Leroy P Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13438
commit f2b82301b5a0e1df40accee403db2055e1512609 Author: Lee Leahy leroy.p.leahy@intel.com Date: Thu Jan 7 11:24:24 2016 -0800
Documentation: Add x86 documentation for required files
Document the required files to perform a minimal coreboot/FSP build for x86.
TEST=None
Change-Id: I65b2947114634fce982ce82fb7c577fd5f47ed10 Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- Documentation/x86Development.html | 52 +++++++++++++++++ src/drivers/intel/fsp1_1/fsp1_1.html | 44 +++++++++++++++ src/mainboard/intel/board.html | 83 +++++++++++++++++++++++++++ src/soc/intel/soc.html | 105 +++++++++++++++++++++++++++++++++++ 4 files changed, 284 insertions(+)
diff --git a/Documentation/x86Development.html b/Documentation/x86Development.html new file mode 100644 index 0000000..e0369e4 --- /dev/null +++ b/Documentation/x86Development.html @@ -0,0 +1,52 @@ +<!DOCTYPE html> +<html> + <head> + <title>Development</title> + </head> + <body> + +<h1>Coreboot/FSP Development Process for Intel x86</h1> +<p> + The x86 development process for coreboot is broken into the following components: +</p> +<ul> + <li>Coreboot <a target="_blank" href="../src/soc/intel/soc.html">SoC</a> development</li> + <li>Coreboot <a target="_blank" href="../src/mainboard/intel/board.html">mainboard</a> development</li> + <li><a target="_blank" href="../src/drivers/intel/fsp1_1/fsp1_1.html">FSP 1.1</a> integration</li> +</ul> +<p> + The combined steps below describe how to bring up coreboot for a + system-on-a-chip (SoC) and a development board: +</p> +<table> + <tr bgcolor="#ffffc0"> + <td>The initial coreboot steps are single threaded! + The initial minimal FSP development is also single threaded. + Progress can speed up by adding more developers after the minimal coreboot/FSP + implementation reaches the payload. + </td> + </tr> +</table> +<ol> + <li>Get and build the necessary tools: + <ol type="A"> + <li>sudo apt-get install m4 bison flex ncurses-dev</li> + <li>make crossgcc</li> + </ol> + </li> + <li>Get something to build: + <ol type="A"> + <li><a target="_blank" href="../src/drivers/intel/fsp1_1/fsp1_1.html#RequiredFiles">FSP 1.1</a> required files</li> + <li><a target="_blank" href="../src/soc/intel/soc.html#RequiredFiles">SoC</a> required files</li> + <li><a target="_blank" href="../src/mainboard/intel/board.html#RequiredFiles">Board</a> required files</li> + </ol> + </li> + <li>Get result to start <a target="_blank" href="../src/soc/intel/soc.html#Descriptor">booting</a></li> + <li><a target="_blank" href="../src/soc/intel/soc.html#EarlyDebug">Early Debug</a></li> +</ol> + + +<hr> +<p>Modified: 27 January 2016</p> + </body> +</html> \ No newline at end of file diff --git a/src/drivers/intel/fsp1_1/fsp1_1.html b/src/drivers/intel/fsp1_1/fsp1_1.html new file mode 100644 index 0000000..dcfd588 --- /dev/null +++ b/src/drivers/intel/fsp1_1/fsp1_1.html @@ -0,0 +1,44 @@ +<!DOCTYPE html> +<html> + <head> + <title>FSP 1.1</title> + </head> + <body> + +<h1>x86 FSP 1.1 Development</h1> +<p> + Firmware Support Package (FSP) development requires System-on-a-Chip (SoC) + and board support. The combined steps are listed + <a target="_blank" href="../../../../Documentation/x86Development.html">here</a>. + The development steps for FSP are listed below: +</p> +<ol> + <li><a href="#RequiredFiles">Required Files</a></li> +</ol> + + +<hr> +<h1><a name="RequiredFiles">Required Files</a></h1> +<h2><a name="CorebootRequiredFiles">Coreboot Required Files</a></h2> +<ol> + <li>Create the directories: + <ul> + <li>src/vendorcode/intel/fsp/fsp1_1/<Chip Family></li> + <li>3rdparty/blobs/mainboard/<Board Vendor>/<Board Name></li> + </ul> + </li> + <li> + The following files need to be copied from the FSP build or release into the + directories above: + <ul> + <li>FspUpdVpd.h: src/vendorcode/intel/fsp/fsp1_1/<Chip Family>/FspUpdVpd.h</li> + <li>FSP.bin: 3rdparty/blobs/mainboard/<Board Vendor>/<Board Name>/fsp.bin</li> + </ul> + </li> +</ol> + + +<hr> +<p>Modified: 27 January 2016</p> + </body> +</html> \ No newline at end of file diff --git a/src/mainboard/intel/board.html b/src/mainboard/intel/board.html new file mode 100644 index 0000000..a7b5b32 --- /dev/null +++ b/src/mainboard/intel/board.html @@ -0,0 +1,83 @@ +<!DOCTYPE html> +<html> + <head> + <title>Board</title> + </head> + <body> + +<h1>x86 Board Development</h1> +<p> + Board development requires System-on-a-Chip (SoC) support. + The combined steps are listed + <a target="_blank" href="../../../Documentation/x86Development.html">here</a>. + The development steps for the board are listed below: +</p> +<ol> + <li><a href="#RequiredFiles">Required Files</a></li> +</ol> + + +<hr> +<h1><a name="RequiredFiles">Required Files</a></h1> +<p> + Create the board directory as src/mainboard/<Vendor>/<Board>. +</p> + +<p> + The following files are required to build a new board: +</p> +<ol> + <li>Kconfig.name - Defines the Kconfig value for the board</li> + <li>Kconfig + <ol type="A"> + <li>Selects the SoC for the board and specifies the SPI flash size + <ol type="I"> + <li>BOARD_ROMSIZE_KB_<Size></li> + <li>SOC_<Vendor>_<Chip Family></li> + </ol> + </li> + <li>Declare the Kconfig values for: + <ol type="I"> + <li>MAINBOARD_DIR</li> + <li>MAINBOARD_PART_NUMBER</li> + <li>MAINBOARD_VENDOR</li> + </ol> + </li> + </ol> + </li> + <li>devicetree.cb - Enable root bridge and serial port + <ol type="A"> + <li>The first line must be "chip soc/Intel/<soc family>"; + this path is used by the generated static.c to include the chip.h + header file + </li> + </ol> + </li> + <li>romstage.c + <ol type="A"> + <li>Add routine mainboard_romstage_entry which calls romstage_common</li> + </ol> + </li> + <li>Configure coreboot build: + <ol type="A"> + <li>Set LOCALVERSION</li> + <li>FLASHMAP_OFFSET = 0x00700000</li> + <li>Select vendor for the board</li> + <li>Select the board</li> + <LI>CBFS_SIZE = 0x00100000</li> + <li>Set the CPU_MICROCODE_CBFS_LEN</li> + <li>Set the CPU_MICROCODE_CBFS_LOC</li> + <li>Set the FSP_IMAGE_ID_STRING</li> + <li>Set the FSP_LOC</li> + <li>Disable GOP_SUPPORT</li> + <li>No payload</li> + <li>Choose the default value for all other options</li> + </ol> + </li> +</ol> + + +<hr> +<p>Modified: 27 January 2016</p> + </body> +</html> \ No newline at end of file diff --git a/src/soc/intel/soc.html b/src/soc/intel/soc.html new file mode 100644 index 0000000..0778c4d --- /dev/null +++ b/src/soc/intel/soc.html @@ -0,0 +1,105 @@ +<!DOCTYPE html> +<html> + <head> + <title>SoC</title> + </head> + <body> + +<h1>x86 System on a Chip (SoC) Development</h1> +<p> + SoC development is best done in parallel with development for a specific + board. The combined steps are listed + <a target="_blank" href="../../../Documentation/x86Development.html">here</a>. + The development steps for the SoC are listed below: +</p> +<ol> + <li><a target="_blank" href="../../drivers/intel/fsp1_1/fsp1_1.html#RequiredFiles">FSP 1.1</a> required files</li> + <li>SoC <a href="#RequiredFiles">Required Files</a></li> + <li><a href="#Descriptor">Start Booting</a></li> + <li><a href="#EarlyDebug">Early Debug</a></li> +</ol> + + +<hr> +<h1><a name="RequiredFiles">Required Files</a></h1> +<p> + Create the directory as src/soc/<Vendor>/<Chip Family>. +</p> + +<p> + The following files are required to build a new SoC: +</p> +<ul> + <li>Include files + <ul> + <li>include/soc/pei_data.h</li> + <li>include/soc/pm.h</li> + </ul> + </li> + <li>Kconfig - Defines the Kconfig value for the SoC and selects the tool + chains for the various stages: + <ul> + <li>select ARCH_BOOTBLOCK_<Tool Chain></li> + <li>select ARCH_RAMSTAGE_<Tool Chain></li> + <li>select ARCH_ROMSTAGE_<Tool Chain></li> + <li>select ARCH_VERSTAGE_<Tool Chain></li> + </ul> + </li> + <li>Makefile.inc - Specify the include paths</li> + <li>memmap.c - Top of usable RAM</li> +</ul> + + +<hr> +<h1><a name="Descriptor">Start Booting</a></h1> +<p> + Some SoC parts require additional firmware components in the flash. + This section describes how to add those pieces. +</p> + +<h2>Intel Firmware Descriptor</h2> +<p> + The Intel Firmware Descriptor (IFD) is located at the base of the flash part. + The following command overwrites the base of the flash image with the Intel + Firmware Descriptor: +</p> +<pre><code>dd if=descriptor.bin of=build/coreboot.rom conv=notrunc >/dev/null 2>&1</code></pre> + + +<h2><a name="MEB">Management Engine Binary</a></h2> +<p> + Some SoC parts contain and require that the Management Engine (ME) be running + before it is possible to bring the x86 processor out of reset. A binary file + containing the management engine code must be added to the firmware using the + ifdtool. The following commands add this binary blob: +</p> +<pre><code>util/ifdtool/ifdtool -i ME:me.bin build/coreboot.rom +mv build/coreboot.rom.new build/coreboot.rom +</code></pre> + + +<h2><a name="EarlyDebug">Early Debug</a></h2> +<p> + Early debugging between the reset vector and the time the serial port is enabled + is most easily done by writing values to port 0x80. +</p> + + +<h2>Success</h2> +<p> + When the reset vector is successfully invoked, port 0x80 will output the following value: +</p> +<ul> + <li>0x01: <a target="_blank" href="http://review.coreboot.org/gitweb?p=coreboot.git;a=blob;f=src/include/console/post_codes.h;hb=HEAD#l45">POST_RESET_VECTOR_CORRECT</a> + - Bootblock successfully executed the + <a target="_blank" href="http://review.coreboot.org/gitweb?p=coreboot.git;a=blob;f=src/cpu/x86/16bit/reset16.inc;hb=HEAD#l4">reset vector</a> + and entered the 16-bit code at + <a target="_blank" href="http://review.coreboot.org/gitweb?p=coreboot.git;a=blob;f=src/cpu/x86/16bit/entry16.inc;hb=HEAD#l35">_start</a> + </li> +</ul> + + +<hr> +<p>Modified: 27 January 2016</p> + </body> +</html> \ No newline at end of file
