Wonkyu Kim has uploaded a new patch set (#12) to the change originally created by Ravishankar Sarawadi. ( https://review.coreboot.org/c/coreboot/+/37868 )
Change subject: mb/intel/tglrvp: Add initial mainboard code ......................................................................
This is a initial mainboard code aimed to serve as base for further mainboard check-ins.
This is a copy patch from icelake_rvp as on commit ID: I64db2460115f5fb35ca197b83440f8ee47470761
Below are the changes done over the copy patch:
1. Rename "Icelake" with "Tigerlake". 2. Replace "icelake_rvp" with "tglrvp". 3. Rename "icl" with "tgl". 4. Remove unwanted SPD file, add empty SPD as placeholder. 5. Replace "soc/intel/icelake" with "soc/intel/tigerlake". 6. Empty romstage_fsp_params.c, to fill it later with SOC specific config. 7. Empty GPIO configuration, to be filled as per board. 8. Change copyright year to 2019. 9. Add board support namely BOARD_INTEL_TGLRVP_UP3 10. Replace icl_u and icl_y variant with tglrvp variant. 11. Remove basebord gpio.c and rely on variant override. 12. Remove HDA verb table and config support.
Changes to follow on top of this: 1. Add correct memory parameters, add SPDs. 2. Clean up devicetree as per tigerlake SOC. 3. Add GPIO support. 4. Update chromeos.fmd to make 32MB BIOS region.
TEST=Build tigerlake rvp board
Signed-off-by: Ravi Sarawadi ravishankar.sarawadi@intel.com Change-Id: I86ada611de1cf28a1b872eea35cf41c0dc1c57f1 --- A src/mainboard/intel/tglrvp/Kconfig A src/mainboard/intel/tglrvp/Kconfig.name A src/mainboard/intel/tglrvp/Makefile.inc A src/mainboard/intel/tglrvp/acpi/mainboard.asl A src/mainboard/intel/tglrvp/board_id.c A src/mainboard/intel/tglrvp/board_id.h A src/mainboard/intel/tglrvp/board_info.txt A src/mainboard/intel/tglrvp/bootblock.c A src/mainboard/intel/tglrvp/chromeos.c A src/mainboard/intel/tglrvp/chromeos.fmd A src/mainboard/intel/tglrvp/dsdt.asl A src/mainboard/intel/tglrvp/mainboard.c A src/mainboard/intel/tglrvp/romstage_fsp_params.c A src/mainboard/intel/tglrvp/spd/Makefile.inc A src/mainboard/intel/tglrvp/spd/empty.spd.hex A src/mainboard/intel/tglrvp/spd/spd.h A src/mainboard/intel/tglrvp/spd/spd_util.c A src/mainboard/intel/tglrvp/variants/baseboard/include/baseboard/ec.h A src/mainboard/intel/tglrvp/variants/baseboard/include/baseboard/gpio.h A src/mainboard/intel/tglrvp/variants/baseboard/include/baseboard/variants.h A src/mainboard/intel/tglrvp/variants/tglrvp_up3/Makefile.inc A src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb A src/mainboard/intel/tglrvp/variants/tglrvp_up3/gpio.c 23 files changed, 1,220 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/37868/12
