Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15036
commit a74818660ee7bd63a88096f820165b49011885b8 Author: Julius Werner jwerner@chromium.org Date: Mon May 16 16:37:56 2016 -0700
libpayload: Reintroduce CONFIG_LP_CHROMEOS to set suitable defaults
Chrome OS builds always have some inherent differences to "standard" libpayload configurations: they don't want to use curses or things like storage drivers, they always use the coreboot framebuffer and USB, etc. This patch reintroduces CONFIG_LP_CHROMEOS as an option that only affects Kconfig defaults. This allows Chrome OS builds to select most of what they need in one go and reduces board-specific .config files to only the options that are really specific to that board.
Also restricts the 8250_SERIAL_CONSOLE Kconfig to only default to yes on x86 boards, which probably makes sense for all of libpayload (some but far from all ARM boards use 8250-compatible UARTs, and we should probably not default a platform option unless it's going to be correct with very high probability).
BRANCH=None BUG=None TEST=Built and booted Jerry and Oak.
Change-Id: Ie0c0593ffd399608d2cbfb83d20891f6f1864915 Signed-off-by: Martin Roth martinroth@chromium.org Original-Commit-Id: e558f59 Original-Change-Id: I609637cd2ea7dfb4558aa3c04c90b64038c9ab57 Original-Signed-off-by: Julius Werner jwerner@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/347970 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org --- payloads/libpayload/Kconfig | 29 +++++++++++++++++++---------- 1 file changed, 19 insertions(+), 10 deletions(-)
diff --git a/payloads/libpayload/Kconfig b/payloads/libpayload/Kconfig index 20f10ee..951d757 100644 --- a/payloads/libpayload/Kconfig +++ b/payloads/libpayload/Kconfig @@ -34,6 +34,7 @@ menu "Generic Options"
config GPL bool "GPLv2-licensed Options" + default y if CHROMEOS default n help Prompt for options that will build code licensed under the GNU General @@ -55,6 +56,12 @@ config DEVELOPER Prompt for developer options. These options are only interesting for libpayload developers.
+config CHROMEOS + bool "Chrome OS Options" + default n + help + Select configuration defaults appropriate for Chrome OS boards. + choice prompt "Compiler to use" default COMPILER_GCC @@ -117,7 +124,7 @@ endchoice config MULTIBOOT bool "Multiboot header support" depends on ARCH_X86 - default y + default y if !CHROMEOS
config HEAP_SIZE int "Heap size" @@ -158,7 +165,7 @@ config LIBC
config CURSES bool "Build a curses library" - default y + default y if !CHROMEOS
choice prompt "Curses implementation" @@ -208,6 +215,7 @@ menu "Console Options"
config SKIP_CONSOLE_INIT bool "Skip initializing the consoles at startup" + default y if CHROMEOS default n help Normally, libpayload will initialize console input/output on startup @@ -225,7 +233,7 @@ config SERIAL_CONSOLE config 8250_SERIAL_CONSOLE bool "8250-compatible serial port driver (including IO and MMIO)" depends on SERIAL_CONSOLE - default y + default y if ARCH_X86
config S5P_SERIAL_CONSOLE bool "Exynos SOC, S5P compatible serial port driver" @@ -289,7 +297,7 @@ config VIDEO_CONSOLE config VGA_VIDEO_CONSOLE bool "VGA video console driver" depends on ARCH_X86 && VIDEO_CONSOLE - default y + default y if !CHROMEOS
config GEODELX_VIDEO_CONSOLE bool "Geode LX video console driver" @@ -299,6 +307,7 @@ config GEODELX_VIDEO_CONSOLE config COREBOOT_VIDEO_CONSOLE bool "coreboot video console driver" depends on VIDEO_CONSOLE && !GEODELX_VIDEO_CONSOLE + default y if CHROMEOS default n help Say Y here if coreboot switched to a graphics mode and @@ -352,11 +361,11 @@ config RTC_PORT_EXTENDED_VIA config SPEAKER bool "Support for PC speaker" depends on ARCH_X86 - default y + default y if !CHROMEOS
config STORAGE bool "Support for storage devices" - default y + default y if !CHROMEOS help Select this option if you want support for storage devices (like hard drives, memory sticks or optical drives). @@ -513,7 +522,7 @@ config USB config USB_UHCI bool "Support for USB UHCI controllers" depends on USB && ARCH_X86 - default y + default y if !CHROMEOS help Select this option if you are going to use USB 1.1 on an Intel based system. @@ -521,7 +530,7 @@ config USB_UHCI config USB_OHCI bool "Support for USB OHCI controllers" depends on USB - default y + default y if !CHROMEOS help Select this option if you are going to use USB 1.1 on a non-Intel based system. @@ -529,14 +538,14 @@ config USB_OHCI config USB_EHCI bool "Support for USB EHCI controllers" depends on USB - default y + default y if !CHROMEOS help Select this option if you want to use USB 2.0
config USB_XHCI bool "Support for USB xHCI controllers" depends on USB - default y + default y if !CHROMEOS help Select this option if you want to use USB 3.0
