Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12377
commit 2e5ab67e0dca454d357aa6f71a7625ec3bf27333 Author: Stefan Reinauer stefan.reinauer@coreboot.org Date: Tue Nov 10 11:32:16 2015 -0800
[REMOVAL] tyan/s2880
As announced in http://permalink.gmane.org/gmane.linux.bios/81918 I am removing all boards older than 10 years from the tree.
Change-Id: Ifd1dfa35ae13ec01d932250994086edebece924d Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- src/mainboard/tyan/s2880/Kconfig | 49 -------- src/mainboard/tyan/s2880/Kconfig.name | 2 - src/mainboard/tyan/s2880/board_info.txt | 4 - src/mainboard/tyan/s2880/cmos.layout | 60 --------- src/mainboard/tyan/s2880/devicetree.cb | 98 --------------- src/mainboard/tyan/s2880/irq_tables.c | 34 ------ src/mainboard/tyan/s2880/mptable.c | 208 -------------------------------- src/mainboard/tyan/s2880/romstage.c | 116 ------------------ 8 files changed, 571 deletions(-)
diff --git a/src/mainboard/tyan/s2880/Kconfig b/src/mainboard/tyan/s2880/Kconfig deleted file mode 100644 index 62b4e70..0000000 --- a/src/mainboard/tyan/s2880/Kconfig +++ /dev/null @@ -1,49 +0,0 @@ -if BOARD_TYAN_S2880 - -config BOARD_SPECIFIC_OPTIONS # dummy - def_bool y - select CPU_AMD_SOCKET_940 - select NORTHBRIDGE_AMD_AMDK8 - select SOUTHBRIDGE_AMD_AMD8131 - select SOUTHBRIDGE_AMD_AMD8111 - select SUPERIO_WINBOND_W83627HF - select HAVE_OPTION_TABLE - select HAVE_PIRQ_TABLE - select HAVE_MP_TABLE - select BOARD_ROMSIZE_KB_512 - select SB_HT_CHAIN_UNITID_OFFSET_ONLY - select QRANK_DIMM_SUPPORT - -config MAINBOARD_DIR - string - default tyan/s2880 - -config APIC_ID_OFFSET - hex - default 0x0 - -config MAINBOARD_PART_NUMBER - string - default "S2880" - -config MAX_CPUS - int - default 2 - -config MAX_PHYSICAL_CPUS - int - default 2 - -config HT_CHAIN_UNITID_BASE - hex - default 0x1 - -config HT_CHAIN_END_UNITID_BASE - hex - default 0x20 - -config IRQ_SLOT_COUNT - int - default 13 - -endif # BOARD_TYAN_S2880 diff --git a/src/mainboard/tyan/s2880/Kconfig.name b/src/mainboard/tyan/s2880/Kconfig.name deleted file mode 100644 index 439e9aa..0000000 --- a/src/mainboard/tyan/s2880/Kconfig.name +++ /dev/null @@ -1,2 +0,0 @@ -config BOARD_TYAN_S2880 - bool "S2880 (Thunder K8S)" diff --git a/src/mainboard/tyan/s2880/board_info.txt b/src/mainboard/tyan/s2880/board_info.txt deleted file mode 100644 index cc3c490..0000000 --- a/src/mainboard/tyan/s2880/board_info.txt +++ /dev/null @@ -1,4 +0,0 @@ -Board name: Thunder K8S (S2880) -Category: server -Board URL: http://www.tyan.com/archive/products/html/thunderk8s.html -Release year: 2003 diff --git a/src/mainboard/tyan/s2880/cmos.layout b/src/mainboard/tyan/s2880/cmos.layout deleted file mode 100644 index 4e081ea..0000000 --- a/src/mainboard/tyan/s2880/cmos.layout +++ /dev/null @@ -1,60 +0,0 @@ -entries - -0 384 r 0 reserved_memory -384 1 e 4 boot_option -388 4 r 0 reboot_bits -392 3 e 5 baud_rate -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core -400 1 e 1 