Attention is currently required from: Arthur Heymans, Jérémy Compostella, Lean Sheng Tan, Patrick Rudolph, Shuo Liu.
Hello Arthur Heymans, Jérémy Compostella, Lean Sheng Tan, Patrick Rudolph, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81209?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Jérémy Compostella, Verified+1 by build bot (Jenkins)
Change subject: symbols: Add __maybe_unused flag to region variable symbols ......................................................................
In DECLARE_REGION and DECLARE_OPTIONAL_REGION, a set of 3 variables will be defined, that is the region 'base', 'end' and 'size'. However, in many codes, the users will only selectively use 'end' or 'size' instead of both of them, which will trigger comipler errors for unused variables. This patch sets __maybe_unused attributes on 'end' and 'size' so that users do not need to use all of them.
TEST=intel/archercity CRB
Change-Id: Ia5ed183b2dd7a474ce51de47dbc1f9e3f61e5a41 Signed-off-by: Shuo Liu shuo.liu@intel.com --- M src/include/symbols.h 1 file changed, 6 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/09/81209/3
