Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4913
commit f96280caaef6fbd65fcf385f4b3b810188d01cf9 Author: Shawn Nematbakhsh shawnn@chromium.org Date: Mon Oct 28 16:15:02 2013 -0700
baytrail: Add SATA driver
Add SATA driver for baytrail platform.
BUG=chrome-os-partner:23643 TEST=Manual, in dev mode. Verify on rambi that SATA disk is detected, and kernel is found + booted.
Change-Id: I5c13e03203c8f26d233c7d10af8ff6812c460578 Signed-off-by: Shawn Nematbakhsh shawnn@chromium.org Reviewed-on: https://chromium-review.googlesource.com/174914 Reviewed-by: Aaron Durbin adurbin@chromium.org Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/soc/intel/baytrail/Makefile.inc | 1 + src/soc/intel/baytrail/baytrail/pci_devs.h | 6 +- src/soc/intel/baytrail/baytrail/sata.h | 26 ++++ src/soc/intel/baytrail/chip.h | 10 +- src/soc/intel/baytrail/sata.c | 240 +++++++++++++++++++++++++++++ 5 files changed, 279 insertions(+), 4 deletions(-)
diff --git a/src/soc/intel/baytrail/Makefile.inc b/src/soc/intel/baytrail/Makefile.inc index 3e62ccf..ad3f94f 100644 --- a/src/soc/intel/baytrail/Makefile.inc +++ b/src/soc/intel/baytrail/Makefile.inc @@ -33,6 +33,7 @@ smm-y += smihandler.c ramstage-y += smm.c ramstage-y += southcluster.c ramstage-$(CONFIG_HAVE_REFCODE_BLOB) += refcode.c +ramstage-y += sata.c
# Remove as ramstage gets fleshed out ramstage-y += placeholders.c diff --git a/src/soc/intel/baytrail/baytrail/pci_devs.h b/src/soc/intel/baytrail/baytrail/pci_devs.h index f20102a..6b38a71 100644 --- a/src/soc/intel/baytrail/baytrail/pci_devs.h +++ b/src/soc/intel/baytrail/baytrail/pci_devs.h @@ -45,8 +45,10 @@ /* SATA */ #define SATA_DEV 19 #define SATA_FUNC 0 -# define ACHI1_DEVID 0x0f22 -# define ACHI2_DEVID 0x0f23 +#define IDE1_DEVID 0x0f20 +#define IDE2_DEVID 0x0f21 +#define AHCI1_DEVID 0x0f22 +#define AHCI2_DEVID 0x0f23
/* xHCI */ #define XHCI_DEV 20 diff --git a/src/soc/intel/baytrail/baytrail/sata.h b/src/soc/intel/baytrail/baytrail/sata.h new file mode 100644 index 0000000..7704c18 --- /dev/null +++ b/src/soc/intel/baytrail/baytrail/sata.h @@ -0,0 +1,26 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef BAYTRAIL_SATA_H +#define BAYTRAIL_SATA_H + +#define SATA_SIRI 0xa0 +#define SATA_SIRD 0xa4 + +#endif diff --git a/src/soc/intel/baytrail/chip.h b/src/soc/intel/baytrail/chip.h index b6d3f84..d17474f 100644 --- a/src/soc/intel/baytrail/chip.h +++ b/src/soc/intel/baytrail/chip.h @@ -17,12 +17,18 @@ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */
-#ifndef _BAYTRAIL_CHIP_H_ -#define _BAYTRAIL_CHIP_H_ /* The devicetree parser expects chip.h to reside directly in the path * specified by the devicetree. */
+#ifndef _BAYTRAIL_CHIP_H_ +#define _BAYTRAIL_CHIP_H_ + +#include <stdint.h> + struct soc_intel_baytrail_config { + uint8_t sata_port_map; + uint8_t sata_ahci; + uint8_t ide_legacy_combined; };
