Attention is currently required from: Jason Nien, Martin Roth.
Hello Jason Nien, Martin Roth,
https://review.coreboot.org/c/coreboot/+/72694
Change subject: mb/google/skyrim/var/frostflow: Override SPI flash bus speed ......................................................................
Add configuration to bump up the SPI flash bus speed from 66 MHz to 100 MHz starting the board version of the current phase.
BUG=b:260127676 TEST=Build and boot to OS in Frostflow with 100 MHz SPI bus speed. Observe that the boot time improved by 100 ms compared to 66 MHz SPI flash bus speed.
firmware log: SPI fast read speed: 100 MHz At 66 MHz: Total Time: 1,563,384 At 100 MHz: Total Time: 1,462,570
Change-Id: I9435f4ad0d3541b040703dc9a453badbd080dc09 Signed-off-by: Frank Wu frank_wu@compal.corp-partner.google.com --- M src/mainboard/google/skyrim/Kconfig 1 file changed, 26 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/72694/2
