6 A
https://review.coreboot.org/c/coreboot/+/39850/4/src/mainboard/google/hatch/... PS4, Line 98: Please use exactly one space and no tab.
https://review.coreboot.org/c/coreboot/+/39850/4/src/mainboard/google/hatch/... PS4, Line 127: / Please add spaces around the operator.
https://review.coreboot.org/c/coreboot/+/39850/4/src/mainboard/google/hatch/... PS4, Line 139: gpio_configure_pads. */ Fits on one line in 96 characters.
https://review.coreboot.org/c/coreboot/+/39850/4/src/mainboard/google/hatch/... PS4, Line 144: && !gpio_get(GPIO_DP_HPD)) { One line? Only copied, so fix in a commit before or in a follow-up?
https://review.coreboot.org/c/coreboot/+/39850/4/src/mainboard/google/hatch/... PS4, Line 149: setup set up
Patch Set 4:
(12 comments)
depends
Ack
Ack
information
Ack
What is that?
Pcode is like a microprocessor who manage the power like PL1, PL2, PsysPLx and etc.
Ack
k is kilo, 1000. The unit here is ohms.
Sorry my ignorance, I am no engineer, but I get 9.6 A. […]
Ack
Ack
Ack
Ack
I like the original style, it's clear to me.
set up
Ack
Hello build bot (Jenkins), Harry Pan,
Change subject: mb/google/hatch/vr/puff: Add psys_pmax calculation ......................................................................
BUG=b:151972149 TEST=emerge-puff coreboot chromeos-bootimage check firmware log and ensure psys_pmax is passed to FSP check the data from dump_intel_rapl_consumption in the OS and ensure the power data is close to an external power meter.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/39850/5
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/39850/6
Jamie Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39850 )
Patch Set 6: Code-Review+1
Edward O'Callaghan has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39850 )
Patch Set 6: Code-Review+2
Patch Set 6:
Could you add the unit despite it cancelling each other out?
Patch Set 6:
https://review.coreboot.org/c/coreboot/+/39850/6/src/mainboard/google/hatch/... File src/mainboard/google/hatch/variants/puff/mainboard.c:
https://review.coreboot.org/c/coreboot/+/39850/6/src/mainboard/google/hatch/... PS6, Line 105: u16 volts_milli; In a follow-up the variable names should be cleaned up.
`vlimit_mv` or s,o and the same for `watt`.
Hello Shelley Chen, build bot (Jenkins), Jamie Chen, Furquan Shaikh, Kangheui Won, Harry Pan, Edward O'Callaghan, Gaggery Tsai,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/39850/7
Patch Set 7: Code-Review+2
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/39850/8
Patrick Georgi has uploaded a new patch set (#9) to the change originally created by Gaggery Tsai. ( https://review.coreboot.org/c/coreboot/+/39850 )
This patch adds psys_pmax calculation. There are two types of power sources. One is barrel jack and the other is USB TYPE-C. The voltage level is fixed for a barrel jack while TYPE-C may vary depending on power ratings. We need to get voltage information from EC and calculate correct psys_pmax value. The psys_pmax needs to be set before FSP-S since FSP-S will handle the setting passing to pcode, so move the routine ahead to variant_ramstage_init.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/39850/9
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39850 )
Patch Set 9:
Ack
Patch Set 9:
(2 comments)
I think this is pretty obvious.
