Attention is currently required from: Felix Held, Fred Reitberger, Jason Glenesk, Matt DeVillier.
Hello Felix Held, Fred Reitberger, Jason Glenesk, Matt DeVillier,
https://review.coreboot.org/c/coreboot/+/78426?usp=email
Change subject: soc/amd/common/psp_verstage: Add PSP_VERSTACK_STACK_IS_MAPPED config ......................................................................
Crypto Engine in PSP prefers the buffer from Static RAM (SRAM). Hence if a buffer comes from within SRAM address range, then it is passed directly to Crypto Engine. Otherwise a bounce bufer from the stack is used. But on SoCs like Picasso where PSP Verstage stack is mapped to a virtual address space this check fails causing a bounce buffer to be used and hence a stack overflow. Fix this issue by assuming that the buffer comes from the SRAM always in such SoCs and pass the buffer directly to crypto engine.
BUG=b:259649666 TEST=Build and boot to OS in Dalboz with unsigned PSP verstage.
Change-Id: I2161c8f0720c770efa5c05aece9584c3cbe7712a Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com --- M src/soc/amd/common/psp_verstage/Kconfig M src/soc/amd/common/psp_verstage/vboot_crypto.c 2 files changed, 12 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/26/78426/2
