Attention is currently required from: Jason Glenesk, Raul Rangel, Marshall Dawson. Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Marshall Dawson,
https://review.coreboot.org/c/coreboot/+/52584
Change subject: [WIP] soc/amd/cezanne,common,picasso: use BERT region reserved by FSP driver ......................................................................
commit ce0e2a014009390c4527e064efb59260ef4d3a3b (drivers/intel/fsp2_0: use FSP to allocate APEI BERT memory region) adds a mechanism to reserve the BERT region inside the coreboot code, so we can get rid of the workaround to reserve it in the FSP and return the location in a HOB. mcfg->bert_size defaults to 0 which makes the FSP not generate the corresponding HOB, but that field is planned to be removed at least on Cezanne, so don't explicitly set it to 0.
TODO: test if Linux likes this or not
BUG=b:169934025
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Iaca89b47793bf9982181560f026459a18e7db134 --- M src/soc/amd/cezanne/fsp_m_params.c M src/soc/amd/common/block/cpu/noncar/memmap.c M src/soc/amd/picasso/fsp_m_params.c M src/vendorcode/amd/fsp/cezanne/FspGuids.h M src/vendorcode/amd/fsp/picasso/FspGuids.h 5 files changed, 4 insertions(+), 25 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/52584/3