power_on_after_fail -412 4 e 6 debug_level -440 4 e 9 slow_cpu -444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory -728 256 h 0 user_data -984 16 h 0 check_sum -# Reserve the extended AMD configuration registers -1000 24 r 0 amd_reserved - - - -enumerations - -#ID value text -1 0 Disable -1 1 Enable -2 0 Enable -2 1 Disable -4 0 Fallback -4 1 Normal -5 0 115200 -5 1 57600 -5 2 38400 -5 3 19200 -5 4 9600 -5 5 4800 -5 6 2400 -5 7 1200 -6 6 Notice -6 7 Info -6 8 Debug -6 9 Spew -8 0 DDR400 -8 1 DDR333 -8 2 DDR266 -8 3 DDR200 -9 0 off -9 1 87.5% -9 2 75.0% -9 3 62.5% -9 4 50.0% -9 5 37.5% -9 6 25.0% -9 7 12.5% - -checksums - -checksum 392 983 984 diff --git a/src/mainboard/tyan/s2880/devicetree.cb b/src/mainboard/tyan/s2880/devicetree.cb deleted file mode 100644 index 3e18f55..0000000 --- a/src/mainboard/tyan/s2880/devicetree.cb +++ /dev/null @@ -1,98 +0,0 @@ -chip northbridge/amd/amdk8/root_complex - device cpu_cluster 0 on - chip cpu/amd/socket_940 - device lapic 0 on end - end - end - device domain 0 on - subsystemid 0x10f1 0x2880 inherit - chip northbridge/amd/amdk8 - device pci 18.0 on # northbridge - # devices on link 0, link 0 == LDT 0 - chip southbridge/amd/amd8131 - # the on/off keyword is mandatory - device pci 0.0 on - device pci 9.0 on end #broadcom - device pci 9.1 on end -# chip drivers/lsi/53c1030 -# device pci a.0 on end -# device pci a.1 on end -# register "fw_address" = "0xfff8c000" -# end - end - device pci 0.1 on end - device pci 1.0 on end - device pci 1.1 on end - end - chip southbridge/amd/amd8111 - # this "device pci 0.0" is the parent the next one - # PCI bridge - device pci 0.0 on - device pci 0.0 on end - device pci 0.1 on end - device pci 0.2 off end - device pci 1.0 off end - device pci 5.0 on end #some sata - device pci 6.0 on end #adti - end - device pci 1.0 on - chip superio/winbond/w83627hf - device pnp 2e.0 on # Floppy - io 0x60 = 0x3f0 - irq 0x70 = 6 - drq 0x74 = 2 - end - device pnp 2e.1 off # Parallel Port - io 0x60 = 0x378 - irq 0x70 = 7 - end - device pnp 2e.2 on # Com1 - io 0x60 = 0x3f8 - irq 0x70 = 4 - end - device pnp 2e.3 off # Com2 - io 0x60 = 0x2f8 - irq 0x70 = 3 - end - device pnp 2e.5 on # Keyboard - io 0x60 = 0x60 - io 0x62 = 0x64 - irq 0x70 = 1 - irq 0x72 = 12 - end - device pnp 2e.6 off # CIR - io 0x60 = 0x100 - end - device pnp 2e.7 off # GAME_MIDI_GIPO1 - io 0x60 = 0x220 - io 0x62 = 0x300 - irq 0x70 = 9 - end - device pnp 2e.8 off end # GPIO2 - device pnp 2e.9 off end # GPIO3 - device pnp 2e.a off end # ACPI - device pnp 2e.b on # HW Monitor - io 0x60 = 0x290 - irq 0x70 = 5 - end - end - end - device pci 1.1 on end - device pci 1.2 on end - device pci 1.3 on end - device pci 1.5 off end - device pci 1.6 off end - register "ide0_enable" = "1" - register "ide1_enable" = "1" - end - end # device pci 18.0 - - device pci 18.0 on end - device pci 18.0 on end - - device pci 18.1 on end - device pci 18.2 on end - device pci 18.3 on end - end - end -end diff --git