srinivas.kulkarni@intel.com has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/81231?usp=email )
Change subject: vc/intel/fsp/mtl: Update header files from 3471_91 to 3471_92 ......................................................................
Update header files for FSP for Meteor Lake platform to version 3471_92, previous version being 3471_91.
FSPS: 1. Added UPD's ThcMode, ThcWakeOnTouch 2. Reserved bit changes
BUG=b:329548127 TEST=Able to build and boot google/rex to ChromeOS.
Change-Id: I19bd52ebdb14af5b768d996a4586eddef67e7033 --- M src/vendorcode/intel/fsp/fsp2_0/meteorlake/FspsUpd.h 1 file changed, 51 insertions(+), 36 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/31/81231/1
diff --git a/src/vendorcode/intel/fsp/fsp2_0/meteorlake/FspsUpd.h b/src/vendorcode/intel/fsp/fsp2_0/meteorlake/FspsUpd.h index 637bc37..e5c5847 100644 --- a/src/vendorcode/intel/fsp/fsp2_0/meteorlake/FspsUpd.h +++ b/src/vendorcode/intel/fsp/fsp2_0/meteorlake/FspsUpd.h @@ -1,6 +1,6 @@ /** @file
-Copyright (c) 2023, Intel Corporation. All rights reserved.<BR> +Copyright (c) 2024, Intel Corporation. All rights reserved.<BR>
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: @@ -1580,7 +1580,22 @@
/** Offset 0x08F2 - Reserved **/ - UINT8 Reserved39[122]; + UINT8 Reserved39[8]; + +/** Offset 0x08FA - Touch Host Controller Mode + Switch between Intel THC protocol and Industry standard HID Over SPI protocol. 0x0:Thc, 0x1:Hid +**/ + UINT8 ThcMode[2]; + +/** Offset 0x08FC - Touch Host Controller Wake On Touch + Based on this setting vGPIO for given THC will be in native mode, and additional + _CRS for wake will be exposed in ACPI +**/ + UINT8 ThcWakeOnTouch[2]; + +/** Offset 0x08FE - Reserved +**/ + UINT8 Reserved40[110];
/** Offset 0x096C - PCIE RP Pcie Speed Determines each PCIE Port speed capability. 0: Auto; 1: Gen1; 2: Gen2; 3: Gen3 (see: @@ -1628,7 +1643,7 @@
/** Offset 0x0A54 - Reserved **/ - UINT8 Reserved40[3767]; + UINT8 Reserved41[3767];
/** Offset 0x190B - PCIE RP Enable Peer Memory Write This member describes whether Peer Memory Writes are enabled on the platform. @@ -1651,7 +1666,7 @@
/** Offset 0x1919 - Reserved **/ - UINT8 Reserved41; + UINT8 Reserved42;
/** Offset 0x191A - PCH Pm PME_B0_S5_DIS When cleared (default), wake events from PME_B0_STS are allowed in S5 if PME_B0_EN = 1. @@ -1684,7 +1699,7 @@
/** Offset 0x191F - Reserved **/ - UINT8 Reserved42[4]; + UINT8 Reserved43[4];
/** Offset 0x1923 - PCH Pm Slp S3 Min Assert SLP_S3 Minimum Assertion Width Policy. Default is PchSlpS350ms. @@ -1820,7 +1835,7 @@
/** Offset 0x196C - Reserved **/ - UINT8 Reserved43[2]; + UINT8 Reserved44[2];
/** Offset 0x196E - Enable SATA Port DmVal DEVSLP Idle Timeout (DITO), Default is 625. @@ -1862,7 +1877,7 @@
/** Offset 0x1992 - Reserved **/ - UINT8 Reserved44[2]; + UINT8 Reserved45[2];
/** Offset 0x1994 - IEH Mode Integrated Error Handler Mode, 0: Bypass, 1: Enable @@ -1872,7 +1887,7 @@
/** Offset 0x1995 - Reserved **/ - UINT8 Reserved45[11]; + UINT8 Reserved46[11];