Ack
Edward O'Callaghan has submitted this change. ( https://review.coreboot.org/c/coreboot/+/39850 )
Signed-off-by: Gaggery Tsai gaggery.tsai@intel.com Change-Id: I8ea01f856411e05a533489280fc2b4a46a1440c5 Reviewed-on: https://review.coreboot.org/c/coreboot/+/39850 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Edward O'Callaghan quasisec@chromium.org --- M src/mainboard/google/hatch/variants/puff/mainboard.c 1 file changed, 37 insertions(+), 18 deletions(-)
Approvals: build bot (Jenkins): Verified Edward O'Callaghan: Looks good to me, approved
diff --git a/src/mainboard/google/hatch/variants/puff/mainboard.c b/src/mainboard/google/hatch/variants/puff/mainboard.c index 3f74c96..ceeb0c5 100644 --- a/src/mainboard/google/hatch/variants/puff/mainboard.c +++ b/src/mainboard/google/hatch/variants/puff/mainboard.c @@ -31,23 +31,6 @@ stopwatch_duration_msecs(&sw)); }
-void variant_ramstage_init(void) -{ - static const long display_timeout_ms = 3000; - - /* This is reconfigured back to whatever FSP-S expects by - gpio_configure_pads. */ - gpio_input(GPIO_HDMI_HPD); - gpio_input(GPIO_DP_HPD); - if (display_init_required() - && !gpio_get(GPIO_HDMI_HPD) - && !gpio_get(GPIO_DP_HPD)) { - /* This has to be done before FSP-S runs. */ - if (google_chromeec_wait_for_displayport(display_timeout_ms)) - wait_for_hpd(GPIO_DP_HPD, display_timeout_ms); - } -} - /* * For type-C chargers, set PL2 to 90% of max power to account for * cable loss and FET Rdson loss in the path from the source. @@ -86,6 +69,24 @@ * | n (U22) | 29 | .9n | .9n | x(43) | * +-------------+-----+---------+---------+-------+ */ + +/* + * Psys_pmax considerations + * + * Given the hardware design in puff, the serial shunt resistor is 0.01ohm. + * The full scale of hardware PSYS signal 0.8v maps to system current 9.6A + * instead of real system power. The equation is shown below: + * PSYS = 0.8v = (0.01ohm x Iinput) x 50 (INA213, gain 50V/V) x 15k/(15k + 75k) + * Hence, Iinput (Amps) = 9.6A + * Since there is no voltage information from PSYS, different voltage input + * would map to different Psys_pmax settings: + * For Type-C 15V, the Psys_pmax sholud be 15v x 9.6A = 144W + * For Type-C 20V, the Psys_pmax should be 20v x 9.6A = 192W + * For a barral jack, the Psys_pmax should be 19v x 9.6A = 182.4W + */ +#define PSYS_IMAX 9600 +#define BJ_VOLTS_MV 19000 + static void mainboard_set_power_limits(config_t *conf) { enum usb_chg_type type; @@ -108,15 +109,33 @@ /* set minimum duty cycle */ conf->tdp_psyspl3_dutycycle = PUFF_MIN_DUTYCYCLE; conf->tdp_pl4 = SET_PSYSPL2(psyspl2); + } else { + /* Input type is barrel jack */ + volts_mv = BJ_VOLTS_MV; } + /* voltage unit is milliVolts and current is in milliAmps */ + conf->psys_pmax = (u16)(((u32)PSYS_IMAX * volts_mv) / 1000000);
conf->tdp_pl2_override = PUFF_PL2; /* set psyspl2 to 90% of max adapter power */ conf->tdp_psyspl2 = SET_PSYSPL2(psyspl2); }
-void variant_mainboard_enable(struct device *dev) +void variant_ramstage_init(void) { + static const long display_timeout_ms = 3000; config_t *conf = config_of_soc(); + + /* This is reconfigured back to whatever FSP-S expects by gpio_configure_pads. */ + gpio_input(GPIO_HDMI_HPD); + gpio_input(GPIO_DP_HPD); + if (display_init_required() + && !gpio_get(GPIO_HDMI_HPD) + && !gpio_get(GPIO_DP_HPD)) { + /* This has to be done before FSP-S runs. */ + if (google_chromeec_wait_for_displayport(display_timeout_ms)) + wait_for_hpd(GPIO_DP_HPD, display_timeout_ms); + } + /* Psys_pmax needs to be setup before FSP-S */ mainboard_set_power_limits(conf); }