a/src/mainboard/tyan/s2880/irq_tables.c b/src/mainboard/tyan/s2880/irq_tables.c deleted file mode 100644 index be08105..0000000 --- a/src/mainboard/tyan/s2880/irq_tables.c +++ /dev/null @@ -1,34 +0,0 @@ -#include <arch/pirq_routing.h> - -static const struct irq_routing_table intel_irq_routing_table = { - PIRQ_SIGNATURE, /* u32 signature */ - PIRQ_VERSION, /* u16 version */ - 32+16*CONFIG_IRQ_SLOT_COUNT, /* there can be total CONFIG_IRQ_SLOT_COUNT devices on the bus */ - 1, /* Where the interrupt router lies (bus) */ - (4<<3)|3, /* Where the interrupt router lies (dev) */ - 0, /* IRQs devoted exclusively to PCI usage */ - 0x1022, /* Vendor */ - 0x746b, /* Device */ - 0, /* Miniport data */ - { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ - 0x59, /* u8 checksum , this hase to set to some value that would give 0 after the sum of all bytes for this structure (including checksum) */ - { - {1,(4<<3)|0, {{0x1, 0xdef8}, {0x2, 0xdef8}, {0x3, 0xdef8}, {0x4, 0xdef8}}, 0, 0}, - {0x4,0, {{0, 0}, {0, 0}, {0, 0}, {0x4, 0xdef8}}, 0, 0}, - {0x3,(3<<3)|0, {{0x1, 0xdef8}, {0x2, 0xdef8}, {0x3, 0xdef8}, {0x4, 0xdef8}}, 0x1, 0}, - {0x3,(6<<3)|0, {{0x2, 0xdef8}, {0x3, 0xdef8}, {0x4, 0xdef8}, {0x1, 0xdef8}}, 0x2, 0}, - {0x2,(8<<3)|0, {{0x4, 0xdef8}, {0x1, 0xdef8}, {0x2, 0xdef8}, {0x3, 0xdef8}}, 0x3, 0}, - {0x2,(7<<3)|0, {{0x3, 0xdef8}, {0x4, 0xdef8}, {0x1, 0xdef8}, {0x2, 0xdef8}}, 0x4, 0}, - {0x4,(6<<3)|0, {{0x3, 0xdef8}, {0, 0}, {0, 0}, {0, 0}}, 0, 0}, - {0x4,(4<<3)|0, {{0x1, 0xdef8}, {0x2, 0xdef8}, {0x3, 0xdef8}, {0x4, 0xdef8}}, 0x5, 0}, - {0x2,(9<<3)|0, {{0x1, 0xdef8}, {0x2, 0xdef8}, {0, 0}, {0, 0}}, 0, 0}, - {0x2,(0xa<<3)|0, {{0x1, 0xdef8}, {0x2, 0xdef8}, {0, 0}, {0, 0}}, 0, 0}, - {0x4,(5<<3)|0, {{0x2, 0xdef8}, {0, 0}, {0, 0}, {0, 0}}, 0, 0}, - {0x3,(4<<3)|0, {{0x2, 0xdef8}, {0x3, 0xdef8}, {0x4, 0xdef8}, {0x1, 0xdef8}}, 0x6, 0}, - {0x3,(5<<3)|0, {{0x3, 0xdef8}, {0x4, 0xdef8}, {0x1, 0xdef8}, {0x2, 0xdef8}}, 0x7, 0}, - } -}; -unsigned long write_pirq_routing_table(unsigned long addr) -{ - return copy_pirq_routing_table(addr, &intel_irq_routing_table); -} diff --git a/src/mainboard/tyan/s2880/mptable.c b/src/mainboard/tyan/s2880/mptable.c deleted file mode 100644 index 10db9bb..0000000 --- a/src/mainboard/tyan/s2880/mptable.c +++ /dev/null @@ -1,208 +0,0 @@ -#include <console/console.h> -#include <arch/smp/mpspec.h> -#include <arch/ioapic.h> -#include <device/pci.h> -#include <string.h> -#include <stdint.h> -#if CONFIG_LOGICAL_CPUS -#include <cpu/amd/multicore.h> -#endif - -static unsigned node_link_to_bus(unsigned node, unsigned link) -{ - device_t dev; - unsigned reg; - - dev = dev_find_slot(0, PCI_DEVFN(0x18, 1)); - if (!dev) { - return 0; - } - for(reg = 0xE0; reg < 0xF0; reg += 0x04) { - uint32_t config_map; - unsigned dst_node; - unsigned dst_link; - unsigned bus_base; - config_map = pci_read_config32(dev, reg); - if ((config_map & 3) != 3) { - continue; - } - dst_node = (config_map >> 4) & 7; - dst_link = (config_map >> 8) & 3; - bus_base = (config_map >> 16) & 0xff; -#if 0 - printk(BIOS_DEBUG, "node.link=bus: %d.