Duncan Laurie has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/52737 )
Change subject: libpayload: i8042: Enable keyboard translation by defualt on exit ......................................................................
Add a Kconfig option to set the keyboard translation state on exit and set the default to true. This restores the keyboard to the power-up defaults for firmware that does not always run libpayload keyboard init to have consistent state, and provides an option to disable translation for keyboards that might need it.
Change-Id: I25dfe3f425a5bb57e97476564886672b707aa3bd Signed-off-by: Duncan Laurie dlaurie@google.com --- M payloads/libpayload/Kconfig M payloads/libpayload/drivers/i8042/keyboard.c 2 files changed, 6 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/52737/1
diff --git a/payloads/libpayload/Kconfig b/payloads/libpayload/Kconfig index 7a502b5..f7d78e0 100644 --- a/payloads/libpayload/Kconfig +++ b/payloads/libpayload/Kconfig @@ -385,6 +385,11 @@ depends on PC_KEYBOARD default n
+config PC_KEYBOARD_TRANSLATION + bool "Enable or Disable translation in PC keyboard set 2 on exit" + depends on PC_KEYBOARD + default y + endmenu
menu "Drivers" diff --git a/payloads/libpayload/drivers/i8042/keyboard.c b/payloads/libpayload/drivers/i8042/keyboard.c index a695723..952f5f1 100644 --- a/payloads/libpayload/drivers/i8042/keyboard.c +++ b/payloads/libpayload/drivers/i8042/keyboard.c @@ -658,7 +658,7 @@ /* Nobody but us seems to still use scancode set #1. So try to hand over with more modern settings. */ set_scancode_set(2); - i8042_set_kbd_translation(false); + i8042_set_kbd_translation(CONFIG(LP_PC_KEYBOARD_TRANSLATION));
/* Send keyboard disconnect command */ i8042_cmd(I8042_CMD_DIS_KB);
