Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/27369 )
Change subject: soc/intel/basecode: Add support for updating ucode loaded via FIT ......................................................................
Patch Set 38:
The implementation looks good. Only the update condition that Patrick R. already noticed seems concerning.
https://review.coreboot.org/#/c/27369/30/src/soc/intel/common/basecode/fw_up... File src/soc/intel/common/basecode/fw_update/ucode_update.c:
https://review.coreboot.org/#/c/27369/30/src/soc/intel/common/basecode/fw_up... PS30, Line 163: if (staging_rev != current_ucode || current_ucode != slot_rev ||
in a scenario where the header (which has ucode revision) is written completely but the ucode data i […]
If you want to handle a corrupted RW ucode this way, you'll need more safety guards. I mean check for exactly that condition `TS_ENABLE && staging_rev == slot_rev && current_ucode == slot_rev` Otherwise, you may rewrite the staging ucode for spurious reasons. For instance, think about what would happen if TS doesn't stick for some reasons, e.g. battery failure and somebody implemented ucode_update_reboot() as a cold boot. You could be running into a reboot loop constantly erasing and rewriting the staging ucode.
You could avoid this by explicitly checking before writing if slot_microcode and staging microcoding really differ.
Beside that one of the checks is really superfluous, the current `if` is the equivalent of:
if (staging_rev != current_ucode) version_mismatch = 1; else /* staging_rev == current_ucode */ if (current_ucode != slot_rev) version_mismatch = 1; else /* staging_rev == current_ucode && current_ucode == slot_rev */ if (staging_rev != slot_rev) /* impossible */ version_mismatch = 1;
I guess the control flow could be
if (staging_rev != slot_rev || current_ucode != slot_rev) { ... if (!memcmp(..., slot_microcode, get_microcode_size(...))) perform_update(slot_microcode); }
Or slightly optimized usual case:
if (staging_rev != slot_rev) { perform_update(slot_microcode); } else if (current_ucode != slot_rev) { ... if (!memcmp(..., slot_microcode, get_microcode_size(...))) perform_update(slot_microcode); }
