Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10634
commit ccc34278b25d890821e403f053bf87c1716af473 Author: Patrick Georgi pgeorgi@chromium.org Date: Mon Jun 22 19:43:18 2015 +0200
google/foster: add new mainboard
This is an nvidia t210 based board. The commit includes all Chrome OS changes up to Change-Id: I714fdc87e7.
Change-Id: I8630e86a4b0e8756693f8989ce147d6d762cefe1 Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- src/mainboard/google/foster/Kconfig | 97 +++ src/mainboard/google/foster/Kconfig.name | 3 + src/mainboard/google/foster/Makefile.inc | 50 ++ src/mainboard/google/foster/bct/Makefile.inc | 30 + src/mainboard/google/foster/bct/cfg2inc.sh | 34 + src/mainboard/google/foster/bct/emmc.cfg | 16 + src/mainboard/google/foster/bct/jtag.cfg | 16 + src/mainboard/google/foster/bct/odmdata.cfg | 1 + .../google/foster/bct/sdram-samsung-3GB-204.cfg | 691 +++++++++++++++++++++ .../google/foster/bct/sdram-samsung-3GB-204.inc | 477 ++++++++++++++ src/mainboard/google/foster/bct/sdram-unused.inc | 4 + src/mainboard/google/foster/bct/spi.cfg | 16 + src/mainboard/google/foster/boardid.c | 28 + src/mainboard/google/foster/bootblock.c | 95 +++ src/mainboard/google/foster/chromeos.c | 102 +++ src/mainboard/google/foster/devicetree.cb | 95 +++ src/mainboard/google/foster/ec_dummy.c | 9 + src/mainboard/google/foster/mainboard.c | 129 ++++ src/mainboard/google/foster/memlayout.ld | 6 + src/mainboard/google/foster/pmic.c | 93 +++ src/mainboard/google/foster/pmic.h | 74 +++ src/mainboard/google/foster/reset.c | 29 + src/mainboard/google/foster/romstage.c | 40 ++ src/mainboard/google/foster/verstage.c | 29 + 24 files changed, 2164 insertions(+)
diff --git a/src/mainboard/google/foster/Kconfig b/src/mainboard/google/foster/Kconfig new file mode 100644 index 0000000..571a3b1 --- /dev/null +++ b/src/mainboard/google/foster/Kconfig @@ -0,0 +1,97 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2014 Google Inc. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc. +## + +if BOARD_GOOGLE_FOSTER + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select BOARD_ID_AUTO + select BOARD_ROMSIZE_KB_4096 + select CHROMEOS_VBNV_FLASH + select SPI_FLASH + select SOC_NVIDIA_TEGRA210 + select MAINBOARD_HAS_BOOTBLOCK_INIT + select MAINBOARD_HAS_CHROMEOS + select VIRTUAL_DEV_SWITCH + select BOOTROM_SDRAM_INIT # use BootRom to config sdram + select COMMON_CBFS_SPI_WRAPPER + select SPI_FLASH_WINBOND + +config MAINBOARD_DIR + string + default google/foster + +config MAINBOARD_PART_NUMBER + string + default "Foster" + +config DRAM_SIZE_MB + int + default 2048 + +choice + prompt "BCT boot media" + default FOSTER_BCT_CFG_SPI + help + Which boot media to configure the BCT for. + +config FOSTER_BCT_CFG_SPI + bool "SPI" + help + Configure the BCT for booting from SPI. + +config FOSTER_BCT_CFG_EMMC + bool "eMMC" + help + Configure the BCT for booting from eMMC. + +endchoice + +config BOOT_MEDIA_SPI_BUS + int "SPI bus with boot media ROM" + range 1 7 + depends on FOSTER_BCT_CFG_SPI + default 7 + help + Which SPI bus the boot media is connected to. + +config BOOT_MEDIA_SPI_CHIP_SELECT + int "Chip select for SPI boot media" + range 0 3 + depends on FOSTER_BCT_CFG_SPI + default 0 + help + Which chip select to use for boot media. + +# For foster, we are using vboot2. Thus, index for stages: +# VBOOT_ROMSTAGE_INDEX -> Use default value of 0x2 +# VBOOT_RAMSTAGE_INDEX -> Use 0x3 +config VBOOT_RAMSTAGE_INDEX + hex + default 0x3 + +config DRIVER_TPM_I2C_BUS + hex + default 0x2 + +config DRIVER_TPM_I2C_ADDR + hex + default 0x20 + +endif # BOARD_GOOGLE_FOSTER diff --git a/src/mainboard/google/foster/Kconfig.name b/src/mainboard/google/foster/Kconfig.name new file mode 100644 index 0000000..b7e6f37 --- /dev/null +++ b/src/mainboard/google/foster/Kconfig.name @@ -0,0 +1,3 @@ +config BOARD_GOOGLE_FOSTER + bool "Foster" + diff --git a/src/mainboard/google/foster/Makefile.inc b/src/mainboard/google/foster/Makefile.inc new file mode 100644 index 0000000..29478c0 --- /dev/null +++ b/src/mainboard/google/foster/Makefile.inc @@ -0,0 +1,50 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2014 Google Inc. +## Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc. +## + +# Add a handler for BCT config files +$(call add-special-class,bct-cfg) +bct-cfg-handler= $(eval $(obj)/generated/bct.cfg: $(1)$(2)) + +$(obj)/generated/bct.cfg: + @printf " CAT $(subst $(obj)/,,$(@))\n" + cat $^ > $@ + +subdirs-y += bct + +bootblock-y += bootblock.c +bootblock-y += pmic.c +bootblock-y += reset.c + +verstage-y += verstage.c +verstage-y += chromeos.c +verstage-y += reset.c + +romstage-y += reset.c +romstage-y += romstage.c +romstage-y += chromeos.c + +ramstage-y += boardid.c +ramstage-y += mainboard.c +ramstage-y += reset.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld +verstage-y += memlayout.ld diff --git a/src/mainboard/google/foster/bct/Makefile.inc b/src/mainboard/google/foster/bct/Makefile.inc new file mode 100644 index 0000000..88fed7e --- /dev/null +++ b/src/mainboard/google/foster/bct/Makefile.inc @@ -0,0 +1,30 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2013 Google Inc. +## Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc. +## + +bct-cfg-$(CONFIG_FOSTER_BCT_CFG_EMMC) += emmc.cfg +bct-cfg-$(CONFIG_FOSTER_BCT_CFG_SPI) += spi.cfg +bct-cfg-y += odmdata.cfg +bct-cfg-y += jtag.cfg +#NOTE: When full LPDDR4 SDRAM config is done in romstage, remove this +bct-cfg-$(CONFIG_BOOTROM_SDRAM_INIT) += sdram-samsung-3GB-204.cfg + +# Note when SDRAM config (sdram-*.cfg) files are changed, we have to regenerate +# the include files (sdram-*.inc) by running "./cfg2inc.sh sdram-*.cfg". +# TODO(hungte) Change cfg2inc.sh to NVIDIA's official tool in cbootimage. diff --git a/src/mainboard/google/foster/bct/cfg2inc.sh b/src/mainboard/google/foster/bct/cfg2inc.sh new file mode 100644 index 0000000..f8f3c44 --- /dev/null +++ b/src/mainboard/google/foster/bct/cfg2inc.sh @@ -0,0 +1,34 @@ +#!/bin/sh +# +# This file is part of the coreboot project. +# +# Copyright 2014 Google Inc. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc. + +bct_cfg2inc() { + local in_file="$1" + local out_file="$2" + echo "{ /* generated from ${in_file}; do not edit. */" >"${out_file}" + # Note currently we can only handle DDR3 type memory, even in C + # implementation. + sed "/^#.*$/d; s/^SDRAM.0./ /; s/\r$//; s/;$/,/;" \ + "${in_file}" >> "${out_file}" + echo "}," >>"${out_file}" +} + +for file in $@; do + echo "Generating $file => ${file%cfg}inc..." + bct_cfg2inc "${file}" "${file%cfg}inc" +done diff --git a/src/mainboard/google/foster/bct/emmc.cfg b/src/mainboard/google/foster/bct/emmc.cfg new file mode 100644 index 0000000..4b6b5d5 --- /dev/null +++ b/src/mainboard/google/foster/bct/emmc.cfg @@ -0,0 +1,16 @@ +# Copyright (c) 2015 The Chromium OS Authors. All rights reserved. +# Distributed under the terms of the GNU General Public License v2 + +Version = 0x00210001; +BlockSize = 0x00004000; +PageSize = 0x00000200; +PartitionSize = 0x01000000; + +# +# T210 bct only supports one boot device +# +DevType[0] = NvBootDevType_Sdmmc; +DeviceParam[0].SdmmcParams.ClockDivider = 0x00000009; +DeviceParam[0].SdmmcParams.DataWidth = NvBootSdmmcDataWidth_8Bit; +DeviceParam[0].SdmmcParams.MaxPowerClassSupported = 0x00000000; +DeviceParam[0].SdmmcParams.MultiPageSupport = 0x00000000; diff --git a/src/mainboard/google/foster/bct/jtag.cfg b/src/mainboard/google/foster/bct/jtag.cfg new file mode 100644 index 0000000..e9bbd02 --- /dev/null +++ b/src/mainboard/google/foster/bct/jtag.cfg @@ -0,0 +1,16 @@ +# +# Set DebugCtrl to 1 to reenable Jtag +# +DebugCtrl = 0; +# +# Fill in chip unique id +# +# ChipUid can be found by running tegrarcm in tegra recovery mode +# (also hooking up A-A USB cable) and looking for console output +# on line starting with "Chip UID:" +# +# Command example: +# $ sudo tegrarcm --bct=/build/foster/firmware/bct/board.bct --bootloader=/build/foster/firmware/u-boot.bin --loadaddr=0x80108000 +# Where board.bct and u-boot.bin do not have to be prebuilt. +# +ChipUid = 0x00000000000000000000000000000000; diff --git a/src/mainboard/google/foster/bct/odmdata.cfg b/src/mainboard/google/foster/bct/odmdata.cfg new file mode 100644 index 0000000..45648af --- /dev/null +++ b/src/mainboard/google/foster/bct/odmdata.cfg @@ -0,0 +1 @@ +OdmData = 0x00294000; diff --git a/src/mainboard/google/foster/bct/sdram-samsung-3GB-204.cfg b/src/mainboard/google/foster/bct/sdram-samsung-3GB-204.cfg new file mode 100644 index 0000000..d12f6b9 --- /dev/null +++ b/src/mainboard/google/foster/bct/sdram-samsung-3GB-204.cfg @@ -0,0 +1,691 @@ +# CFG Version 06 +# Do not edit. Generated by t210_emc_reg_tool_P972.exe V9.7.2. Command: +# t210_emc_reg_tool_P972.exe -i E2581_3GB.par 04.90196078431372549019 -dram_board_cfg 33 +# -data_bus_to_0 1 -fly_by_time_ps 1700 -dbi_rd_en 1 -is_bkv 1 -t T210_DSC_E2581A00_lpddr4_tbkv_est_072514.txt +# -o E2581_A00_3GB_P972_configs\E2581_A00_3GB_Samsung_4GB_lpddr4_204Mhz_P972_v1.cfg +# Parameter file: E2581_3GB.par, tck = 4.90 ns (204.00 MHz) +SDRAM[0].MemoryType = NvBootMemoryType_LpDdr4; +SDRAM[0].PllMInputDivider = 0x00000001; +SDRAM[0].PllMFeedbackDivider = 0x00000022; +SDRAM[0].PllMStableTime = 0x0000012c; +SDRAM[0].PllMSetupControl = 0x00000000; +SDRAM[0].PllMPostDivider = 0x00000000; +SDRAM[0].PllMKCP = 0x00000000; +SDRAM[0].PllMKVCO = 0x00000000; +SDRAM[0].EmcBctSpare0 = 0x00000000; +SDRAM[0].EmcBctSpare1 = 0x00000000; +SDRAM[0].EmcBctSpare2 = 0x00000000; +SDRAM[0].EmcBctSpare3 = 0x00000000; +SDRAM[0].EmcBctSpare4 = 0x7001bc3c; +SDRAM[0].EmcBctSpare5 = 0x00000032; +SDRAM[0].EmcBctSpare6 = 0x7001b404; +SDRAM[0].EmcBctSpare7 = 0x71245603; +SDRAM[0].EmcBctSpare8 = 0x7000e6c8; +SDRAM[0].EmcBctSpare9 = 0x00000000; +SDRAM[0].EmcBctSpare10 = 0x00000000; +SDRAM[0].EmcBctSpare11 = 0x00000000; +SDRAM[0].EmcBctSpare12 = 0x7001bc3c; +SDRAM[0].EmcBctSpare13 = 0x00000033; +SDRAM[0].EmcClockSource = 0x40188002; +SDRAM[0].EmcClockSourceDll = 0x40000000; +SDRAM[0].ClkRstControllerPllmMisc2Override = 