HAOUAS Elyes has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/41632 )
Change subject: sb/intel/i82801gx/early_init: Use pci_update_config ......................................................................
Change-Id: Ibe5a6cab384594ef023abd7dc9246c0d7bd7c8c4 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/southbridge/intel/i82801gx/early_init.c 1 file changed, 4 insertions(+), 15 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/32/41632/1
diff --git a/src/southbridge/intel/i82801gx/early_init.c b/src/southbridge/intel/i82801gx/early_init.c index a913873..b2963b5 100644 --- a/src/southbridge/intel/i82801gx/early_init.c +++ b/src/southbridge/intel/i82801gx/early_init.c @@ -61,9 +61,6 @@ #if ENV_ROMSTAGE void i82801gx_early_init(void) { - uint8_t reg8; - uint32_t reg32; - enable_smbus();
/* Setting up Southbridge. In the northbridge code. */ @@ -84,22 +81,14 @@ pci_write_config8(PCI_DEV(0, 0x1e, 0), SMLT, 0x20);
/* reset rtc power status */ - reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), GEN_PMCON_3); - reg8 &= ~RTC_BATTERY_DEAD; - pci_write_config8(PCI_DEV(0, 0x1f, 0), GEN_PMCON_3, reg8); + pci_update_config8(PCI_DEV(0, 0x1f, 0), GEN_PMCON_3, ~RTC_BATTERY_DEAD, 0);
/* USB transient disconnect */ - reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xad); - reg8 |= (3 << 0); - pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xad, reg8); + pci_update_config8(PCI_DEV(0, 0x1f, 0), 0xad, ~0, (3 << 0));
- reg32 = pci_read_config32(PCI_DEV(0, 0x1d, 7), 0xfc); - reg32 |= (1 << 29) | (1 << 17); - pci_write_config32(PCI_DEV(0, 0x1d, 7), 0xfc, reg32); + pci_update_config32(PCI_DEV(0, 0x1d, 7), 0xfc, ~0, (1 << 29) | (1 << 17));
- reg32 = pci_read_config32(PCI_DEV(0, 0x1d, 7), 0xdc); - reg32 |= (1 << 31) | (1 << 27); - pci_write_config32(PCI_DEV(0, 0x1d, 7), 0xdc, reg32); + pci_update_config32(PCI_DEV(0, 0x1d, 7), 0xdc, ~0, (1 << 31) | (1 << 27));
/* Enable IOAPIC */ RCBA8(OIC) = 0x03;
HAOUAS Elyes has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/41632 )
Abandoned
Merge conflict