%d=%d 0x%2x->0x%08x\n", - dst_node, dst_link, bus_base, - reg, config_map); -#endif - if ((dst_node == node) && (dst_link == link)) - { - return bus_base; - } - } - return 0; -} - -static void *smp_write_config_table(void *v) -{ - struct mp_config_table *mc; - int bus_isa; - unsigned char bus_chain_0; - unsigned char bus_8131_1; - unsigned char bus_8131_2; - unsigned char bus_8111_1; - unsigned apicid_base; - unsigned apicid_8111; - unsigned apicid_8131_1; - unsigned apicid_8131_2; - - mc = (void *)(((char *)v) + SMP_FLOATING_TABLE_LEN); - - mptable_init(mc, LOCAL_APIC_ADDR); - - smp_write_processors(mc); - - { - device_t dev; - - /* HT chain 0 */ - bus_chain_0 = node_link_to_bus(0, 0); - if (bus_chain_0 == 0) { - printk(BIOS_DEBUG, "ERROR - cound not find bus for node 0 chain 0, using defaults\n"); - bus_chain_0 = 1; - } - - /* 8111 */ - dev = dev_find_slot(bus_chain_0, PCI_DEVFN(0x03,0)); - if (dev) { - bus_8111_1 = pci_read_config8(dev, PCI_SECONDARY_BUS); - } - else { - printk(BIOS_DEBUG, "ERROR - could not find PCI 1:03.0, using defaults\n"); - - bus_8111_1 = 4; - } - /* 8131-1 */ - dev = dev_find_slot(bus_chain_0, PCI_DEVFN(0x01,0)); - if (dev) { - bus_8131_1 = pci_read_config8(dev, PCI_SECONDARY_BUS); - - } - else { - printk(BIOS_DEBUG, "ERROR - could not find PCI 1:01.0, using defaults\n"); - - bus_8131_1 = 2; - } - /* 8131-2 */ - dev = dev_find_slot(bus_chain_0, PCI_DEVFN(0x02,0)); - if (dev) { - bus_8131_2 = pci_read_config8(dev, PCI_SECONDARY_BUS); - - } - else { - printk(BIOS_DEBUG, "ERROR - could not find PCI 1:02.0, using defaults\n"); - - bus_8131_2 = 3; - } - } - -/*Bus: Bus ID Type*/ - mptable_write_buses(mc, NULL, &bus_isa); - -/*I/O APICs: APIC ID Version State Address*/ -#if CONFIG_LOGICAL_CPUS - apicid_base = get_apicid_base(3); -#else - apicid_base = CONFIG_MAX_PHYSICAL_CPUS; -#endif - apicid_8111 = apicid_base+0; - apicid_8131_1 = apicid_base+1; - apicid_8131_2 = apicid_base+2; - smp_write_ioapic(mc, apicid_8111, 0x11, VIO_APIC_VADDR); - { - - device_t dev; - struct resource *res; - dev = dev_find_slot(bus_chain_0, PCI_DEVFN(0x1,1)); - if (dev) { - res = find_resource(dev, PCI_BASE_ADDRESS_0); - if (res) { - smp_write_ioapic(mc, apicid_8131_1, 0x11, - res2mmio(res, 0, 0)); - } - } - dev = dev_find_slot(bus_chain_0, PCI_DEVFN(0x2,1)); - if (dev) { - res = find_resource(dev, PCI_BASE_ADDRESS_0); - if (res) { - smp_write_ioapic(mc, apicid_8131_2, 0x11, - res2mmio(res, 0, 0)); - } - } - - } - - mptable_add_isa_interrupts(mc, bus_isa, apicid_8111, 0); - -/*I/O Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_chain_0, (4<<2)|0, apicid_8111, 0x13); - - -//On Board AMD USB - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (0<<2)|3, apicid_8111, 0x13); - -//On Board ATI Display Adapter - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (6<<2)|0, apicid_8111, 0x12); - -//Slot 5 PCI 32 