0x00000000; +SDRAM[0].ClkRstControllerPllmMisc2OverrideEnable = 0x00000000; +SDRAM[0].ClearClk2Mc1 = 0x00000000; +SDRAM[0].EmcAutoCalInterval = 0x001fffff; +SDRAM[0].EmcAutoCalConfig = 0xa01a51d8; +SDRAM[0].EmcAutoCalConfig2 = 0x05500000; +SDRAM[0].EmcAutoCalConfig3 = 0x00770000; +SDRAM[0].EmcAutoCalConfig4 = 0x00770000; +SDRAM[0].EmcAutoCalConfig5 = 0x00770000; +SDRAM[0].EmcAutoCalConfig6 = 0x00770000; +SDRAM[0].EmcAutoCalConfig7 = 0x00770000; +SDRAM[0].EmcAutoCalConfig8 = 0x00770000; +SDRAM[0].EmcAutoCalVrefSel0 = 0xb3afa6a6; +SDRAM[0].EmcAutoCalVrefSel1 = 0x00009e3c; +SDRAM[0].EmcAutoCalChannel = 0xc1e00303; +SDRAM[0].EmcPmacroAutocalCfg0 = 0x04040404; +SDRAM[0].EmcPmacroAutocalCfg1 = 0x04040404; +SDRAM[0].EmcPmacroAutocalCfg2 = 0x00000000; +SDRAM[0].EmcPmacroRxTerm = 0x1f1f1f1f; +SDRAM[0].EmcPmacroDqTxDrv = 0x1f1f1f1f; +SDRAM[0].EmcPmacroCaTxDrv = 0x1f1f1f1f; +SDRAM[0].EmcPmacroCmdTxDrv = 0x00001f1f; +SDRAM[0].EmcPmacroAutocalCfgCommon = 0x00000804; +SDRAM[0].EmcPmacroZctrl = 0x00000550; +SDRAM[0].EmcAutoCalWait = 0x000001a1; +SDRAM[0].EmcXm2CompPadCtrl = 0x00000032; +SDRAM[0].EmcXm2CompPadCtrl2 = 0x00000000; +SDRAM[0].EmcXm2CompPadCtrl3 = 0x00000000; +SDRAM[0].EmcAdrCfg = 0x00000001; +SDRAM[0].EmcPinProgramWait = 0x00000002; +SDRAM[0].EmcPinExtraWait = 0x00000000; +SDRAM[0].EmcPinGpioEn = 0x00000003; +SDRAM[0].EmcPinGpio = 0x00000003; +SDRAM[0].EmcTimingControlWait = 0x0000001e; +SDRAM[0].EmcRc = 0x0000000d; +SDRAM[0].EmcRfc = 0x00000025; +SDRAM[0].EmcRfcPb = 0x00000013; +SDRAM[0].EmcRefctrl2 = 0x00000000; +SDRAM[0].EmcRfcSlr = 0x00000000; +SDRAM[0].EmcRas = 0x00000009; +SDRAM[0].EmcRp = 0x00000004; +SDRAM[0].EmcR2r = 0x00000000; +SDRAM[0].EmcW2w = 0x00000000; +SDRAM[0].EmcR2w = 0x0000000b; +SDRAM[0].EmcW2r = 0x0000000d; +SDRAM[0].EmcR2p = 0x00000008; +SDRAM[0].EmcW2p = 0x0000000b; +SDRAM[0].EmcTppd = 0x00000004; +SDRAM[0].EmcCcdmw = 0x00000020; +SDRAM[0].EmcRdRcd = 0x00000006; +SDRAM[0].EmcWrRcd = 0x00000006; +SDRAM[0].EmcRrd = 0x00000006; +SDRAM[0].EmcRext = 0x00000003; +SDRAM[0].EmcWext = 0x00000000; +SDRAM[0].EmcWdv = 0x00000004; +SDRAM[0].EmcWdvChk = 0x00000006; +SDRAM[0].EmcWsv = 0x00000002; +SDRAM[0].EmcWev = 0x00000000; +SDRAM[0].EmcWdvMask = 0x00000004; +SDRAM[0].EmcWsDuration = 0x00000008; +SDRAM[0].EmcWeDuration = 0x0000000d; +SDRAM[0].EmcQUse = 0x00000005; +SDRAM[0].EmcQuseWidth = 0x00000006; +SDRAM[0].EmcIbdly = 0x00000000; +SDRAM[0].EmcObdly = 0x00000000; +SDRAM[0].EmcEInput = 0x00000002; +SDRAM[0].EmcEInputDuration = 0x0000000d; +SDRAM[0].EmcPutermExtra = 0x00000002; +SDRAM[0].EmcPutermWidth = 0x0000000b; +SDRAM[0].EmcQRst = 0x00010000; +SDRAM[0].EmcQSafe = 0x00000012; +SDRAM[0].EmcRdv = 0x00000014; +SDRAM[0].EmcRdvMask = 0x00000016; +SDRAM[0].EmcRdvEarly = 0x00000012; +SDRAM[0].EmcRdvEarlyMask = 0x00000014; +SDRAM[0].EmcQpop = 0x0000000a; +SDRAM[0].EmcRefresh = 0x00000304; +SDRAM[0].EmcBurstRefreshNum = 0x00000000; +SDRAM[0].EmcPreRefreshReqCnt = 0x000000c1; +SDRAM[0].EmcPdEx2Wr = 0x00000008; +SDRAM[0].EmcPdEx2Rd = 0x00000008; +SDRAM[0].EmcPChg2Pden = 0x00000003; +SDRAM[0].EmcAct2Pden = 0x00000003; +SDRAM[0].EmcAr2Pden = 0x00000003; +SDRAM[0].EmcRw2Pden = 0x00000012; +SDRAM[0].EmcCke2Pden = 0x00000005; +SDRAM[0].EmcPdex2Cke = 0x00000002; +SDRAM[0].EmcPdex2Mrr = 0x0000000d; +SDRAM[0].EmcTxsr = 0x00000027; +SDRAM[0].EmcTxsrDll = 0x00000027; +SDRAM[0].EmcTcke = 0x00000005; +SDRAM[0].EmcTckesr = 0x00000005; +SDRAM[0].EmcTpd = 0x00000004; +SDRAM[0].EmcTfaw = 0x00000009; +SDRAM[0].EmcTrpab = 0x00000005; +SDRAM[0].EmcTClkStable = 0x00000003; +SDRAM[0].EmcTClkStop = 0x00000009; +SDRAM[0].EmcTRefBw = 0x0000031c; +SDRAM[0].EmcFbioCfg5 = 0x9160a00d; +SDRAM[0].EmcFbioCfg7 = 0x00003bbf; +SDRAM[0].EmcFbioCfg8 = 0x0cf30000; +SDRAM[0].EmcCmdMappingCmd0_0 = 0x07050203; +SDRAM[0].EmcCmdMappingCmd0_1 = 0x06041b1c; +SDRAM[0].EmcCmdMappingCmd0_2 = 0x05252523; +SDRAM[0].EmcCmdMappingCmd1_0 = 0x1e0d0b0a; +SDRAM[0].EmcCmdMappingCmd1_1 = 0x240c091d; +SDRAM[0].EmcCmdMappingCmd1_2 = 0x04262608; +SDRAM[0].EmcCmdMappingCmd2_0 = 0x051b0302; +SDRAM[0].EmcCmdMappingCmd2_1 = 0x0604231c; +SDRAM[0].EmcCmdMappingCmd2_2 = 0x09252507; +SDRAM[0].EmcCmdMappingCmd3_0 = 0x0c0b0d0a; +SDRAM[0].EmcCmdMappingCmd3_1 = 0x08091e1d; +SDRAM[0].EmcCmdMappingCmd3_2 = 0x08262624; +SDRAM[0].EmcCmdMappingByte = 0x0a270623; +SDRAM[0].EmcFbioSpare = 0x00000012; +SDRAM[0].EmcCfgRsv = 0xff00ff00; +SDRAM[0].EmcMrs = 0x00000000; +SDRAM[0].EmcEmrs = 0x00000000; +SDRAM[0].EmcEmrs2 = 0x00000000; +SDRAM[0].EmcEmrs3 = 0x00000000; +SDRAM[0].EmcMrw1 = 0x08010004; +SDRAM[0].EmcMrw2 = 0x08020000; +SDRAM[0].EmcMrw3 = 0x080d0000; +SDRAM[0].EmcMrw4 = 0xc0000000; +SDRAM[0].EmcMrw6 = 0x08037171; +SDRAM[0].EmcMrw8 = 0x080b0000; +SDRAM[0].EmcMrw9 = 0x0c0e6b6b; +SDRAM[0].EmcMrw10 = 0x00000000; +SDRAM[0].EmcMrw12 = 0x0c0d0808; +SDRAM[0].EmcMrw13 = 0x0c0d0000; +SDRAM[0].EmcMrw14 = 0x08161414; +SDRAM[0].EmcMrwExtra = 0x08010004; +SDRAM[0].EmcWarmBootMrwExtra = 0x08110000; +SDRAM[0].EmcWarmBootExtraModeRegWriteEnable = 0x00000001; +SDRAM[0].EmcExtraModeRegWriteEnable = 0x00000000; +SDRAM[0].EmcMrwResetCommand = 0x00000000; +SDRAM[0].EmcMrwResetNInitWait = 0x00000000; +SDRAM[0].EmcMrsWaitCnt = 0x00cc0015; +SDRAM[0].EmcMrsWaitCnt2 = 0x0033000a; +SDRAM[0].EmcCfg = 0xf3200000; +SDRAM[0].EmcCfg2 = 0x00110805; +SDRAM[0].EmcCfgPipe = 0x0fff0fff; +SDRAM[0].EmcCfgPipeClk = 0x00000000; +SDRAM[0].EmcFdpdCtrlCmdNoRamp = 0x00000001; +SDRAM[0].EmcCfgUpdate = 0x70000301; +SDRAM[0].EmcDbg = 0x01000c00; +SDRAM[0].EmcDbgWriteMux = 0x00000001; +SDRAM[0].EmcCmdQ = 0x10004408; +SDRAM[0].EmcMc2EmcQ = 0x06000404; +SDRAM[0].EmcDynSelfRefControl = 0x80000713; +SDRAM[0].AhbArbitrationXbarCtrlMemInitDone = 0x00000001; +SDRAM[0].EmcCfgDigDll = 0x002c00a0; +SDRAM[0].EmcCfgDigDll_1 = 0x00003701; +SDRAM[0].EmcCfgDigDllPeriod = 0x00008000; +SDRAM[0].EmcDevSelect = 0x00000000; +SDRAM[0].EmcSelDpdCtrl = 0x00040008; +SDRAM[0].EmcFdpdCtrlDq = 0x8020221f; +SDRAM[0].EmcFdpdCtrlCmd = 0x0220f40f; +SDRAM[0].EmcPmacroIbVrefDq_0 = 0x28282828; +SDRAM[0].EmcPmacroIbVrefDq_1 = 0x28282828; +SDRAM[0].EmcPmacroIbVrefDqs_0 = 0x11111111; +SDRAM[0].EmcPmacroIbVrefDqs_1 = 0x11111111; +SDRAM[0].EmcPmacroIbRxrt = 0x000000be; +SDRAM[0].EmcCfgPipe1 = 0x0fff0fff; +SDRAM[0].EmcCfgPipe2 = 0x0fff0fff; +SDRAM[0].EmcPmacroQuseDdllRank0_0 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank0_1 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank0_2 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank0_3 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank0_4 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank0_5 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank1_0 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank1_1 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank1_2 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank1_3 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank1_4 = 0x00000000; +SDRAM[0].EmcPmacroQuseDdllRank1_5 = 0x00000000; +SDRAM[0].EmcPmacroObDdllLongDqRank0_0 = 0x00000000; +SDRAM[0].EmcPmacroObDdllLongDqRank0_1 = 0x00000000; +SDRAM[0].EmcPmacroObDdllLongDqRank0_2 = 0x00000000; +SDRAM[0].EmcPmacroObDdllLongDqRank0_3 = 0x00000000; +SDRAM[0].EmcPmacroObDdllLongDqRank0_4 = 0x00080007; +SDRAM[0].EmcPmacroObDdllLongDqRank0_5 = 0x00090006; +SDRAM[0].EmcPmacroObDdllLongDqRank1_0 = 0x00000000; +SDRAM[0].EmcPmacroObDdllLongDqRank1_1 = 0x00000000; +SDRAM[0].EmcPmacroObDdllLongDqRank1_2 = 0x00000000; +SDRAM[0].EmcPmacroObDdllLongDqRank1_3 = 0x00000000; +SDRAM[0].EmcPmacroObDdllLongDqRank1_4 = 0x00080007; +SDRAM[0].EmcPmacroObDdllLongDqRank1_5 = 0x00090006; +SDRAM[0].EmcPmacroObDdllLongDqsRank0_0 = 0x00340033; +SDRAM[0].EmcPmacroObDdllLongDqsRank0_1 = 0x00340037; +SDRAM[0].EmcPmacroObDdllLongDqsRank0_2 = 0x00360037; +SDRAM[0].EmcPmacroObDdllLongDqsRank0_3 = 0x00330036; +SDRAM[0].EmcPmacroObDdllLongDqsRank0_4 = 0x000a000c; +SDRAM[0].EmcPmacroObDdllLongDqsRank0_5 = 0x000d000a; +SDRAM[0].EmcPmacroObDdllLongDqsRank1_0 = 0x00340033; +SDRAM[0].EmcPmacroObDdllLongDqsRank1_1 = 0x00340037; +SDRAM[0].EmcPmacroObDdllLongDqsRank1_2 = 0x00360037; +SDRAM[0].EmcPmacroObDdllLongDqsRank1_3 = 0x00330036; +SDRAM[0].EmcPmacroObDdllLongDqsRank1_4 = 0x000a000c; +SDRAM[0].EmcPmacroObDdllLongDqsRank1_5 = 0x000d000a; +SDRAM[0].EmcPmacroIbDdllLongDqsRank0_0 = 0x00F000F0; +SDRAM[0].EmcPmacroIbDdllLongDqsRank0_1 = 0x00F000F0; +SDRAM[0].EmcPmacroIbDdllLongDqsRank0_2 = 0x00F000F0; +SDRAM[0].EmcPmacroIbDdllLongDqsRank0_3 = 0x00F000F0; +SDRAM[0].EmcPmacroIbDdllLongDqsRank1_0 = 0x00F000F0; +SDRAM[0].EmcPmacroIbDdllLongDqsRank1_1 = 0x00F000F0; +SDRAM[0].EmcPmacroIbDdllLongDqsRank1_2 = 0x00F000F0; +SDRAM[0].EmcPmacroIbDdllLongDqsRank1_3 = 0x00F000F0; +SDRAM[0].EmcPmacroDdllLongCmd_0 = 0x00070007; +SDRAM[0].EmcPmacroDdllLongCmd_1 = 0x00080008; +SDRAM[0].EmcPmacroDdllLongCmd_2 = 0x00060006; +SDRAM[0].EmcPmacroDdllLongCmd_3 = 0x00090009; +SDRAM[0].EmcPmacroDdllLongCmd_4 = 0x00000007; +SDRAM[0].EmcPmacroDdllShortCmd_0 = 0x00000000; +SDRAM[0].EmcPmacroDdllShortCmd_1 = 0x00000000; +SDRAM[0].EmcPmacroDdllShortCmd_2 = 0x00000000; +SDRAM[0].WarmBootWait = 0x00000001; +SDRAM[0].EmcOdtWrite = 0x00000000; +SDRAM[0].EmcZcalInterval = 0x00064000; +SDRAM[0].EmcZcalWaitCnt = 0x000900cc; +SDRAM[0].EmcZcalMrwCmd = 0x0051004f; +SDRAM[0].EmcMrsResetDll = 0x00000000; +SDRAM[0].EmcZcalInitDev0 = 0x80000001; +SDRAM[0].EmcZcalInitDev1 = 0x40000001; +SDRAM[0].EmcZcalInitWait = 0x00000001; +SDRAM[0].EmcZcalWarmColdBootEnables = 0x00000003; +SDRAM[0].EmcMrwLpddr2ZcalWarmBoot = 0x040a00ab; +SDRAM[0].EmcZqCalDdr3WarmBoot = 0x00000011; +SDRAM[0].EmcZqCalLpDdr4WarmBoot = 0x00000001; +SDRAM[0].EmcZcalWarmBootWait = 0x00000001; +SDRAM[0].EmcMrsWarmBootEnable = 0x00000001; +SDRAM[0].EmcMrsResetDllWait = 0x00000000; +SDRAM[0].EmcMrsExtra = 0x00000000; +SDRAM[0].EmcWarmBootMrsExtra = 0x00000000; +SDRAM[0].EmcEmrsDdr2DllEnable = 0x00000000; +SDRAM[0].EmcMrsDdr2DllReset = 0x00000000; +SDRAM[0].EmcEmrsDdr2OcdCalib = 0x00000000; +SDRAM[0].EmcDdr2Wait = 0x00000000; +SDRAM[0].EmcClkenOverride = 0x00000000; +SDRAM[0].EmcExtraRefreshNum = 0x00000002; +SDRAM[0].EmcClkenOverrideAllWarmBoot = 