Attention is currently required from: Christian Walter, Jonathan Zhang, Krystian Hebel, Martin L Roth, Martin Roth, Michał Żygowski, Sergii Dmytruk.
Hello Christian Walter, Felix Held, Jonathan Zhang, Krystian Hebel, Martin L Roth, Martin Roth, Michał Żygowski, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/67057?usp=email
to look at the new patch set (#23).
Change subject: drivers/ipmi: add Block Transfer (BT) interface ......................................................................
Unlike already implemented Keyboard Controller Style (KCS) interface Block Transfer interface is not byte-oriented and implies that device is capable of buffering command before processing it. Another difference is that polling can be replaced with interrupts, though not used by this implementation.
Change-Id: Idb67972d1c38bbae04c7b4de3405350c229a05b9 Signed-off-by: Sergii Dmytruk sergii.dmytruk@3mdeb.com --- M Documentation/drivers/index.md A Documentation/drivers/ipmi_bt.md M src/drivers/ipmi/Kconfig M src/drivers/ipmi/Makefile.mk A src/drivers/ipmi/ipmi_bt.c A src/drivers/ipmi/ipmi_bt.h A src/drivers/ipmi/ipmi_bt_ops.c M src/drivers/ipmi/ipmi_ops_premem.c 8 files changed, 404 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/57/67057/23