/** Offset 0x19A0 - PCH Thermal Throttling Custimized T0Level Value Custimized T0Level value. @@ -1910,7 +1925,7 @@
/** Offset 0x19A9 - Reserved **/ - UINT8 Reserved46[9]; + UINT8 Reserved47[9];
/** Offset 0x19B2 - DMI Thermal Sensor Autonomous Width Enable DMI Thermal Sensor Autonomous Width Enable. @@ -2018,7 +2033,7 @@
/** Offset 0x19C5 - Reserved **/ - UINT8 Reserved47; + UINT8 Reserved48;
/** Offset 0x19C6 - Thermal Device Temperature Decides the temperature. @@ -2043,7 +2058,7 @@
/** Offset 0x19E3 - Reserved **/ - UINT8 Reserved48; + UINT8 Reserved49;
/** Offset 0x19E4 - xHCI High Idle Time LTR override Value used for overriding LTR recommendation for xHCI High Idle Time LTR setting @@ -2086,7 +2101,7 @@
/** Offset 0x19F3 - Reserved **/ - UINT8 Reserved49[5]; + UINT8 Reserved50[5];
/** Offset 0x19F8 - BgpdtHash[4] BgpdtHash values @@ -2100,7 +2115,7 @@
/** Offset 0x1A1C - Reserved **/ - UINT8 Reserved50[4]; + UINT8 Reserved51[4];
/** Offset 0x1A20 - BiosGuardModulePtr BiosGuardModulePtr default values @@ -2126,7 +2141,7 @@
/** Offset 0x1A32 - Reserved **/ - UINT8 Reserved51[22]; + UINT8 Reserved52[22];
/** Offset 0x1A48 - Skip Ssid Programming. When set to TRUE, silicon code will not do any SSID programming and platform code @@ -2137,7 +2152,7 @@
/** Offset 0x1A49 - Reserved **/ - UINT8 Reserved52; + UINT8 Reserved53;
/** Offset 0x1A4A - Change Default SVID Change the default SVID used in FSP to programming internal devices. This is only @@ -2153,7 +2168,7 @@
/** Offset 0x1A4E - Reserved **/ - UINT8 Reserved53[2]; + UINT8 Reserved54[2];
/** Offset 0x1A50 - SVID SDID table Poniter. The address of the table of SVID SDID to customize each SVID SDID entry. This is @@ -2227,7 +2242,7 @@
/** Offset 0x1A6E - Reserved **/ - UINT8 Reserved54[127]; + UINT8 Reserved55[127];
/** Offset 0x1AED - Enable the write to USB 3.0 TX Output Unique Transition Bit Mode for rate 3 Enable the write to USB 3.0 TX Output Unique Transition Bit Mode for rate 3, Each @@ -2292,7 +2307,7 @@
/** Offset 0x1B3F - Reserved **/ - UINT8 Reserved55; + UINT8 Reserved56;
/** Offset 0x1B40 - GT Frequency Limit 0xFF: Auto(Default), 2: 100 Mhz, 3: 150 Mhz, 4: 200 Mhz, 5: 250 Mhz, 6: 300 Mhz, @@ -2316,7 +2331,7 @@
/** Offset 0x1B42 - Reserved **/ - UINT8 Reserved56[2]; + UINT8 Reserved57[2];
/** Offset 0x1B44 - Enable TSN Multi-VC Enable/disable Multi Virtual Channels(VC) in TSN. @@ -2326,7 +2341,7 @@
/** Offset 0x1B45 - Reserved **/ - UINT8 Reserved57[11]; + UINT8 Reserved58[11];
/** Offset 0x1B50 - LogoPixelHeight Address Address of LogoPixelHeight @@ -2340,7 +2355,7 @@
/** Offset 0x1B58 - Reserved **/ - UINT8 Reserved58; + UINT8 Reserved59;
/** Offset 0x1B59 - ITbt Usb4CmMode value ITbt Usb4CmMode value. 0:Firmware CM, 1:Software CM @@ -2349,7 +2364,7 @@
/** Offset 0x1B5A - Reserved **/ - UINT8 Reserved59[75]; + UINT8 Reserved60[75];
/** Offset 0x1BA5 - RSR feature Enable or Disable RSR feature; 0: Disable; <b>1: Enable </b> @@ -2359,7 +2374,7 @@