extern struct chip_operations soc_intel_baytrail_ops; diff --git a/src/soc/intel/baytrail/sata.c b/src/soc/intel/baytrail/sata.c new file mode 100644 index 0000000..18b7fdf --- /dev/null +++ b/src/soc/intel/baytrail/sata.c @@ -0,0 +1,240 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <arch/io.h> +#include <baytrail/pci_devs.h> +#include <baytrail/ramstage.h> +#include <baytrail/sata.h> +#include <console/console.h> +#include <delay.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> + +#include "chip.h" + +typedef struct soc_intel_baytrail_config config_t; + +static inline void sir_write(struct device *dev, int idx, u32 value) +{ + pci_write_config32(dev, SATA_SIRI, idx); + pci_write_config32(dev, SATA_SIRD, value); +} + +static void sata_init(struct device *dev) +{ + config_t *config = dev->chip_info; + u32 reg32; + u16 reg16; + u8 reg8; + + printk(BIOS_DEBUG, "SATA: Initializing...\n"); + + if (config == NULL) { + printk(BIOS_ERR, "SATA: ERROR: Device not in devicetree.cb!\n"); + return; + } + + if (!config->sata_ahci) { + /* Set legacy or native decoding mode */ + if (config->ide_legacy_combined) { + reg8 = pci_read_config8(dev, 0x09); + reg8 &= ~0x5; + pci_write_config8(dev, 0x09, reg8); + } else { + reg8 = pci_read_config8(dev, 0x09); + reg8 |= 0x5; + pci_write_config8(dev, 0x09, reg8); + } + + /* Set capabilities pointer */ + pci_write_config8(dev, 0x34, 0x70); + reg16 = pci_read_config16(dev, 0x70); + reg16 &= ~0xFF00; + pci_write_config16(dev, 0x70, reg16); + } + + /* Primary timing - decode enable */ + reg16 = pci_read_config16(dev, 0x40); + reg16 |= 1 << 15; + pci_write_config16(dev, 0x40, reg16); + + /* Secondary timing - decode enable */ + reg16 = pci_read_config16(dev, 0x42); + reg16 |= 1 << 15; + pci_write_config16(dev, 0x42, reg16); + + /* Port mapping enables */ + reg16 = pci_read_config16(dev, 0x90); + reg16 |= (config->sata_port_map ^ 0x3) << 8; + pci_write_config16(dev, 0x90, reg16); + + /* Port control enables */ + reg16 = pci_read_config16(dev, 0x92); + reg16 &= ~0x003f; + reg16 |= config->sata_port_map; + pci_write_config16(dev, 0x92, reg16); + + if (config->sata_ahci) { + u32 abar = pci_read_config32(dev, PCI_BASE_ADDRESS_5); + + /* Enable CR memory space decoding */ + reg16 = pci_read_config16(dev, 0x04); + reg16 |= 0x2; + pci_write_config16(dev, 0x04, reg16); + + /* Set capibility register */ + reg32 = read32(abar + 0x00); + reg32 |= 0x0c046000; // set PSC+SSC+SALP+SSS+SAM + reg32 &= ~0x00f20060; // clear SXS+EMS+PMS+gen bits + reg32 |= (0x3 << 20); // Gen3 SATA + write32(abar + 0x00, reg32); + + /* Ports enabled */ + reg32 = read32(abar + 0x0c); + reg32 &= (u32)(~0x3f); + reg32 |= config->sata_port_map; + write32(abar + 0xc, reg32); + /* Two extra reads to latch */ + read32(abar + 0x0c); + read32(abar + 0x0c); + + /* Set cap2 - Support devslp */ + reg32 = (1 << 5) | (1 << 4) | (1 << 3); + write32(abar + 0x24, reg32); + + /* Set PxCMD registers */ + reg32 = read32(abar + 0x118); + reg32 &= ~((1 << 27) | (1 << 26) | (1 << 22) | (1 << 21) | + (1 << 19) | (1 << 18) | (1 << 1)); + reg32 |= 2; + write32(abar + 0x118, reg32); + + reg32 = read32(abar + 0x198); + reg32 &= ~((1 << 27) | (1 << 26) | (1 << 22) | (1 << 21) | + (1 << 19) | (1 << 18) | (1 << 1)); + reg32 |= 2; + write32(abar + 0x198, reg32); + + /* Clear reset features */ + write32(abar + 0xc8, 0); + + /* Enable interrupts */ + reg8 = read8(abar + 0x04); + reg8 |= 0x02; + write8(abar + 0x04, reg8); + + } else { + /* TODO(shawnn): Configure IDE SATA speed regs */ + } + + /* 1.4 us delay after configuring port / enable bits */ + udelay(2); + + /* Enable clock for ports */ + reg32 = pci_read_config32(dev, 0x94); + reg32 |= 0x3f << 24; + pci_write_config32(dev, 0x94, reg32); + reg32 &= (config->sata_port_map ^ 0x3) << 24; + pci_write_config32(dev, 0x94, reg32); + + /* Lock SataGc register */ + reg32 = (0x1 << 31) | (0x7 << 12); + pci_write_config32(dev, 0x98, reg32); +} + +static void sata_enable(device_t dev) +{ + config_t *config = dev->chip_info; + u8 reg8; + u16 reg16; + u32 reg32; + + southcluster_enable_dev(dev); + if (!config) + return; + + /* Port mapping -- mask off SPD + SMS + SC bits, then re-set */ + reg16 = pci_read_config16(dev, 0x90); + reg16 &= ~0x03e0; + reg16 |= (config->sata_port_map ^ 0x3) << 8; + if(config->sata_ahci) + reg16 |= 0x60; + pci_write_config16(dev, 0x90, reg16); + + /* Set reg 0x94 before starting configuration */ + reg32 = pci_read_config32(dev, 0x94); + reg32 &= (u32)(~0x1ff); + reg32 |= 0x183; + pci_write_config32(dev, 0x94, reg32); + + /* Set ORM bit */ + reg16 = pci_read_config16(dev, 0x92); + reg16 |= (1 << 15); + pci_write_config16(dev, 0x92, reg16); + + /* R_PCH_SATA_TM2 - Undocumented in EDS, set according to ref. code */ + reg32 = pci_read_config32(dev, 0x98); + reg32 &= (u32)~(0x1f80 | (1 << 6) | (1 << 5)); + reg32 |= (1 << 29) | (1 << 25) | (1 << 23) | (1 << 22) | + (1 << 20) | (1 << 19) | (1 << 18) | (1 << 9) | (1 << 5); + pci_write_config32(dev, 0x98, reg32); + + /* CMD reg - set bus master enable (BME) */ + reg8 = pci_read_config8(dev, 0x04); + reg8 |= (1 << 2); + pci_write_config8(dev, 0x04, reg8); + + /* "Test mode registers" */ + sir_write(dev, 0x70, 0x00288301); + sir_write(dev, 0x54, 0x00000300); + sir_write(dev, 0x58, 0x50000000); + /* "OOB Detection Margin */ + sir_write(dev, 0x6c, 0x130C0603); + /* "Gasket Control" */ + sir_write(dev, 0xf4, 0); + + /* PCS - Enable requested SATA ports */ + reg8 = pci_read_config8(dev, 0x92); + reg8 &= ~0x03; + reg8 |= config->sata_port_map; + pci_write_config8(dev, 0x92, reg8); +} + +static struct device_operations sata_ops = { + .read_resources = pci_dev_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = sata_init, + .enable = sata_enable, + .scan_bus = NULL, + .ops_pci = &soc_pci_ops, +}; + +static const unsigned short pci_device_ids[] = { + IDE1_DEVID, IDE2_DEVID, /* IDE */ + AHCI1_DEVID, AHCI2_DEVID, /* AHCI */ + 0, +}; + +static const struct pci_driver baytrail_sata __pci_driver = { + .ops = &sata_ops, + .vendor = PCI_VENDOR_ID_INTEL, + .devices = pci_device_ids, +};