0x00000000; +SDRAM[0].McClkenOverrideAllWarmBoot = 0x00000000; +SDRAM[0].EmcCfgDigDllPeriodWarmBoot = 0x00000003; +SDRAM[0].PmcVddpSel = 0x00000001; +SDRAM[0].PmcVddpSelWait = 0x00000002; +SDRAM[0].PmcDdrPwr = 0x0000000f; +SDRAM[0].PmcDdrCfg = 0x20120100; +SDRAM[0].PmcIoDpd3Req = 0x4befffff; +SDRAM[0].PmcIoDpd3ReqWait = 0x00000001; +SDRAM[0].PmcIoDpd4ReqWait = 0x00000002; +SDRAM[0].PmcRegShort = 0x00000000; +SDRAM[0].PmcNoIoPower = 0x00000000; +SDRAM[0].PmcDdrCntrlWait = 0x00000000; +SDRAM[0].PmcDdrCntrl = 0x0007ff8b; +SDRAM[0].EmcAcpdControl = 0x00000000; +SDRAM[0].EmcSwizzleRank0Byte0 = 0x71245603; +SDRAM[0].EmcSwizzleRank0Byte1 = 0x16243705; +SDRAM[0].EmcSwizzleRank0Byte2 = 0x12574630; +SDRAM[0].EmcSwizzleRank0Byte3 = 0x26147503; +SDRAM[0].EmcSwizzleRank1Byte0 = 0x71345602; +SDRAM[0].EmcSwizzleRank1Byte1 = 0x20456713; +SDRAM[0].EmcSwizzleRank1Byte2 = 0x64071325; +SDRAM[0].EmcSwizzleRank1Byte3 = 0x54023167; +SDRAM[0].EmcTxdsrvttgen = 0x00000000; +SDRAM[0].EmcDataBrlshft0 = 0x00249249; +SDRAM[0].EmcDataBrlshft1 = 0x00249249; +SDRAM[0].EmcDqsBrlshft0 = 0x00000000; +SDRAM[0].EmcDqsBrlshft1 = 0x00000000; +SDRAM[0].EmcCmdBrlshft0 = 0x00000000; +SDRAM[0].EmcCmdBrlshft1 = 0x00000000; +SDRAM[0].EmcCmdBrlshft2 = 0x00000012; +SDRAM[0].EmcCmdBrlshft3 = 0x00000012; +SDRAM[0].EmcQuseBrlshft0 = 0x00000000; +SDRAM[0].EmcQuseBrlshft1 = 0x00000000; +SDRAM[0].EmcQuseBrlshft2 = 0x00000000; +SDRAM[0].EmcQuseBrlshft3 = 0x00000000; +SDRAM[0].EmcDllCfg0 = 0x1f13412f; +SDRAM[0].EmcDllCfg1 = 0x00010014; +SDRAM[0].EmcPmcScratch1 = 0x4befffff; +SDRAM[0].EmcPmcScratch2 = 0x7fffffff; +SDRAM[0].EmcPmcScratch3 = 0x4005d70b; +SDRAM[0].EmcPmacroPadCfgCtrl = 0x00020000; +SDRAM[0].EmcPmacroVttgenCtrl0 = 0x00030808; +SDRAM[0].EmcPmacroVttgenCtrl1 = 0x00015000; +SDRAM[0].EmcPmacroVttgenCtrl2 = 0x00101010; +SDRAM[0].EmcPmacroBrickCtrlRfu1 = 0x00001600; +SDRAM[0].EmcPmacroCmdBrickCtrlFdpd = 0x00000000; +SDRAM[0].EmcPmacroBrickCtrlRfu2 = 0x00000000; +SDRAM[0].EmcPmacroDataBrickCtrlFdpd = 0x00000000; +SDRAM[0].EmcPmacroBgBiasCtrl0 = 0x00000030; +SDRAM[0].EmcPmacroDataPadRxCtrl = 0x10050037; +SDRAM[0].EmcPmacroCmdPadRxCtrl = 0x00000000; +SDRAM[0].EmcPmacroDataRxTermMode = 0x00000010; +SDRAM[0].EmcPmacroCmdRxTermMode = 0x00003000; +SDRAM[0].EmcPmacroDataPadTxCtrl = 0x02000111; +SDRAM[0].EmcPmacroCommonPadTxCtrl = 0x00000008; +SDRAM[0].EmcPmacroCmdPadTxCtrl = 0x0a000000; +SDRAM[0].EmcCfg3 = 0x00000040; +SDRAM[0].EmcPmacroTxPwrd0 = 0x10000000; +SDRAM[0].EmcPmacroTxPwrd1 = 0x08000000; +SDRAM[0].EmcPmacroTxPwrd2 = 0x10000000; +SDRAM[0].EmcPmacroTxPwrd3 = 0x08000000; +SDRAM[0].EmcPmacroTxPwrd4 = 0x00000000; +SDRAM[0].EmcPmacroTxPwrd5 = 0x00000000; +SDRAM[0].EmcConfigSampleDelay = 0x00000020; +SDRAM[0].EmcPmacroBrickMapping0 = 0x28190081; +SDRAM[0].EmcPmacroBrickMapping1 = 0x44853293; +SDRAM[0].EmcPmacroBrickMapping2 = 0x76a76a5b; +SDRAM[0].EmcPmacroTxSelClkSrc0 = 0x00000000; +SDRAM[0].EmcPmacroTxSelClkSrc1 = 0x00000000; +SDRAM[0].EmcPmacroTxSelClkSrc2 = 0x00000000; +SDRAM[0].EmcPmacroTxSelClkSrc3 = 0x00000000; +SDRAM[0].EmcPmacroTxSelClkSrc4 = 0x00000000; +SDRAM[0].EmcPmacroTxSelClkSrc5 = 0x00000000; +SDRAM[0].EmcPmacroDdllBypass = 0xefffefff; +SDRAM[0].EmcPmacroDdllPwrd0 = 0xc0c0c0c0; +SDRAM[0].EmcPmacroDdllPwrd1 = 0xc0c0c0c0; +SDRAM[0].EmcPmacroDdllPwrd2 = 0xdcdcdcdc; +SDRAM[0].EmcPmacroCmdCtrl0 = 0x0a0a0a0a; +SDRAM[0].EmcPmacroCmdCtrl1 = 0x0a0a0a0a; +SDRAM[0].EmcPmacroCmdCtrl2 = 0x0a0a0a0a; +SDRAM[0].McEmemAdrCfg = 0x00000001; +SDRAM[0].McEmemAdrCfgDev0 = 0x000d0302; +SDRAM[0].McEmemAdrCfgDev1 = 0x000d0302; +SDRAM[0].McEmemAdrCfgChannelMask = 0xffff2400; +SDRAM[0].McEmemAdrCfgBankMask0 = 0x6e574400; +SDRAM[0].McEmemAdrCfgBankMask1 = 0x39722800; +SDRAM[0].McEmemAdrCfgBankMask2 = 0x4b9c1000; +SDRAM[0].McEmemCfg = 0x00000c00; +SDRAM[0].McEmemArbCfg = 0x08000001; +SDRAM[0].McEmemArbOutstandingReq = 0x8000004c; +SDRAM[0].McEmemArbRefpbHpCtrl = 0x000a1020; +SDRAM[0].McEmemArbRefpbBankCtrl = 0x80001028; +SDRAM[0].McEmemArbTimingRcd = 0x00000001; +SDRAM[0].McEmemArbTimingRp = 0x00000000; +SDRAM[0].McEmemArbTimingRc = 0x00000003; +SDRAM[0].McEmemArbTimingRas = 0x00000001; +SDRAM[0].McEmemArbTimingFaw = 0x00000002; +SDRAM[0].McEmemArbTimingRrd = 0x00000001; +SDRAM[0].McEmemArbTimingRap2Pre = 0x00000002; +SDRAM[0].McEmemArbTimingWap2Pre = 0x00000005; +SDRAM[0].McEmemArbTimingR2R = 0x00000001; +SDRAM[0].McEmemArbTimingW2W = 0x00000001; +SDRAM[0].McEmemArbTimingR2W = 0x00000004; +SDRAM[0].McEmemArbTimingW2R = 0x00000005; +SDRAM[0].McEmemArbTimingRFCPB = 0x00000004; +SDRAM[0].McEmemArbDaTurns = 0x02020000; +SDRAM[0].McEmemArbDaCovers = 0x00030201; +SDRAM[0].McEmemArbMisc0 = 0x71c30504; +SDRAM[0].McEmemArbMisc1 = 0x70000f0f; +SDRAM[0].McEmemArbMisc2 = 0x00000000; +SDRAM[0].McEmemArbRing1Throttle = 0x001f0000; +SDRAM[0].McEmemArbOverride = 0x10000000; +SDRAM[0].McEmemArbOverride1 = 0x00000000; +SDRAM[0].McEmemArbRsv = 0xff00ff00; +SDRAM[0].McDaCfg0 = 0x00000001; +SDRAM[0].McEmemArbTimingCcdmw = 0x00000008; +SDRAM[0].McClkenOverride = 0x00008000; +SDRAM[0].McStatControl = 0x00000000; +SDRAM[0].McVideoProtectBom = 0xfff00000; +SDRAM[0].McVideoProtectBomAdrHi = 0x00000000; +SDRAM[0].McVideoProtectSizeMb = 0x00000000; +SDRAM[0].McVideoProtectVprOverride = 0xe4bac343; +SDRAM[0].McVideoProtectVprOverride1 = 0x00001ed3; +SDRAM[0].McVideoProtectGpuOverride0 = 0x00000000; +SDRAM[0].McVideoProtectGpuOverride1 = 0x00000000; +SDRAM[0].McSecCarveoutBom = 0xfff00000; +SDRAM[0].McSecCarveoutAdrHi = 0x00000000; +SDRAM[0].McSecCarveoutSizeMb = 0x00000000; +SDRAM[0].McVideoProtectWriteAccess = 0x00000000; +SDRAM[0].McSecCarveoutProtectWriteAccess = 0x00000000; +SDRAM[0].McGeneralizedCarveout1Bom = 0x00000000; +SDRAM[0].McGeneralizedCarveout1BomHi = 0x00000000; +SDRAM[0].McGeneralizedCarveout1Size128kb = 0x00000008; +SDRAM[0].McGeneralizedCarveout1Access0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout1Access1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout1Access2 = 0x00300000; +SDRAM[0].McGeneralizedCarveout1Access3 = 0x03000000; +SDRAM[0].McGeneralizedCarveout1Access4 = 0x00000000; +SDRAM[0].McGeneralizedCarveout1ForceInternalAccess0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout1ForceInternalAccess1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout1ForceInternalAccess2 = 0x00000000; +SDRAM[0].McGeneralizedCarveout1ForceInternalAccess3 = 0x00000000; +SDRAM[0].McGeneralizedCarveout1ForceInternalAccess4 = 0x00000000; +SDRAM[0].McGeneralizedCarveout1Cfg0 = 0x04000c75; +SDRAM[0].McGeneralizedCarveout2Bom = 0x00000000; +SDRAM[0].McGeneralizedCarveout2BomHi = 0x00000000; +SDRAM[0].McGeneralizedCarveout2Size128kb = 0x00000002; +SDRAM[0].McGeneralizedCarveout2Access0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout2Access1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout2Access2 = 0x03000000; +SDRAM[0].McGeneralizedCarveout2Access3 = 0x00000000; +SDRAM[0].McGeneralizedCarveout2Access4 = 0x00000300; +SDRAM[0].McGeneralizedCarveout2ForceInternalAccess0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout2ForceInternalAccess1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout2ForceInternalAccess2 = 0x00000000; +SDRAM[0].McGeneralizedCarveout2ForceInternalAccess3 = 0x00000000; +SDRAM[0].McGeneralizedCarveout2ForceInternalAccess4 = 0x00000000; +SDRAM[0].McGeneralizedCarveout2Cfg0 = 0x0440167c; +SDRAM[0].McGeneralizedCarveout3Bom = 0x00000000; +SDRAM[0].McGeneralizedCarveout3BomHi = 0x00000000; +SDRAM[0].McGeneralizedCarveout3Size128kb = 0x00000000; +SDRAM[0].McGeneralizedCarveout3Access0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout3Access1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout3Access2 = 0x03000000; +SDRAM[0].McGeneralizedCarveout3Access3 = 0x00000000; +SDRAM[0].McGeneralizedCarveout3Access4 = 0x00000300; +SDRAM[0].McGeneralizedCarveout3ForceInternalAccess0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout3ForceInternalAccess1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout3ForceInternalAccess2 = 0x00000000; +SDRAM[0].McGeneralizedCarveout3ForceInternalAccess3 = 0x00000000; +SDRAM[0].McGeneralizedCarveout3ForceInternalAccess4 = 0x00000000; +SDRAM[0].McGeneralizedCarveout3Cfg0 = 0x04401e7c; +SDRAM[0].McGeneralizedCarveout4Bom = 0x00000000; +SDRAM[0].McGeneralizedCarveout4BomHi = 0x00000000; +SDRAM[0].McGeneralizedCarveout4Size128kb = 0x00000008; +SDRAM[0].McGeneralizedCarveout4Access0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout4Access1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout4Access2 = 0x00300000; +SDRAM[0].McGeneralizedCarveout4Access3 = 0x00000000; +SDRAM[0].McGeneralizedCarveout4Access4 = 0x00000000; +SDRAM[0].McGeneralizedCarveout4ForceInternalAccess0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout4ForceInternalAccess1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout4ForceInternalAccess2 = 0x00000000; +SDRAM[0].McGeneralizedCarveout4ForceInternalAccess3 = 0x00000000; +SDRAM[0].McGeneralizedCarveout4ForceInternalAccess4 = 0x00000000; +SDRAM[0].McGeneralizedCarveout4Cfg0 = 0x04002442; +SDRAM[0].McGeneralizedCarveout5Bom = 0x00000000; +SDRAM[0].McGeneralizedCarveout5BomHi = 0x00000000; +SDRAM[0].McGeneralizedCarveout5Size128kb = 0x00000008; +SDRAM[0].McGeneralizedCarveout5Access0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout5Access1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout5Access2 = 0x00300000; +SDRAM[0].McGeneralizedCarveout5Access3 = 0x00000000; +SDRAM[0].McGeneralizedCarveout5Access4 = 0x00000000; +SDRAM[0].McGeneralizedCarveout5ForceInternalAccess0 = 0x00000000; +SDRAM[0].McGeneralizedCarveout5ForceInternalAccess1 = 0x00000000; +SDRAM[0].McGeneralizedCarveout5ForceInternalAccess2 = 0x00000000; +SDRAM[0].McGeneralizedCarveout5ForceInternalAccess3 = 0x00000000; +SDRAM[0].McGeneralizedCarveout5ForceInternalAccess4 = 0x00000000; +SDRAM[0].McGeneralizedCarveout5Cfg0 = 0x04002c42; +SDRAM[0].EmcCaTrainingEnable = 0x00000000; +SDRAM[0].SwizzleRankByteEncode = 0x0000000e; +SDRAM[0].BootRomPatchControl = 0x00000000; +SDRAM[0].BootRomPatchData = 0x00000000; +SDRAM[0].McMtsCarveoutBom = 0xfff00000; +SDRAM[0].McMtsCarveoutAdrHi = 0x00000000; +SDRAM[0].McMtsCarveoutSizeMb = 0x00000000; +SDRAM[0].McMtsCarveoutRegCtrl = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE0_0 {0x7001b800} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE0_1 {0x7001b804} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE0_2 {0x7001b808} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE0_3 {0x7001b80c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE1_0 {0x7001b810} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE1_1 {0x7001b814} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE1_2 {0x7001b818} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE1_3 {0x7001b81c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE2_0 {0x7001b820} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE2_1 {0x7001b824} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE2_2 {0x7001b828} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE2_3 {0x7001b82c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE3_0 {0x7001b830} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE3_1 {0x7001b834} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE3_2 {0x7001b838} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE3_3 {0x7001b83c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE4_0 {0x7001b840} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE4_1 {0x7001b844} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE4_2 {0x7001b848} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE4_3 {0x7001b84c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE5_0 {0x7001b850} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE5_1 {0x7001b854} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE5_2 {0x7001b858} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE5_3 {0x7001b85c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE6_0 {0x7001b860} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE6_1 {0x7001b864} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE6_2 {0x7001b868} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE6_3 {0x7001b86c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE7_0 {0x7001b870} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE7_1 {0x7001b874} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE7_2 {0x7001b878} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_BYTE7_3 {0x7001b87c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD0_0 {0x7001b880} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD0_1 {0x7001b884} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD0_2 {0x7001b888} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD0_3 {0x7001b88c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD1_0 {0x7001b890} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD1_1 {0x7001b894} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD1_2 {0x7001b898} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD1_3 {0x7001b89c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD2_0 {0x7001b8a0} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD2_1 {0x7001b8a4} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD2_2 {0x7001b8a8} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD2_3 {0x7001b8ac} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD3_0 {0x7001b8b0} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD3_1 {0x7001b8b4} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD3_2 {0x7001b8b8} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK0_CMD3_3 {0x7001b8bc} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE0_0 {0x7001b900} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE0_1 {0x7001b904} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE0_2 {0x7001b908} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE0_3 {0x7001b90c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE1_0 {0x7001b910} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE1_1 {0x7001b914} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE1_2 {0x7001b918} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE1_3 {0x7001b91c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE2_0 {0x7001b920} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE2_1 {0x7001b924} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE2_2 {0x7001b928} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE2_3 {0x7001b92c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE3_0 {0x7001b930} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE3_1 {0x7001b934} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE3_2 {0x7001b938} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE3_3 {0x7001b93c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE4_0 {0x7001b940} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE4_1 {0x7001b944} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE4_2 {0x7001b948} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE4_3 {0x7001b94c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE5_0 {0x7001b950} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE5_1 {0x7001b954} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE5_2 {0x7001b958} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE5_3 {0x7001b95c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE6_0 {0x7001b960} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE6_1 {0x7001b964} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE6_2 {0x7001b968} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE6_3 {0x7001b96c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE7_0 {0x7001b970} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE7_1 {0x7001b974} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE7_2 {0x7001b978} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_BYTE7_3 {0x7001b97c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD0_0 {0x7001b980} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD0_1 {0x7001b984} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD0_2 {0x7001b988} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD0_3 {0x7001b98c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD1_0 {0x7001b990} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD1_1 {0x7001b994} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD1_2 {0x7001b998} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD1_3 {0x7001b99c} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD2_0 {0x7001b9a0} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD2_1 {0x7001b9a4} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD2_2 {0x7001b9a8} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD2_3 {0x7001b9ac} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD3_0 {0x7001b9b0} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD3_1 {0x7001b9b4} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD3_2 {0x7001b9b8} = 0x00000000; +#@ EMC_PMACRO_OB_DDLL_SHORT_DQ_RANK1_CMD3_3 {0x7001b9bc} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE0_0 {0x7001ba00} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE0_1 {0x7001ba04} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE0_2 {0x7001ba08} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE1_0 {0x7001ba10} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE1_1 {0x7001ba14} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE1_2 {0x7001ba18} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE2_0 {0x7001ba20} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE2_1 {0x7001ba24} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE2_2 {0x7001ba28} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE3_0 {0x7001ba30} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE3_1 {0x7001ba34} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE3_2 {0x7001ba38} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE4_0 {0x7001ba40} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE4_1 {0x7001ba44} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE4_2 {0x7001ba48} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE5_0 {0x7001ba50} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE5_1 {0x7001ba54} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE5_2 {0x7001ba58} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE6_0 {0x7001ba60} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE6_1 {0x7001ba64} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE6_2 {0x7001ba68} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE7_0 {0x7001ba70} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE7_1 {0x7001ba74} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK0_BYTE7_2 {0x7001ba78} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE0_0 {0x7001bb00} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE0_1 {0x7001bb04} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE0_2 {0x7001bb08} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE1_0 {0x7001bb10} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE1_1 {0x7001bb14} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE1_2 {0x7001bb18} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE2_0 {0x7001bb20} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE2_1 {0x7001bb24} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE2_2 {0x7001bb28} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE3_0 {0x7001bb30} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE3_1 {0x7001bb34} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE3_2 {0x7001bb38} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE4_0 {0x7001bb40} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE4_1 {0x7001bb44} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE4_2 {0x7001bb48} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE5_0 {0x7001bb50} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE5_1 {0x7001bb54} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE5_2 {0x7001bb58} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE6_0 {0x7001bb60} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE6_1 {0x7001bb64} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE6_2 {0x7001bb68} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE7_0 {0x7001bb70} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE7_1 {0x7001bb74} = 0x00000000; +#@ EMC_PMACRO_IB_DDLL_SHORT_DQ_RANK1_BYTE7_2 {0x7001bb78} = 0x00000000; +#@ EMC_TR_TIMING_0 {0x7001b3b4} = 0x01186033; +#@ EMC_TR_DVFS {0x7001b460} = 0x00000000; +#@ EMC_TR_CTRL_1 {0x7001b3bc} = 0x00000000; +#@ EMC_TR_RDV {0x7001b3c4} = 0x00000014; +#@ EMC_TR_QPOP {0x7001b3f4} = 0x0000000a; +#@ EMC_TR_RDV_MASK {0x7001b3f8} = 0x00000016; +#@ EMC_TR_QSAFE {0x7001b3fc} = 0x00000012; +#@ EMC_TR_QRST {0x7001b400} = 0x00010000; +#@ EMC_TRAINING_CTRL {0x7001be04} = 0x00009080; +#@ EMC_TRAINING_SETTLE {0x7001be44} = 0x07070404; +#@ EMC_TRAINING_VREF_SETTLE {0x7001be6c} = 0x00040065; +#@ EMC_TRAINING_CA_FINE_CTRL {0x7001be30} = 0x0513801f; +#@ EMC_TRAINING_CA_CTRL_MISC {0x7001be34} = 0x1f101100; +#@ EMC_TRAINING_CA_CTRL_MISC1 {0x7001be38} = 0x00000014; +#@ EMC_TRAINING_CA_VREF_CTRL {0x7001be3c} = 0x00107240; +#@ EMC_TRAINING_QUSE_CORS_CTRL {0x7001be0c} = 0x01124000; +#@ EMC_TRAINING_QUSE_FINE_CTRL {0x7001be10} = 0x01125b6a; +#@ EMC_TRAINING_QUSE_CTRL_MISC {0x7001be14} = 0x0f081000; +#@ EMC_TRAINING_QUSE_VREF_CTRL {0x7001bed0} = 0x00105800; +#@ EMC_TRAINING_READ_FINE_CTRL {0x7001be24} = 0x1110fc00; +#@ EMC_TRAINING_READ_CTRL_MISC {0x7001be28} = 0x0f081300; +#@ EMC_TRAINING_READ_VREF_CTRL {0x7001be2c} = 0x00105800; +#@ EMC_TRAINING_WRITE_FINE_CTRL {0x7001be18} = 0x1114fc00; +#@ EMC_TRAINING_WRITE_CTRL_MISC {0x7001be1c} = 0x07000300; +#@ EMC_TRAINING_WRITE_VREF_CTRL {0x7001be20} = 0x00107240; +#@ EMC_TRAINING_MPC {0x7001be5c} = 0x55553c5a; +#@ MC_MLL_MPCORER_PTSA_RATE {0x7001944c} = 0x0000001b; +#@ MC_PTSA_GRANT_DECREMENT {0x70019960} = 0x0000024c; +#@ MC_LATENCY_ALLOWANCE_XUSB_0 {0x7001937c} = 0x00ff00b2; +#@ MC_LATENCY_ALLOWANCE_XUSB_1 {0x70019380} = 0x00ff00da; +#@ MC_LATENCY_ALLOWANCE_TSEC_0 {0x70019390} = 0x00ff009d; +#@ MC_LATENCY_ALLOWANCE_SDMMCA_0 {0x700193b8} = 0x00ff00ff; +#@ MC_LATENCY_ALLOWANCE_SDMMCAA_0 {0x700193bc} = 0x00ff000c; +#@ MC_LATENCY_ALLOWANCE_SDMMC_0 {0x700193c0} = 0x00ff00ff; +#@ MC_LATENCY_ALLOWANCE_SDMMCAB_0 {0x700193c4} = 0x00ff000c; +#@ MC_LATENCY_ALLOWANCE_PPCS_0 {0x70019344} = 0x007f0049; +#@ MC_LATENCY_ALLOWANCE_PPCS_1 {0x70019348} = 0x00ff0080; +#@ MC_LATENCY_ALLOWANCE_MPCORE_0 {0x70019320} = 0x00ff0004; +#@ MC_LATENCY_ALLOWANCE_HC_0 {0x70019310} = 0x000800ad; +#@ MC_LATENCY_ALLOWANCE_HC_1 {0x70019314} = 0x000000ff; +#@ MC_LATENCY_ALLOWANCE_AVPC_0 {0x700192e4} = 0x00ff0004; +#@ MC_LATENCY_ALLOWANCE_GPU_0 {0x700193ac} = 0x00ff00c6; +#@ MC_LATENCY_ALLOWANCE_GPU2_0 {0x700193e8} = 0x00ff00c6; +#@ MC_LATENCY_ALLOWANCE_NVENC_0 {0x70019328} = 0x00ff006d; +#@ MC_LATENCY_ALLOWANCE_NVDEC_0 {0x700193d8} = 0x00ff00ff; +#@ MC_LATENCY_ALLOWANCE_VIC_0 {0x70019394} = 0x00ff00e2; +#@ MC_LATENCY_ALLOWANCE_VI2_0 {0x70019398} = 0x000000ff; +#@ MC_LATENCY_ALLOWANCE_ISP2_0 {0x70019370} = 0x00000080; +#@ MC_LATENCY_ALLOWANCE_ISP2_1 {0x70019374} = 0x00ff00ff; +#@ MC_LATENCY_ALLOWANCE_NVJPG_0 {0x700193e4} = 0x00ff00ea; +#@ MC_LATENCY_ALLOWANCE_APE_0 {0x700193dc} = 0x00ff00ff; +#@ MC_LATENCY_ALLOWANCE_TSECB_0 {0x700193f0} = 0x00ff009d; +#@ MC_LATENCY_ALLOWANCE_ISP2B_0 {0x70019384} = 0x00000080; +#@ MC_LATENCY_ALLOWANCE_ISP2B_1 {0x70019388} = 0x00ff00ff; +#@ MC_LATENCY_ALLOWANCE_SATA_0 {0x70019350} = 0x00ff00ff; +#@ MC_LATENCY_ALLOWANCE_AFI_0 {0x700192e0} = 0x00ff00da; +#@ MC_LATENCY_ALLOWANCE_HDA_0 {0x70019318} = 0x00ff0024; +#@ EMC_MRW10_CH0 {0x7001e4b4} = 0x880c6b6b; +#@ EMC_MRW10_CH1 {0x7001f4b4} = 0x880c6b6b; +#@ EMC_MRW11_CH0 {0x7001e4b8} = 0x480c6b6b; +#@ EMC_MRW11_CH1 {0x7001f4b8} = 0x480c6b6b; +#@ tPDEX [dvfs dram_timing] = 0x00000018; +#@ tRP [dvfs dram_timing] = 0x00000012; +#@ tRFC [dvfs dram_timing] = 0x000000b4; +#@ tFC_lpddr4 [dvfs dram_timing hard_coded] = 0x00000104; +#@ RL [dvfs dram_timing] = 0x00000006; + diff --git a/src/mainboard/google/foster/bct/sdram-samsung-3GB-204.inc b/src/mainboard/google/foster/bct/sdram-samsung-3GB-204.inc new file mode 100644 index 0000000..29d55c9 --- /dev/null +++ b/src/mainboard/google/foster/bct/sdram-samsung-3GB-204.inc @@ -0,0 +1,477 @@ +{ /* generated from sdram-samsung-3GB-204.cfg; do not edit. */ + .MemoryType = NvBootMemoryType_LpDdr4, + .PllMInputDivider = 0x00000001, + .PllMFeedbackDivider = 0x00000022, + .PllMStableTime = 0x0000012c, + .PllMSetupControl = 0x00000000, + .PllMPostDivider = 0x00000000, + .PllMKCP = 0x00000000, + .PllMKVCO = 0x00000000, + .EmcBctSpare0 = 0x00000000, + .EmcBctSpare1 = 0x00000000, + .EmcBctSpare2 = 0x00000000, + .EmcBctSpare3 = 0x00000000, + .EmcBctSpare4 = 0x7001bc3c, + .EmcBctSpare5 = 0x00000032, + .EmcBctSpare6 = 0x7001b404, + .EmcBctSpare7 = 0x71245603, + .EmcBctSpare8 = 0x7000e6c8, + .EmcBctSpare9 = 0x00000000, + .EmcBctSpare10 = 0x00000000, + .EmcBctSpare11 = 0x00000000, + .EmcBctSpare12 = 0x7001bc3c, + .EmcBctSpare13 = 0x00000033, + .EmcClockSource = 0x40188002, + .EmcClockSourceDll = 0x40000000, + .ClkRstControllerPllmMisc2Override = 0x00000000, + .ClkRstControllerPllmMisc2OverrideEnable = 0x00000000, + .ClearClk2Mc1 = 0x00000000, + .EmcAutoCalInterval = 0x001fffff, + .EmcAutoCalConfig = 0xa01a51d8, + .EmcAutoCalConfig2 = 0x05500000, + .EmcAutoCalConfig3 = 0x00770000, + .EmcAutoCalConfig4 = 0x00770000, + .EmcAutoCalConfig5 = 0x00770000, + .EmcAutoCalConfig6 = 0x00770000, + .EmcAutoCalConfig7 = 0x00770000, + .EmcAutoCalConfig8 = 0x00770000, + .EmcAutoCalVrefSel0 = 0xb3afa6a6, + .EmcAutoCalVrefSel1 = 0x00009e3c, + .EmcAutoCalChannel = 0xc1e00303, + .EmcPmacroAutocalCfg0 = 0x04040404, + .EmcPmacroAutocalCfg1 = 0x04040404, + .EmcPmacroAutocalCfg2 = 0x00000000, + .EmcPmacroRxTerm = 0x1f1f1f1f, + .EmcPmacroDqTxDrv = 0x1f1f1f1f, + .EmcPmacroCaTxDrv = 0x1f1f1f1f, + .EmcPmacroCmdTxDrv = 0x00001f1f, + .EmcPmacroAutocalCfgCommon = 0x00000804, + .EmcPmacroZctrl = 0x00000550, + .EmcAutoCalWait = 0x000001a1, + .EmcXm2CompPadCtrl = 0x00000032, + .EmcXm2CompPadCtrl2 = 0x00000000, + .EmcXm2CompPadCtrl3 = 0x00000000, + .EmcAdrCfg = 0x00000001, + .EmcPinProgramWait = 0x00000002, + .EmcPinExtraWait = 0x00000000, + .EmcPinGpioEn = 0x00000003, + .EmcPinGpio = 0x00000003, + .EmcTimingControlWait = 0x0000001e, + .EmcRc = 0x0000000d, + .EmcRfc = 0x00000025, + .EmcRfcPb = 0x00000013, + .EmcRefctrl2 = 0x00000000, + .EmcRfcSlr = 0x00000000, + .EmcRas = 0x00000009, + .EmcRp = 0x00000004, + .EmcR2r = 0x00000000, + .EmcW2w = 0x00000000, + .EmcR2w = 0x0000000b, + .EmcW2r = 0x0000000d, + .EmcR2p = 0x00000008, + .EmcW2p = 0x0000000b, + .EmcTppd = 0x00000004, + .EmcCcdmw = 0x00000020, + .EmcRdRcd = 0x00000006, + .EmcWrRcd = 0x00000006, + .EmcRrd = 0x00000006, + .EmcRext = 0x00000003, + .EmcWext = 0x00000000, + .EmcWdv = 0x00000004, + .EmcWdvChk = 0x00000006, + .EmcWsv = 0x00000002, + .EmcWev = 0x00000000, + .EmcWdvMask = 0x00000004, + .EmcWsDuration = 0x00000008, + .EmcWeDuration = 0x0000000d, + .EmcQUse = 0x00000005, + .EmcQuseWidth = 0x00000006, + .EmcIbdly = 0x00000000, + .EmcObdly = 0x00000000, + .EmcEInput = 0x00000002, + .EmcEInputDuration = 0x0000000d, + .EmcPutermExtra = 0x00000002, + .EmcPutermWidth = 0x0000000b, + .EmcQRst = 0x00010000, + .EmcQSafe = 0x00000012, + .EmcRdv = 0x00000014, + .EmcRdvMask = 0x00000016, + .EmcRdvEarly = 0x00000012, + .EmcRdvEarlyMask = 0x00000014, + .EmcQpop = 0x0000000a, + .EmcRefresh = 0x00000304, + .EmcBurstRefreshNum = 0x00000000, + .EmcPreRefreshReqCnt = 0x000000c1, + .EmcPdEx2Wr = 0x00000008, + .EmcPdEx2Rd = 0x00000008, + .EmcPChg2Pden = 0x00000003, + .EmcAct2Pden = 0x00000003, + .EmcAr2Pden = 0x00000003, + .EmcRw2Pden = 0x00000012, + .EmcCke2Pden = 0x00000005, + .EmcPdex2Cke = 0x00000002, + .EmcPdex2Mrr = 0x0000000d, + .EmcTxsr = 0x00000027, + .EmcTxsrDll = 0x00000027, + .EmcTcke = 0x00000005, + .EmcTckesr = 0x00000005, + .EmcTpd = 0x00000004, + .EmcTfaw = 0x00000009, + .EmcTrpab = 0x00000005, + .EmcTClkStable = 0x00000003, + .EmcTClkStop = 0x00000009, + .EmcTRefBw = 0x0000031c, + .EmcFbioCfg5 = 0x9160a00d, + .EmcFbioCfg7 = 0x00003bbf, + .EmcFbioCfg8 = 0x0cf30000, + .EmcCmdMappingCmd0_0 = 0x07050203, + .EmcCmdMappingCmd0_1 = 0x06041b1c, + .EmcCmdMappingCmd0_2 = 0x05252523, + .EmcCmdMappingCmd1_0 = 0x1e0d0b0a, + .EmcCmdMappingCmd1_1 = 0x240c091d, + .EmcCmdMappingCmd1_2 = 0x04262608, + .EmcCmdMappingCmd2_0 = 0x051b0302, + .EmcCmdMappingCmd2_1 = 0x0604231c, + .EmcCmdMappingCmd2_2 = 0x09252507, + .EmcCmdMappingCmd3_0 = 0x0c0b0d0a, + .EmcCmdMappingCmd3_1 = 0x08091e1d, + .EmcCmdMappingCmd3_2 = 0x08262624, + .EmcCmdMappingByte = 0x0a270623, + .EmcFbioSpare = 0x00000012, + .EmcCfgRsv = 0xff00ff00, + .EmcMrs = 0x00000000, + .EmcEmrs = 0x00000000, + .EmcEmrs2 = 0x00000000, + .EmcEmrs3 = 0x00000000, + .EmcMrw1 = 0x08010004, + .EmcMrw2 = 0x08020000, + .EmcMrw3 = 0x080d0000, + .EmcMrw4 = 0xc0000000, + .EmcMrw6 = 0x08037171, + .EmcMrw8 = 0x080b0000, + .EmcMrw9 = 0x0c0e6b6b, + .EmcMrw10 = 0x00000000, + .EmcMrw12 = 0x0c0d0808, + .EmcMrw13 = 0x0c0d0000, + .EmcMrw14 = 0x08161414, + .EmcMrwExtra = 0x08010004, + .EmcWarmBootMrwExtra = 0x08110000, + .EmcWarmBootExtraModeRegWriteEnable = 0x00000001, + .EmcExtraModeRegWriteEnable = 0x00000000, + .EmcMrwResetCommand = 0x00000000, + .EmcMrwResetNInitWait = 0x00000000, + .EmcMrsWaitCnt = 0x00cc0015, + .EmcMrsWaitCnt2 = 0x0033000a, + .EmcCfg = 0xf3200000, + .EmcCfg2 = 0x00110805, + .EmcCfgPipe = 0x0fff0fff, + .EmcCfgPipeClk = 0x00000000, + .EmcFdpdCtrlCmdNoRamp = 0x00000001, + .EmcCfgUpdate = 0x70000301, + .EmcDbg = 0x01000c00, + .EmcDbgWriteMux = 0x00000001, + .EmcCmdQ = 0x10004408, + .EmcMc2EmcQ = 0x06000404, + .EmcDynSelfRefControl = 0x80000713, + .AhbArbitrationXbarCtrlMemInitDone = 0x00000001, + .EmcCfgDigDll = 0x002c00a0, + .EmcCfgDigDll_1 = 0x00003701, + .EmcCfgDigDllPeriod = 0x00008000, + .EmcDevSelect = 0x00000000, + .EmcSelDpdCtrl = 0x00040008, + .EmcFdpdCtrlDq = 0x8020221f, + .EmcFdpdCtrlCmd = 0x0220f40f, + .EmcPmacroIbVrefDq_0 = 0x28282828, + .EmcPmacroIbVrefDq_1 = 0x28282828, + .EmcPmacroIbVrefDqs_0 = 0x11111111, + .EmcPmacroIbVrefDqs_1 = 0x11111111, + .EmcPmacroIbRxrt = 0x000000be, + .EmcCfgPipe1 = 0x0fff0fff, + .EmcCfgPipe2 = 0x0fff0fff, + .EmcPmacroQuseDdllRank0_0 = 0x00000000, + .EmcPmacroQuseDdllRank0_1 = 0x00000000, + .EmcPmacroQuseDdllRank0_2 = 0x00000000, + .EmcPmacroQuseDdllRank0_3 = 0x00000000, + .EmcPmacroQuseDdllRank0_4 = 0x00000000, + .EmcPmacroQuseDdllRank0_5 = 0x00000000, + .EmcPmacroQuseDdllRank1_0 = 0x00000000, + .EmcPmacroQuseDdllRank1_1 = 0x00000000, + .EmcPmacroQuseDdllRank1_2 = 0x00000000, + .EmcPmacroQuseDdllRank1_3 = 0x00000000, + .EmcPmacroQuseDdllRank1_4 = 0x00000000, + .EmcPmacroQuseDdllRank1_5 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_0 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_1 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_2 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_3 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_4 = 0x00080007, + .EmcPmacroObDdllLongDqRank0_5 = 0x00090006, + .EmcPmacroObDdllLongDqRank1_0 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_1 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_2 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_3 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_4 = 0x00080007, + .EmcPmacroObDdllLongDqRank1_5 = 0x00090006, + .EmcPmacroObDdllLongDqsRank0_0 = 0x00340033, + .EmcPmacroObDdllLongDqsRank0_1 = 0x00340037, + .EmcPmacroObDdllLongDqsRank0_2 = 0x00360037, + .EmcPmacroObDdllLongDqsRank0_3 = 0x00330036, + .EmcPmacroObDdllLongDqsRank0_4 = 0x000a000c, + .EmcPmacroObDdllLongDqsRank0_5 = 0x000d000a, + .EmcPmacroObDdllLongDqsRank1_0 = 0x00340033, + .EmcPmacroObDdllLongDqsRank1_1 = 0x00340037, + .EmcPmacroObDdllLongDqsRank1_2 = 0x00360037, + .EmcPmacroObDdllLongDqsRank1_3 = 0x00330036, + .EmcPmacroObDdllLongDqsRank1_4 = 0x000a000c, + .EmcPmacroObDdllLongDqsRank1_5 = 0x000d000a, + .EmcPmacroIbDdllLongDqsRank0_0 = 0x00F000F0, + .EmcPmacroIbDdllLongDqsRank0_1 = 0x00F000F0, + .EmcPmacroIbDdllLongDqsRank0_2 = 0x00F000F0, + .EmcPmacroIbDdllLongDqsRank0_3 = 0x00F000F0, + .EmcPmacroIbDdllLongDqsRank1_0 = 0x00F000F0, + .EmcPmacroIbDdllLongDqsRank1_1 = 0x00F000F0, + .EmcPmacroIbDdllLongDqsRank1_2 = 0x00F000F0, + .EmcPmacroIbDdllLongDqsRank1_3 = 0x00F000F0, + .EmcPmacroDdllLongCmd_0 = 0x00070007, + .EmcPmacroDdllLongCmd_1 = 0x00080008, + .EmcPmacroDdllLongCmd_2 = 0x00060006, + .EmcPmacroDdllLongCmd_3 = 0x00090009, + .EmcPmacroDdllLongCmd_4 = 0x00000007, + .EmcPmacroDdllShortCmd_0 = 0x00000000, + .EmcPmacroDdllShortCmd_1 = 0x00000000, + .EmcPmacroDdllShortCmd_2 = 0x00000000, + .WarmBootWait = 0x00000001, + .EmcOdtWrite = 0x00000000, + .EmcZcalInterval = 0x00064000, + .EmcZcalWaitCnt = 0x000900cc, + .EmcZcalMrwCmd = 0x0051004f, + .EmcMrsResetDll = 0x00000000, + .EmcZcalInitDev0 = 0x80000001, + .EmcZcalInitDev1 = 0x40000001, + .EmcZcalInitWait = 0x00000001, + .EmcZcalWarmColdBootEnables = 0x00000003, + .EmcMrwLpddr2ZcalWarmBoot = 0x040a00ab, + .EmcZqCalDdr3WarmBoot = 0x00000011, + .EmcZqCalLpDdr4WarmBoot = 0x00000001, + .EmcZcalWarmBootWait = 0x00000001, + .EmcMrsWarmBootEnable = 0x00000001, + .EmcMrsResetDllWait = 0x00000000, + .EmcMrsExtra = 0x00000000, + .EmcWarmBootMrsExtra = 0x00000000, + .EmcEmrsDdr2DllEnable = 0x00000000, + .EmcMrsDdr2DllReset = 0x00000000, + .EmcEmrsDdr2OcdCalib = 0x00000000, + .EmcDdr2Wait = 0x00000000, + .EmcClkenOverride = 0x00000000, + .EmcExtraRefreshNum = 0x00000002, + .EmcClkenOverrideAllWarmBoot = 0x00000000, + .McClkenOverrideAllWarmBoot = 0x00000000, + .EmcCfgDigDllPeriodWarmBoot = 0x00000003, + .PmcVddpSel = 0x00000001, + .PmcVddpSelWait = 0x00000002, + .PmcDdrPwr = 0x0000000f, + .PmcDdrCfg = 0x20120100, + .PmcIoDpd3Req = 0x4befffff, + .PmcIoDpd3ReqWait = 0x00000001, + .PmcIoDpd4ReqWait = 0x00000002, + .PmcRegShort = 0x00000000, + .PmcNoIoPower = 0x00000000, + .PmcDdrCntrlWait = 0x00000000, + .PmcDdrCntrl = 0x0007ff8b, + .EmcAcpdControl = 0x00000000, + .EmcSwizzleRank0Byte0 = 0x71245603, + .EmcSwizzleRank0Byte1 = 0x16243705, + .EmcSwizzleRank0Byte2 = 0x12574630, + .EmcSwizzleRank0Byte3 = 0x26147503, + .EmcSwizzleRank1Byte0 = 0x71345602, + .EmcSwizzleRank1Byte1 = 0x20456713, + .EmcSwizzleRank1Byte2 = 0x64071325, + .EmcSwizzleRank1Byte3 = 0x54023167, + .EmcTxdsrvttgen = 0x00000000, + .EmcDataBrlshft0 = 0x00249249, + .EmcDataBrlshft1 = 0x00249249, + .EmcDqsBrlshft0 = 0x00000000, + .EmcDqsBrlshft1 = 0x00000000, + .EmcCmdBrlshft0 = 0x00000000, + .EmcCmdBrlshft1 = 0x00000000, + .EmcCmdBrlshft2 = 0x00000012, + .EmcCmdBrlshft3 = 0x00000012, + .EmcQuseBrlshft0 = 0x00000000, + .EmcQuseBrlshft1 = 0x00000000, + .EmcQuseBrlshft2 = 0x00000000, + .EmcQuseBrlshft3 = 0x00000000, + .EmcDllCfg0 = 0x1f13412f, + .EmcDllCfg1 = 0x00010014, + .EmcPmcScratch1 = 0x4befffff, + .EmcPmcScratch2 = 0x7fffffff, + .EmcPmcScratch3 = 0x4005d70b, + .EmcPmacroPadCfgCtrl = 0x00020000, + .EmcPmacroVttgenCtrl0 = 0x00030808, + .EmcPmacroVttgenCtrl1 = 0x00015000, + .EmcPmacroVttgenCtrl2 = 0x00101010, + .EmcPmacroBrickCtrlRfu1 = 0x00001600, + .EmcPmacroCmdBrickCtrlFdpd = 0x00000000, + .EmcPmacroBrickCtrlRfu2 = 0x00000000, + .EmcPmacroDataBrickCtrlFdpd = 0x00000000, + .EmcPmacroBgBiasCtrl0 = 0x00000030, + .EmcPmacroDataPadRxCtrl = 0x10050037, + .EmcPmacroCmdPadRxCtrl = 0x00000000, + .EmcPmacroDataRxTermMode = 0x00000010, + .EmcPmacroCmdRxTermMode = 0x00003000, + .EmcPmacroDataPadTxCtrl = 0x02000111, + .EmcPmacroCommonPadTxCtrl = 0x00000008, + .EmcPmacroCmdPadTxCtrl = 0x0a000000, + .EmcCfg3 = 0x00000040, + .EmcPmacroTxPwrd0 = 0x10000000, + .EmcPmacroTxPwrd1 = 0x08000000, + .EmcPmacroTxPwrd2 = 0x10000000, + .EmcPmacroTxPwrd3 = 0x08000000, + .EmcPmacroTxPwrd4 = 0x00000000, + .EmcPmacroTxPwrd5 = 0x00000000, + .EmcConfigSampleDelay = 0x00000020, + .EmcPmacroBrickMapping0 = 0x28190081, + .EmcPmacroBrickMapping1 = 0x44853293, + .EmcPmacroBrickMapping2 = 0x76a76a5b, + .EmcPmacroTxSelClkSrc0 = 0x00000000, + .EmcPmacroTxSelClkSrc1 = 0x00000000, + .EmcPmacroTxSelClkSrc2 = 0x00000000, + .EmcPmacroTxSelClkSrc3 = 0x00000000, + .EmcPmacroTxSelClkSrc4 = 0x00000000, + .EmcPmacroTxSelClkSrc5 = 0x00000000, + .EmcPmacroDdllBypass = 0xefffefff, + .EmcPmacroDdllPwrd0 = 0xc0c0c0c0, + .EmcPmacroDdllPwrd1 = 0xc0c0c0c0, + .EmcPmacroDdllPwrd2 = 0xdcdcdcdc, + .EmcPmacroCmdCtrl0 = 0x0a0a0a0a, + .EmcPmacroCmdCtrl1 = 0x0a0a0a0a, + .EmcPmacroCmdCtrl2 = 0x0a0a0a0a, + .McEmemAdrCfg = 0x00000001, + .McEmemAdrCfgDev0 = 0x000d0302, + .McEmemAdrCfgDev1 = 0x000d0302, + .McEmemAdrCfgChannelMask = 0xffff2400, + .McEmemAdrCfgBankMask0 = 0x6e574400, + .McEmemAdrCfgBankMask1 = 0x39722800, + .McEmemAdrCfgBankMask2 = 0x4b9c1000, + .McEmemCfg = 0x00000c00, + .McEmemArbCfg = 0x08000001, + .McEmemArbOutstandingReq = 0x8000004c, + .McEmemArbRefpbHpCtrl = 0x000a1020, + .McEmemArbRefpbBankCtrl = 0x80001028, + .McEmemArbTimingRcd = 0x00000001, + .McEmemArbTimingRp = 0x00000000, + .McEmemArbTimingRc = 0x00000003, + .McEmemArbTimingRas = 0x00000001, + .McEmemArbTimingFaw = 0x00000002, + .McEmemArbTimingRrd = 0x00000001, + .McEmemArbTimingRap2Pre = 0x00000002, + .McEmemArbTimingWap2Pre = 0x00000005, + .McEmemArbTimingR2R = 0x00000001, + .McEmemArbTimingW2W = 0x00000001, + .McEmemArbTimingR2W = 0x00000004, + .McEmemArbTimingW2R = 0x00000005, + .McEmemArbTimingRFCPB = 0x00000004, + .McEmemArbDaTurns = 0x02020000, + .McEmemArbDaCovers = 0x00030201, + .McEmemArbMisc0 = 0x71c30504, + .McEmemArbMisc1 = 0x70000f0f, + .McEmemArbMisc2 = 0x00000000, + .McEmemArbRing1Throttle = 0x001f0000, + .McEmemArbOverride = 0x10000000, + .McEmemArbOverride1 = 0x00000000, + .McEmemArbRsv = 0xff00ff00, + .McDaCfg0 = 0x00000001, + .McEmemArbTimingCcdmw = 0x00000008, + .McClkenOverride = 0x00008000, + .McStatControl = 0x00000000, + .McVideoProtectBom = 0xfff00000, + .McVideoProtectBomAdrHi = 0x00000000, + .McVideoProtectSizeMb = 0x00000000, + .McVideoProtectVprOverride = 0xe4bac343, + .McVideoProtectVprOverride1 = 0x00001ed3, + .McVideoProtectGpuOverride0 = 0x00000000, + .McVideoProtectGpuOverride1 = 0x00000000, + .McSecCarveoutBom = 0xfff00000, + .McSecCarveoutAdrHi = 0x00000000, + .McSecCarveoutSizeMb = 0x00000000, + .McVideoProtectWriteAccess = 0x00000000, + .McSecCarveoutProtectWriteAccess = 0x00000000, + .McGeneralizedCarveout1Bom = 0x00000000, + .McGeneralizedCarveout1BomHi = 0x00000000, + .McGeneralizedCarveout1Size128kb = 0x00000008, + .McGeneralizedCarveout1Access0 = 0x00000000, + .McGeneralizedCarveout1Access1 = 0x00000000, + .McGeneralizedCarveout1Access2 = 0x00300000, + .McGeneralizedCarveout1Access3 = 0x03000000, + .McGeneralizedCarveout1Access4 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout1Cfg0 = 0x04000c75, + .McGeneralizedCarveout2Bom = 0x00000000, + .McGeneralizedCarveout2BomHi = 0x00000000, + .McGeneralizedCarveout2Size128kb = 0x00000002, + .McGeneralizedCarveout2Access0 = 0x00000000, + .McGeneralizedCarveout2Access1 = 0x00000000, + .McGeneralizedCarveout2Access2 = 0x03000000, + .McGeneralizedCarveout2Access3 = 0x00000000, + .McGeneralizedCarveout2Access4 = 0x00000300, + .McGeneralizedCarveout2ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout2Cfg0 = 0x0440167c, + .McGeneralizedCarveout3Bom = 0x00000000, + .McGeneralizedCarveout3BomHi = 0x00000000, + .McGeneralizedCarveout3Size128kb = 0x00000000, + .McGeneralizedCarveout3Access0 = 0x00000000, + .McGeneralizedCarveout3Access1 = 0x00000000, + .McGeneralizedCarveout3Access2 = 0x03000000, + .McGeneralizedCarveout3Access3 = 0x00000000, + .McGeneralizedCarveout3Access4 = 0x00000300, + .McGeneralizedCarveout3ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout3Cfg0 = 0x04401e7c, + .McGeneralizedCarveout4Bom = 0x00000000, + .McGeneralizedCarveout4BomHi = 0x00000000, + .McGeneralizedCarveout4Size128kb = 0x00000008, + .McGeneralizedCarveout4Access0 = 0x00000000, + .McGeneralizedCarveout4Access1 = 0x00000000, + .McGeneralizedCarveout4Access2 = 0x00300000, + .McGeneralizedCarveout4Access3 = 0x00000000, + .McGeneralizedCarveout4Access4 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout4Cfg0 = 0x04002442, + .McGeneralizedCarveout5Bom = 0x00000000, + .McGeneralizedCarveout5BomHi = 0x00000000, + .McGeneralizedCarveout5Size128kb = 0x00000008, + .McGeneralizedCarveout5Access0 = 0x00000000, + .McGeneralizedCarveout5Access1 = 0x00000000, + .McGeneralizedCarveout5Access2 = 0x00300000, + .McGeneralizedCarveout5Access3 = 0x00000000, + .McGeneralizedCarveout5Access4 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout5Cfg0 = 0x04002c42, + .EmcCaTrainingEnable = 0x00000000, + .SwizzleRankByteEncode = 0x0000000e, + .BootRomPatchControl = 0x00000000, + .BootRomPatchData = 0x00000000, + .McMtsCarveoutBom = 0xfff00000, + .McMtsCarveoutAdrHi = 0x00000000, + .McMtsCarveoutSizeMb = 0x00000000, + .McMtsCarveoutRegCtrl = 0x00000000, + +}, diff --git a/src/mainboard/google/foster/bct/sdram-unused.inc b/src/mainboard/google/foster/bct/sdram-unused.inc new file mode 100644 index 0000000..bef63dc --- /dev/null +++ b/src/mainboard/google/foster/bct/sdram-unused.inc @@ -0,0 +1,4 @@ +{ /* dummy. */ + .MemoryType = NvBootMemoryType_Unused, + 0, +}, diff --git a/src/mainboard/google/foster/bct/spi.cfg b/src/mainboard/google/foster/bct/spi.cfg new file mode 100644 index 0000000..2cf9e56 --- /dev/null +++ b/src/mainboard/google/foster/bct/spi.cfg @@ -0,0 +1,16 @@ +# Copyright (c) 2015 The Chromium OS Authors. All rights reserved. +# Distributed under the terms of the GNU General Public License v2 + +Version = 0x00210001; +BlockSize = 32768; +PageSize = 2048; +PartitionSize = 4194304; + +# +# T210 bct only supports one boot device +# +DevType[0] = NvBootDevType_Spi; +DeviceParam[0].SpiFlashParams.ReadCommandTypeFast = NV_FALSE; +DeviceParam[0].SpiFlashParams.ClockDivider = 0x16; +DeviceParam[0].SpiFlashParams.ClockSource = NvBootSpiClockSource_PllPOut0; +DeviceParam[0].SpiFlashParams.PageSize2kor16k = 0; diff --git a/src/mainboard/google/foster/boardid.c b/src/mainboard/google/foster/boardid.c new file mode 100644 index 0000000..d5a352e --- /dev/null +++ b/src/mainboard/google/foster/boardid.c @@ -0,0 +1,28 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <boardid.h> +#include <console/console.h> +#include <gpio.h> + +uint8_t board_id(void) +{ + return 0; +} diff --git a/src/mainboard/google/foster/bootblock.c b/src/mainboard/google/foster/bootblock.c new file mode 100644 index 0000000..e2ad465 --- /dev/null +++ b/src/mainboard/google/foster/bootblock.c @@ -0,0 +1,95 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <arch/io.h> +#include <bootblock_common.h> +#include <console/console.h> +#include <device/i2c.h> +#include <soc/addressmap.h> +#include <soc/clk_rst.h> +#include <soc/clock.h> +#include <soc/funitcfg.h> +#include <soc/nvidia/tegra/i2c.h> +#include <soc/padconfig.h> +#include <soc/spi.h> /* FIXME: move back to soc code? */ + +#include "pmic.h" + +static const struct pad_config pmic_pads[] = { + PAD_CFG_SFIO(PWR_I2C_SCL, PINMUX_INPUT_ENABLE, I2CPMU), + PAD_CFG_SFIO(PWR_I2C_SDA, PINMUX_INPUT_ENABLE, I2CPMU), +}; + +static const struct pad_config spiflash_pads[] = { + /* QSPI fLash: mosi, miso, clk, cs0, hold, wp */ + PAD_CFG_SFIO(QSPI_IO0, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, QSPI), + PAD_CFG_SFIO(QSPI_IO1, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, QSPI), + PAD_CFG_SFIO(QSPI_SCK, PINMUX_INPUT_ENABLE, QSPI), + PAD_CFG_SFIO(QSPI_CS_N, PINMUX_INPUT_ENABLE, QSPI), + PAD_CFG_SFIO(QSPI_IO2, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, QSPI), + PAD_CFG_SFIO(QSPI_IO3, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, QSPI), +}; + +/********************* TPM ************************************/ +static const struct pad_config tpm_pads[] = { + PAD_CFG_SFIO(GEN3_I2C_SCL, PINMUX_INPUT_ENABLE, I2C3), + PAD_CFG_SFIO(GEN3_I2C_SDA, PINMUX_INPUT_ENABLE, I2C3), +}; + +static const struct funit_cfg funits[] = { + /* PMIC on I2C5 (PWR_I2C* pads) at 400kHz. */ + FUNIT_CFG(I2C5, PLLP, 400, pmic_pads, ARRAY_SIZE(pmic_pads)), + /* SPI flash at 24MHz on QSPI controller. */ + FUNIT_CFG(QSPI, PLLP, 24000, spiflash_pads, ARRAY_SIZE(spiflash_pads)), + /* Foster has no TPM yet. This is for futurn TPM on I2C3 @ 400kHz. */ + FUNIT_CFG(I2C3, PLLP, 400, tpm_pads, ARRAY_SIZE(tpm_pads)), +}; + +static const struct pad_config uart_console_pads[] = { + /* UARTA: tx, rx, rts, cts */ + PAD_CFG_SFIO(UART1_TX, PINMUX_PULL_NONE, UARTA), + PAD_CFG_SFIO(UART1_RX, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, UARTA), + PAD_CFG_SFIO(UART1_RTS, PINMUX_PULL_UP, UARTA), + PAD_CFG_SFIO(UART1_CTS, PINMUX_PULL_UP, UARTA), +}; + +void bootblock_mainboard_early_init(void) +{ + soc_configure_pads(uart_console_pads, ARRAY_SIZE(uart_console_pads)); +} + +static void set_clock_sources(void) +{ + /* UARTA gets PLLP, deactivate CLK_UART_DIV_OVERRIDE */ + write32(CLK_RST_REG(clk_src_uarta), PLLP << CLK_SOURCE_SHIFT); +} + +void bootblock_mainboard_init(void) +{ + set_clock_sources(); + + soc_configure_funits(funits, ARRAY_SIZE(funits)); + + i2c_init(I2CPWR_BUS); + pmic_init(I2CPWR_BUS); + + /* Foster has no TPM yet. This is for future TPM. */ + i2c_init(I2C3_BUS); +} diff --git a/src/mainboard/google/foster/chromeos.c b/src/mainboard/google/foster/chromeos.c new file mode 100644 index 0000000..83dd652 --- /dev/null +++ b/src/mainboard/google/foster/chromeos.c @@ -0,0 +1,102 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <boot/coreboot_tables.h> +#include <console/console.h> +#include <ec/google/chromeec/ec.h> +#include <ec/google/chromeec/ec_commands.h> +#include <gpio.h> +#include <string.h> +#include <vendorcode/google/chromeos/chromeos.h> + +void fill_lb_gpios(struct lb_gpios *gpios) +{ + int count = 0; + + /* TBD(twarren@nvidia.com): Any analogs for these on Foster-FFD? */ + + /* Write Protect: active low */ + gpios->gpios[count].port = -1; + gpios->gpios[count].polarity = ACTIVE_LOW; + gpios->gpios[count].value = get_write_protect_state(); + strncpy((char *)gpios->gpios[count].name, "write protect", + GPIO_MAX_NAME_LENGTH); + count++; + + /* Recovery: active high */ + gpios->gpios[count].port = -1; + gpios->gpios[count].polarity = ACTIVE_HIGH; + gpios->gpios[count].value = get_recovery_mode_switch(); + strncpy((char *)gpios->gpios[count].name, "recovery", + GPIO_MAX_NAME_LENGTH); + count++; + + /* TODO: Power: active low / high depending on board id */ + gpios->gpios[count].port = GPIO(X5); + gpios->gpios[count].polarity = ACTIVE_LOW; + gpios->gpios[count].value = -1; + strncpy((char *)gpios->gpios[count].name, "power", + GPIO_MAX_NAME_LENGTH); + count++; + + /* Developer: virtual GPIO active high */ + gpios->gpios[count].port = -1; + gpios->gpios[count].polarity = ACTIVE_HIGH; + gpios->gpios[count].value = get_developer_mode_switch(); + strncpy((char *)gpios->gpios[count].name, "developer", + GPIO_MAX_NAME_LENGTH); + count++; + + /* TODO: Reset: active low (output) */ + gpios->gpios[count].port = GPIO(I5); + gpios->gpios[count].polarity = ACTIVE_LOW; + gpios->gpios[count].value = -1; + strncpy((char *)gpios->gpios[count].name, "reset", + GPIO_MAX_NAME_LENGTH); + count++; + + gpios->size = sizeof(*gpios) + (count * sizeof(struct lb_gpio)); + gpios->count = count; + + printk(BIOS_ERR, "Added %d GPIOS size %d\n", count, gpios->size); +} + +int get_developer_mode_switch(void) +{ + return 0; +} + +int get_recovery_mode_switch(void) +{ +#if CONFIG_EC_GOOGLE_CHROMEEC + uint32_t ec_events; + + ec_events = google_chromeec_get_events_b(); + return !!(ec_events & + EC_HOST_EVENT_MASK(EC_HOST_EVENT_KEYBOARD_RECOVERY)); +#else + return 0; +#endif +} + +int get_write_protect_state(void) +{ + return 0; +} diff --git a/src/mainboard/google/foster/devicetree.cb b/src/mainboard/google/foster/devicetree.cb new file mode 100644 index 0000000..947a269 --- /dev/null +++ b/src/mainboard/google/foster/devicetree.cb @@ -0,0 +1,95 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2015 Google Inc. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc. +## + +chip soc/nvidia/tegra210 + register "spintable_addr" = "0x80000008" + + device cpu_cluster 0 on + device cpu 0 on end + device cpu 1 on end + device cpu 2 on end + device cpu 3 on end + end + + register "display_controller" = "TEGRA_ARM_DISPLAYA" + register "xres" = "1366" + register "yres" = "768" + + # framebuffer resolution + register "display_xres" = "1368" + register "display_yres" = "678" + + # bits per pixel and color depth + register "framebuffer_bits_per_pixel" = "16" + register "color_depth" = "6" + + register "panel_bits_per_pixel" = "18" + +# How to compute these: xrandr --verbose will give you this: +#Detailed mode: Clock 285.250 MHz, 272 mm x 181 mm +# 2560 2608 2640 2720 hborder 0 +# 1700 1703 1713 1749 vborder 0 +#Then you can compute your values: +#H front porch = 2608 - 2560 = 48 +#H sync = 2640 - 2608 = 32 +#H back porch = 2720 - 2640 = 80 +#V front porch = 1703 - 1700 = 3 +#V sync = 1713 - 1703 = 10 +#V back porch = 1749 - 1713 = 36 +#href_to_sync and vref_to_sync are from the vendor +#this is just an example for a Pixel panel; other panels differ. +# Here is a peppy panel: +# 1366x768 (0x45) 76.4MHz -HSync -VSync *current +preferred +# h: width 1366 start 1502 end 1532 total 1592 +# v: height 768 start 776 end 788 total 800 + register "href_to_sync" = "1" + register "hfront_porch" = "136" + register "hsync_width" = "30" + register "hback_porch" = "60" + + register "vref_to_sync" = "1" + register "vfront_porch" = "8" + register "vsync_width" = "12" + register "vback_porch" = "12" + + register "pixel_clock" = "76400000" + + register "win_opt" = "SOR_ENABLE" + + # + # dp specific fields + # + register "dp.pwm" = "1" + + # various panel delay time + register "dp.vdd_to_hpd_delay_ms" = "200" + register "dp.hpd_unplug_min_us" = "2000" + register "dp.hpd_plug_min_us" = "250" + register "dp.hpd_irq_min_us" = "250" + + # link configurations + register "dp.lane_count" = "1" + register "dp.enhanced_framing" = "1" + register "dp.link_bw" = "10" + # "10" is defined as SOR_LINK_SPEED_G2_7 in sor.h + + register "dp.drive_current" = "0x40404040" + register "dp.preemphasis" = "0x0f0f0f0f" + register "dp.postcursor" = "0" +end diff --git a/src/mainboard/google/foster/ec_dummy.c b/src/mainboard/google/foster/ec_dummy.c new file mode 100644 index 0000000..01a935c --- /dev/null +++ b/src/mainboard/google/foster/ec_dummy.c @@ -0,0 +1,9 @@ +/* Dummy CHROMEEC file to provide