/** Offset 0x1BA6 - Reserved **/ - UINT8 Reserved60[4]; + UINT8 Reserved61[4];
/** Offset 0x1BAA - Enable or Disable HWP Enable/Disable Intel(R) Speed Shift Technology support. Enabling will expose the @@ -2756,7 +2771,7 @@
/** Offset 0x1C1A - Reserved **/ - UINT8 Reserved61[2]; + UINT8 Reserved62[2];
/** Offset 0x1C1C - Package Long duration turbo mode power limit Power Limit 1 in Milli Watts. BIOS will round to the nearest 1/8W when programming. @@ -2796,7 +2811,7 @@
/** Offset 0x1C2C - Reserved **/ - UINT8 Reserved62[4]; + UINT8 Reserved63[4];
/** Offset 0x1C30 - Tcc Offset Time Window for RATL **/ @@ -2873,7 +2888,7 @@
/** Offset 0x1C54 - Reserved **/ - UINT8 Reserved63; + UINT8 Reserved64;
/** Offset 0x1C55 - Race To Halt Enable/Disable Race To Halt feature. RTH will dynamically increase CPU frequency @@ -2885,7 +2900,7 @@
/** Offset 0x1C56 - Reserved **/ - UINT8 Reserved64; + UINT8 Reserved65;
/** Offset 0x1C57 - Set HW P-State Interrupts Enabled for for MISC_PWR_MGMT Set HW P-State Interrupts Enabled for for MISC_PWR_MGMT; <b>0: Disable</b>; 1: Enable. @@ -2895,7 +2910,7 @@
/** Offset 0x1C58 - Reserved **/ - UINT8 Reserved65[4]; + UINT8 Reserved66[4];
/** Offset 0x1C5C - Enable or Disable C1 Cstate Demotion Enable or Disable C1 Cstate Auto Demotion. Disable; <b>1: Enable</b> @@ -2953,7 +2968,7 @@
/** Offset 0x1C64 - Reserved **/ - UINT8 Reserved66; + UINT8 Reserved67;
/** Offset 0x1C65 - Dual Tau Boost Enable Dual Tau Boost feature. This is only applicable for Desktop 35W/65W/125W @@ -2964,7 +2979,7 @@
/** Offset 0x1C66 - Reserved **/ - UINT8 Reserved67[34]; + UINT8 Reserved68[34];
/** Offset 0x1C88 - End of Post message Test, Send End of Post message. Disable(0x0): Disable EOP message, Send in PEI(0x1): @@ -3002,7 +3017,7 @@
/** Offset 0x1C8D - Reserved **/ - UINT8 Reserved68[17]; + UINT8 Reserved69[17];
/** Offset 0x1C9E - Enable LOCKDOWN SMI Enable SMI_LOCK bit to prevent writes to the Global SMI Enable bit. @@ -3031,7 +3046,7 @@
/** Offset 0x1CA2 - Reserved **/ - UINT8 Reserved69[2]; + UINT8 Reserved70[2];
/** Offset 0x1CA4 - PCIE RP Ltr Max Snoop Latency Latency Tolerance Reporting, Max Snoop Latency. @@ -3080,7 +3095,7 @@
/** Offset 0x1E1D - Reserved **/ - UINT8 Reserved70; + UINT8 Reserved71;
/** Offset 0x1E1E - PCIE RP Slot Power Limit Value Specifies upper limit on power supplie by slot. Leave as 0 to set to default. @@ -3127,7 +3142,7 @@
/** Offset 0x1E5E - Reserved **/ - UINT8 Reserved71[105]; + UINT8 Reserved72[105];
/** Offset 0x1EC7 - PMC C10 dynamic threshold dajustment enable Set if you want to enable PMC C10 dynamic threshold adjustment. Only works on supported SKUs @@ -3137,7 +3152,7 @@
/** Offset 0x1EC8 - Reserved **/ - UINT8 Reserved72[36]; + UINT8 Reserved73[36];
/** Offset 0x1EEC - FspEventHandler <b>Optional</b> pointer to the boot loader's implementation of FSP_EVENT_HANDLER. @@ -3146,7 +3161,7 @@
/** Offset 0x1EF0 - Reserved **/ - UINT8 Reserved73[32]; + UINT8 Reserved74[32]; } FSP_S_CONFIG;
/** Fsp S UPD Configuration