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (4<<2)|0, apicid_8111, 0x10); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (4<<2)|1, apicid_8111, 0x11); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (4<<2)|2, apicid_8111, 0x12); // - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (4<<2)|3, apicid_8111, 0x13); // - -//On Board Promise Serial ATA - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (5<<2)|0, apicid_8111, 0x11); - -//Slot 3 PCIX 100/66 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (8<<2)|0, apicid_8131_1, 0x3); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (8<<2)|1, apicid_8131_1, 0x0); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (8<<2)|2, apicid_8131_1, 0x1);// - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (8<<2)|3, apicid_8131_1, 0x2);// - -//Slot 4 PCIX 100/66 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (7<<2)|0, apicid_8131_1, 0x2); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (7<<2)|1, apicid_8131_1, 0x3);// - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (7<<2)|2, apicid_8131_1, 0x0);// - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (7<<2)|3, apicid_8131_1, 0x1);// - -//On Board NIC and LSI scsi - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (9<<2)|0, apicid_8131_1, 0x0); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (9<<2)|1, apicid_8131_1, 0x1); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (0xa<<2)|0, apicid_8131_1, 0x0); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (0xa<<2)|1, apicid_8131_1, 0x1); - -//Slot 1 PCI-X 133/100/66 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (3<<2)|0, apicid_8131_2, 0x0); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (3<<2)|1, apicid_8131_2, 0x1); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (3<<2)|2, apicid_8131_2, 0x2); // - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (3<<2)|3, apicid_8131_2, 0x3); // - -//Slot 2 PCI-X 133/100/66 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (6<<2)|0, apicid_8131_2, 0x1); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (6<<2)|1, apicid_8131_2, 0x2); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (6<<2)|2, apicid_8131_2, 0x3);// - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (6<<2)|3, apicid_8131_2, 0x0);// - -/*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN#*/ - mptable_lintsrc(mc, bus_isa); - /* There is no extension information... */ - - /* Compute the checksums */ - return mptable_finalize(mc); -} - -unsigned long write_smp_table(unsigned long addr) -{ - void *v; - v = smp_write_floating_table(addr, 0); - return (unsigned long)smp_write_config_table(v); -} diff --git a/src/mainboard/tyan/s2880/romstage.c b/src/mainboard/tyan/s2880/romstage.c deleted file mode 100644 index dba58f2..0000000 --- a/src/mainboard/tyan/s2880/romstage.c +++ /dev/null @@ -1,116 +0,0 @@ -#include <stdint.h> -#include <string.h> -#include <device/pci_def.h> -#include <arch/io.h> -#include <device/pnp_def.h> -#include <stdlib.h> -#include <pc80/mc146818rtc.h> -#include <console/console.h> -#include <lib.h> -#include <spd.h> -#include <cpu/amd/model_fxx_rev.h> -#include "northbridge/amd/amdk8/incoherent_ht.c" -#include "southbridge/amd/amd8111/early_smbus.c" -#include <northbridge/amd/amdk8/raminit.h> -#include <delay.h> -#include "northbridge/amd/amdk8/reset_test.c" -#include "northbridge/amd/amdk8/debug.c" -#include <superio/winbond/common/winbond.h> -#include <superio/winbond/w83627hf/w83627hf.h> -#include <cpu/x86/bist.h> -#include "northbridge/amd/amdk8/setup_resource_map.c" -#include "southbridge/amd/amd8111/early_ctrl.c" - -#define SERIAL_DEV PNP_DEV(0x2e, W83627HF_SP1) - -static void memreset_setup(void) -{ - if (is_cpu_pre_c0()) - outb((1<<2)|(0<<0), SMBUS_IO_BASE + 0xc0 + 16); //REVC_MEMRST_EN=0 - else - outb((1<<2)|(1<<0), SMBUS_IO_BASE + 0xc0 + 16); //REVC_MEMRST_EN=1 - outb((1<<2)|(0<<0), SMBUS_IO_BASE + 0xc0 + 17); -} - -static void memreset(int controllers, const struct mem_controller *ctrl) -{ - if (is_cpu_pre_c0()) { - udelay(800); - outb((1<<2)|(1<<0), SMBUS_IO_BASE + 0xc0 + 17); //REVB_MEMRST_L=1 - udelay(90); - } -} - -static void activate_spd_rom(const struct mem_controller *ctrl) { } - -static inline int spd_read_byte(unsigned device, unsigned address) -{ - return smbus_read_byte(device, address); -} - -#include "northbridge/amd/amdk8/raminit.c" -#include "northbridge/amd/amdk8/resourcemap.c" -#include "northbridge/amd/amdk8/coherent_ht.c" -#include "lib/generic_sdram.c" -#include "cpu/amd/dualcore/dualcore.c" -#include "cpu/amd/model_fxx/init_cpus.c" - -void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) -{ - static const struct mem_controller cpu[] = { - { - .node_id = 0, - .f0 = PCI_DEV(0, 0x18, 0), - .f1 = PCI_DEV(0, 0x18, 1), - .f2 = PCI_DEV(0, 0x18, 2), - .f3 = PCI_DEV(0, 0x18, 3), - .channel0 = { DIMM0, DIMM2, 0, 0 }, - .channel1 = { DIMM1, DIMM3, 0, 0 }, - }, -#if CONFIG_MAX_PHYSICAL_CPUS > 1 - { - .node_id = 1, - .f0 = PCI_DEV(0, 0x19, 0), - .f1 = PCI_DEV(0, 0x19, 1), - .f2 = PCI_DEV(0, 0x19, 2), - .f3 = PCI_DEV(0, 0x19, 3), - .channel0 = { DIMM4, DIMM6, 0, 0 }, - .channel1 = { DIMM5, DIMM7, 0, 0 }, - }, -#endif - }; - - int needs_reset; - - if (bist == 0) - init_cpus(cpu_init_detectedx); - - winbond_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); - console_init(); - - /* Halt if there was a built in self test failure */ - report_bist_failure(bist); - - setup_default_resource_map(); - - needs_reset = setup_coherent_ht_domain(); - -#if CONFIG_LOGICAL_CPUS - // It is said that we should start core1 after all core0 launched - start_other_cores(); -#endif - // automatically set that for you, but you might meet tight space - needs_reset |= ht_setup_chains_x(); - - if (needs_reset) { - printk(BIOS_INFO, "ht reset -\n"); - soft_reset(); - } - - enable_smbus(); - - memreset_setup(); - sdram_initialize(ARRAY_SIZE(cpu), cpu); - - post_cache_as_ram(); -}
