Attention is currently required from: Kevin Chang, Paul Menzel, Tim Wawrzynczak, YH Lin. Joey Peng has uploaded a new patch set (#13) to the change originally created by Kevin Chang. ( https://review.coreboot.org/c/coreboot/+/60341 )
Change subject: mb/google/brya/var/taeko: Run-time probe for NVMe SSD and MMC ......................................................................
Taeko will use two PCIE port signals with one slot, one CLK and one CLKREQ. In order to accommodate this, probe statements are added to the devicetree. This only affects NVME SSD and EMMC.
BUG=b:211914322 TEST=Test on takeo trace in FSP log can find the correct root ports have been set depending on CBI.
Cq-Depend: chromium:3358662 Signed-off-by: Kevin Chang kevin.chang@lcfc.corp-partner.google.com Change-Id: I4486f23ea02374c84a9b1ce04f568d78aeabd573 --- M src/mainboard/google/brya/variants/taeko/overridetree.cb 1 file changed, 12 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/41/60341/13