stub functions for vboot compilation */ + +#include <stdint.h> + +int google_chromeec_vbnv_context(int is_read, uint8_t *data, int len); +int google_chromeec_vbnv_context(int is_read, uint8_t *data, int len) +{ + return 0; +} diff --git a/src/mainboard/google/foster/mainboard.c b/src/mainboard/google/foster/mainboard.c new file mode 100644 index 0000000..3f4e10f --- /dev/null +++ b/src/mainboard/google/foster/mainboard.c @@ -0,0 +1,129 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <arch/io.h> +#include <arch/mmu.h> +#include <boot/coreboot_tables.h> +#include <delay.h> +#include <device/device.h> +#include <memrange.h> +#include <soc/addressmap.h> +#include <soc/clk_rst.h> +#include <soc/clock.h> +#include <soc/funitcfg.h> +#include <soc/nvidia/tegra/i2c.h> +#include <soc/padconfig.h> +#include <soc/spi.h> +#include <soc/nvidia/tegra/dc.h> +#include <soc/display.h> + +#include <vendorcode/google/chromeos/chromeos.h> + +static const struct pad_config sdmmc1_pad[] = { + /* MMC1(SDCARD) */ + PAD_CFG_SFIO(SDMMC1_CLK, PINMUX_INPUT_ENABLE, SDMMC1), + PAD_CFG_SFIO(SDMMC1_CMD, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, SDMMC1), + PAD_CFG_SFIO(SDMMC1_DAT0, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, SDMMC1), + PAD_CFG_SFIO(SDMMC1_DAT1, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, SDMMC1), + PAD_CFG_SFIO(SDMMC1_DAT2, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, SDMMC1), + PAD_CFG_SFIO(SDMMC1_DAT3, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, SDMMC1), + /* MMC1 Card Detect pin */ + PAD_CFG_GPIO_INPUT(GPIO_PZ1, PINMUX_PULL_UP), + /* Disable SD card reader power so it can be reset even on warm boot. + Payloads must enable power before accessing SD card slots. */ + PAD_CFG_GPIO_OUT0(GPIO_PZ4, PINMUX_PULL_NONE), +}; + +static const struct pad_config audio_codec_pads[] = { + /* GPIO_X1_AUD(BB3) is AUDIO_LDO_EN (->CODEC RESET_N pin) */ + PAD_CFG_GPIO_OUT1(GPIO_X1_AUD, PINMUX_PULL_DOWN), +}; + +static const struct pad_config padcfgs[] = { + /* We pull the USB VBUS signals up but keep them as inputs since the + * voltage source likes to drive them low on overcurrent conditions */ + PAD_CFG_GPIO_INPUT(USB_VBUS_EN1, PINMUX_PULL_NONE | PINMUX_PARKED | + PINMUX_INPUT_ENABLE | PINMUX_LPDR | PINMUX_IO_HV), + + /* Add backlight vdd/enable/pwm/dp hpd pad cfgs here */ +}; + +static const struct pad_config i2c1_pad[] = { + /* GEN1 I2C */ + PAD_CFG_SFIO(GEN1_I2C_SCL, PINMUX_INPUT_ENABLE, I2C1), + PAD_CFG_SFIO(GEN1_I2C_SDA, PINMUX_INPUT_ENABLE, I2C1), +}; + +static const struct pad_config i2s1_pad[] = { + /* I2S1 */ + PAD_CFG_SFIO(DAP1_SCLK, PINMUX_INPUT_ENABLE, I2S1), + PAD_CFG_SFIO(DAP1_FS, PINMUX_INPUT_ENABLE, I2S1), + PAD_CFG_SFIO(DAP1_DOUT, PINMUX_INPUT_ENABLE, I2S1), + PAD_CFG_SFIO(DAP1_DIN, PINMUX_INPUT_ENABLE | PINMUX_TRISTATE, I2S1), + /* codec MCLK via AUD SFIO */ + PAD_CFG_SFIO(AUD_MCLK, PINMUX_PULL_NONE, AUD), +}; + +static const struct funit_cfg audio_funit[] = { + /* We need 1.5MHz for I2S1. So we use CLK_M */ + FUNIT_CFG(I2S1, CLK_M, 1500, i2s1_pad, ARRAY_SIZE(i2s1_pad)), +}; + +static const struct funit_cfg funitcfgs[] = { + FUNIT_CFG(SDMMC1, PLLP, 48000, sdmmc1_pad, ARRAY_SIZE(sdmmc1_pad)), + FUNIT_CFG(SDMMC4, PLLP, 48000, NULL, 0), + FUNIT_CFG(I2C1, PLLP, 100, i2c1_pad, ARRAY_SIZE(i2c1_pad)), + FUNIT_CFG_USB(USBD), +}; + +/* Audio init: clocks and enables/resets */ +static void setup_audio(void) +{ + /* Audio codec (ES755) uses OSC freq (via AUD_MCLK), s/b 38.4MHz */ + soc_configure_funits(audio_funit, ARRAY_SIZE(audio_funit)); + + /* + * As per NVIDIA hardware team, we need to take ALL audio devices + * connected to AHUB (AUDIO, APB2APE, I2S, SPDIF, etc.) out of reset + * and clock-enabled, otherwise reading AHUB devices (in our case, + * I2S/APBIF/AUDIO<XBAR>) will hang. + */ + soc_configure_ape(); + clock_enable_audio(); +} + +static void mainboard_init(device_t dev) +{ + soc_configure_pads(padcfgs, ARRAY_SIZE(padcfgs)); + soc_configure_funits(funitcfgs, ARRAY_SIZE(funitcfgs)); + + i2c_init(I2C1_BUS); + setup_audio(); +} + +static void mainboard_enable(device_t dev) +{ + dev->ops->init = &mainboard_init; +} + +struct chip_operations mainboard_ops = { + .name = "foster", + .enable_dev = mainboard_enable, +}; diff --git a/src/mainboard/google/foster/memlayout.ld b/src/mainboard/google/foster/memlayout.ld new file mode 100644 index 0000000..a71dcb8 --- /dev/null +++ b/src/mainboard/google/foster/memlayout.ld @@ -0,0 +1,6 @@ +#if IS_ENABLED(CONFIG_VBOOT2_VERIFY_FIRMWARE) +#include <soc/memlayout_vboot2.ld> +#else +#include <soc/memlayout.ld> +#endif + diff --git a/src/mainboard/google/foster/pmic.c b/src/mainboard/google/foster/pmic.c new file mode 100644 index 0000000..b549107 --- /dev/null +++ b/src/mainboard/google/foster/pmic.c @@ -0,0 +1,93 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (c) 2013-2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <boardid.h> +#include <console/console.h> +#include <delay.h> +#include <device/i2c.h> +#include <stdint.h> +#include <stdlib.h> + +#include "pmic.h" +#include "reset.h" + +enum { + MAX77620_I2C_ADDR = 0x3c +}; + +struct max77620_init_reg { + u8 reg; + u8 val; + u8 delay; +}; + +static struct max77620_init_reg init_list[] = { + /* TODO */ +}; + +static void pmic_write_reg(unsigned bus, uint8_t reg, uint8_t val, int delay) +{ + if (i2c_writeb(bus, MAX77620_I2C_ADDR, reg, val)) { + printk(BIOS_ERR, "%s: reg = 0x%02X, value = 0x%02X failed!\n", + __func__, reg, val); + /* Reset the SoC on any PMIC write error */ + cpu_reset(); + } else { + if (delay) + udelay(500); + } +} + +static void pmic_slam_defaults(unsigned bus) +{ + int i; + for (i = 0; i < ARRAY_SIZE(init_list); i++) { + struct max77620_init_reg *reg = &init_list[i]; + pmic_write_reg(bus, reg->reg, reg->val, reg->delay); + } +} + +void pmic_init(unsigned bus) +{ + /* Restore PMIC POR defaults, in case kernel changed 'em */ + pmic_slam_defaults(bus); + + /* Setup/Enable GPIO5 - VDD_CPU_REG_EN */ + pmic_write_reg(bus, MAX77620_GPIO5_REG, 0x09, 1); + + /* Setup/Enable GPIO1 - VDD_HDMI_5V0_BST_EN -- ??? */ + pmic_write_reg(bus, MAX77620_GPIO1_REG, 0x09, 1); + + /* GPIO 0,1,5,6,7 = GPIO, 2,3,4 = alt mode */ + pmic_write_reg(bus, MAX77620_AME_GPIO, 0x1c, 1); + + /* Disable SD1 Remote Sense, Set SD1 for LPDDR4 to 1.125v? */ + pmic_write_reg(bus, MAX77620_CNFG2SD_REG, 0x04, 1); + + pmic_write_reg(bus, MAX77620_SD1_REG, 0x2a, 1); + + /* CNFG1_L2 = 0xF2 for 3.3v, enabled */ + pmic_write_reg(bus, MAX77620_CNFG1_L2_REG, 0xf2, 1); + + /* CNFG1_L1 = 0xCA for 1.05v, enabled */ + pmic_write_reg(bus, MAX77620_CNFG1_L1_REG, 0xca, 1); + + printk(BIOS_DEBUG, "PMIC init done\n"); +} diff --git a/src/mainboard/google/foster/pmic.h b/src/mainboard/google/foster/pmic.h new file mode 100644 index 0000000..a2556f5 --- /dev/null +++ b/src/mainboard/google/foster/pmic.h @@ -0,0 +1,74 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef __MAINBOARD_GOOGLE_FOSTER_PMIC_H__ +#define __MAINBOARD_GOOGLE_FOSTER_PMIC_H__ + +#define MAX77620_SD0_REG 0x16 +#define MAX77620_SD1_REG 0x17 +#define MAX77620_SD2_REG 0x18 +#define MAX77620_SD3_REG 0x19 +#define MAX77620_CNFG2SD_REG 0x22 + +#define MAX77620_CNFG1_L0_REG 0x23 +#define MAX77620_CNFG2_L0_REG 0x24 +#define MAX77620_CNFG1_L1_REG 0x25 +#define MAX77620_CNFG2_L1_REG 0x26 +#define MAX77620_CNFG1_L2_REG 0x27 +#define MAX77620_CNFG2_L2_REG 0x28 +#define MAX77620_CNFG1_L3_REG 0x29 +#define MAX77620_CNFG2_L3_REG 0x2A +#define MAX77620_CNFG1_L4_REG 0x2B +#define MAX77620_CNFG2_L4_REG 0x2C +#define MAX77620_CNFG1_L5_REG 0x2D +#define MAX77620_CNFG2_L5_REG 0x2E +#define MAX77620_CNFG1_L6_REG 0x2F +#define MAX77620_CNFG2_L6_REG 0x30 +#define MAX77620_CNFG1_L7_REG 0x31 +#define MAX77620_CNFG2_L7_REG 0x32 +#define MAX77620_CNFG1_L8_REG 0x33 +#define MAX77620_CNFG2_L8_REG 0x34 +#define MAX77620_CNFG3_LDO_REG 0x35 + +#define MAX77620_GPIO0_REG 0x36 +#define MAX77620_GPIO1_REG 0x37 +#define MAX77620_GPIO2_REG 0x38 +#define MAX77620_GPIO3_REG 0x39 +#define MAX77620_GPIO4_REG 0x3A +#define MAX77620_GPIO5_REG 0x3B +#define MAX77620_GPIO6_REG 0x3C +#define MAX77620_GPIO7_REG 0x3D +#define MAX77620_GPIO_PUE_GPIO 0x3E +#define MAX77620_GPIO_PDE_GPIO 0x3F + +#define MAX77620_AME_GPIO 0x40 +#define MAX77620_REG_ONOFF_CFG1 0x41 +#define MAX77620_REG_ONOFF_CFG2 0x42 + +#define MAX77620_CID0_REG 0x58 +#define MAX77620_CID1_REG 0x59 +#define MAX77620_CID2_REG 0x5A +#define MAX77620_CID3_REG 0x5B +#define MAX77620_CID4_REG 0x5C +#define MAX77620_CID5_REG 0x5D + +void pmic_init(unsigned bus); + +#endif /* __MAINBOARD_GOOGLE_FOSTER_PMIC_H__ */ diff --git a/src/mainboard/google/foster/reset.c b/src/mainboard/google/foster/reset.c new file mode 100644 index 0000000..0c44a64 --- /dev/null +++ b/src/mainboard/google/foster/reset.c @@ -0,0 +1,29 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <arch/io.h> +#include <gpio.h> +#include <reset.h> + +void hard_reset(void) +{ + gpio_output(GPIO(I5), 0); + while(1); +} diff --git a/src/mainboard/google/foster/romstage.c b/src/mainboard/google/foster/romstage.c new file mode 100644 index 0000000..178ac10 --- /dev/null +++ b/src/mainboard/google/foster/romstage.c @@ -0,0 +1,40 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <soc/addressmap.h> +#include <soc/clock.h> +#include <soc/funitcfg.h> +#include <soc/nvidia/tegra/i2c.h> +#include <soc/padconfig.h> +#include <soc/romstage.h> + +void romstage_mainboard_init(void) +{ + /* No EC or TPM on Foster, do nothing here */ +} + +void mainboard_configure_pmc(void) +{ +} + +void mainboard_enable_vdd_cpu(void) +{ + /* VDD_CPU is already enabled in bootblock. */ +} diff --git a/src/mainboard/google/foster/verstage.c b/src/mainboard/google/foster/verstage.c new file mode 100644 index 0000000..d5bcd44 --- /dev/null +++ b/src/mainboard/google/foster/verstage.c @@ -0,0 +1,29 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <soc/addressmap.h> +#include <soc/funitcfg.h> +#include <soc/padconfig.h> +#include <soc/verstage.h> +#include <soc/nvidia/tegra/i2c.h> + +void verstage_mainboard_init(void) +{ +}
